Old 12-12-2019, 07:15   #706 (permalink)
Member: 1505751
Thanks Meter: 107
Vivo S1 tested ISP Pinout
The Following 5 Users Say Thank You to ajit sheoran For This Useful Post:
Old 12-19-2019, 04:31   #707 (permalink)
Mobile_Control's Avatar
Member: 998119
Thanks Meter: 90
Samsung SM-A750FN isp
The Following 3 Users Say Thank You to Mobile_Control For This Useful Post:
Old 12-19-2019, 19:45   #708 (permalink)
Member: 2940084
Pinout
Not connected I have problem
Old 12-21-2019, 11:51   #709 (permalink)
Member: 22054
Thanks Meter: 8
A720f
Originally Posted by alireza-shams View Post
hI i need A720F emmc direct pinout .
https://www.youtube.com/watch?v=R9UhZYm-Lao
Old 12-21-2019, 18:59   #710 (permalink)
Member: 2560904
i want pinout Emmc LG VS415PP
Old 01-19-2020, 16:54   #711 (permalink)
Member: 138423
Sonork: 75171702
Thanks Meter: 12
Originally Posted by subzerillo View Post
Hello.
Please share pinout for Samsung A50 (SM-A505G / SM-A505F)
I know that riffbox has that pinout but I do not own it. I only have Medusa and Easy Jtag.
do you have a found?
Old 01-19-2020, 21:04   #712 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
Hello.
ha-ha-ha!!!!
RIFF box have a UFS pinout?
The Following User Says Thank You to layder For This Useful Post:
Old 01-27-2020, 15:07   #713 (permalink)
Member: 1630066
Sonork: 520074
Thanks Meter: 215
huawei honor 7 PLK-L01
Setting frequence to 21 MHz
CMD Pullup Level: 2041 mV
CMD Active Level: 1938 mV
EMMC Device Information :
EMMC CID: 110100303634474532009616578952C0
EMMC CSD: D05E00320F5903FFFFFFFFEF924000D2
EMMC Manufacture : TOSHIBA , EMMC NAME: 064GE2 , HEX: 303634474532 , S/N: 96165789 , rev. 0x00
EMMC Manufacture ID: 0x11 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 5/2015
EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 393472 , Response: Not Clean
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD Information :
Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1)
Boot Bus Config: 0x02 , width 8bit
H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: 064GE2_96165789_20200127_184412.extcsd
EMMC Init completed.
Scanning soft partitions
GPT header is found and is valid
Partition: vrl, [000000080000 - 0000000C0000], size: 000000040000 (256. KB)
Partition: vrl_backup, [0000000C0000 - 000000100000], size: 000000040000 (256. KB)
Partition: mcuimage, [000000100000 - 000000140000], size: 000000040000 (256. KB)
Partition: reserved0, [000000140000 - 000000200000], size: 0000000C0000 (768. KB)
Partition: fastboot, [000000200000 - 000000600000], size: 000000400000 (4.00 MB)
Partition: modemnvm_factory, [000000600000 - 000000A00000], size: 000000400000 (4.00 MB)
Partition: nvme, [000000A00000 - 000001000000], size: 000000600000 (6.00 MB)
Partition: oeminfo, [000001000000 - 000003000000], size: 000002000000 (32.0 MB)
Partition: splash, [000003000000 - 000003800000], size: 000000800000 (8.00 MB)
Partition: modemnvm_backup, [000003800000 - 000003C00000], size: 000000400000 (4.00 MB)
Partition: modemnvm_img, [000003C00000 - 000004400000], size: 000000800000 (8.00 MB)
Partition: modemnvm_system, [000004400000 - 000004800000], size: 000000400000 (4.00 MB)
Partition: securetystorage, [000004800000 - 000006800000], size: 000002000000 (32.0 MB)
Partition: 3rdmodemnvm, [000006800000 - 000007800000], size: 000001000000 (16.0 MB)
Partition: 3rdmodemnvmback, [000007800000 - 000008800000], size: 000001000000 (16.0 MB)
Partition: reserved1, [000008800000 - 000009400000], size: 000000C00000 (12.0 MB)
Partition: modem_om, [000009400000 - 00000A000000], size: 000000C00000 (12.0 MB)
Partition: splash2, [00000A000000 - 00000E400000], size: 000004400000 (68.0 MB)
Partition: misc, [00000E400000 - 00000E600000], size: 000000200000 (2.00 MB)
Partition: modemnvm_update, [00000E600000 - 00000FE00000], size: 000001800000 (24.0 MB)
Partition: recovery2, [00000FE00000 - 000013E00000], size: 000004000000 (64.0 MB)
Partition: reserved2, [000013E00000 - 000017E00000], size: 000004000000 (64.0 MB)
Partition: teeos, [000017E00000 - 000018200000], size: 000000400000 (4.00 MB)
Partition: trustfirmware, [000018200000 - 000018400000], size: 000000200000 (2.00 MB)
Partition: sensorhub, [000018400000 - 000019400000], size: 000001000000 (16.0 MB)
Partition: hifi, [000019400000 - 00001A000000], size: 000000C00000 (12.0 MB)
Partition: boot, [00001A000000 - 00001B800000], size: 000001800000 (24.0 MB)
Partition: recovery, [00001B800000 - 00001D800000], size: 000002000000 (32.0 MB)
Partition: dtimage, [00001D800000 - 00001F800000], size: 000002000000 (32.0 MB)
Partition: modem, [00001F800000 - 000023800000], size: 000004000000 (64.0 MB)
Partition: modem_dsp, [000023800000 - 000024000000], size: 000000800000 (8.00 MB)
Partition: dfx, [000024000000 - 000025000000], size: 000001000000 (16.0 MB)
Partition: 3rdmodem, [000025000000 - 000029000000], size: 000004000000 (64.0 MB)
Partition: cache, [000029000000 - 000039000000], size: 000010000000 (256. MB)
Partition: hisitest0, [000039000000 - 000039200000], size: 000000200000 (2.00 MB)
Partition: hisitest1, [000039200000 - 000039400000], size: 000000200000 (2.00 MB)
Partition: hisitest2, [000039400000 - 000039800000], size: 000000400000 (4.00 MB)
Partition: system, [000039800000 - 0000D9800000], size: 0000A0000000 (2.50 GB)
Partition: cust, [0000D9800000 - 0000F9800000], size: 000020000000 (512. MB)
Partition: userdata, [0000F9800000 - 000E8F800000], size: 000D96000000 (54.3 GB)
GPT header successfully parsed
Get firmware version
Brand = HONOR
Manufacturer = HUAWEI
Device = HWPLK
Model = PLK
Phone platform = hi3635
CPU Abi = arm64-v8a
Android release = 6.0
Firmware version = PLK-AL10C00B389
Firmware date = Wed Oct 11 19:37:39 CST 2017
The Following 2 Users Say Thank You to ilyasrao For This Useful Post:
Old 02-03-2020, 13:32   #714 (permalink)
Member: 2847396
Thanks Meter: 4
vivo v9 youth 1727 isp pinouts required??
Old 02-10-2020, 00:58   #715 (permalink)
Member: 2351944
Hi i need j510f emmc pinout plzzzzzzzzz
Old 02-10-2020, 14:30   #716 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
You need desolder eMMC
Old 02-13-2020, 11:34   #717 (permalink)
Member: 2494126
Thanks Meter: 3
Anyone got pinout for
Huawei Y625 (-U21 if possible, but all models will help)
Huawei Y560 (-L01 if possible, but all models will help)
Old 02-14-2020, 23:05   #718 (permalink)
kzafquiel's Avatar
Member: 1318721
Thanks Meter: 166
motorola
xt1952 isp moto g7 play
check it
Old 02-27-2020, 16:50   #719 (permalink)
Member: 2947493
busco el pinaut de samsung a50 si alguien me podrķa proporcionar..
Old 03-06-2020, 09:12   #720 (permalink)
Member: 476227
SM-G361F Correct isp pinout
sorry but (You must have 10 posts in order to post links)
search my picture with pinout in russian support forum
Page generated in 0.24873 seconds with 9 queries
