Problem running interface EasyJTAG Plus hi team i have problem in EasyJTAG Plus Not working on win10 bit 32 bit 64 But it works on win 7 Possible solution to the problem |
you need more detailiase of you problem to get help from us i work with box at win 10 x64 more, when 2 years |
I'm working on this release easyjtag_emmc_plus_1.5.3.0 the box Works on Windows 7 100% But on Windows all bit does not work And what data are required of me? But the latest version of EasyJtag_Release_v3.4.RC5 Works 100% on the same Windows 10 |
screenshot of drivers at device manager, screenshot of plus software error |
https://img.gem-flash.com/images/577...7432548745.png |
try to tempory disable RIM Virtual Serial ports and Find USB-EasyJTAG HiSpeed device, change view - Select "Device by connection", search JTAG Com port, and change EasyJTAG COM number to COM2 |
Emmc plus not open win 10 64 os Emmc plus not open win 10 64 os https://i.imgur.com/LMS1uTw.png Jtag ok https://i.imgur.com/ukD7MVr.png |
how to solve this problem layder sir? |
try use admin rights I use EasyJTAG Plus software at win10x64 3-4 year and all work or ask ofаicial supporter - mr. Blang |
even i found no problem with easy jteg and i m using win10 64 bit also but u can face problem if u installed wrong drivers and if u have v1 box (personally experience when i have v1 box ) |
You must disable Driver Signature Verification on 64-Bit Windows 8 or 10 So That You Can Install Unsigned Drivers, don't forget to install the drivers manually later. |
easyjtag plus is not running at windows 10 help easyjtag is working fine at windows 10 but plus is not working. i have also windows 8.1 installed another pc, there is no any problem with windows 8.1. |
i(dot)imgur(dot)com/z6BBuI2(dot)png (dot) = . use above link to see the image |
Use Windows 7 32 Im using It very fine |
