07-14-2018, 19:42 | #1 (permalink) |
Freak Poster Join Date: Jun 2010 Location: Gsm World(India)
Member: 1333065 Status: Offline Sonork: 100.1656291 Thanks Meter: 12 | Need tutorial for boot repair I need u guys to help me to do dead boot repair for samsung G532F in easy jtag in a detailed way(Like files u need,etc).I appreciate for your help.. |
09-16-2019, 15:51 | #4 (permalink) |
Freak Poster Join Date: Jan 2017 Location: ALASKA
Member: 2678828 Status: Offline Thanks Meter: 231 | G532F deadboot repair prob need help . i did repair G532F deadboot after repair phone boot Download mode and i flash it with correct firmware . now the phone is stuck in recovery mode and give me error E:faild to mount/Cache (no such file ordirectory) |
11-04-2019, 20:56 | #9 (permalink) |
Junior Member Join Date: May 2011 Location: mymensingh, bangladesh
Member: 1586105 Status: Offline Thanks Meter: 17 | Need sm g532f scatter file for boot repair Need sm g532f scatter file for boot repair for easy jtag plus Anybody help, and saport this file Bootloader file methode fail Emmc health good |
06-11-2020, 15:21 | #11 (permalink) |
No Life Poster Join Date: Mar 2018 Location: Future.... ✌️
Member: 2825953 Status: Offline Thanks Meter: 246 | G532F QN16BB eMMC Cannot Erase or can't write flash eMMC_tool Suite ver. 1.6.2.0 (release date: 30.06.2019) Microsoft Windows 10 (64 bit) build 10240 (10.0.10240.16384) Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 36 MHz CMD Pullup Level: 2089 mV CMD Active Level: 2493 mV EMMC Device Information : EMMC CID: 150100514E3136424200D754C625A419 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QN16BB , HEX: 514E31364242 , S/N: D754C625 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 10/2017 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Maybe not clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QN16BB_D754C625_20200610_140646.extcsd EMMC Init completed. Get firmware version Brand = samsung Manufacturer = samsung Device = grandpplte Model = SM-G532F Phone platform = mt6737t CPU Abi = armeabi-v7a Mediatek platform = MT6737T Android release = 6.0.1 Firmware version = MMB29T.G532FXXU1ARL1 Firmware date = Wed Dec 26 18:16:32 KST 2018 Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 36 MHz CMD Pullup Level: 2071 mV CMD Active Level: 2481 mV EMMC Device Information : EMMC CID: 150100514E3136424200D754C625A419 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QN16BB , HEX: 514E31364242 , S/N: D754C625 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 10/2017 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Maybe not clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QN16BB_D754C625_20200610_140920.extcsd EMMC Init completed. Operation: Find table from emmc Vendor: Qualcomm Searching GPT ... GPT header is found and is valid Checking for ROM2 ... ROM2 is not blank Checking for ROM3 ... ROM3 is blank GPT header successfully parsed Operation: Read by vendor... Destination dir: D:\Samsung File\G532F\G532F Security Backup\ Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 36 MHz CMD Pullup Level: 2089 mV CMD Active Level: 2492 mV EMMC Device Information : EMMC CID: 150100514E3136424200D754C625A419 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QN16BB , HEX: 514E31364242 , S/N: D754C625 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 10/2017 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Maybe not clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QN16BB_D754C625_20200610_141058.extcsd EMMC Init completed. Backup partition: 8xxx_msimage Address: 000000004400, size: 0000003FBC00 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 3742.35 Kb/s XML-file created successfully Backup partition: PrimaryGPT Address: 000000000000, size: 000000004400 GPTHeader is valid Partition name: nvram Address: 000000800000, size: 000000800000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 4088.02 Kb/s Partition name: EFS Address: 000002800000, size: 000000800000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 3991.01 Kb/s Partition name: nvdata Address: 000003000000, size: 000002000000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 4134.32 Kb/s All done time: [00:00:17:547] 6/10/2020 3:10:04 PM> EMMC CID: 150100514E3136424200D754C625A419 6/10/2020 3:10:04 PM> EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D 6/10/2020 3:10:04 PM> EMMC Manufacture : SAMSUNG , EMMC NAME: QN16BB , HEX: 514E31364242 , S/N: D754C625 , rev. 0x00 6/10/2020 3:10:04 PM> EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 10/2017 6/10/2020 3:10:04 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) 6/10/2020 3:10:04 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 6/10/2020 3:10:04 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Maybe not clean 6/10/2020 3:10:04 PM> EMMC Permanent Write Protection: No 6/10/2020 3:10:04 PM> EMMC Temporary Write Protection: No 6/10/2020 3:10:04 PM> Extended CSD Information : 6/10/2020 3:10:04 PM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) 6/10/2020 3:10:04 PM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) 6/10/2020 3:10:04 PM> Boot Bus Config: 0x00 , width 1bit 6/10/2020 3:10:04 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled 6/10/2020 3:10:04 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 6/10/2020 3:10:04 PM> Device supports partitioning features 6/10/2020 3:10:04 PM> Device can have enhanced technological features in partitions and user data area 6/10/2020 3:10:04 PM> Device can have extended partitions attribute 6/10/2020 3:10:04 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 6/10/2020 3:10:04 PM> Backup saved: QN16BB_D754C625_20200610_151004.extcsd 6/10/2020 3:10:04 PM> EMMC Init completed. 6/10/2020 3:10:04 PM> 6/10/2020 3:10:05 PM> Operation: Erasing eMMC... 6/10/2020 3:10:05 PM> 6/10/2020 3:10:05 PM> Erasing for: ROM1 , start: 0x000000000000 , size: 0x000000020000 6/10/2020 3:10:05 PM> eMMC switching to ROM1 6/10/2020 3:13:35 PM> Erasing partition... 6/10/2020 3:14:35 PM> Error erasing at address: 000000000000 , error: -4, DATA RCV CRC Error ... Retry #1 6/10/2020 3:19:35 PM> Error erasing at address: 000000000000 , error: -4, DATA RCV CRC Error ... Retry #2 6/10/2020 3:24:35 PM> Error erasing at address: 000000000000 , error: -4, DATA RCV CRC Error ... Retry #3 6/10/2020 3:25:40 PM> Too many errors. Erasing has been stopped 6/10/2020 3:25:40 PM> |
06-13-2020, 08:34 | #12 (permalink) |
No Life Poster Join Date: Aug 2011
Member: 1630066 Status: Offline Sonork: 520074 Thanks Meter: 215 | you have selected vender qualcomm in reading this is mediatek device nor qualcomm write gp partition than write dump https://tii.ai/KuvVQl https://notexe.com/5q88kvpki6 |
The Following User Says Thank You to ilyasrao For This Useful Post: |
06-13-2020, 21:51 | #14 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
The Following User Says Thank You to layder For This Useful Post: |
