05-24-2017, 12:05 | #1 (permalink) |
Freak Poster Join Date: Nov 2012 Location: Imus,Cavite
Member: 1844172 Status: Offline Sonork: 100.1620999 Thanks Meter: 49 | Need help G355H dead boot. Retry Fail! ---------- eMMC Device Information ---------- EMMC CID : 1501004B3558594D420316B0DEE88134 EMMC CSD : D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 08/2014 Rev.0x3 EMMC NAME: K5XYMB , S/N: 380690152 EMMC NAME (HEX): 4B3558594D4200 EMMC ROM1 (Main User Data) Capacity: 3728 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 512 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x08. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: K5XYMB_ 380690152_20170524_1859.extcsd Done. Z3X EasyJtag Software ver. 2.5.0.8 Skip loading eMMC Addon Firmware CMD Pullup Level:2103 mV CMD Active Level:2413 mV Box IO Level:2800 mV CLK Rate:14000 khz Erasing 00000200 bytes from 00000000 ...ROM1 Erase Done. Processing file...C:\Users\gsmpro\Downloads\g355h dump v2\g355h dump v2\K5XYMB_2150096581_20150400_0347.extcsd Processing file...C:\Users\gsmpro\Downloads\g355h dump v2\g355h dump v2\EMMC_ROM1_00000000_08000000.bin Processing file...C:\Users\gsmpro\Downloads\g355h dump v2\g355h dump v2\EMMC_ROM2_00000000_00400000.bin Processing file...C:\Users\gsmpro\Downloads\g355h dump v2\g355h dump v2\EMMC_ROM3_00000000_00400000.bin Running:Repair extCSD... Z3X EasyJtag Software ver. 2.5.0.8 Skip loading eMMC Addon Firmware CMD Pullup Level:2103 mV CMD Active Level:2413 mV Box IO Level:2800 mV CLK Rate:14000 khz Writing... Done. Z3X EasyJtag Software ver. 2.5.0.8 Skip loading eMMC Addon Firmware CMD Pullup Level:2103 mV CMD Active Level:2413 mV Length limit is enabled! Input file : C:\Users\gsmpro\Downloads\g355h dump v2\g355h dump v2\EMMC_ROM1_00000000_08000000.bin Writing 0000000200 bytes to 0000000000... ROM1 (USER ROM) Retry writing adress 0x0000000000 (Attempt #0)... Retry Fail! Retry writing adress 0x0000000000 (Attempt #0)... Retry Fail! Retry writing adress 0x0000000000 (Attempt #0)... Retry Fail! Retry writing adress 0x0000000000 (Attempt #0)... Retry Fail! Retry writing adress 0x0000000000 (Attempt #0)... Retry Fail! Write Block Failed, Reason: CARD Ready Timeout Error Done. Done with error(s) Z3X EasyJtag Software ver. 2.5.0.8 Skip loading eMMC Addon Firmware CMD Pullup Level:2103 mV CMD Active Level:2413 mV Input file : C:\Users\gsmpro\Downloads\g355h dump v2\g355h dump v2\EMMC_ROM2_00000000_00400000.bin Writing 0000400000 bytes to 0000000000 ...ROM2 (BOOT1 ROM) Done. Write Speed: 1430 kB/s Z3X EasyJtag Software ver. 2.5.0.8 Skip loading eMMC Addon Firmware CMD Pullup Level:2103 mV CMD Active Level:2413 mV Input file : C:\Users\gsmpro\Downloads\g355h dump v2\g355h dump v2\EMMC_ROM3_00000000_00400000.bin Writing 0000400000 bytes to 0000000000 ...ROM3 (BOOT2 ROM) Done. Write Speed: 1460 kB/s |
05-25-2017, 15:43 | #3 (permalink) |
No Life Poster Join Date: Aug 2011
Member: 1630066 Status: Offline Sonork: 520074 Thanks Meter: 215 | use this file https://www.androidfilehost.com/?fid=24052804347849828 in EasyJTAG Plus write by vender ( samsung ) use pit and bl only after write pit and bl reboot mobile in odin mode and full flash with repartition |
