04-30-2021, 07:53 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Bangladesh
Member: 621121 Status: Offline Thanks Meter: 366 | Acer Z205 emmc dead or not ? Code: 30-Apr-21 11:06:43 AM> 30-Apr-21 11:06:43 AM> eMMC_tool Suite ver. 1.6.4.0 (release date: 30.12.2020) 30-Apr-21 11:06:46 AM> Microsoft Windows 10 (64 bit) build 16299 (10.0.16299.15) 30-Apr-21 11:06:46 AM> 30-Apr-21 11:06:46 AM> Looking for EasyJTAG box... 30-Apr-21 11:06:46 AM> EasyJTAG API ver. 3403 30-Apr-21 11:06:46 AM> OpenUSB returned = 0 30-Apr-21 11:06:47 AM> EasyJTAG Box Serial = 0014D520AAB084B4 30-Apr-21 11:06:48 AM> Card Serial = AAC20012 30-Apr-21 11:06:48 AM> EasyJTAG Box Firmware = 2.5301 30-Apr-21 11:06:48 AM> 30-Apr-21 11:13:35 AM> Looking for EasyJTAG box... 30-Apr-21 11:13:35 AM> EasyJTAG API ver. 3403 30-Apr-21 11:13:35 AM> Setting IO Levels to 1.8V 30-Apr-21 11:13:35 AM> Setting frequence to 36 MHz 30-Apr-21 11:13:35 AM> EasyJTAG Box Serial = 0014D520AAB084B4 30-Apr-21 11:13:35 AM> EasyJTAG Box Firmware = 2.5301 30-Apr-21 11:13:36 AM> Setting interface to EasyJtag2/ISP_HiPower 30-Apr-21 11:13:36 AM> Setting bus width to 4 Bit 30-Apr-21 11:13:36 AM> HiPower mode is ON 30-Apr-21 11:13:36 AM> Setting frequence to 36 MHz 30-Apr-21 11:13:36 AM> CMD Pullup Level: 1829 mV 30-Apr-21 11:13:36 AM> CMD Active Level: 1879 mV 30-Apr-21 11:13:37 AM> eMMC Init returned = 0 30-Apr-21 11:13:37 AM> EMMC Device Information : 30-Apr-21 11:13:37 AM> EMMC CID: 7001004D4D4330344758E3F1B92D9195 30-Apr-21 11:13:37 AM> EMMC CSD: D04F01320F5903FFFFFFFFE78A400051 30-Apr-21 11:13:37 AM> EMMC Manufacture : KINGSTONE , EMMC NAME: MMC04G , HEX: 4D4D43303447 , S/N: E3F1B92D , rev. 0x58 30-Apr-21 11:13:37 AM> EMMC Manufacture ID: 0x70 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 9/2014 30-Apr-21 11:13:37 AM> EMMC ROM 1 (Main User Data) Capacity: 3688 MB (0000E6800000) 30-Apr-21 11:13:37 AM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 2048 KB (000000200000) 30-Apr-21 11:13:37 AM> EMMC RPMB (Replay Protected Memory Block) Capacity: 128 KB (000000020000) Counter: 0 , Response: Maybe not clean 30-Apr-21 11:13:37 AM> EMMC Permanent Write Protection: No 30-Apr-21 11:13:37 AM> EMMC Temporary Write Protection: No 30-Apr-21 11:13:37 AM> Extended CSD Information : 30-Apr-21 11:13:37 AM> Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) 30-Apr-21 11:13:37 AM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) 30-Apr-21 11:13:37 AM> Boot Bus Config: 0x00 , width 1bit 30-Apr-21 11:13:37 AM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled 30-Apr-21 11:13:37 AM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 30-Apr-21 11:13:37 AM> Device supports partitioning features 30-Apr-21 11:13:37 AM> Device can have enhanced technological features in partitions and user data area 30-Apr-21 11:13:37 AM> Device can have extended partitions attribute 30-Apr-21 11:13:37 AM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 30-Apr-21 11:13:37 AM> Backup saved: MMC04G_E3F1B92D_20210430_111337.extcsd 30-Apr-21 11:13:37 AM> EMMC Init completed. 30-Apr-21 11:13:37 AM> 30-Apr-21 11:13:38 AM> Warning: BusWidth is automatically set to 1 Bit 30-Apr-21 11:13:38 AM> 30-Apr-21 11:13:39 AM> Scanning soft partitions 30-Apr-21 11:13:45 AM> Partition table not found 30-Apr-21 11:13:45 AM> 30-Apr-21 11:13:45 AM> Get firmware version 30-Apr-21 11:13:56 AM> 30-Apr-21 11:14:07 AM> 30-Apr-21 11:14:08 AM> Brand = acer 30-Apr-21 11:14:08 AM> Manufacturer = Acer 30-Apr-21 11:14:08 AM> Device = acer_z205p 30-Apr-21 11:14:08 AM> Model = Z205 30-Apr-21 11:14:08 AM> CPU Abi = armeabi-v7a 30-Apr-21 11:14:08 AM> Mediatek platform = MT6572 30-Apr-21 11:14:08 AM> Android release = 4.4.2 30-Apr-21 11:14:08 AM> Firmware version = Acer_AV0K0_Z205P_1.003.00_AAP_DIGIHID 30-Apr-21 11:14:08 AM> Firmware date = 2014? 09? 24? ??? 09:32:33 CST 30-Apr-21 11:14:20 AM> 30-Apr-21 11:14:20 AM> Looking for EasyJTAG box... 30-Apr-21 11:14:20 AM> EasyJTAG API ver. 3403 30-Apr-21 11:14:20 AM> Setting IO Levels to 1.8V 30-Apr-21 11:14:20 AM> Setting frequence to 36 MHz 30-Apr-21 11:14:20 AM> EasyJTAG Box Serial = 0014D520AAB084B4 30-Apr-21 11:14:20 AM> EasyJTAG Box Firmware = 2.5301 30-Apr-21 11:14:22 AM> Setting interface to EasyJtag2/ISP_HiPower 30-Apr-21 11:14:22 AM> Setting bus width to 1 Bit 30-Apr-21 11:14:22 AM> HiPower mode is ON 30-Apr-21 11:14:22 AM> Setting frequence to 36 MHz 30-Apr-21 11:14:22 AM> CMD Pullup Level: 1829 mV 30-Apr-21 11:14:22 AM> CMD Active Level: 1879 mV 30-Apr-21 11:14:22 AM> eMMC Init returned = 0 30-Apr-21 11:14:22 AM> EMMC Device Information : 30-Apr-21 11:14:22 AM> EMMC CID: 7001004D4D4330344758E3F1B92D9195 30-Apr-21 11:14:22 AM> EMMC CSD: D04F01320F5903FFFFFFFFE78A400051 30-Apr-21 11:14:22 AM> EMMC Manufacture : KINGSTONE , EMMC NAME: MMC04G , HEX: 4D4D43303447 , S/N: E3F1B92D , rev. 0x58 30-Apr-21 11:14:22 AM> EMMC Manufacture ID: 0x70 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 9/2014 30-Apr-21 11:14:22 AM> EMMC ROM 1 (Main User Data) Capacity: 3688 MB (0000E6800000) 30-Apr-21 11:14:22 AM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 2048 KB (000000200000) 30-Apr-21 11:14:22 AM> EMMC RPMB (Replay Protected Memory Block) Capacity: 128 KB (000000020000) Counter: 0 , Response: Clean 30-Apr-21 11:14:22 AM> EMMC Permanent Write Protection: No 30-Apr-21 11:14:22 AM> EMMC Temporary Write Protection: No 30-Apr-21 11:14:22 AM> Extended CSD Information : 30-Apr-21 11:14:22 AM> Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) 30-Apr-21 11:14:22 AM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) 30-Apr-21 11:14:22 AM> Boot Bus Config: 0x00 , width 1bit 30-Apr-21 11:14:22 AM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled 30-Apr-21 11:14:22 AM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 30-Apr-21 11:14:22 AM> Device supports partitioning features 30-Apr-21 11:14:22 AM> Device can have enhanced technological features in partitions and user data area 30-Apr-21 11:14:22 AM> Device can have extended partitions attribute 30-Apr-21 11:14:22 AM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 30-Apr-21 11:14:22 AM> Backup saved: MMC04G_E3F1B92D_20210430_111422.extcsd 30-Apr-21 11:14:22 AM> EMMC Init completed. 30-Apr-21 11:14:22 AM> 30-Apr-21 11:14:22 AM> This operation is performed only for Samsung eMMC, Sandisk eMMC or EMMC 5.0 and higher 30-Apr-21 11:14:22 AM> 30-Apr-21 11:15:00 AM> Looking for EasyJTAG box... 30-Apr-21 11:15:00 AM> EasyJTAG API ver. 3403 30-Apr-21 11:15:00 AM> Setting IO Levels to 1.8V 30-Apr-21 11:15:00 AM> Setting frequence to 36 MHz 30-Apr-21 11:15:00 AM> EasyJTAG Box Serial = 0014D520AAB084B4 30-Apr-21 11:15:00 AM> EasyJTAG Box Firmware = 2.5301 30-Apr-21 11:15:02 AM> Setting interface to EasyJtag2/ISP_HiPower 30-Apr-21 11:15:02 AM> Setting bus width to 1 Bit 30-Apr-21 11:15:02 AM> HiPower mode is ON 30-Apr-21 11:15:02 AM> Setting frequence to 36 MHz 30-Apr-21 11:15:02 AM> CMD Pullup Level: 1831 mV 30-Apr-21 11:15:02 AM> CMD Active Level: 1882 mV 30-Apr-21 11:15:02 AM> eMMC Init returned = 0 30-Apr-21 11:15:02 AM> EMMC Device Information : 30-Apr-21 11:15:02 AM> EMMC CID: 7001004D4D4330344758E3F1B92D9195 30-Apr-21 11:15:02 AM> EMMC CSD: D04F01320F5903FFFFFFFFE78A400051 30-Apr-21 11:15:02 AM> EMMC Manufacture : KINGSTONE , EMMC NAME: MMC04G , HEX: 4D4D43303447 , S/N: E3F1B92D , rev. 0x58 30-Apr-21 11:15:02 AM> EMMC Manufacture ID: 0x70 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 9/2014 30-Apr-21 11:15:02 AM> EMMC ROM 1 (Main User Data) Capacity: 3688 MB (0000E6800000) 30-Apr-21 11:15:02 AM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 2048 KB (000000200000) 30-Apr-21 11:15:02 AM> EMMC RPMB (Replay Protected Memory Block) Capacity: 128 KB (000000020000) Counter: 0 , Response: Clean 30-Apr-21 11:15:02 AM> EMMC Permanent Write Protection: No 30-Apr-21 11:15:02 AM> EMMC Temporary Write Protection: No 30-Apr-21 11:15:02 AM> Extended CSD Information : 30-Apr-21 11:15:02 AM> Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) 30-Apr-21 11:15:02 AM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) 30-Apr-21 11:15:02 AM> Boot Bus Config: 0x00 , width 1bit 30-Apr-21 11:15:02 AM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled 30-Apr-21 11:15:02 AM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 30-Apr-21 11:15:02 AM> Device supports partitioning features 30-Apr-21 11:15:02 AM> Device can have enhanced technological features in partitions and user data area 30-Apr-21 11:15:02 AM> Device can have extended partitions attribute 30-Apr-21 11:15:02 AM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 30-Apr-21 11:15:02 AM> Backup saved: MMC04G_E3F1B92D_20210430_111502.extcsd 30-Apr-21 11:15:02 AM> EMMC Init completed. 30-Apr-21 11:15:02 AM> 30-Apr-21 11:15:03 AM> Operation: Find table from emmc 30-Apr-21 11:15:03 AM> 30-Apr-21 11:15:03 AM> Vendor: Mediatek 30-Apr-21 11:15:03 AM> Platform: MT6572 30-Apr-21 11:15:03 AM> Searching GPT ... 30-Apr-21 11:15:03 AM> GPT header is not found 30-Apr-21 11:15:03 AM> Searching PMT (MediaTek) ... 30-Apr-21 11:15:16 AM> PMT found at address 0x0000E6701000 30-Apr-21 11:15:16 AM> Searching MBR ... 30-Apr-21 11:15:16 AM> MBR found 30-Apr-21 11:15:16 AM> PMT successfully parsed 30-Apr-21 11:15:16 AM> 30-Apr-21 11:15:46 AM> Looking for EasyJTAG box... 30-Apr-21 11:15:46 AM> EasyJTAG API ver. 3403 30-Apr-21 11:15:46 AM> Setting IO Levels to 1.8V 30-Apr-21 11:15:46 AM> Setting frequence to 36 MHz 30-Apr-21 11:15:46 AM> EasyJTAG Box Serial = 0014D520AAB084B4 30-Apr-21 11:15:46 AM> EasyJTAG Box Firmware = 2.5301 30-Apr-21 11:15:47 AM> Setting interface to EasyJtag2/ISP_HiPower 30-Apr-21 11:15:48 AM> Setting bus width to 1 Bit 30-Apr-21 11:15:48 AM> HiPower mode is ON 30-Apr-21 11:15:48 AM> Setting frequence to 36 MHz 30-Apr-21 11:15:48 AM> CMD Pullup Level: 1831 mV 30-Apr-21 11:15:48 AM> CMD Active Level: 1881 mV 30-Apr-21 11:15:48 AM> eMMC Init returned = 0 30-Apr-21 11:15:48 AM> EMMC Device Information : 30-Apr-21 11:15:48 AM> EMMC CID: 7001004D4D4330344758E3F1B92D9195 30-Apr-21 11:15:48 AM> EMMC CSD: D04F01320F5903FFFFFFFFE78A400051 30-Apr-21 11:15:48 AM> EMMC Manufacture : KINGSTONE , EMMC NAME: MMC04G , HEX: 4D4D43303447 , S/N: E3F1B92D , rev. 0x58 30-Apr-21 11:15:48 AM> EMMC Manufacture ID: 0x70 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 9/2014 30-Apr-21 11:15:48 AM> EMMC ROM 1 (Main User Data) Capacity: 3688 MB (0000E6800000) 30-Apr-21 11:15:48 AM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 2048 KB (000000200000) 30-Apr-21 11:15:48 AM> EMMC RPMB (Replay Protected Memory Block) Capacity: 128 KB (000000020000) Counter: 0 , Response: Clean 30-Apr-21 11:15:48 AM> EMMC Permanent Write Protection: No 30-Apr-21 11:15:48 AM> EMMC Temporary Write Protection: No 30-Apr-21 11:15:48 AM> Extended CSD Information : 30-Apr-21 11:15:48 AM> Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) 30-Apr-21 11:15:48 AM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) 30-Apr-21 11:15:48 AM> Boot Bus Config: 0x00 , width 1bit 30-Apr-21 11:15:48 AM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled 30-Apr-21 11:15:48 AM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 30-Apr-21 11:15:48 AM> Device supports partitioning features 30-Apr-21 11:15:48 AM> Device can have enhanced technological features in partitions and user data area 30-Apr-21 11:15:48 AM> Device can have extended partitions attribute 30-Apr-21 11:15:48 AM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 30-Apr-21 11:15:48 AM> Backup saved: MMC04G_E3F1B92D_20210430_111548.extcsd 30-Apr-21 11:15:48 AM> EMMC Init completed. 30-Apr-21 11:15:48 AM> 30-Apr-21 11:15:48 AM> Operation: Reading from eMMC... 30-Apr-21 11:15:48 AM> 30-Apr-21 11:16:20 AM> Reading from: ROM1 , start: 0x000000000000 , size: 0x000003D40000 30-Apr-21 11:16:20 AM> Output file: P:\Mobile\Jtag\Acer\EMMC_MMC04G_ROM1_000000000000_000003D40000.bin 30-Apr-21 11:16:20 AM> eMMC switching to ROM1 30-Apr-21 11:16:21 AM> Reading partition... 30-Apr-21 11:16:39 AM> Done reading partition. Read speed: 3456.91 Kb/s 30-Apr-21 11:16:50 AM> 30-Apr-21 11:17:01 AM> 30-Apr-21 11:17:01 AM> All done time: [00:00:41:071] 30-Apr-21 11:17:01 AM> 30-Apr-21 11:17:20 AM> Looking for EasyJTAG box... 30-Apr-21 11:17:20 AM> EasyJTAG API ver. 3403 30-Apr-21 11:17:20 AM> Setting IO Levels to 1.8V 30-Apr-21 11:17:20 AM> Setting frequence to 36 MHz 30-Apr-21 11:17:20 AM> EasyJTAG Box Serial = 0014D520AAB084B4 30-Apr-21 11:17:20 AM> EasyJTAG Box Firmware = 2.5301 30-Apr-21 11:17:21 AM> Setting interface to EasyJtag2/ISP_HiPower 30-Apr-21 11:17:21 AM> Setting bus width to 1 Bit 30-Apr-21 11:17:21 AM> HiPower mode is ON 30-Apr-21 11:17:21 AM> Setting frequence to 36 MHz 30-Apr-21 11:17:21 AM> CMD Pullup Level: 1829 mV 30-Apr-21 11:17:21 AM> CMD Active Level: 1881 mV 30-Apr-21 11:17:22 AM> eMMC Init returned = 0 30-Apr-21 11:17:22 AM> EMMC Device Information : 30-Apr-21 11:17:22 AM> EMMC CID: 7001004D4D4330344758E3F1B92D9195 30-Apr-21 11:17:22 AM> EMMC CSD: D04F01320F5903FFFFFFFFE78A400051 30-Apr-21 11:17:22 AM> EMMC Manufacture : KINGSTONE , EMMC NAME: MMC04G , HEX: 4D4D43303447 , S/N: E3F1B92D , rev. 0x58 30-Apr-21 11:17:22 AM> EMMC Manufacture ID: 0x70 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 9/2014 30-Apr-21 11:17:22 AM> EMMC ROM 1 (Main User Data) Capacity: 3688 MB (0000E6800000) 30-Apr-21 11:17:22 AM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 2048 KB (000000200000) 30-Apr-21 11:17:22 AM> EMMC RPMB (Replay Protected Memory Block) Capacity: 128 KB (000000020000) Counter: 0 , Response: Clean 30-Apr-21 11:17:22 AM> EMMC Permanent Write Protection: No 30-Apr-21 11:17:22 AM> EMMC Temporary Write Protection: No 30-Apr-21 11:17:22 AM> Extended CSD Information : 30-Apr-21 11:17:22 AM> Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) 30-Apr-21 11:17:22 AM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) 30-Apr-21 11:17:22 AM> Boot Bus Config: 0x00 , width 1bit 30-Apr-21 11:17:22 AM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled 30-Apr-21 11:17:22 AM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 30-Apr-21 11:17:22 AM> Device supports partitioning features 30-Apr-21 11:17:22 AM> Device can have enhanced technological features in partitions and user data area 30-Apr-21 11:17:22 AM> Device can have extended partitions attribute 30-Apr-21 11:17:22 AM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 30-Apr-21 11:17:22 AM> Backup saved: MMC04G_E3F1B92D_20210430_111722.extcsd 30-Apr-21 11:17:22 AM> EMMC Init completed. 30-Apr-21 11:17:22 AM> 30-Apr-21 11:17:22 AM> Operation: Reading from eMMC... 30-Apr-21 11:17:22 AM> 30-Apr-21 11:17:26 AM> Reading from: ROM2 , start: 0x000000000000 , size: 0x000000200000 30-Apr-21 11:17:26 AM> Output file: P:\Mobile\Jtag\Acer\EMMC_MMC04G_ROM2_000000000000_000000200000.bin 30-Apr-21 11:17:26 AM> eMMC switching to ROM2 30-Apr-21 11:17:26 AM> Reading partition... 30-Apr-21 11:17:27 AM> Done reading partition. Read speed: 2562.47 Kb/s 30-Apr-21 11:17:38 AM> 30-Apr-21 11:17:49 AM> 30-Apr-21 11:17:49 AM> All done time: [00:00:23:611] 30-Apr-21 11:17:49 AM> 30-Apr-21 11:17:57 AM> Looking for EasyJTAG box... 30-Apr-21 11:17:57 AM> EasyJTAG API ver. 3403 30-Apr-21 11:17:57 AM> Setting IO Levels to 1.8V 30-Apr-21 11:17:57 AM> Setting frequence to 36 MHz 30-Apr-21 11:17:57 AM> EasyJTAG Box Serial = 0014D520AAB084B4 30-Apr-21 11:17:57 AM> EasyJTAG Box Firmware = 2.5301 30-Apr-21 11:17:59 AM> Setting interface to EasyJtag2/ISP_HiPower 30-Apr-21 11:17:59 AM> Setting bus width to 1 Bit 30-Apr-21 11:17:59 AM> HiPower mode is ON 30-Apr-21 11:17:59 AM> Setting frequence to 36 MHz 30-Apr-21 11:17:59 AM> CMD Pullup Level: 1828 mV 30-Apr-21 11:17:59 AM> CMD Active Level: 1881 mV 30-Apr-21 11:17:59 AM> eMMC Init returned = 0 30-Apr-21 11:17:59 AM> EMMC Device Information : 30-Apr-21 11:17:59 AM> EMMC CID: 7001004D4D4330344758E3F1B92D9195 30-Apr-21 11:17:59 AM> EMMC CSD: D04F01320F5903FFFFFFFFE78A400051 30-Apr-21 11:17:59 AM> EMMC Manufacture : KINGSTONE , EMMC NAME: MMC04G , HEX: 4D4D43303447 , S/N: E3F1B92D , rev. 0x58 30-Apr-21 11:17:59 AM> EMMC Manufacture ID: 0x70 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 9/2014 30-Apr-21 11:18:00 AM> EMMC ROM 1 (Main User Data) Capacity: 3688 MB (0000E6800000) 30-Apr-21 11:18:00 AM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 2048 KB (000000200000) 30-Apr-21 11:18:00 AM> EMMC RPMB (Replay Protected Memory Block) Capacity: 128 KB (000000020000) Counter: 0 , Response: Clean 30-Apr-21 11:18:00 AM> EMMC Permanent Write Protection: No 30-Apr-21 11:18:00 AM> EMMC Temporary Write Protection: No 30-Apr-21 11:18:00 AM> Extended CSD Information : 30-Apr-21 11:18:00 AM> Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) 30-Apr-21 11:18:00 AM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) 30-Apr-21 11:18:00 AM> Boot Bus Config: 0x00 , width 1bit 30-Apr-21 11:18:00 AM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled 30-Apr-21 11:18:00 AM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 30-Apr-21 11:18:00 AM> Device supports partitioning features 30-Apr-21 11:18:00 AM> Device can have enhanced technological features in partitions and user data area 30-Apr-21 11:18:00 AM> Device can have extended partitions attribute 30-Apr-21 11:18:00 AM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 30-Apr-21 11:18:00 AM> Backup saved: MMC04G_E3F1B92D_20210430_111800.extcsd 30-Apr-21 11:18:00 AM> EMMC Init completed. 30-Apr-21 11:18:00 AM> 30-Apr-21 11:18:00 AM> Operation: Reading from eMMC... 30-Apr-21 11:18:00 AM> 30-Apr-21 11:18:02 AM> Reading from: ROM3 , start: 0x000000000000 , size: 0x000000200000 30-Apr-21 11:18:02 AM> Output file: P:\Mobile\Jtag\Acer\EMMC_MMC04G_ROM3_000000000000_000000200000.bin 30-Apr-21 11:18:02 AM> eMMC switching to ROM3 30-Apr-21 11:18:03 AM> Reading partition... 30-Apr-21 11:18:03 AM> Done reading partition. Read speed: 2617.92 Kb/s 30-Apr-21 11:18:15 AM> 30-Apr-21 11:18:26 AM> 30-Apr-21 11:18:26 AM> All done time: [00:00:23:730] 30-Apr-21 11:18:26 AM> 30-Apr-21 11:18:36 AM> Looking for EasyJTAG box... 30-Apr-21 11:18:36 AM> EasyJTAG API ver. 3403 30-Apr-21 11:18:36 AM> Setting IO Levels to 1.8V 30-Apr-21 11:18:36 AM> Setting frequence to 36 MHz 30-Apr-21 11:18:36 AM> EasyJTAG Box Serial = 0014D520AAB084B4 30-Apr-21 11:18:36 AM> EasyJTAG Box Firmware = 2.5301 30-Apr-21 11:18:38 AM> Setting interface to EasyJtag2/ISP_HiPower 30-Apr-21 11:18:38 AM> Setting bus width to 1 Bit 30-Apr-21 11:18:38 AM> HiPower mode is ON 30-Apr-21 11:18:38 AM> Setting frequence to 36 MHz 30-Apr-21 11:18:38 AM> CMD Pullup Level: 1828 mV 30-Apr-21 11:18:38 AM> CMD Active Level: 1881 mV 30-Apr-21 11:18:38 AM> eMMC Init returned = 0 30-Apr-21 11:18:38 AM> EMMC Device Information : 30-Apr-21 11:18:38 AM> EMMC CID: 7001004D4D4330344758E3F1B92D9195 30-Apr-21 11:18:38 AM> EMMC CSD: D04F01320F5903FFFFFFFFE78A400051 30-Apr-21 11:18:38 AM> EMMC Manufacture : KINGSTONE , EMMC NAME: MMC04G , HEX: 4D4D43303447 , S/N: E3F1B92D , rev. 0x58 30-Apr-21 11:18:38 AM> EMMC Manufacture ID: 0x70 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 9/2014 30-Apr-21 11:18:38 AM> EMMC ROM 1 (Main User Data) Capacity: 3688 MB (0000E6800000) 30-Apr-21 11:18:38 AM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 2048 KB (000000200000) 30-Apr-21 11:18:38 AM> EMMC RPMB (Replay Protected Memory Block) Capacity: 128 KB (000000020000) Counter: 0 , Response: Clean 30-Apr-21 11:18:38 AM> EMMC Permanent Write Protection: No 30-Apr-21 11:18:38 AM> EMMC Temporary Write Protection: No 30-Apr-21 11:18:38 AM> Extended CSD Information : 30-Apr-21 11:18:38 AM> Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) 30-Apr-21 11:18:38 AM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) 30-Apr-21 11:18:38 AM> Boot Bus Config: 0x00 , width 1bit 30-Apr-21 11:18:38 AM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled 30-Apr-21 11:18:38 AM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 30-Apr-21 11:18:38 AM> Device supports partitioning features 30-Apr-21 11:18:38 AM> Device can have enhanced technological features in partitions and user data area 30-Apr-21 11:18:38 AM> Device can have extended partitions attribute 30-Apr-21 11:18:38 AM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 30-Apr-21 11:18:39 AM> Backup saved: MMC04G_E3F1B92D_20210430_111839.extcsd 30-Apr-21 11:18:39 AM> EMMC Init completed. 30-Apr-21 11:18:39 AM> 30-Apr-21 11:18:39 AM> Operation: File Explorer... 30-Apr-21 11:18:39 AM> 30-Apr-21 11:18:39 AM> Scan from: MMC04G 30-Apr-21 11:18:39 AM> 30-Apr-21 11:18:39 AM> Vendor: Mediatek 30-Apr-21 11:18:39 AM> Searching GPT ... 30-Apr-21 11:18:39 AM> GPT header is not found 30-Apr-21 11:18:39 AM> Searching PMT (MediaTek) ... 30-Apr-21 11:18:52 AM> PMT found at address 0x0000E6701000 30-Apr-21 11:18:52 AM> Searching MBR ... 30-Apr-21 11:18:52 AM> MBR found 30-Apr-21 11:18:52 AM> 30-Apr-21 11:18:53 AM> Scan done 30-Apr-21 11:18:53 AM> 30-Apr-21 11:18:53 AM> Mount [PROTECT_F] successfully PartType: LINUX 30-Apr-21 11:18:53 AM> Mount [PROTECT_S] successfully PartType: LINUX 30-Apr-21 11:18:53 AM> Mount [system] successfully PartType: LINUX 30-Apr-21 11:18:53 AM> Mount [cache] successfully PartType: LINUX 30-Apr-21 11:18:53 AM> Mount [data] successfully PartType: LINUX 30-Apr-21 11:18:53 AM> 30-Apr-21 11:18:53 AM> Get firmware version 30-Apr-21 11:18:53 AM> Brand = acer 30-Apr-21 11:18:53 AM> Manufacturer = Acer 30-Apr-21 11:18:53 AM> Device = acer_z205p 30-Apr-21 11:18:53 AM> Model = Z205 30-Apr-21 11:18:53 AM> CPU Abi = armeabi-v7a 30-Apr-21 11:18:53 AM> Mediatek platform = MT6572 30-Apr-21 11:18:53 AM> Android release = 4.4.2 30-Apr-21 11:18:53 AM> Firmware version = Acer_AV0K0_Z205P_1.003.00_AAP_DIGIHID 30-Apr-21 11:18:53 AM> Firmware date = 2014? 09? 24? ??? 09:32:33 CST Code: Operation : HW Test [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 7001004D4D4330344758E3F1B92D9195 Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0xBE0B0000 EMICFG_RET_FAILED CodeDefine : DA_DRAMC_RANK0_CALIBRATION_FAILED Boot Error! Operation Failed Elapsed: 00:00:36 Reconnect Power/Cable! |
