nsync2005 | 11-22-2020 16:34 | g532g emmc 16gb hi
I changed the emmc from g532g to a kmq310013b-b319, what files to write to start the phone
I wrote boot1 and boot 2 always the phone does not want to turn on Code:
Setting frequence to 21 MHz
CMD Pullup Level: 2103 mV
CMD Active Level: 2722 mV
EMMC Device Information :
EMMC CID: 150100513832334D420097B34E912394
EMMC CSD: D02701320F5903FFF6DBFFEF92404008
EMMC Manufacture : SAMSUNG , EMMC NAME: Q823MB , HEX: 513832334D42 , S/N: 97B34E91 , rev. 0x00
EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 2/2016
EMMC ROM 1 (Main User Data) Capacity: 14910 MB (0003A3E00000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 2048 KB (000000200000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 128 KB (000000020000) Counter: 0 , Response: Clean
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD Information :
Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot
Boot Bus Config: 0x00 , width 1bit
H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: Q823MB_97B34E91_20201122_162921.extcsd
EMMC Init completed.
Scanning soft partitions
GPT header is found and is valid
Partition: BOTA0, [000000400000 - 000000800000], size: 000000400000 (4,00 MB)
Partition: NVRAM, [000000800000 - 000001000000], size: 000000800000 (8,00 MB)
Partition: LK, [000001000000 - 000001200000], size: 000000200000 (2,00 MB)
Partition: BOTA1, [000001200000 - 000001400000], size: 000000200000 (2,00 MB)
Partition: SECRO, [000001400000 - 000001B00000], size: 000000700000 (7,00 MB)
Partition: SECCFG, [000001B00000 - 000001B80000], size: 000000080000 (512 KB)
Partition: EFUSE, [000001B80000 - 000001C00000], size: 000000080000 (512 KB)
Partition: TEE1, [000001C00000 - 000002200000], size: 000000600000 (6,00 MB)
Partition: BOTA2, [000002200000 - 000002800000], size: 000000600000 (6,00 MB)
Partition: EFS, [000002800000 - 000003000000], size: 000000800000 (8,00 MB)
Partition: NVDATA, [000003000000 - 000005000000], size: 000002000000 (32,0 MB)
Partition: PARAM, [000005000000 - 000005800000], size: 000000800000 (8,00 MB)
Partition: RECOVERY, [000005800000 - 000006800000], size: 000001000000 (16,0 MB)
Partition: BOOT, [000006800000 - 000007800000], size: 000001000000 (16,0 MB)
Partition: MD1IMG, [000007800000 - 000009800000], size: 000002000000 (32,0 MB)
Partition: MD1DSP, [000009800000 - 000009C00000], size: 000000400000 (4,00 MB)
Partition: KEYSTORE, [000009C00000 - 00000A400000], size: 000000800000 (8,00 MB)
Partition: OMEKEYSTORE, [00000A400000 - 00000A780000], size: 000000380000 (3,50 MB)
Partition: PROINFO, [00000A780000 - 00000AA00000], size: 000000280000 (2,50 MB)
Partition: PARA, [00000AA00000 - 00000AA80000], size: 000000080000 (512 KB)
Partition: PERSISTENT, [00000AA80000 - 00000AB00000], size: 000000080000 (512 KB)
Partition: STEADY, [00000AB00000 - 00000AC00000], size: 000000100000 (1,00 MB)
Partition: PROTECT1, [00000AC00000 - 00000B400000], size: 000000800000 (8,00 MB)
Partition: PROTECT2, [00000B400000 - 00000BC00000], size: 000000800000 (8,00 MB)
Partition: RESERVE2, [00000BC00000 - 00000C000000], size: 000000400000 (4,00 MB)
Partition: SYSTEM, [00000C000000 - 0000CC800000], size: 0000C0800000 (3,01 GB)
Partition: CACHE, [0000CC800000 - 0000E5800000], size: 000019000000 (400 MB)
Partition: HIDDEN, [0000E5800000 - 0000E9400000], size: 000003C00000 (60,0 MB)
Partition: USERDATA, [0000E9400000 - 0003A3DFBE00], size: 0002BA9FBE00 (10,9 GB)
GPT header successfully parsed
Get firmware version
Firmware info not found |
