Old 06-11-2020, 15:21   #1 (permalink)
-=P.F.U=-'s Avatar
Member: 2825953
Thanks Meter: 146
G532F QN16BB eMMC Cannot Erase or can't write flash
eMMC_tool Suite ver. 1.6.2.0 (release date: 30.06.2019)
Microsoft Windows 10 (64 bit) build 10240 (10.0.10240.16384)
Setting interface to EasyJtag2/ISP
Setting bus width to 1 Bit
Setting frequence to 36 MHz
CMD Pullup Level: 2089 mV
CMD Active Level: 2493 mV
EMMC Device Information :
EMMC CID: 150100514E3136424200D754C625A419
EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D
EMMC Manufacture : SAMSUNG , EMMC NAME: QN16BB , HEX: 514E31364242 , S/N: D754C625 , rev. 0x00
EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 10/2017
EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Maybe not clean
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD Information :
Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
Boot Bus Config: 0x00 , width 1bit
H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: QN16BB_D754C625_20200610_140646.extcsd
EMMC Init completed.
Get firmware version
Brand = samsung
Manufacturer = samsung
Device = grandpplte
Model = SM-G532F
Phone platform = mt6737t
CPU Abi = armeabi-v7a
Mediatek platform = MT6737T
Android release = 6.0.1
Firmware version = MMB29T.G532FXXU1ARL1
Firmware date = Wed Dec 26 18:16:32 KST 2018
CMD Pullup Level: 2071 mV
CMD Active Level: 2481 mV
Backup saved: QN16BB_D754C625_20200610_140920.extcsd
Operation: Find table from emmc
Vendor: Qualcomm
Searching GPT ...
GPT header is found and is valid
Checking for ROM2 ...
ROM2 is not blank
Checking for ROM3 ...
ROM3 is blank
GPT header successfully parsed
Operation: Read by vendor...
Destination dir: D:\Samsung File\G532F\G532F Security Backup\
CMD Active Level: 2492 mV
Backup saved: QN16BB_D754C625_20200610_141058.extcsd
Backup partition: 8xxx_msimage
Address: 000000004400, size: 0000003FBC00
eMMC switching to ROM1
Reading partition...
Done reading partition. Read speed: 3742.35 Kb/s
XML-file created successfully
Backup partition: PrimaryGPT
Address: 000000000000, size: 000000004400
GPTHeader is valid
Partition name: nvram
Address: 000000800000, size: 000000800000
Done reading partition. Read speed: 4088.02 Kb/s
Partition name: EFS
Address: 000002800000, size: 000000800000
Done reading partition. Read speed: 3991.01 Kb/s
Partition name: nvdata
Address: 000003000000, size: 000002000000
Done reading partition. Read speed: 4134.32 Kb/s
All done time: [00:00:17:547]
6/10/2020 3:10:04 PM> EMMC CID: 150100514E3136424200D754C625A419
6/10/2020 3:10:04 PM> EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D
6/10/2020 3:10:04 PM> EMMC Manufacture : SAMSUNG , EMMC NAME: QN16BB , HEX: 514E31364242 , S/N: D754C625 , rev. 0x00
6/10/2020 3:10:04 PM> EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 10/2017
6/10/2020 3:10:04 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000)
6/10/2020 3:10:04 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
6/10/2020 3:10:04 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Maybe not clean
6/10/2020 3:10:04 PM> EMMC Permanent Write Protection: No
6/10/2020 3:10:04 PM> EMMC Temporary Write Protection: No
6/10/2020 3:10:04 PM> Extended CSD Information :
6/10/2020 3:10:04 PM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
6/10/2020 3:10:04 PM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
6/10/2020 3:10:04 PM> Boot Bus Config: 0x00 , width 1bit
6/10/2020 3:10:04 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
6/10/2020 3:10:04 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07
6/10/2020 3:10:04 PM> Device supports partitioning features
6/10/2020 3:10:04 PM> Device can have enhanced technological features in partitions and user data area
6/10/2020 3:10:04 PM> Device can have extended partitions attribute
6/10/2020 3:10:04 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
6/10/2020 3:10:04 PM> Backup saved: QN16BB_D754C625_20200610_151004.extcsd
6/10/2020 3:10:04 PM> EMMC Init completed.
6/10/2020 3:10:05 PM> Operation: Erasing eMMC...
6/10/2020 3:10:05 PM> Erasing for: ROM1 , start: 0x000000000000 , size: 0x000000020000
6/10/2020 3:10:05 PM> eMMC switching to ROM1
6/10/2020 3:13:35 PM> Erasing partition...
6/10/2020 3:14:35 PM> Error erasing at address: 000000000000 , error: -4, DATA RCV CRC Error ... Retry #1
6/10/2020 3:19:35 PM> Error erasing at address: 000000000000 , error: -4, DATA RCV CRC Error ... Retry #2
6/10/2020 3:24:35 PM> Error erasing at address: 000000000000 , error: -4, DATA RCV CRC Error ... Retry #3
6/10/2020 3:25:40 PM> Too many errors. Erasing has been stopped
Old 06-13-2020, 08:34   #2 (permalink)
Member: 1630066
Sonork: 520074
Thanks Meter: 197
you have selected vender qualcomm in reading
this is mediatek device nor qualcomm
write gp partition than write dump https://tii.ai/KuvVQl https://notexe.com/5q88kvpki6
The Following User Says Thank You to ilyasrao For This Useful Post:
Old 06-13-2020, 08:52   #3 (permalink)
Member: 1972033
Thanks Meter: 22
bro i want to ask u something wat is gp partition if u dont mind to explain
Old 06-13-2020, 21:51   #4 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 1,826
https://forum.gsmhosting.com/vbb/f67...ution-2585863/
The Following User Says Thank You to layder For This Useful Post:
Page generated in 0.25907 seconds with 7 queries
