Old 01-21-2021, 06:45   #1 (permalink)
jmr
Member: 614683
Sonork: 100.1605379
Thanks Meter: 370
S10e problem read backup
i have same problem cant read dump
Identify UFS Chip.
UFS Chip Voltage: Low
Check ISP connect.
Calibrate ISP.
VCC: 3247mV
VCCQ2: 1912mV
Chip Info:
Manufacturer: TOSHIBA
ProductName: THGAF8T0T43BAIRA
SerialNumber: SCLOCN402K00
Firmware Version: 0.0B
UFS Version: 2.1
Maximum Number of LUs: 32
Number of LUs found: 4
LUN 0:
Block size: 0x1000
Size: 0x1DC5C00000 / 119,092,000,000B / 119GB
LUN 1 (Boot A):
Block size: 0x1000
Size: 0x800000 / 0,008,000,000B / 8MB
LUN 2 (Boot B):
Block size: 0x1000
LUN 3:
Block size: 0x1000
Size: 0x3C00000 / 0,060,000,000B / 60MB
Number of W-LUs found: 1
W-LUN 0xC4 (REPORT LUNS):
Block size: 0x100
Size: 0x1000000 / 0,016,000,000B / 16MB
Full size: 0x1DCC800000 / 119,200,000,000B / 119GB
Health:
Device life time method A: 0x01 (0%-10% device life time used)
Device life time method B: 0x01 (0%-10% device life time used)
Pre End of Life: 0x01 (Used less then 80% of reserved blocks)
Chip config is OTP
Read UFS LUN0, Address: 0x0 ,Length: 0x40000000
Output file :C:\S10e lotmode\UFS_THGAF8T0T43BAIRA_0_00000000_40000000.b in
Start
Can't read address 0x0, Code: -108, Reason: UTP: response timeout
Try to reconnect UFS
Reconnected continue read
Can't read address 0x0, Code: -2139062144, Reason: Unknown error (-2139062144)
Can't stop LU, Code: -2139062144, Reason: Unknown error (-2139062144)
Done.
Old 01-22-2021, 12:18   #2 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
try to connect RST pin at PCB to VCCQ2
Page generated in 0.14175 seconds with 8 queries
