![]() | #261 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2006 Location: GSM WORLD
Member: 412843 Status: Offline Sonork: 100.1604902 Thanks Meter: 498 ![]() | @love edition Thanks A Lot Sir I Already Got But If You Have Any Clear Image Plz Share For Others (I Dont Have Clear Image) But It Has Serious Problem (May Be EMMC Totally Damaged) If You Have Any Solution Will Ge Grateful Toshiba EMMC In LG F200L Is There Any Solution For Toshiba EMMC? Code: Z3X EasyJtag Software ver. 2.0.3.0 Loading eMMC Addon Firmware... IO: 1800 mV Box S/N: XXXXXXXXXX, ,FW Ver.: 01.52 CMD Pullup Level:1722 mV CMD Active Level:1763 mV eMMC Device Information EMMC CID : 11010030313647393200C7D4043F7F5E EMMC CSD : D00E00320F5903FFFFFFFFEF92400044 EMMC Manufacturer ID: 0011 , OEM ID: 0100 EMMC Date: 07/2012 Rev.0x0 EMMC NAME: <b>016G92</b> , S/N: 3352560703 EMMC NAME (HEX): 30313647393200 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 512 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. Backup saved: 016G92_3352560703_20150604_1614.extcsd Done. When Try To Flash Error On 10% I Also Tried To Read Dump Via Direct EMMC Error Is Here Code: Z3X EasyJtag Software ver. 2.0.3.0 Skip loading eMMC Addon Firmware CMD Pullup Level:1443 mV CMD Active Level:1608 mV Output file :C:\Documents and Settings\RAO\Desktop\512MB_EMMC_ROM1_00000000_20000000.bin Reading 0x000020000000 bytes from 0x000000000000 ...ROM1 ( USER ROM) Retry reading adress 0x00066000 (Attempt #1) Retry Fail! Retry reading adress 0x00066000 (Attempt #2) Retry Fail! Retry reading adress 0x00066000 (Attempt #3) Retry Fail! Read Block Failed, Reason: CARD Data FIFO Timeout Error Done. Need More Help Plz Thanks Anticipation |
![]() | #263 (permalink) |
Junior Member Join Date: Jun 2015
Member: 2410377 Status: Offline Thanks Meter: 0 | Z3X EasyJtag Software ver. 2.0.3.0 Skip loading eMMC Addon Firmware CMD Pullup Level:2196 mV CMD Active Level:2402 mV Reading 0x000380000000 bytes from 0x000000000000 ...ROM1 ( USER ROM) Retry reading adress 0x00000000 (Attempt #1) It seems to be stuck at after "Retry reading adress 0x00000000 (Attempt #1)" about how long should this take? |
![]() | #268 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2013 Location: Nepal Age: 42
Member: 1906979 Status: Offline Sonork: 100.1681049 Thanks Meter: 162 ![]() | this is direct emmc pinouts for work with direct emmc only. there is no model number nedded. read rom1 and rom2 from working phone and write in damaged phone, using this pinouts, in easy jtag direct emmc tab |
