Old 02-12-2016, 18:25   #91 (permalink)
Member: 1020890
Thanks Meter: 3
If you don't have BA33C18FP/HFP ...
If you don't have BA33C18FP/HFP but still want to get a source of 3.3v and 1.8v, and you have broken XBox360 laying around take a look on this.
Attached pictures are:
- a fragment of the schematics with 2 ICs NCP1117 - one for 1.8V and the other for 3.3V.
- a picture of PCB where these ICs are installed.
You can use all elements you needed from PCB - ICs (U5B2, U5B1) and capacitors (C5B5, C5B6, C5B4, C5b3, C5B1 and C5B2).
Gently remove them from PCB and use them to build your own PCB or breadboard.
Old 02-13-2016, 21:52   #92 (permalink)
Member: 1020890
Thanks Meter: 3
Or you can go this way.
Just cut it off the xbox PCB.
The Following User Says Thank You to fraser34 For This Useful Post:
Old 02-18-2016, 08:54   #93 (permalink)
Member: 462488
hi , please what is the difference between wipe/write and repair
Old 02-27-2016, 17:10   #94 (permalink)
tattoum's Avatar
Member: 16625
Sonork: 1578753
Thanks Meter: 160
please help
i am trying to connec i9192 emmc cmd, D0, and clk with usb cable connected to phone but impossible to connect this is log :
Z3X EasyJtag Software ver. 2.0.7.5
Loading eMMC Addon Firmware... IO: 2800 mV
Box S/N: 11F======, ,FW Ver.: 01.52
CMD Pullup Level:2052 mV
CMD Active Level:2340 mV
HiPower™ mode is off!
Can't init device, Reason: CMD Timeout Error
Done.
then i connected 100 ohm resitor from 1,8v to cmd and Do, now connect but not correctly this is log :
Box S/N: 11FFF=======, ,FW Ver.: 01.52
CMD Pullup Level:1742 mV
CMD Active Level:2289 mV
eMMC Device Information
EMMC CID : 45010053454D30384790205C7136707C
EMMC CSD : D00F00320F5903FFFFFFFFFF92404010
EMMC Manufacturer ID: 0045 , OEM ID: 0100
EMMC Date: 07/2013 Rev.0x90
EMMC NAME: SEM08G , S/N: 542929206
EMMC NAME (HEX): 53454D30384700
Can't init EMMC, Reason: CARD Data FIFO Timeout Error
Check Data Line!
Done.
The Following User Says Thank You to tattoum For This Useful Post:
Old 04-03-2016, 07:29   #95 (permalink)
Member: 2438055
Sonork: rusdi26
Thanks Meter: 20
how about the cmd -voltage small ***** . cmd voltage is not equal to do and clk . what happened to my box
This information EMMC using molex socket using the box easyjtag
Z3X EasyJtag Software ver. 2.0.8.0
Loading eMMC Addon Firmware... IO: 3300 mV
Box S/N: 0C00000AB1E4083F, ,FW Ver.: 01.52
CMD Pullup Level:546 mV
CMD Active Level:1062 mV
Done.
CMD Pullup Level:629 mV
CMD Active Level:2949 mV
Done.
CMD Pullup Level:639 mV
Done.
Done.
CMD Active Level:2939 mV
Done.
Done.
Warning: CMD Pullup Level (0 mV) too low , check cables etc.!
CMD Active Level:2248 mV
Done.
Warning: CMD Pullup Level (41 mV) too low , check cables etc.!
Done.
Done.
socket and adapter walking in the other
Old 04-20-2016, 09:52   #96 (permalink)
Member: 2491556
Thanks Meter: 2
Rusdi26 - I have the same problem.
Everytime I use the Z3x I get Can't init device, Reason: CMD Timeout Error .. what ever device I connect to
It is so frustrating
Old 04-20-2016, 14:48   #97 (permalink)
Member: 1569669
Thanks Meter: 257
Hi,
Please make photo of your setup (ISP soldering).
Let me know what ISP eMMC adapter you use or make photo.
Or maybe you use some eMMC socket????
"The box worked for a few days" - your box stop to connect (was working good before) or what?
Describe clearly your problem with photos, video, log etc!!!
And I can help you step by step.
I can see this log in your previous message:
"Z3X EasyJtag Software ver. 2.0.4.0
Loading eMMC Addon Firmware... IO: 2050 mV
Box S/N: XXXXXXXXXXXXXXXX, ,FW Ver.: 01.51
CMD Pullup Level:1330 mV
CMD Active Level:1784 mV
Can't init EMMC, Reason: CMD Timeout Error"
If you still use this sw and fw revision, it means that your software is very old and box firmware needs to be 1.52 for correct work (maybe Its general connection fail reason)!
Please start shell, download latest Easy-Jtag setup (2.0.8.3) and install it. After start Easy-Jtag, software update your box firmware automatically to 1.52.
Another reason, you can use incorrect ISP adapter. Check GND output on adapter is connected to box Pin 19.
If you have some box HW problem, I also can help you step by step, but need more info about your problem.
Best Regards
The Following User Says Thank You to vikboston For This Useful Post:
Old 04-20-2016, 15:05   #98 (permalink)
Member: 2491556
Thanks Meter: 2
Thank you,.
This was very helpful for me
Old 01-17-2017, 14:42   #99 (permalink)
Member: 2177146
Thanks Meter: 14
Please try uploading photos
Old 01-19-2017, 13:58   #100 (permalink)
Member: 2674565
Thanks for this very helpful.
Old 01-29-2017, 16:51   #101 (permalink)
Member: 2678573
ok...ok....ok...ok....ok...thank bro
Old 01-30-2017, 04:20   #102 (permalink)
mahzra azra's Avatar
Member: 1722956
Sonork: mybestfriend.adeel
Thanks Meter: 304
hello. i need some help about easy jtag plus.
i connnect emmc simply but how to change emmc cid ???i dont know .i tried with my best but wast.
HiPower mode is OFF
CMD Pullup Level: 1680 mV
CMD Active Level: 1753 mV
EMMC Device Information :
EMMC CID: 7001004D4D4330344702E79826B151F0
EMMC CSD: D04F01320F5903FFFFFFFFE78A400050
EMMC Manufacture Name: KINGSTONE
EMMC NAME: MMC04G , S/N: E79826B1 , rev. 02
EMMC NAME (HEX): 4D4D43303447
EMMC ROM 1 (Main User Data) Capacity: 3628 MB (0000E2C00000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 2048 KB (000000200000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 128 KB (000000020000)
Backup saved: MMC04G_E79826B1_20170130_195218.extcsd
EMMC Init completed.
look this that is kingstone emmc and i want to make it hynix.when i tried it it eror this--
HiPower mode is OFF
CMD Pullup Level: 1670 mV
Backup saved: MMC04G_E79826B1_20170130_195241.extcsd
Repairing eMMC CID...
Error: Unable to restore eMMC CID...
if any one have full knowladge about it please contect me my whatsup.9936182923.
i used only emmc in my work.thanks those who will help me.
Old 05-04-2017, 08:32   #103 (permalink)
Member: 2177146
Thanks Meter: 14
how to conect with cable
http://uupload.ir/files/2km_photo_20...4_11-49-37.jpg
Please specify the name of the base
Old 05-07-2017, 13:33   #104 (permalink)
Member: 2177146
Thanks Meter: 14
how to repair boot with jtag?please explain step by step
Old 05-07-2017, 15:09   #105 (permalink)
Member: 2177146
Thanks Meter: 14
hi please setp by setp explain it
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.18321 seconds with 8 queries
