Member: 2117988
Sonork: 100.1667932 Thanks Meter: 44 | Quote:
Originally Posted by blang FAQ - DIRECT EMMC connect in pictures!! DONT ASK MORE!
HERE SAMPLE OF CONNECTION TO PCB.
===============FAQ==============================
Q - If i not have Adapter can i connect to EMMC direct on boart?
A - YES. But need use 2 external power.
Q - Why i need use double voltage?
A - VCC - power of NAND memory inside eMMC (can be 2.8 - 3.3V)
VCCQ - power of internal emmc controller. (can be 1.8 - 2.8V) (need setup vccq in sw same with real voltage)
Q - Do i need connect anything else to phone PCB ?
A - NO. NO NEED CONNECT BATTERY OR USB CABLE TO PCB.
NEED ONLY 6 WIRES: GND, CLK, CMD, DAT0, VCC, VCCQ
Q - Can i repair EMMC CHIP (suddenly dead phones)
A - NO. AT THIS moment you cant repair EMMC. But we work on solution for update internal emmc firmware. May be ... who know.
Q - Can i repair Suddenly dead phones.
A - Yes. If something was erased in EMMC CHIP.
Q - Can i repair boot on phone with disable JTAG?
A - Yes you can. (N7100,I9300 boot inside ROM2, after write ROM2 phones back to work)
Q - Can i repair dead phones I9082, i9105, S6810P with disabled JTAG, after touch ROM2.
A -YES you can. Just need write ROM2 via EMMC direct connection.
Q - Where i can take EMMC DIRECT connection pinout on BOARD?
A - Tested EMMC direct connect pinout we uploading to EMMC pinout under phone folder name on support.
Q - How can i find byself EMMC pinout.
A - Yes you can most of emmc have same pinouts. Need desolder EMMC and find where go 5 pins. CMD,CLK, DAT0, VCC,VCCQ
Q - What phones supported by EMMC Tool.
A - Supported any phones for READ/WRITE based on known EMMC. At this moment we support most of known EMMC.
HERE list of EMMC based samsung:
Q - Known Error and Problems:
Correct data: ------------------------------------------------------------------Wrong log: --------------------------------------------------------WHAT TO DO:
My log Loading eMMC Addon Firmware...
CMD Pullup Level:1691 mV --------------------------------------------CMD Pullup Level: 907 mV----------------check BAD power lines, vccq may be low or zero
CMD Active Level:2289 mV--------------------------------------------CMD Active Level:1679 mV----------------check BAD power lines, vccq may be low or zero
EMMC CID 15010056545530304D008456646B7F1D
EMMC CSD D02701320F5903FFF6DBFFFF8E40406D
EMMC Manufactorer ID: 15
EMMC OEM ID: 0100
EMMC Date: 07/2012 FW rev.0x0 HW rev.0x0
EMMC Serial #: 2220254315
EMMC NAME: VTU00M-----------------------------------------------------EMMC NAME: 000000-------------------------bad emmc, at this moment only replace
EMMC Capacity: 15028 MB (High Density Card)
-------------------------------------------------------------------Writing 20000000 bytes to 00000000 ...ROM1-----------1. Problem with GND (should be strong wire)
-------------------------------------------------------------------eMMC ACK Error at addr:0x0-----------------------------2. BAD emmc
--------------------------------------------------------------------------------------------------------------------------------3. BAD power wires
================================================== - Samsung Galaxy Note II N7100 (16GB),
- Samsung GALAXY S4 (I9500/16GB),
- Samsung I9300 GALAXY SIII (Unicom Edition),
- Samsung I9100 GALAXY SII (16GB),
- Samsung I9003 GALAXY SII (16GB),
- Samsung I9300 GALAXY SIII (International Edition, 16 Гб),
- Samsung Galaxy i9220,
- Samsung Galaxy Note N7102 II (32GB / Unico),
- Samsung W2013, Samsung S7568 ,
- Samsung I9300 GALAXY SIII (International Edition, 32 Гб),
- Samsung W999, Samsung Galaxy Note II N7100 32G,
- Samsung S7572,
- Samsung E120LGalaxy SII HD LTE
- Samsung W899,
- Samsung I9268, Samsung S7562i (Galaxy S Duos),
- Samsung GALAXY Примечание II N719 ,
- Samsung I879,
- Samsung Galaxy Note II N7102 (16GB / dual),
- Samsung Galxy Note III,
- Samsung Galaxy i9220 Примечание (белый),
- Samsung I939D GALAXY SIII (двойной версии карт),
- Samsung GALAXY Примечание II N7108 (мобильная версия),
- Samsung I9308 GALAXY SIII (мобильная версия),
- Samsung B9388, Samsung I8262D (GALAXY Dous),
- Samsung I8190 GALAXY SIII Mini (16GB),
- Samsung I9070 Galaxy S (8GB),
- Samsung I9100 GALAXY SII ( белый),
- Samsung I8190 GALAXY SIII Mini (8 Гб),
- Samsung i9100G (GALAXY SII),
- Samsung I8552 (Galaxy Win),
- Samsung I9108 (GALAXY SII),
- Samsung B9120 (усилитель II),
- Samsung I8750 (ATIV S/16GB),
- Samsung I9105P (GALAXY SII Plus),
- Samsung I9305 (GALAXY SIII LTE),
- Samsung I939 GALAXY SIII (Telecom версии),
- Samsung I9260 GALAXY премьера (16GB),
- Samsung I8160 (Galaxy Ace 2),
- Samsung GALAXY S4 (I9508 / Mobile)
- Samsung N7105 (Galaxy Note II LTE),
- Samsung I699 (GALAXY Trend),
- Samsung I9260 GALAXY премьера (8GB),
- Samsung GALAXY S4 (I959 / Телеком версии),
- Samsung I929 (GALAXY SII DUO),
- Samsung I9050,
- Samsung I9228, Samsung I9103 (Galaxy R),
- Samsung I909 (Galaxy S),
- Samsung I779,
- Samsung I8250,
- Samsung I8150 (Galaxy W),
- Samsung I919 (GALAXY S DUOS),
- Samsung GALAXY S4 (I9505 / Quad / 4G версия),
- Samsung I8258,
- Samsung I919U (GALAXY S Duos),
- Samsung GALAXY S4 (I9500/32GB),
- Samsung I8530 (Galaxy Beam),
- Samsung B9062,
- Samsung S6358 (Galaxy Ace Уважаемые),
- Samsung I9018 (Galaxy S),
- Samsung I619 (Galaxy Ace Уважаемые),
- Samsung I809 (Galaxy S),
- Samsung N8000 (Galaxy Note 10.1),
- Samsung i9200 (Galaxy Mega 6.3/16GB),
- Samsung i9200 (Galaxy Mega 6.3/8GB),
- Samsung S7500 (Galaxy Ace Plus),
- Samsung I9208 (Galaxy Mega 6.3),
- Samsung Galaxy Note 8.0 (N5100/3G + WiFi),
- Samsung E210S (GALAXY SIII),
- Samsung I535 (GALAXY SIII),
- Samsung D710 (Эпическая сенсорный 4G),
- Samsung I759,
- Samsung I9150 (Galaxy 5.8 Mega ),
- Samsung S6352 (Galaxy Ace родного)
- Samsung S7508 (Galaxy Ace Plus),
- Samsung S5698 (Galaxy Xcover),
- Samsung S7530 (OMNIA M),
- Samsung GALAXY SIII (TD-LTE версия),
- Samsung I659 (Galaxy Ace Plus),
- Samsung I717 (Galaxy Note),
- Samsung I9300 GALAXY SIII (International Edition, 64 Гб),
- Samsung I9020 (Nexus S),
- Samsung GALAXY SII i9100G (Tencent версии),
- Samsung I9220 Galaxy Note (Extreme Edition),
- Samsung S6108 (Galaxy Y POP)
- Samsung I9023 (Nexus S),
- Samsung I8558 (Galaxy Win),
- Samsung Galaxy Tab 7.7 P6800 (16 Гб версия),
- Samsung S7530E (OMNIA M),
- Samsung B5330 (Galaxy Chat),
- Samsung I8730 (Galaxy Express),
- Samsung I9205 (Galaxy Mega 6,3),
- Samsung I747 (GALAXY SIII),
- Samsung I9070 Galaxy S (16GB),
- Samsung I339,
- Samsung I9100 GALAXY SII (32GB),
- Samsung I9100 GALAXY SII (Unicom Edition),
- Samsung GALAXY S4 (I9500/64GB),
- Samsung I519, Samsung E110S (Celox),
- Samsung I667 (Фокус 2),
- Samsung I9210 (Galaxy SII LTE),
- Samsung S6500D,
- Samsung T889 (Galaxy Note II),
- Samsung I727 (Galaxy SII усилится),
- Samsung I8750 (ATIV S/32GB)
- Samsung S5300 (Galaxy карманные),
- Samsung i9088 (Galaxy S),
- Samsung L710 GALAXY SIII (двухъядерные версии),
- Samsung I9080 (GALAXY Гранд),
- Samsung T989 (Hercules),
- Samsung S6812i,
- Samsung B5510 (GALAXY Y Pro),
- Samsung I777 (Синга),
- Samsung S6500 (Galaxy Mini 2),
- Samsung E170K (Galaxy R Style),
- Samsung I930 (ATIV Odyssey),
- Samsung E220 (GALAXY Pop/8GB),
- Samsung S7272 (Galaxy Ace 3),
- Samsung S5280 (GALAXY Star)
- Samsung I9152 (Galaxy Mega 5,8),
- Samsung i677 (Фокус Flash),
- Samsung S7710 (Galaxy Xcover 2),
- Samsung E220 (GALAXY Pop/16GB),
- Samsung S6012 (Galaxy Music Duos),
- Samsung S6810 (Galaxy славы),
- Samsung R830 (Galaxy Axiom),
- Samsung GALAXY SIII +,
- Samsung S5301 (Galaxy Pocket Plus),
- Samsung S6812 (Galaxy славы),
- Samsung I547 (Galaxy Rugby Pro),
- Samsung I6282D (Galaxy Core),
- Samsung M950 (Galaxy Reverb),
- Samsung I437 (Galaxy Express),
- Samsung S6312 (GALAXY Молодые Duos),
- Samsung T699 (Реле 4G Galaxy S),
- Samsung S6310 (GALAXY Young),
- Samsung M340S (Galaxy M),
- Samsung L300 (Galaxy Победы 4G LTE),
- Samsung I847 (регби SMART),
- Samsung Galaxy SII WiMAX,
- Samsung S759 (Omnia M),
- Samsung I577 (Galaxy Exhilarate),
- Samsung I405 (Galaxy Metrix 4G),
- Samsung E310S (Mega Galaxy 6.3),
- Samsung T959 (Очаровывай 4G),
- Samsung M190S (Galaxy S Hoppin),
- Samsung I7500U Samsung,
- Samsung I757 (Galaxy SII Скийрокет HD),
- Samsung Nexus S 4G
| when i try to connect with emmc i get this error log
Z3X EasyJtag Software ver. 2.0.5.0
Loading eMMC Addon Firmware... IO: 2800 mV
Box S/N: ,FW Ver.: 01.52
CMD Pullup Level:2825 mV
CMD Active Level:2763 mV
Can't init device, Reason: CMD Timeout Error
Done. |
