07-14-2019, 10:35 | #1 (permalink) |
Insane Poster Join Date: Sep 2012 Location: Manila / Pilipinas
Member: 1807389 Status: Offline Thanks Meter: 29 | help oppo a3s cph1803 dead |
The Following User Says Thank You to elusyonado For This Useful Post: |
10-04-2019, 11:56 | #7 (permalink) |
Major Poster Join Date: Mar 2014 Location: Philippines
Member: 2141040 Status: Offline Thanks Meter: 17 | same also , first time to also here is the logs EasyJtag Suite Classic ver.: 3.6.1.4 / wxWidgets 3.1.2-W-U started. OS ver.: Windows 10 (build 10586). Admin rights FAIL Android Explorer ver:1.0.0.13 Autorun Agent ver:1.0.0.0 Crash Reporting ver:1.4.0.3 eMMC Odin ver:1.0.0.6 QUALCOMM Direct ver:1.0.6936.8894 Android ADB API ver:2.0.0.0 FTDI API ver:3.2.4.0 LibUSB API ver:1.2.6.0 Visual C++ Runtime ver:10.0.30319.1 Setting box Pinout ... Box Drivers version: 10.0.10586.306, are OK Z3X Card Serial : AAA1-C5FB , ver: 22 Z3X Card Activation [JTAGPLUS] : NOT ACTIVATED Z3X Card Activation [LG] : NOT ACTIVATED Z3X Card Activation [SAMS] : NOT ACTIVATED Z3X Card Activation [JTAG] : ACTIVATED Found 5 serial devices COM1 ACPI\VEN_PNP&DEV_0501 Communications Port (COM1) COM3 Intel(R) Active Management Technology - SOL (COM3) COM39 root\rimports RIM Virtual Serial Port v2 (COM39) COM40 root\rimports RIM Virtual Serial Port v2 (COM40) COM160 USB\VID_0325&PID_0032&REV_0100&MI_00 USB Serial Device (COM160) Selected pinout: EasyJTAG GEN1 ISP Pinout Change EasyJTAG Pinout OK Z3X EasyJtag Software ver. 3.6.1.4 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 0200300EC96F8F0A, ,FW Ver.: 01.63 CMD Pullup Level:2010 mV CMD Active Level:1619 mV Box IO Level:2800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100514536334D4206472A9ACFA578 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 10/2018 Rev.0x6 eMMC NAME: QE63MB , S/N: 1193974479 eMMC NAME (HEX): 514536334D42 IC Name: Samsung , KMQE60013M-B318/16GB @BGA221 EMMC ROM1 (Main User Data) Capacity: 14910 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB RPMB Info mmc_init Error, Reason: CMD Timeout Error EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: QE63MB_1193974479_20191004_1523.extcsd Done. Z3X EasyJtag Software ver. 3.6.1.4 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 0200300EC96F8F0A, ,FW Ver.: 01.63 CMD Pullup Level:2010 mV CMD Active Level:2526 mV Box IO Level:2800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100514536334D4206472A9ACFA578 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 10/2018 Rev.0x6 eMMC NAME: QE63MB , S/N: 1193974479 eMMC NAME (HEX): 514536334D42 IC Name: Samsung , KMQE60013M-B318/16GB @BGA221 EMMC ROM1 (Main User Data) Capacity: 14910 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 27832 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: QE63MB_1193974479_20191004_1524.extcsd Done. Z3X EasyJtag Software ver. 3.6.1.4 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 0200300EC96F8F0A, ,FW Ver.: 01.63 Warning: CMD Pullup Level (257 mV) too low , check cables etc.! CMD Active Level:2536 mV Box IO Level:2800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100514536334D4206472A9ACFA578 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 10/2018 Rev.0x6 eMMC NAME: QE63MB , S/N: 1193974479 eMMC NAME (HEX): 514536334D42 IC Name: Samsung , KMQE60013M-B318/16GB @BGA221 EMMC ROM1 (Main User Data) Capacity: 14910 MB , 0x1D1F000 pages , 0x3A3E00000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 27832 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Partition table scan: GPT: present Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 1D1F000 sectors 14.6 GiB Soft (Partitioned) Disk/Image size: 1D1EFBC sectors 14.6 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 First usable sector: 34 Last usable sector: 30535646 Partition info successfully found ------ Android information ------ Detected LINUX(Android) CACHE : 0x001FB00000 (256.0MB) Erasing... Done. Detected LINUX(Android) USERDATA : 0x0158000000 (9.184GB) Erasing... Done. --------------------------------------------- Done. Running:Format FRP Partition... Z3X EasyJtag Software ver. 3.6.1.4 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 0200300EC96F8F0A, ,FW Ver.: 01.63 CMD Pullup Level:2021 mV CMD Active Level:2547 mV Box IO Level:2800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100514536334D4206472A9ACFA578 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 10/2018 Rev.0x6 eMMC NAME: QE63MB , S/N: 1193974479 eMMC NAME (HEX): 514536334D42 IC Name: Samsung , KMQE60013M-B318/16GB @BGA221 EMMC ROM1 (Main User Data) Capacity: 14910 MB , 0x1D1F000 pages , 0x3A3E00000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 27832 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Partition table scan: GPT: present Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 1D1F000 sectors 14.6 GiB Soft (Partitioned) Disk/Image size: 1D1EFBC sectors 14.6 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 First usable sector: 34 Last usable sector: 30535646 Partition info successfully found Formatting FRP... Detected LINUX(Android) CACHE : 0x001FB00000 (256.0MB) , formatting... Done. Detected LINUX(Android) CONFIG : 0x002FC80000 (32.0KB) formatting... Done. Detected LINUX(Android) USERDATA : 0x0158000000 (9.184GB) , formatting... Done. Done. Done. please help me team |
10-04-2019, 12:18 | #8 (permalink) |
No Life Poster Join Date: Feb 2009 Location: inside apples a15
Member: 975554 Status: Offline Sonork: KG state:prenormal Thanks Meter: 253 | for this model dont use clear pin pass or frp use only format userdata..it will only send command to phone to factory reset it..done many times without dead..be very carefull also when removing shield mostly while removing the shield you already killed the device |
The Following User Says Thank You to simpleprince49 For This Useful Post: |
10-08-2019, 08:50 | #9 (permalink) |
Freak Poster Join Date: Dec 2017 Location: Dar es salaam,Tanzania
Member: 2790329 Status: Offline Thanks Meter: 27 | If you connect device to computer and show 9008 port,you need to looo click resistor.solved many times Sent from my Redmi Note 4 using Tapatalk |
