06-29-2020, 09:48 | #1 (permalink) |
Crazy Poster Join Date: Sep 2010 Location: iran
Member: 1402783 Status: Offline Thanks Meter: 5 | f11 pro error flashing easy jtag https://imgur.com/FBfIYVGeMMC_tool Suite ver. 1.6.3.0 (release date: 23.06.2020) Microsoft Windows 7 (32 bit) build 7601 (6.1.7600.16385) Changelog: 23.06.2020 (ver 1.6.3.0) Fix: Bugs that have been found through your crash report Operation: Extract OFP Filename: CPH1969_11_A.05_190315_07454cfc.ofp Header found Extracting files. Please, wait ... Extracted 35 files All done Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 24 MHz CMD Pullup Level: 1010 mV CMD Active Level: 1796 mV Can't init device. Reason: CMD Timeout Error Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 24 MHz CMD Pullup Level: 1697 mV CMD Active Level: 1855 mV Can't init device. Reason: CMD Timeout Error Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 24 MHz CMD Pullup Level: 1700 mV CMD Active Level: 1857 mV Can't init device. Reason: CMD Timeout Error Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 24 MHz CMD Pullup Level: 1701 mV CMD Active Level: 1856 mV Can't init device. Reason: CMD Timeout Error Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 24 MHz CMD Pullup Level: 1715 mV CMD Active Level: 1862 mV Can't init device. Reason: CMD Timeout Error Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 24 MHz CMD Pullup Level: 1805 mV CMD Active Level: 1872 mV EMMC Device Information : EMMC CID: 15010033483643414202449BCC4516B3 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: 3H6CAB , HEX: 334836434142 , S/N: 449BCC45 , rev. 0x02 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 1/2019 EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 1533 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x02 , width 8bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: 3H6CAB_449BCC45_20200629_161750.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: boot_para, [000000008000 - 000000108000], size: 000000100000 (1.00 MB) Partition: recovery, [000000108000 - 000004108000], size: 000004000000 (64.0 MB) Partition: para, [000004108000 - 000004188000], size: 000000080000 (512. KB) Partition: opporeserve1, [000004188000 - 000004988000], size: 000000800000 (8.00 MB) Partition: opporeserve2, [000004988000 - 000008988000], size: 000004000000 (64.0 MB) Partition: opporeserve3, [000008988000 - 00000C988000], size: 000004000000 (64.0 MB) Partition: oppo_custom, [00000C988000 - 00000CA88000], size: 000000100000 (1.00 MB) Partition: expdb, [00000CA88000 - 00000DE88000], size: 000001400000 (20.0 MB) Partition: frp, [00000DE88000 - 00000DF88000], size: 000000100000 (1.00 MB) Partition: nvcfg, [00000DF88000 - 00000FF88000], size: 000002000000 (32.0 MB) Partition: nvdata, [00000FF88000 - 000013F88000], size: 000004000000 (64.0 MB) Partition: metadata, [000013F88000 - 000015F88000], size: 000002000000 (32.0 MB) Partition: protect1, [000015F88000 - 000016788000], size: 000000800000 (8.00 MB) Partition: protect2, [000016788000 - 000017000000], size: 000000878000 (8.47 MB) Partition: seccfg, [000017000000 - 000017800000], size: 000000800000 (8.00 MB) Partition: persist, [000017800000 - 00001A800000], size: 000003000000 (48.0 MB) Partition: sec1, [00001A800000 - 00001AA00000], size: 000000200000 (2.00 MB) Partition: proinfo, [00001AA00000 - 00001AD00000], size: 000000300000 (3.00 MB) Partition: md1img, [00001AD00000 - 000021100000], size: 000006400000 (100. MB) Partition: spmfw, [000021100000 - 000021200000], size: 000000100000 (1.00 MB) Partition: scp1, [000021200000 - 000021800000], size: 000000600000 (6.00 MB) Partition: scp2, [000021800000 - 000021E00000], size: 000000600000 (6.00 MB) Partition: sspm_1, [000021E00000 - 000021F00000], size: 000000100000 (1.00 MB) Partition: sspm_2, [000021F00000 - 000022000000], size: 000000100000 (1.00 MB) Partition: cam_vpu1, [000022000000 - 000022F00000], size: 000000F00000 (15.0 MB) Partition: cam_vpu2, [000022F00000 - 000023E00000], size: 000000F00000 (15.0 MB) Partition: cam_vpu3, [000023E00000 - 000024D00000], size: 000000F00000 (15.0 MB) Partition: gz1, [000024D00000 - 000025D00000], size: 000001000000 (16.0 MB) Partition: gz2, [000025D00000 - 000026D00000], size: 000001000000 (16.0 MB) Partition: nvram, [000026D00000 - 00002AD00000], size: 000004000000 (64.0 MB) Partition: lk, [00002AD00000 - 00002B200000], size: 000000500000 (5.00 MB) Partition: lk2, [00002B200000 - 00002B700000], size: 000000500000 (5.00 MB) Partition: boot, [00002B700000 - 00002D700000], size: 000002000000 (32.0 MB) Partition: logo, [00002D700000 - 00002E700000], size: 000001000000 (16.0 MB) Partition: dtbo, [00002E700000 - 00002F700000], size: 000001000000 (16.0 MB) Partition: tee1, [00002F700000 - 00002FC00000], size: 000000500000 (5.00 MB) Partition: tee2, [00002FC00000 - 000030800000], size: 000000C00000 (12.0 MB) Partition: odm, [000030800000 - 000040800000], size: 000010000000 (256. MB) Partition: vendor, [000040800000 - 000083800000], size: 000043000000 (1.05 GB) Partition: system, [000083800000 - 0001D0800000], size: 00014D000000 (5.20 GB) Partition: cache, [0001D0800000 - 0001EB800000], size: 00001B000000 (432. MB) Partition: userdata, [0001EB800000 - 000E8BCFBE00], size: 000CA04FBE00 (50.5 GB) Partition: otp, [000E8BCFBE00 - 000E8E7FBE00], size: 000002B00000 (43.0 MB) Partition: flashinfo, [000E8E7FBE00 - 000E8F7FBE00], size: 000001000000 (16.0 MB) GPT header successfully parsed Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 24 MHz CMD Pullup Level: 1805 mV CMD Active Level: 1872 mV EMMC Device Information : EMMC CID: 15010033483643414202449BCC4516B3 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: 3H6CAB , HEX: 334836434142 , S/N: 449BCC45 , rev. 0x02 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 1/2019 EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 1533 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x02 , width 8bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: 3H6CAB_449BCC45_20200629_161802.extcsd EMMC Init completed. Opening file: MT6771_Android_scatter.txt The new format of scatter config_version: V1.1.2 platform: MT6771 preloader_oppo6771_18531.bin Found 10 supported eMMC CID: name = 'DV6DMB' hex = 0x445636444D42 [SAMSUNG] name = '3V6CMB' hex = 0x335636434D42 [SAMSUNG] name = '3H6CAB' hex = 0x334836434142 [SAMSUNG] name = 'hC8aP>' hex = 0x68433861503E [SKHYNIX] name = 'S0J9K9' hex = 0x53304A394B39 [MICRON] name = 'DH6DAB' hex = 0x444836444142 [SAMSUNG] name = 'hC8aP>' hex = 0x68433861503E [SKHYNIX] name = 'S0J9K8' hex = 0x53304A394B38 [MICRON] name = 'S0J9M9' hex = 0x53304A394D39 [MICRON] Maybe external DRAM detected The size of the last section has been updated Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 24 MHz CMD Pullup Level: 1806 mV CMD Active Level: 1873 mV EMMC Device Information : EMMC CID: 15010033483643414202449BCC4516B3 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: 3H6CAB , HEX: 334836434142 , S/N: 449BCC45 , rev. 0x02 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 1/2019 EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 1533 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x02 , width 8bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: 3H6CAB_449BCC45_20200629_161824.extcsd EMMC Init completed. Operation: Write by vendor (MediaTek) Creating GPT-partitioninig Writing PrimaryGPT at address: 000000000000 Writing BackupGPT at address: 000E8F7FBE00 GPT-partitioning done Partition name: preloader Filename: preloader_oppo6771_18531.bin , Offset: 000000000000 , filesize: 265004 bytes eMMC switching to ROM3 Erasing partition... Writing partition... Done writing partition. Write speed: 796.30 KB/s Partition name: preloader Filename: preloader_oppo6771_18531.bin , Offset: 000000000000 , filesize: 265004 bytes eMMC switching to ROM2 Erasing partition... Writing partition... Done writing partition. Write speed: 792.73 KB/s Partition name: recovery Filename: recovery.img , Offset: 000000108000 , filesize: 35857264 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2605.11 KB/s Partition name: opporeserve2 Filename: opporeserve2.img , Offset: 000004988000 , filesize: 5300372 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 10 Done writing partition. Write speed: 2663.26 KB/s Partition name: md1img Filename: md1img.img , Offset: 00001AD00000 , filesize: 87854112 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Error writing at address: 00001F120000 , error: -8, DATA SND CRC Error(Small ROM Size, maybe) ... Retry #1 Error writing at address: 00001F120000 , error: -1, CMD Timeout Error ... Retry #2 Done writing partition. Write speed: 2666.96 KB/s Partition name: spmfw Filename: spmfw.img , Offset: 000021100000 , filesize: 40576 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 621.96 KB/s Partition name: scp1 Filename: scp.img , Offset: 000021200000 , filesize: 585888 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2020.31 KB/s Partition name: scp2 Filename: scp.img , Offset: 000021800000 , filesize: 585888 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2591.43 KB/s Partition name: sspm_1 Filename: sspm.img , Offset: 000021E00000 , filesize: 496464 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2198.86 KB/s Partition name: sspm_2 Filename: sspm.img , Offset: 000021F00000 , filesize: 496464 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2580.13 KB/s Partition name: cam_vpu1 Filename: cam_vpu1.img , Offset: 000022000000 , filesize: 1652768 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2484.19 KB/s Partition name: cam_vpu2 Filename: cam_vpu2.img , Offset: 000022F00000 , filesize: 14225552 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2717.12 KB/s Partition name: cam_vpu3 Filename: cam_vpu3.img , Offset: 000023E00000 , filesize: 6027760 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2656.94 KB/s Partition name: lk Filename: lk.img , Offset: 00002AD00000 , filesize: 1123344 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2362.60 KB/s Partition name: lk2 Filename: lk.img , Offset: 00002B200000 , filesize: 1123344 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2586.40 KB/s Partition name: boot Filename: boot.img , Offset: 00002B700000 , filesize: 10595184 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2682.70 KB/s Partition name: logo Filename: logo.bin , Offset: 00002D700000 , filesize: 4089360 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2604.08 KB/s Partition name: dtbo Filename: dtbo.img , Offset: 00002E700000 , filesize: 185968 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1258.81 KB/s Partition name: tee1 Filename: tee.img , Offset: 00002F700000 , filesize: 507216 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1953.60 KB/s Partition name: tee2 Filename: tee.img , Offset: 00002FC00000 , filesize: 507216 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2458.36 KB/s Partition name: odm Filename: odm.img , Offset: 000030800000 , filesize: 6398160 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 15 Done writing partition. Write speed: 2652.91 KB/s Partition name: vendor Filename: vendor.img , Offset: 000040800000 , filesize: 781947208 bytes eMMC switching to ROM1 Erasing partition... Error erasing at address: 000067360000 , error: -101, CARD Ready Timeout Error ... Retry #1 Writing partition... Sparse image found v.1.0 Total chunks: 25 Error writing at address: 0000479FA000 , error: -8, DATA SND CRC Error(Small ROM Size, maybe) ... Retry #1 Error writing at address: 0000479FA000 , error: -1, CMD Timeout Error ... Retry #2 Error writing at address: 0000479FA000 , error: -1, CMD Timeout Error ... Retry #3 Error writing at address: 0000525F7000 , error: -8, DATA SND CRC Error(Small ROM Size, maybe) ... Retry #1 Error writing at address: 0000525F7000 , error: -1, CMD Timeout Error ... Retry #2 Error writing at address: 0000525F7000 , error: -1, CMD Timeout Error ... Retry #3 Error writing at address: 00005CF7A000 , error: -8, DATA SND CRC Error(Small ROM Size, maybe) ... Retry #1 Error writing at address: 00005CF7A000 , error: -1, CMD Timeout Error ... Retry #2 Error writing at address: 00005CF7A000 , error: -1, CMD Timeout Error ... Retry #3 Error writing at address: 0000679B7000 , error: -1, CMD Timeout Error ... Retry #1 Error writing at address: 0000679B7000 , error: -1, CMD Timeout Error ... Retry #2 Error writing at address: 0000679B7000 , error: -1, CMD Timeout Error ... Retry #3 Done writing partition. Write speed: 2713.53 KB/s Writing DL_Info... Writing DL_Info done Writing eMMC Register ... Reg: 179 Value: 0x48 Reg: 177 Value: 0x00 Reg: 162 Value: 0x01 All done time: [00:07:05:000] Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 24 MHz CMD Pullup Level: 1806 mV CMD Active Level: 1871 mV EMMC Device Information : EMMC CID: 15010033483643414202449BCC4516B3 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: 3H6CAB , HEX: 334836434142 , S/N: 449BCC45 , rev. 0x02 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 1/2019 EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 1533 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: 3H6CAB_449BCC45_20200629_162549.extcsd EMMC Init completed. Operation: Write by vendor (MediaTek) Creating GPT-partitioninig Writing PrimaryGPT at address: 000000000000 Writing BackupGPT at address: 000E8F7FBE00 GPT-partitioning done Partition name: system Filename: system.img , Offset: 000083800000 , filesize: 3819930552 bytes eMMC switching to ROM1 Erasing partition... Error erasing at address: 00010EAE0000 , error: -101, CARD Ready Timeout Error ... Retry #1 Error erasing at address: 000196DA0000 , error: -101, CARD Ready Timeout Error ... Retry #1 Writing partition... Sparse image found v.1.0 Total chunks: 77 Error writing at address: 0000888CB000 , error: -8, DATA SND CRC Error(Small ROM Size, maybe) ... Retry #1 Error writing at address: 0000888CB000 , error: -1, CMD Timeout Error ... Retry #2 Error writing at address: 0000888CB000 , error: -1, CMD Timeout Error ... Retry #3 Error writing at address: 00009352B000 , error: -8, DATA SND CRC Error(Small ROM Size, maybe) ... Retry #1 Error writing at address: 00009352B000 , error: -1, CMD Timeout Error ... Retry #2 Error writing at address: 00009352B000 , error: -1, CMD Timeout Error ... Retry #3 Too many errors. Writing has been stopped Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 24 MHz CMD Pullup Level: 1805 mV CMD Active Level: 1871 mV EMMC Device Information : EMMC CID: 15010033483643414202449BCC4516B3 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: 3H6CAB , HEX: 334836434142 , S/N: 449BCC45 , rev. 0x02 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 1/2019 EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 1533 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: 3H6CAB_449BCC45_20200629_163052.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: boot_para, [000000008000 - 000000108000], size: 000000100000 (1.00 MB) Partition: recovery, [000000108000 - 000004108000], size: 000004000000 (64.0 MB) Partition: para, [000004108000 - 000004188000], size: 000000080000 (512. KB) Partition: opporeserve1, [000004188000 - 000004988000], size: 000000800000 (8.00 MB) Partition: opporeserve2, [000004988000 - 000008988000], size: 000004000000 (64.0 MB) Partition: opporeserve3, [000008988000 - 00000C988000], size: 000004000000 (64.0 MB) Partition: oppo_custom, [00000C988000 - 00000CA88000], size: 000000100000 (1.00 MB) Partition: expdb, [00000CA88000 - 00000DE88000], size: 000001400000 (20.0 MB) Partition: frp, [00000DE88000 - 00000DF88000], size: 000000100000 (1.00 MB) Partition: nvcfg, [00000DF88000 - 00000FF88000], size: 000002000000 (32.0 MB) Partition: nvdata, [00000FF88000 - 000013F88000], size: 000004000000 (64.0 MB) Partition: metadata, [000013F88000 - 000015F88000], size: 000002000000 (32.0 MB) Partition: protect1, [000015F88000 - 000016788000], size: 000000800000 (8.00 MB) Partition: protect2, [000016788000 - 000017000000], size: 000000878000 (8.47 MB) Partition: seccfg, [000017000000 - 000017800000], size: 000000800000 (8.00 MB) Partition: persist, [000017800000 - 00001A800000], size: 000003000000 (48.0 MB) Partition: sec1, [00001A800000 - 00001AA00000], size: 000000200000 (2.00 MB) Partition: proinfo, [00001AA00000 - 00001AD00000], size: 000000300000 (3.00 MB) Partition: md1img, [00001AD00000 - 000021100000], size: 000006400000 (100. MB) Partition: spmfw, [000021100000 - 000021200000], size: 000000100000 (1.00 MB) Partition: scp1, [000021200000 - 000021800000], size: 000000600000 (6.00 MB) Partition: scp2, [000021800000 - 000021E00000], size: 000000600000 (6.00 MB) Partition: sspm_1, [000021E00000 - 000021F00000], size: 000000100000 (1.00 MB) Partition: sspm_2, [000021F00000 - 000022000000], size: 000000100000 (1.00 MB) Partition: cam_vpu1, [000022000000 - 000022F00000], size: 000000F00000 (15.0 MB) Partition: cam_vpu2, [000022F00000 - 000023E00000], size: 000000F00000 (15.0 MB) Partition: cam_vpu3, [000023E00000 - 000024D00000], size: 000000F00000 (15.0 MB) Partition: gz1, [000024D00000 - 000025D00000], size: 000001000000 (16.0 MB) Partition: gz2, [000025D00000 - 000026D00000], size: 000001000000 (16.0 MB) Partition: nvram, [000026D00000 - 00002AD00000], size: 000004000000 (64.0 MB) Partition: lk, [00002AD00000 - 00002B200000], size: 000000500000 (5.00 MB) Partition: lk2, [00002B200000 - 00002B700000], size: 000000500000 (5.00 MB) Partition: boot, [00002B700000 - 00002D700000], size: 000002000000 (32.0 MB) Partition: logo, [00002D700000 - 00002E700000], size: 000001000000 (16.0 MB) Partition: dtbo, [00002E700000 - 00002F700000], size: 000001000000 (16.0 MB) Partition: tee1, [00002F700000 - 00002FC00000], size: 000000500000 (5.00 MB) Partition: tee2, [00002FC00000 - 000030800000], size: 000000C00000 (12.0 MB) Partition: odm, [000030800000 - 000040800000], size: 000010000000 (256. MB) Partition: vendor, [000040800000 - 000083800000], size: 000043000000 (1.05 GB) Partition: system, [000083800000 - 0001D0800000], size: 00014D000000 (5.20 GB) Partition: cache, [0001D0800000 - 0001EB800000], size: 00001B000000 (432. MB) Partition: userdata, [0001EB800000 - 000E8BCFBE00], size: 000CA04FBE00 (50.5 GB) Partition: otp, [000E8BCFBE00 - 000E8E7FBE00], size: 000002B00000 (43.0 MB) Partition: flashinfo, [000E8E7FBE00 - 000E8F7FBE00], size: 000001000000 (16.0 MB) GPT header successfully parsed Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 24 MHz CMD Pullup Level: 1806 mV CMD Active Level: 1872 mV EMMC Device Information : EMMC CID: 15010033483643414202449BCC4516B3 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: 3H6CAB , HEX: 334836434142 , S/N: 449BCC45 , rev. 0x02 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 1/2019 EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 1533 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: 3H6CAB_449BCC45_20200629_163057.extcsd EMMC Init completed. Operation: Write by vendor (MediaTek) Creating GPT-partitioninig Writing PrimaryGPT at address: 000000000000 Writing BackupGPT at address: 000E8F7FBE00 GPT-partitioning done Partition name: system Filename: system.img , Offset: 000083800000 , filesize: 3819930552 bytes eMMC switching to ROM1 Erasing partition... Error erasing at address: 000087D60000 , error: -101, CARD Ready Timeout Error ... Retry #1 Error erasing at address: 00010FE40000 , error: -101, CARD Ready Timeout Error ... Retry #1 Error erasing at address: 000195FE0000 , error: -101, CARD Ready Timeout Error ... Retry #1 Writing partition... Sparse image found v.1.0 Total chunks: 77 Error writing at address: 00008878B000 , error: -8, DATA SND CRC Error(Small ROM Size, maybe) ... Retry #1 Error writing at address: 00008878B000 , error: -1, CMD Timeout Error ... Retry #2 Error writing at address: 00008878B000 , error: -1, CMD Timeout Error ... Retry #3 Error writing at address: 00009334B000 , error: -8, DATA SND CRC Error(Small ROM Size, maybe) ... Retry #1 Error writing at address: 00009334B000 , error: -1, CMD Timeout Error ... Retry #2 Error writing at address: 00009334B000 , error: -1, CMD Timeout Error ... Retry #3 Too many errors. Writing has been stopped Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 24 MHz CMD Pullup Level: 1806 mV CMD Active Level: 1872 mV EMMC Device Information : EMMC CID: 15010033483643414202449BCC4516B3 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: 3H6CAB , HEX: 334836434142 , S/N: 449BCC45 , rev. 0x02 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 1/2019 EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 1533 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: 3H6CAB_449BCC45_20200629_163533.extcsd EMMC Init completed. Operation: Write by vendor (MediaTek) Creating GPT-partitioninig Writing PrimaryGPT at address: 000000000000 Writing BackupGPT at address: 000E8F7FBE00 GPT-partitioning done Partition name: userdata Filename: userdata.img , Offset: 0001EB800000 , filesize: 4452308076 bytes eMMC switching to ROM1 Erasing partition... Error erasing at address: 000256100000 , error: -1, CMD Timeout Error ... Retry #1 Error erasing at address: 000256100000 , error: -1, CMD Timeout Error ... Retry #2 Error erasing at address: 000256100000 , error: -1, CMD Timeout Error ... Retry #3 Too many errors. Erasing has been stopped |
06-30-2020, 07:33 | #4 (permalink) |
Freak Poster Join Date: Jul 2016
Member: 2593918 Status: Offline Thanks Meter: 50 | f11 pro error flashing easy jtag https://imgur.com/udG6NSp https://imgur.com/FBfIYVGeMMC_tool Suite ver. 1.6.3.0 (release date: 23.06.2020) Microsoft Windows 7 (32 bit) build 7601 (6.1.7600.16385) Changelog: remove emmc try brother |
