05-27-2014, 18:40 | #1 (permalink) |
No Life Poster Join Date: May 2010
Member: 1300483 Status: Offline Thanks Meter: 27 | emmc oooo fixed but no display plz check logs phone not switching on Please, Reconnect EMMC power lines and press 'VTU00M Repair' again =================================== Running:SAMSUNG: MoviNAND VTU00M Name 0000 Repair... Z3X EasyJtag Software ver. 1.5.0.0 Skip loading eMMC Addon Firmware CMD Pullup Level:1103 mV CMD Active Level:1423 mV Start EMMC repair: Entering repair mode 2... Warning Can't enter repair mode 2, Reason: CARD Ready Timeout Error Please, Reconnect EMMC power lines and press 'VTU00M Repair' again =================================== Running:SAMSUNG: MoviNAND VTU00M Name 0000 Repair... Z3X EasyJtag Software ver. 1.5.0.0 Skip loading eMMC Addon Firmware CMD Pullup Level:1103 mV CMD Active Level:1423 mV Start EMMC repair: Entering repair mode 2... Success Erasing repair area... Success Writing repair area... Success Exit repair mode 2... Reading S.M.A.R.T Can't init EMMC, Reason: CMD Timeout Error =================================== Running:SAMSUNG: Read S.M.A.R.T Report... Z3X EasyJtag Software ver. 1.5.0.0 Skip loading eMMC Addon Firmware CMD Pullup Level:1103 mV CMD Active Level:1423 mV Reading S.M.A.R.T S.M.A.R.T Ver. 0 , Card Error mode : Normal Super Block size : 0x00800000 (8388608 bytes) Super Page size : 0x00004000 (16384 bytes) Optimal Write size : 0x00010000 (65536 bytes) Read Reclaim count : 0 Optimal TRIM size : 0x00002000 (8192 bytes) Total Number of banks : 4 Initial bad blocks per bank : 2,2,3,8 Runtime bad blocks per bank : 0,0,0,0 Reserved blocks left per bank : 49,49,48,43 All Erase counts (min,avg,max): 0,0,1 SLC Erase counts (min,avg,max): 0,0,1 MLC Erase counts (min,avg,max): 0,0,0 S.M.A.R.T Report Done !!! Z3X EasyJtag Software ver. 1.5.0.0 Loading eMMC Addon Firmware... IO: 1850 mV Box S/N: 0AFF600D31564BAE, ,FW Ver.: 01.50 CMD Pullup Level:1196 mV CMD Active Level:1557 mV eMMC Device Information EMMC CID : 15010056545530304DF1E3E56E9F6FA0 EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 06/2012 Rev.0xf1 EMMC NAME: VTU00M , S/N: 3823464095 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. Backup saved: VTU00M_3823464095_20140402_1815.extcsd Done. Writing file...C:\Documents and Settings\mnymo\My Documents\New Folder (3)\EMMC_ROM2_00000000_00200000.bin Z3X EasyJtag Software ver. 1.5.0.0 Skip loading eMMC Addon Firmware CMD Pullup Level:1196 mV CMD Active Level:1557 mV Writing 000000200000 bytes to 00000000 ...ROM2 (BOOT1 ROM) Write Speed: 818 kB/s Done !!! Writing file...C:\Documents and Settings\mnymo\My Documents\New Folder (3)\EMMC_ROM1_00000000_20000000.bin Z3X EasyJtag Software ver. 1.5.0.0 Skip loading eMMC Addon Firmware CMD Pullup Level:1196 mV CMD Active Level:1557 mV Writing 000020000000 bytes to 00000000 ...ROM1 (USER ROM) Write Speed: 831 kB/s Done !!! |
05-27-2014, 18:45 | #2 (permalink) |
Junior Member Join Date: Mar 2012 Location: Belarus/ Minsk
Member: 1736186 Status: Offline Thanks Meter: 23 | good day. you need set boot config 0x48 and boot bus config 0x1. check your log: Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. log with good set boot config: Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. |
The Following User Says Thank You to zippo13 For This Useful Post: |
05-27-2014, 19:24 | #5 (permalink) |
Member: 1736186 Status: Offline Thanks Meter: 23 | step 1 need set boot options like in the picture. and press button "set partitions config 0x48" then do repair ExtCSD from backup step 2 need set boot options like in the picture. and press button "set partitions config 0x01" then do repair ExtCSD from backup step 3 check log. if all good flash rom1 and rom2. sorry for my bad english. |
