04-09-2019, 14:29 | #1 (permalink) |
No Life Poster Join Date: Aug 2017 Location: India
Member: 2746336 Status: Offline Sonork: NULL Thanks Meter: 47 | lg d380 Can't init EMMC, Reason: DATA RCV Timeout Error Compression if OFF Z3X EasyJtag Software ver. 3.4.0.2 Loading eMMC GEN2 Firmware... IO: 1800 mV Box S/N: 026862FABF5A25EA, ,FW Ver.: 02.31 CMD Pullup Level:1823 mV CMD Active Level:1882 mV Box IO Level:1800 mV CLK Rate:1000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 90014A4834473164040507A112974127 eMMC CSD : D02701320F5903FFFFFFFFEF8A4040D3 eMMC Manufacturer ID: 0090 , OEM ID: 014A eMMC Date: 04/2014 Rev.0x5 eMMC NAME: H4G1d , S/N: 127996567 eMMC NAME (HEX): 483447316420 Can't init EMMC, Reason: DATA RCV Timeout Error Check Data Line! Done. Can't init device, Reason: Unknown error (-30) Done. |
04-09-2019, 15:37 | #2 (permalink) |
Member: 2746336 Status: Offline Sonork: NULL Thanks Meter: 47 | now getting this error: Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 1 Mhz CMD Pullup Level: 2145 mV CMD Active Level: 3201 mV EMMC Device Information : EMMC CID: 90014A4834473164040507A112974127 EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D3 EMMC Manufacture : SKHYNIX , EMMC NAME: H4G1d , HEX: 483447316400 , S/N: 07A11297 , rev. 0x05 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 4/2014 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: H4G1d_07A11297_20190409_194800.extcsd EMMC Init completed. Operation: Write by vendor (LG) Creating GPT-partitioninig Writing PrimaryGPT at address: 000000000000 Error writing at address: 000000000000 , error: 34 , 34 Unknown error ... Retry #1 Error writing at address: 000000000000 , error: 34 , 34 Unknown error ... Retry #2 Error writing at address: 000000000000 , error: 34 , 34 Unknown error ... Retry #3 Too many errors. Writing has been stopped |
