EMMC TOOL: emmc pinout Pictuer 7,9,11.....19 CONNECT TOGETHER EMMC POWER PINS , But where is the POWER PINS ? how to connect? |
box mod 4 Attachment(s) For people who don't want to buy the adapter, here is the modification to supply the eMMC from the box: Remove R3, R6 and re-route the pins 17 and 19 to the internal regulators U7 and U6. This means we will have VCCQ 1.8V on pin 19 and VCC 3.3V on pin 17. WARNING, remember that you will have ALL THE TIME this two voltage on the connector, so use this 2 pins ONLY and ONLY when dealing with eMMC direct! |
And the box warranty ??? |
Will be void, so better go buy that adapter, this mod is for people with some guts who will NOT rely on "warranties" but on researches and improvements... |
1 Attachment(s) Forgot to post the log: Code: Generic CMD6 Timer [GENERIC_CMD6_TIME: 0x0a] |
Thank you very much for your solution sir, I was very useful ;) |
I modify everything and connects the emmc, get error check conection |
could connect the pcb samsung i9300 |
plz, release i9500 , i9505 pinout........ thank |
while i try emmc repair for i9300 detect emmc log Loading eMMC Addon Firmware... CMD Pullup Level:1650 mV CMD Active Level:2299 mV EMMC CID 15010056545530304D006A0B6330218F EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufactorer ID: 15 EMMC OEM ID: 0100 EMMC Date: 02/1998 FW rev.0x0 HW rev.0x0 EMMC Serial #: 1779131184 EMMC NAME: VTU00M EMMC Capacity: 15028 MB (High Density Card) ============================================= Extended CSD rev 1.6 (MMC 4.5) ============================================= Card Supported Command sets [S_CMD_SET: 0x01] HPI Features [HPI_FEATURE: 0x01]: implementation based on CMD13 Background operations support [BKOPS_SUPPORT: 0x01] Max Packet Read Cmd [MAX_PACKED_READS: 0x3f] Max Packet Write Cmd [MAX_PACKED_WRITES: 0x3f] Data TAG support [DATA_TAG_SUPPORT: 0x01] Data TAG Unit Size [TAG_UNIT_SIZE: 0x04] Tag Resources Size [TAG_RES_SIZE: 0x00] Context Management Capabilities [CONTEXT_CAPABILITIES: 0x05] Large Unit Size [LARGE_UNIT_SIZE_M1: 0x07] Extended partition attribute support [EXT_SUPPORT: 0x03] Generic CMD6 Timer [GENERIC_CMD6_TIME: 0x0a] Power off notification [POWER_OFF_LONG_TIME: 0x3c] Cache Size [CACHE_SIZE] is 65536 KiB Background operations status [BKOPS_STATUS: 0x00] TRIM Multiplier [TRIM_MULT: 0x02] Secure Feature support [SEC_FEATURE_SUPPORT: 0x55] Boot Information [BOOT_INFO: 0x07] Device supports alternative boot method Device supports dual data rate during boot Device supports high speed timing during boot Boot partition size [BOOT_SIZE_MULTI: 0x10] Access size [ACC_SIZE: 0x07] High-capacity erase unit size [HC_ERASE_GRP_SIZE: 0x01] High-capacity erase timeout [ERASE_TIMEOUT_MULT: 0x01] Reliable write sector count [REL_WR_SEC_C: 0x01] High-capacity W protect group size [HC_WP_GRP_SIZE: 0x50] Sleep current (VCC) [S_C_VCC: 0x07] Sleep current (VCCQ) [S_C_VCCQ: 0x07] Sleep/awake timeout [S_A_TIMEOUT: 0x11] Sector Count [SEC_COUNT: 0x01d5a000] Partition switching timing [PARTITION_SWITCH_TIME: 0x01] Out-of-interrupt busy timing [OUT_OF_INTERRUPT_TIME: 0x02] I/O Driver Strength [DRIVER_STRENGTH: 0x00] Card Type [CARD_TYPE: 0x07] CSD structure version [CSD_STRUCTURE: 0x02] Command set [CMD_SET: 0x00] Command set revision [CMD_SET_REV: 0x00] Power class [POWER_CLASS: 0x00] High-speed interface timing [HS_TIMING: 0x00] Erased memory content [ERASED_MEM_CONT: 0x00] Boot configuration bytes [PARTITION_CONFIG: 0x48] No access to boot partition Boot config protection [BOOT_CONFIG_PROT: 0x00] Boot bus Conditions [BOOT_BUS_CONDITIONS: 0x01] High-density erase group definition [ERASE_GROUP_DEF: 0x00] ============================================= Boot write protection status registers [BOOT_WP_STATUS]: 0x00 Boot Area Write protection [BOOT_WP]: 0x10 Power ReadOnly locking: possible Permanent ReadOnly locking: not possible Read Only lock status: not locked ============================================= User area write protection register [USER_WP]: 0x00 FW configuration [FW_CONFIG]: 0x00 RPMB Size [RPMB_SIZE_MULT]: 0x01 Write reliability setting register [WR_REL_SET]: 0x1f Write reliability parameter register [WR_REL_PARAM]: 0x05 Enable background operations handshake [BKOPS_EN]: 0x00 H/W reset function [RST_N_FUNCTION]: 0x00 HPI management [HPI_MGMT]: 0x00 Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Max Enhanced Area Size [MAX_ENH_SIZE_MULT]: 0x0000bb Partitions attribute [PARTITIONS_ATTRIBUTE]: 0x00 Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 General Purpose Partition Size [GP_SIZE_MULT_4]: 0x000000 [GP_SIZE_MULT_3]: 0x000000 [GP_SIZE_MULT_2]: 0x000000 [GP_SIZE_MULT_1]: 0x000000 Enhanced User Data Area Size [ENH_SIZE_MULT]: 0x000000 Enhanced User Data Start Address [ENH_START_ADDR]: 0x000000 Bad Block Management mode [SEC_BAD_BLK_MGMNT]: 0x00 Periodic Wake-up [PERIODIC_WAKEUP]: 0x00 Program CID/CSD in DDR mode support [PROGRAM_CID_CSD_DDR_SUPPORT]: 0x01 Native sector size [NATIVE_SECTOR_SIZE]: 0x00 Sector size emulation [USE_NATIVE_SECTOR]: 0x00 Sector size [DATA_SECTOR_SIZE]: 0x00 1st initialization after disabling sector size emulation [INI_TIMEOUT_EMU]: 0x00 Class 6 commands control [CLASS_6_CTRL]: 0x00 Number of addressed group to be Released[DYNCAP_NEEDED]: 0x00 Exception events control [EXCEPTION_EVENTS_CTRL]: 0x0000 Exception events status[EXCEPTION_EVENTS_STATUS]: 0x0000 Extended Partitions Attribute [EXT_PARTITIONS_ATTRIBUTE]: 0x0000 Packed command status [PACKED_COMMAND_STATUS]: 0x00 Packed command failure index [PACKED_FAILURE_INDEX]: 0x00 Power Off Notification [POWER_OFF_NOTIFICATION]: 0x00 Control to turn the Cache ON/OFF [CACHE_CTRL]: 0x00 Reading dump to file...E:\z3x\EasyJtag\Repair File pinout\I9300\New Folder\EMMC_00000000_00400000.bin Successefuly connected to box on COM119 Box S/N: 05050F0F3E60A930, ,FW Ver.: 01.47 Loading eMMC Addon Firmware... CMD Pullup Level:1660 mV CMD Active Level:2330 mV EMMC CID 15010056545530304D006A0B6330218F EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufactorer ID: 15 EMMC OEM ID: 0100 EMMC Date: 02/1998 FW rev.0x0 HW rev.0x0 EMMC Serial #: 1779131184 EMMC NAME: VTU00M EMMC Capacity: 15028 MB (High Density Card) Switching EMMC partition... Reading 00400000 bytes from 00000000 ...ROM1 main partation write log Loading eMMC Addon Firmware... CMD Pullup Level:1660 mV CMD Active Level:2330 mV EMMC CID 15010056545530304D006A0B6330218F EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufactorer ID: 15 EMMC OEM ID: 0100 EMMC Date: 02/1998 FW rev.0x0 HW rev.0x0 EMMC Serial #: 1779131184 EMMC NAME: VTU00M EMMC Capacity: 15028 MB (High Density Card) Writing 20000000 bytes to 00000000 ...ROM1 eMMC ACK Error at addr:0x11600 again write error eMMC ACK Error at addr:0xf0c0 but boot partation rom 2 write is ok plz help what is rom 1 write error???? |
i also have same problem plzz help |
HERE list of EMMC based samsung: Samsung Galaxy Note II N7100 (16GB), Samsung GALAXY S4 (I9500/16GB), Samsung I9300 GALAXY SIII (Unicom Edition), Samsung I9100 GALAXY SII (16GB), Samsung I9003 GALAXY SII (16GB), Samsung I9300 GALAXY SIII (International Edition, 16 Гб), Samsung Galaxy i9220, Samsung Galaxy Note N7102 II (32GB / Unico), Samsung W2013, Samsung S7568 , Samsung I9300 GALAXY SIII (International Edition, 32 Гб), Samsung W999, Samsung Galaxy Note II N7100 32G, Samsung S7572, Samsung E120LGalaxy SII HD LTE Samsung W899, Samsung I9268, Samsung S7562i (Galaxy S Duos), Samsung GALAXY Примечание II N719 , Samsung I879, Samsung Galaxy Note II N7102 (16GB / dual), Samsung Galxy Note III, Samsung Galaxy i9220 Примечание (белый), Samsung I939D GALAXY SIII (двойной версии карт), Samsung GALAXY Примечание II N7108 (мобильная версия), Samsung I9308 GALAXY SIII (мобильная версия), Samsung B9388, Samsung I8262D (GALAXY Dous), Samsung I8190 GALAXY SIII Mini (16GB), Samsung I9070 Galaxy S (8GB), Samsung I9100 GALAXY SII ( белый), Samsung I8190 GALAXY SIII Mini (8 Гб), Samsung i9100G (GALAXY SII), Samsung I8552 (Galaxy Win), Samsung I9108 (GALAXY SII), Samsung B9120 (усилитель II), Samsung I8750 (ATIV S/16GB), Samsung I9105P (GALAXY SII Plus), Samsung I9305 (GALAXY SIII LTE), Samsung I939 GALAXY SIII (Telecom версии), Samsung I9260 GALAXY премьера (16GB), Samsung I8160 (Galaxy Ace 2), Samsung GALAXY S4 (I9508 / Mobile) Samsung N7105 (Galaxy Note II LTE), Samsung I699 (GALAXY Trend), Samsung I9260 GALAXY премьера (8GB), Samsung GALAXY S4 (I959 / Телеком версии), Samsung I929 (GALAXY SII DUO), Samsung I9050, Samsung I9228, Samsung I9103 (Galaxy R), Samsung I909 (Galaxy S), Samsung I779, Samsung I8250, Samsung I8150 (Galaxy W), Samsung I919 (GALAXY S DUOS), Samsung GALAXY S4 (I9505 / Quad / 4G версия), Samsung I8258, Samsung I919U (GALAXY S Duos), Samsung GALAXY S4 (I9500/32GB), Samsung I8530 (Galaxy Beam), Samsung B9062, Samsung S6358 (Galaxy Ace Уважаемые), Samsung I9018 (Galaxy S), Samsung I619 (Galaxy Ace Уважаемые), Samsung I809 (Galaxy S), Samsung N8000 (Galaxy Note 10.1), Samsung i9200 (Galaxy Mega 6.3/16GB), Samsung i9200 (Galaxy Mega 6.3/8GB), Samsung S7500 (Galaxy Ace Plus), Samsung I9208 (Galaxy Mega 6.3), Samsung Galaxy Note 8.0 (N5100/3G + WiFi), Samsung E210S (GALAXY SIII), Samsung I535 (GALAXY SIII), Samsung D710 (Эпическая сенсорный 4G), Samsung I759, Samsung I9150 (Galaxy 5.8 Mega ), Samsung S6352 (Galaxy Ace родного) Samsung S7508 (Galaxy Ace Plus), Samsung S5698 (Galaxy Xcover), Samsung S7530 (OMNIA M), Samsung GALAXY SIII (TD-LTE версия), Samsung I659 (Galaxy Ace Plus), Samsung I717 (Galaxy Note), Samsung I9300 GALAXY SIII (International Edition, 64 Гб), Samsung I9020 (Nexus S), Samsung GALAXY SII i9100G (Tencent версии), Samsung I9220 Galaxy Note (Extreme Edition), Samsung S6108 (Galaxy Y POP) Samsung I9023 (Nexus S), Samsung I8558 (Galaxy Win), Samsung Galaxy Tab 7.7 P6800 (16 Гб версия), Samsung S7530E (OMNIA M), Samsung B5330 (Galaxy Chat), Samsung I8730 (Galaxy Express), Samsung I9205 (Galaxy Mega 6,3), Samsung I747 (GALAXY SIII), Samsung I9070 Galaxy S (16GB), Samsung I339, Samsung I9100 GALAXY SII (32GB), Samsung I9100 GALAXY SII (Unicom Edition), Samsung GALAXY S4 (I9500/64GB), Samsung I519, Samsung E110S (Celox), Samsung I667 (Фокус 2), Samsung I9210 (Galaxy SII LTE), Samsung S6500D, Samsung T889 (Galaxy Note II), Samsung I727 (Galaxy SII усилится), Samsung I8750 (ATIV S/32GB) Samsung S5300 (Galaxy карманные), Samsung i9088 (Galaxy S), Samsung L710 GALAXY SIII (двухъядерные версии), Samsung I9080 (GALAXY Гранд), Samsung T989 (Hercules), Samsung S6812i, Samsung B5510 (GALAXY Y Pro), Samsung I777 (Синга), Samsung S6500 (Galaxy Mini 2), Samsung E170K (Galaxy R Style), Samsung I930 (ATIV Odyssey), Samsung E220 (GALAXY Pop/8GB), Samsung S7272 (Galaxy Ace 3), Samsung S5280 (GALAXY Star) Samsung I9152 (Galaxy Mega 5,8), Samsung i677 (Фокус Flash), Samsung S7710 (Galaxy Xcover 2), Samsung E220 (GALAXY Pop/16GB), Samsung S6012 (Galaxy Music Duos), Samsung S6810 (Galaxy славы), Samsung R830 (Galaxy Axiom), Samsung GALAXY SIII +, Samsung S5301 (Galaxy Pocket Plus), Samsung S6812 (Galaxy славы), Samsung I547 (Galaxy Rugby Pro), Samsung I6282D (Galaxy Core), Samsung M950 (Galaxy Reverb), Samsung I437 (Galaxy Express), Samsung S6312 (GALAXY Молодые Duos), Samsung T699 (Реле 4G Galaxy S), Samsung S6310 (GALAXY Young), Samsung M340S (Galaxy M), Samsung L300 (Galaxy Победы 4G LTE), Samsung I847 (регби SMART), Samsung Galaxy SII WiMAX, Samsung S759 (Omnia M), Samsung I577 (Galaxy Exhilarate), Samsung I405 (Galaxy Metrix 4G), Samsung E310S (Mega Galaxy 6.3), Samsung T959 (Очаровывай 4G), Samsung M190S (Galaxy S Hoppin), Samsung I7500U Samsung, Samsung I757 (Galaxy SII Скийрокет HD), Samsung Nexus S 4G But in support only have three models: I9082 ,I9300 and N7100 . where is the other models ? |
