07-27-2019, 02:18 | #481 (permalink) | |
No Life Poster Join Date: Jan 2012 Location: Morocco
Member: 1712203 Status: Offline Thanks Meter: 354 | Quote:
09-24-2019, 05:35 | #484 (permalink) |
No Life Poster Join Date: Apr 2016 Location: B A N G L A D E S H
Member: 2556542 Status: Offline Thanks Meter: 1,790 | samsung g532g after write dump no download mode help Code: Setting frequence to 21 Mhz CMD Pullup Level: 2021 mV CMD Active Level: 2330 mV EMMC Device Information : EMMC CID: 90014A4838473475920121B1E0BE240A EMMC CSD: D02701320F5903FFFFFFFFE78A40002A EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4u , HEX: 483847347500 , S/N: 21B1E0BE , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 2/2017 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: H8G4u_21B1E0BE_20190924_103408.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: bota0, [000000400000 - 000000800000], size: 000000400000 (4.00 MB) Partition: nvram, [000000800000 - 000001000000], size: 000000800000 (8.00 MB) Partition: lk, [000001000000 - 000001200000], size: 000000200000 (2.00 MB) Partition: bota1, [000001200000 - 000001400000], size: 000000200000 (2.00 MB) Partition: secro, [000001400000 - 000001B00000], size: 000000700000 (7.00 MB) Partition: seccfg, [000001B00000 - 000001B80000], size: 000000080000 (512. KB) Partition: efuse, [000001B80000 - 000001C00000], size: 000000080000 (512. KB) Partition: tee1, [000001C00000 - 000002200000], size: 000000600000 (6.00 MB) Partition: bota2, [000002200000 - 000002800000], size: 000000600000 (6.00 MB) Partition: efs, [000002800000 - 000003000000], size: 000000800000 (8.00 MB) Partition: nvdata, [000003000000 - 000005000000], size: 000002000000 (32.0 MB) Partition: param, [000005000000 - 000005800000], size: 000000800000 (8.00 MB) Partition: recovery, [000005800000 - 000006800000], size: 000001000000 (16.0 MB) Partition: boot, [000006800000 - 000007800000], size: 000001000000 (16.0 MB) Partition: md1img, [000007800000 - 000009800000], size: 000002000000 (32.0 MB) Partition: md1dsp, [000009800000 - 000009C00000], size: 000000400000 (4.00 MB) Partition: keystore, [000009C00000 - 00000A400000], size: 000000800000 (8.00 MB) Partition: omekeystore, [00000A400000 - 00000A780000], size: 000000380000 (3.50 MB) Partition: proinfo, [00000A780000 - 00000AA00000], size: 000000280000 (2.50 MB) Partition: para, [00000AA00000 - 00000AA80000], size: 000000080000 (512. KB) Partition: persistent, [00000AA80000 - 00000AB00000], size: 000000080000 (512. KB) Partition: steady, [00000AB00000 - 00000AC00000], size: 000000100000 (1.00 MB) Partition: protect1, [00000AC00000 - 00000B400000], size: 000000800000 (8.00 MB) Partition: protect2, [00000B400000 - 00000BC00000], size: 000000800000 (8.00 MB) Partition: reserve2, [00000BC00000 - 00000C000000], size: 000000400000 (4.00 MB) Partition: system, [00000C000000 - 0000CC800000], size: 0000C0800000 (3.01 GB) Partition: cache, [0000CC800000 - 0000E5800000], size: 000019000000 (400. MB) Partition: hidden, [0000E5800000 - 0000E9400000], size: 000003C00000 (60.0 MB) Partition: userdata, [0000E9400000 - 0001D1C00000], size: 0000E8800000 (3.63 GB) GPT header successfully parsed |
09-24-2019, 12:45 | #485 (permalink) |
No Life Poster Join Date: Nov 2007 Location: United State Of Islam Age: 34
Member: 624551 Status: Offline Sonork: 100.1584837 Thanks Meter: 737 | first check model on Board then repair with pit and latest BL file. after u get download mode then flash with full files.. |
11-03-2019, 07:20 | #487 (permalink) |
Freak Poster Join Date: Jul 2014
Member: 2222183 Status: Offline Thanks Meter: 48 | G532G after flashing dead? see log and how to repair step by step kindly tell me... Z3X EasyJtag Software ver. 3.6.1.15 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 1616FE04ACD6A1EB, ,FW Ver.: 01.63 CMD Pullup Level:2000 mV CMD Active Level:2505 mV Box IO Level:2800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 90014A483847347592012A95B4511522 eMMC CSD : D02701320F5903FFFFFFFFE78A40002A eMMC Manufacturer ID: 0090 , OEM ID: 014A eMMC Date: 01/2018 Rev.0x1 eMMC NAME: H8G4u , S/N: 714454097 eMMC NAME (HEX): 483847347520 EMMC ROM1 (Main User Data) Capacity: 7456 MB , 0xE90000 pages , 0x1D2000000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 0 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.7 (MMC 5.0) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00002000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: H8G4u_ 714454097_20191103_1118.extcsd ============================================= Extended CSD rev 1.7 (MMC 5.0) ============================================= Card Supported Command sets [S_CMD_SET: 0x01] HPI Features [HPI_FEATURE: 0x01]: implementation based on CMD13 Background operations support [BKOPS_SUPPORT: 0x01] Max Packet Read Cmd [MAX_PACKED_READS: 0x3f] Max Packet Write Cmd [MAX_PACKED_WRITES: 0x3f] Data TAG support [DATA_TAG_SUPPORT: 0x01] Data TAG Unit Size [TAG_UNIT_SIZE: 0x00] Tag Resources Size [TAG_RES_SIZE: 0x00] Context Management Capabilities [CONTEXT_CAPABILITIES: 0x78] Large Unit Size [LARGE_UNIT_SIZE_M1: 0x01] Extended partition attribute support [EXT_SUPPORT: 0x03] Generic CMD6 Timer [GENERIC_CMD6_TIME: 0x05] Power off notification [POWER_OFF_LONG_TIME: 0x64] Cache Size [CACHE_SIZE] is 1024 KiB ------------------------- eMMC v5+ ------------------------- Supported modes [SUPPORTED_MODES: 0x01] FFU features [FFU_FEATURES: 0x00] Operation codes timeout [OPERATION_CODE_TIMEOUT: 0x00] FFU Argument [FFU_ARG: 0xfffafff0] Number of FW sectors correctly programmed[NUM_OF_FW_SECT_CORR_PROG: 0] Vendor proprietary health report: [VENDOR_PROPRIETARY_HEALTH_REPORT[301]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[300]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[299]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[298]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[297]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[296]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[295]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[294]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[293]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[292]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[291]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[290]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[289]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[288]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[287]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[286]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[285]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[284]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[283]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[282]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[281]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[280]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[279]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[278]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[277]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[276]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[275]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[274]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[273]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[272]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[271]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[270]]:0x00 _(Device life time estimation type B [DEVICE_LIFE_TIME_EST_TYP_B: 0x0b] i.e. Exceeded its maximum estimated device life time _(Device life time estimation type B [DEVICE_LIFE_TIME_EST_TYP_A: 0x01] i.e. 0% - 10% device life time used Pre EOL information [PRE_EOL_INFO: 0x01] i.e. Normal Optimal read size [OPTIMAL_READ_SIZE: 0x40] Optimal write size [OPTIMAL_WRITE_SIZE: 0x40] Optimal trim unit size [OPTIMAL_TRIM_UNIT_SIZE: 0x07] Device version [DEVICE_VERSION: 0x38 - 0x05] Firmware version: [FIRMWARE_VERSION[261]]: 0x00 [FIRMWARE_VERSION[260]]: 0x00 [FIRMWARE_VERSION[259]]: 0x00 [FIRMWARE_VERSION[258]]: 0x00 [FIRMWARE_VERSION[257]]: 0x31 [FIRMWARE_VERSION[256]]: 0x30 [FIRMWARE_VERSION[255]]: 0x30 [FIRMWARE_VERSION[254]]: 0x53 Power class for 200MHz, DDR at VCC= 3.6V [PWR_CL_DDR_200_360: 0x00] ------------------------------------------------------------- Generic CMD6 Timer [GENERIC_CMD6_TIME: 0x05] Power off notification [POWER_OFF_LONG_TIME: 0x64] Cache Size [CACHE_SIZE] is 1024 KiB Background operations status [BKOPS_STATUS: 0x00] 1st Initialisation Time after programmed sector [INI_TIMEOUT_AP: 0x0a] Power class for 52MHz, DDR at 3.6V [PWR_CL_DDR_52_360: 0x00] Power class for 52MHz, DDR at 1.95V [PWR_CL_DDR_52_195: 0x00] Power class for 200MHz at 3.6V [PWR_CL_200_360: 0x00] Power class for 200MHz, at 1.95V [PWR_CL_200_195: 0x00] Minimum Performance for 8bit at 52MHz in DDR mode: [MIN_PERF_DDR_W_8_52: 0x00] [MIN_PERF_DDR_R_8_52: 0x00] TRIM Multiplier [TRIM_MULT: 0x01] Secure Feature support [SEC_FEATURE_SUPPORT: 0x55] Boot Information [BOOT_INFO: 0x07] Device supports alternative boot method Device supports dual data rate during boot Device supports high speed timing during boot Boot partition size [BOOT_SIZE_MULTI: 0x20] Access size [ACC_SIZE: 0x06] High-capacity erase unit size [HC_ERASE_GRP_SIZE: 0x01] High-capacity erase timeout [ERASE_TIMEOUT_MULT: 0x02] Reliable write sector count [REL_WR_SEC_C: 0x01] High-capacity W protect group size [HC_WP_GRP_SIZE: 0x08] Sleep current (VCC) [S_C_VCC: 0x07] Sleep current (VCCQ) [S_C_VCCQ: 0x07] Sleep/awake timeout [S_A_TIMEOUT: 0x11] Sector Count [SEC_COUNT: 0x00e90000] Minimum Write Performance for 8bit: [MIN_PERF_W_8_52: 0x00] [MIN_PERF_R_8_52: 0x00] [MIN_PERF_W_8_26_4_52: 0x00] [MIN_PERF_R_8_26_4_52: 0x00] Minimum Write Performance for 4bit: [MIN_PERF_W_4_26: 0x00] [MIN_PERF_R_4_26: 0x00] Power classes registers: [PWR_CL_26_360: 0x00] [PWR_CL_52_360: 0x00] [PWR_CL_26_195: 0x00] [PWR_CL_52_195: 0x00] Partition switching timing [PARTITION_SWITCH_TIME: 0x01] Out-of-interrupt busy timing [OUT_OF_INTERRUPT_TIME: 0x05] I/O Driver Strength [DRIVER_STRENGTH: 0x1f] Card Type [CARD_TYPE: 0x57] CSD structure version [CSD_STRUCTURE: 0x02] Command set [CMD_SET: 0x00] Command set revision [CMD_SET_REV: 0x00] Power class [POWER_CLASS: 0x00] High-speed interface timing [HS_TIMING: 0x00] Erased memory content [ERASED_MEM_CONT: 0x00] Boot configuration bytes [PARTITION_CONFIG: 0x48] No access to boot partition Boot config protection [BOOT_CONFIG_PROT: 0x00] Boot bus Conditions [BOOT_BUS_CONDITIONS: 0x00] High-density erase group definition [ERASE_GROUP_DEF: 0x00] Boot write protection status registers [BOOT_WP_STATUS]: 0x00 Boot Area Write protection [BOOT_WP]: 0x00 Power ReadOnly locking: possible Permanent ReadOnly locking: possible Read Only lock status: not locked User area write protection register [USER_WP]: 0x50 FW configuration [FW_CONFIG]: 0x00 RPMB Size [RPMB_SIZE_MULT]: 0x20 Write reliability setting register [WR_REL_SET]: 0x1f Write reliability parameter register [WR_REL_PARAM]: 0x15 Enable background operations handshake [BKOPS_EN]: 0x00 H/W reset function [RST_N_FUNCTION]: 0x01 HPI management [HPI_MGMT]: 0x00 Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Max Enhanced Area Size [MAX_ENH_SIZE_MULT]: 0x0003a4 Partitions attribute [PARTITIONS_ATTRIBUTE]: 0x00 Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 General Purpose Partition Size [GP_SIZE_MULT_4]: 0x000000 [GP_SIZE_MULT_3]: 0x000000 [GP_SIZE_MULT_2]: 0x000000 [GP_SIZE_MULT_1]: 0x000000 Enhanced User Data Area Size [ENH_SIZE_MULT]: 0x000000 Enhanced User Data Start Address [ENH_START_ADDR]: 0x000000 Bad Block Management mode [SEC_BAD_BLK_MGMNT]: 0x00 Periodic Wake-up [PERIODIC_WAKEUP]: 0x00 Program CID/CSD in DDR mode support [PROGRAM_CID_CSD_DDR_SUPPORT]: 0x00 Native sector size [NATIVE_SECTOR_SIZE]: 0x01 Sector size emulation [USE_NATIVE_SECTOR]: 0x00 Sector size [DATA_SECTOR_SIZE]: 0x00 1st initialization after disabling sector size emulation [INI_TIMEOUT_EMU]: 0x0a Class 6 commands control [CLASS_6_CTRL]: 0x00 Number of addressed group to be released[DYNCAP_NEEDED]: 0x00 Exception events control [EXCEPTION_EVENTS_CTRL]: 0x0000 Exception events status [EXCEPTION_EVENTS_STATUS]: 0x0000 Extended Partitions Attribute [EXT_PARTITIONS_ATTRIBUTE]: 0x0000 Packed command status [PACKED_COMMAND_STATUS]: 0x00 Packed command failure index [PACKED_FAILURE_INDEX]: 0x00 Power Off Notification [POWER_OFF_NOTIFICATION]: 0x00 Control to turn the Cache ON/OFF [CACHE_CTRL]: 0x00 Caution: invalid backup GPT header, but valid main header! Warning! Main and backup partition tables differ! Warning! One or more CRCs don't match. You should repair the disk! Caution: Found protective or hybrid MBR and corrupt GPT. Real (Hardware) Disk/Image size: E90000 sectors 7.3 GiB Soft (Partitioned) Disk/Image size: 749FDD sectors 3.6 GiB Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,7643135 Partition info successfully found ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x000C000000 (3.7GB) Unable to mount SYSTEM , code : 95 --------------------------------------------- Detected USERDATA USERDATA : 0x00E9400000 (0.0B) Unable to mount USERDATA , code : 22 Done. install rom 1,2 Error writing address 0x039C0000 Error Code:-8 Reason ATA SND CRC Error Retry writing address 0x00039C0000 (Attempt #1)... Retry Success! Error writing address 0x06E40000 Error Code:-8 Reason ATA SND CRC Error Retry writing address 0x0006E40000 (Attempt #1)... Retry Success! Done, time taken: 116 sec. Average Write Speed: 1552 kB/s Z3X EasyJtag Software ver. 3.6.1.15 Skip loading eMMC Addon Firmware CMD Pullup Level:2000 mV CMD Active Level:2505 mV Input file : C:\Users\akhtar\Desktop\SAMSUNG_SM-G532G_emmc_dump_ROM1_ROM2_200MB\Samsung_SM-G532G_emmc_dump_ROM2.bin Writing 0000200000 bytes to 0000000000 ...ROM2 (BOOT1 ROM) Done, time taken: 3 sec. Average Write Speed: 691 kB/s |
11-08-2019, 12:43 | #490 (permalink) |
No Life Poster Join Date: Nov 2006 Location: philippines Age: 42
Member: 388962 Status: Offline Sonork: 100.1637202 Thanks Meter: 264 | G532G dead needs help hi, can anyone help me about this logs? this phone is working and it died after i flashed with a lower version firmware. so i don't think its emmc problem see logs : Code: Done. extCSD Are not selected , skip writing extCSD Processing file...C:\emmc file repair jtag\g532g\EMMC_QN16BB_ROM1_000000000000_000020000000.bin Processing file...C:\emmc file repair jtag\g532g\EMMC_QN16BB_ROM2_000000000000_000000400000.bin Processing file...C:\emmc file repair jtag\g532g\EMMC_QN16BB_ROM3_000000000000_000000400000.bin Z3X EasyJtag Software ver. 3.6.1.15 Skip loading eMMC Addon Firmware CMD Pullup Level:3165 mV CMD Active Level:3269 mV Input file : C:\emmc file repair jtag\g532g\EMMC_QN16BB_ROM1_000000000000_000020000000.bin Writing 0020000000 bytes to 0000000000... ROM1 (USER ROM) Error writing address 0x06180000 Error Code:-8 Reason :DATA SND CRC Error Retry writing address 0x0006180000 (Attempt #1)... Retry Success! Error writing address 0x0E380000 Error Code:-101 Reason :CARD Ready Timeout Error Retry writing address 0x000E380000 (Attempt #1)... Retry Success! Error writing address 0x131C0000 Error Code:-8 Reason :DATA SND CRC Error Retry writing address 0x00131C0000 (Attempt #1)... Retry Success! Error writing address 0x164C0000 Error Code:-101 Reason :CARD Ready Timeout Error Retry writing address 0x00164C0000 (Attempt #1)... Retry Success! Error writing address 0x19280000 Error Code:-8 Reason :DATA SND CRC Error Retry writing address 0x0019280000 (Attempt #1)... Retry Success! Error writing address 0x1C540000 Error Code:-8 Reason :DATA SND CRC Error Retry writing address 0x001C540000 (Attempt #1)... Retry Success! Error writing address 0x1F740000 Error Code:-8 Reason :DATA SND CRC Error Retry writing address 0x001F740000 (Attempt #1)... i have 3.3v and 21mhz clk i am using charger as power supply and moorc adapter with power supply also. |
11-09-2019, 10:51 | #492 (permalink) | ||||||
Member: 388962 Status: Offline Sonork: 100.1637202 Thanks Meter: 264 | type of connection is via moorc adapter 5 in 1 box type is i really don't know, i bought this box in 2017.. its an old one not yet easy jtag plus but i updated it to plus. Quote:
and i have resoldered all wires Quote:
and this is logs : Quote:
there is an error see logs : Quote:
what do i need to do next please? thank you ALSO, when i try to do hw partition to write to extCSD this is error : Quote:
11-09-2019, 11:38 | #493 (permalink) |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | FW Ver.: 01.63 - old box, 1st generation you can set lover freq (14Mhz) if you get errors, and use 2,8 IO also you can add 2 resistors to adapter ~200 Ohm from CMD and D0 to IO (1,8 line) as at pinouts pictures When you restore boot via BL files and Plus Software, you need De-select Repartition (it needed when eMMC change) Now after repair boot you need write only GPT from ane worked dump from same device (write by vendor - from file - select only GPT) |
The Following User Says Thank You to layder For This Useful Post: |
12-02-2019, 16:36 | #494 (permalink) |
No Life Poster Join Date: Mar 2010 Location: pakistan jhelum
Member: 1261180 Status: Offline Sonork: 100.1590645 Thanks Meter: 97 | write latest bl but sill dead 12/2/2019 8:02:51 PM> 12/2/2019 8:02:51 PM> eMMC_tool Suite ver. 1.6.2.0 (release date: 30.06.2019) 12/2/2019 8:02:54 PM> Microsoft Windows 7 (32 bit) build 7601 (6.1.7601.18015) 12/2/2019 8:02:54 PM> 12/2/2019 8:02:54 PM> Looking for EasyJTAG box... 12/2/2019 8:02:54 PM> EasyJTAG API ver. 3307 12/2/2019 8:02:57 PM> OpenUSB returned = 0 12/2/2019 8:02:58 PM> EasyJTAG Box Serial = 0B011006F8DECFFA 12/2/2019 8:03:00 PM> Card Serial = AA41406B 12/2/2019 8:03:00 PM> EasyJTAG Box Firmware = 1.63 12/2/2019 8:03:00 PM> 12/2/2019 8:03:14 PM> Looking for EasyJTAG box... 12/2/2019 8:03:14 PM> EasyJTAG API ver. 3307 12/2/2019 8:03:14 PM> Setting IO Levels to 3.3V 12/2/2019 8:03:14 PM> Setting frequence to 21 MHz 12/2/2019 8:03:15 PM> EasyJTAG Box Serial = 0B011006F8DECFFA 12/2/2019 8:03:15 PM> EasyJTAG Box Firmware = 1.63 12/2/2019 8:03:18 PM> HiPower mode is ON 12/2/2019 8:03:18 PM> Setting frequence to 21 MHz 12/2/2019 8:03:18 PM> CMD Pullup Level: 2062 mV 12/2/2019 8:03:18 PM> CMD Active Level: 2959 mV 12/2/2019 8:03:19 PM> eMMC Init returned = 0 12/2/2019 8:03:19 PM> EMMC Device Information : 12/2/2019 8:03:19 PM> EMMC CID: 90014A48384734759201195728561534 12/2/2019 8:03:19 PM> EMMC CSD: D02701320F5903FFFFFFFFE78A40002A 12/2/2019 8:03:19 PM> EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4u , HEX: 483847347500 , S/N: 19572856 , rev. 0x01 12/2/2019 8:03:19 PM> EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 1/2018 12/2/2019 8:03:19 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) 12/2/2019 8:03:19 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 12/2/2019 8:03:19 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Maybe not clean 12/2/2019 8:03:19 PM> EMMC Permanent Write Protection: No 12/2/2019 8:03:19 PM> EMMC Temporary Write Protection: No 12/2/2019 8:03:19 PM> Extended CSD Information : 12/2/2019 8:03:19 PM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) 12/2/2019 8:03:19 PM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) 12/2/2019 8:03:19 PM> Boot Bus Config: 0x00 , width 1bit 12/2/2019 8:03:19 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled 12/2/2019 8:03:19 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 12/2/2019 8:03:19 PM> Device supports partitioning features 12/2/2019 8:03:19 PM> Device can have enhanced technological features in partitions and user data area 12/2/2019 8:03:19 PM> Device can have extended partitions attribute 12/2/2019 8:03:19 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 12/2/2019 8:03:19 PM> Backup saved: H8G4u_19572856_20191202_200319.extcsd 12/2/2019 8:03:19 PM> EMMC Init completed. 12/2/2019 8:03:19 PM> 12/2/2019 8:03:19 PM> Get firmware version 12/2/2019 8:03:19 PM> 12/2/2019 8:03:28 PM> Brand = samsung 12/2/2019 8:03:28 PM> Manufacturer = samsung 12/2/2019 8:03:28 PM> Device = grandpplte 12/2/2019 8:03:28 PM> Model = SM-G532G 12/2/2019 8:03:28 PM> Phone platform = mt6737t 12/2/2019 8:03:28 PM> CPU Abi = armeabi-v7a 12/2/2019 8:03:28 PM> Mediatek platform = MT6737T 12/2/2019 8:03:28 PM> Android release = 6.0.1 12/2/2019 8:03:28 PM> Firmware version = MMB29T.G532GDXU1APJ7 12/2/2019 8:03:28 PM> Firmware date = Wed Oct 26 23:36:39 KST 2016 12/2/2019 8:04:16 PM> 12/2/2019 8:04:16 PM> Looking for EasyJTAG box... 12/2/2019 8:04:16 PM> EasyJTAG API ver. 3307 12/2/2019 8:04:16 PM> Setting IO Levels to 3.3V 12/2/2019 8:04:16 PM> Setting frequence to 21 MHz 12/2/2019 8:04:17 PM> EasyJTAG Box Serial = 0B011006F8DECFFA 12/2/2019 8:04:17 PM> EasyJTAG Box Firmware = 1.63 12/2/2019 8:04:21 PM> HiPower mode is ON 12/2/2019 8:04:21 PM> Setting frequence to 21 MHz 12/2/2019 8:04:21 PM> CMD Pullup Level: 1969 mV 12/2/2019 8:04:21 PM> CMD Active Level: 2887 mV 12/2/2019 8:04:21 PM> eMMC Init returned = 0 12/2/2019 8:04:21 PM> EMMC Device Information : 12/2/2019 8:04:21 PM> EMMC CID: 90014A48384734759201195728561534 12/2/2019 8:04:21 PM> EMMC CSD: D02701320F5903FFFFFFFFE78A40002A 12/2/2019 8:04:21 PM> EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4u , HEX: 483847347500 , S/N: 19572856 , rev. 0x01 12/2/2019 8:04:21 PM> EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 1/2018 12/2/2019 8:04:21 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) 12/2/2019 8:04:21 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 12/2/2019 8:04:21 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Maybe not clean 12/2/2019 8:04:21 PM> EMMC Permanent Write Protection: No 12/2/2019 8:04:21 PM> EMMC Temporary Write Protection: No 12/2/2019 8:04:21 PM> Extended CSD Information : 12/2/2019 8:04:21 PM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) 12/2/2019 8:04:21 PM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) 12/2/2019 8:04:21 PM> Boot Bus Config: 0x00 , width 1bit 12/2/2019 8:04:21 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled 12/2/2019 8:04:21 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 12/2/2019 8:04:21 PM> Device supports partitioning features 12/2/2019 8:04:21 PM> Device can have enhanced technological features in partitions and user data area 12/2/2019 8:04:21 PM> Device can have extended partitions attribute 12/2/2019 8:04:21 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 12/2/2019 8:04:21 PM> Backup saved: H8G4u_19572856_20191202_200421.extcsd 12/2/2019 8:04:21 PM> EMMC Init completed. 12/2/2019 8:04:21 PM> 12/2/2019 8:04:21 PM> Opening file: E:\download\G532G DEAD BOOT REPAIR FILE\G532G DEAD BOOT REPAIR FILE\GRANDPPLTE_CIS_SER.pit 12/2/2019 8:04:21 PM> 12/2/2019 8:04:21 PM> Pit: GRANDPPLTE_CIS_SER.pit 12/2/2019 8:04:21 PM> Entry count: 34 12/2/2019 8:04:21 PM> 12/2/2019 8:04:21 PM> The size of the last section has been updated 12/2/2019 8:05:06 PM> Selected file: E:\download\NPL-G532GDDU1ASA3_G532GODD1BRL1-20190124\BL_G532GDDU1ASA3_CL14107410_QB21621617_RE V00_user_low_ship_MULTI_CERT.tar.md5 12/2/2019 8:05:06 PM> 12/2/2019 8:05:06 PM> BL_G532GDDU1ASA3_CL14107410_QB21621617_REV00_user_ low_ship_MULTI_CERT.tar.md5 12/2/2019 8:05:06 PM> The list of files in the firmware: 12/2/2019 8:05:06 PM> preloader.img 12/2/2019 8:05:06 PM> lk.bin 12/2/2019 8:05:06 PM> param.bin 12/2/2019 8:05:06 PM> trustzone.bin 12/2/2019 8:05:06 PM> efuse.img 12/2/2019 8:05:06 PM> 12/2/2019 8:05:14 PM> Looking for EasyJTAG box... 12/2/2019 8:05:14 PM> EasyJTAG API ver. 3307 12/2/2019 8:05:14 PM> Setting IO Levels to 3.3V 12/2/2019 8:05:14 PM> Setting frequence to 21 MHz 12/2/2019 8:05:15 PM> EasyJTAG Box Serial = 0B011006F8DECFFA 12/2/2019 8:05:15 PM> EasyJTAG Box Firmware = 1.63 12/2/2019 8:05:18 PM> HiPower mode is ON 12/2/2019 8:05:18 PM> Setting frequence to 21 MHz 12/2/2019 8:05:18 PM> CMD Pullup Level: 1928 mV 12/2/2019 8:05:18 PM> CMD Active Level: 2835 mV 12/2/2019 8:05:19 PM> eMMC Init returned = 0 12/2/2019 8:05:19 PM> EMMC Device Information : 12/2/2019 8:05:19 PM> EMMC CID: 90014A48384734759201195728561534 12/2/2019 8:05:19 PM> EMMC CSD: D02701320F5903FFFFFFFFE78A40002A 12/2/2019 8:05:19 PM> EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4u , HEX: 483847347500 , S/N: 19572856 , rev. 0x01 12/2/2019 8:05:19 PM> EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 1/2018 12/2/2019 8:05:19 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) 12/2/2019 8:05:19 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 12/2/2019 8:05:19 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Maybe not clean 12/2/2019 8:05:19 PM> EMMC Permanent Write Protection: No 12/2/2019 8:05:19 PM> EMMC Temporary Write Protection: No 12/2/2019 8:05:19 PM> Extended CSD Information : 12/2/2019 8:05:19 PM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) 12/2/2019 8:05:19 PM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) 12/2/2019 8:05:19 PM> Boot Bus Config: 0x00 , width 1bit 12/2/2019 8:05:19 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled 12/2/2019 8:05:19 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 12/2/2019 8:05:19 PM> Device supports partitioning features 12/2/2019 8:05:19 PM> Device can have enhanced technological features in partitions and user data area 12/2/2019 8:05:19 PM> Device can have extended partitions attribute 12/2/2019 8:05:19 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 12/2/2019 8:05:19 PM> Backup saved: H8G4u_19572856_20191202_200519.extcsd 12/2/2019 8:05:19 PM> EMMC Init completed. 12/2/2019 8:05:19 PM> 12/2/2019 8:05:19 PM> Operation: Write by vendor (Samsung) 12/2/2019 8:05:19 PM> 12/2/2019 8:05:19 PM> Creating GPT-partitioninig 12/2/2019 8:05:19 PM> Writing PrimaryGPT at address: 000000000000 12/2/2019 8:05:19 PM> Writing BackupGPT at address: 0001D1FFBE00 12/2/2019 8:05:19 PM> Writing PIT at address: 000000004400 12/2/2019 8:05:19 PM> GPT-partitioning done 12/2/2019 8:05:19 PM> 12/2/2019 8:05:19 PM> Unpacking file: preloader.img 12/2/2019 8:05:19 PM> Unpacking file: lk.bin 12/2/2019 8:05:19 PM> Unpacking file: efuse.img 12/2/2019 8:05:19 PM> Unpacking file: trustzone.bin 12/2/2019 8:05:19 PM> Unpacking file: param.bin 12/2/2019 8:05:19 PM> 12/2/2019 8:05:19 PM> Partition name: BOOTLOADER 12/2/2019 8:05:19 PM> Filename: preloader.img , Offset: 000000000000 , filesize: 170240 bytes 12/2/2019 8:05:19 PM> eMMC switching to ROM2 12/2/2019 8:05:20 PM> Erasing partition... 12/2/2019 8:05:41 PM> Writing partition... 12/2/2019 8:05:42 PM> Done writing partition. Write speed: 166.43 KB/s 12/2/2019 8:05:42 PM> Partition name: LK 12/2/2019 8:05:42 PM> Filename: lk.bin , Offset: 000001000000 , filesize: 614912 bytes 12/2/2019 8:05:42 PM> eMMC switching to ROM1 12/2/2019 8:05:42 PM> Erasing partition... 12/2/2019 8:05:45 PM> Writing partition... 12/2/2019 8:05:47 PM> Done writing partition. Write speed: 330.41 KB/s 12/2/2019 8:05:47 PM> Partition name: EFUSE 12/2/2019 8:05:47 PM> Filename: efuse.img , Offset: 000001B80000 , filesize: 768 bytes 12/2/2019 8:05:47 PM> eMMC switching to ROM1 12/2/2019 8:05:47 PM> Erasing partition... 12/2/2019 8:05:48 PM> Writing partition... 12/2/2019 8:05:48 PM> Done writing partition. Write speed: 15.02 KB/s 12/2/2019 8:05:48 PM> Partition name: TEE1 12/2/2019 8:05:48 PM> Filename: trustzone.bin , Offset: 000001C00000 , filesize: 324352 bytes 12/2/2019 8:05:48 PM> eMMC switching to ROM1 12/2/2019 8:05:48 PM> Erasing partition... 12/2/2019 8:05:49 PM> Writing partition... 12/2/2019 8:05:50 PM> Done writing partition. Write speed: 475.51 KB/s 12/2/2019 8:05:50 PM> Partition name: PARAM 12/2/2019 8:05:50 PM> Filename: param.bin , Offset: 000005000000 , filesize: 747520 bytes 12/2/2019 8:05:50 PM> eMMC switching to ROM1 12/2/2019 8:05:50 PM> Erasing partition... 12/2/2019 8:05:52 PM> Writing partition... 12/2/2019 8:05:53 PM> Done writing partition. Write speed: 532.61 KB/s 12/2/2019 8:06:08 PM> 12/2/2019 8:06:08 PM> Check BootConfig for the selected vendor 12/2/2019 8:06:08 PM> 12/2/2019 8:06:08 PM> All done time: [00:00:48:952] 12/2/2019 8:06:08 PM> 12/2/2019 8:06:23 PM> Looking for EasyJTAG box... 12/2/2019 8:06:23 PM> EasyJTAG API ver. 3307 12/2/2019 8:06:23 PM> Setting IO Levels to 3.3V 12/2/2019 8:06:23 PM> Setting frequence to 21 MHz 12/2/2019 8:06:24 PM> EasyJTAG Box Serial = 0B011006F8DECFFA 12/2/2019 8:06:24 PM> EasyJTAG Box Firmware = 1.63 12/2/2019 8:06:28 PM> HiPower mode is ON 12/2/2019 8:06:28 PM> Setting frequence to 21 MHz 12/2/2019 8:06:28 PM> CMD Pullup Level: 2072 mV 12/2/2019 8:06:28 PM> CMD Active Level: 2959 mV 12/2/2019 8:06:28 PM> eMMC Init returned = 0 12/2/2019 8:06:28 PM> EMMC Device Information : 12/2/2019 8:06:28 PM> EMMC CID: 90014A48384734759201195728561534 12/2/2019 8:06:28 PM> EMMC CSD: D02701320F5903FFFFFFFFE78A40002A 12/2/2019 8:06:28 PM> EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4u , HEX: 483847347500 , S/N: 19572856 , rev. 0x01 12/2/2019 8:06:28 PM> EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 1/2018 12/2/2019 8:06:28 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) 12/2/2019 8:06:28 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 12/2/2019 8:06:28 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Maybe not clean 12/2/2019 8:06:28 PM> EMMC Permanent Write Protection: No 12/2/2019 8:06:28 PM> EMMC Temporary Write Protection: No 12/2/2019 8:06:28 PM> Extended CSD Information : 12/2/2019 8:06:28 PM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) 12/2/2019 8:06:28 PM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) 12/2/2019 8:06:28 PM> Boot Bus Config: 0x00 , width 1bit 12/2/2019 8:06:28 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled 12/2/2019 8:06:28 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 12/2/2019 8:06:28 PM> Device supports partitioning features 12/2/2019 8:06:28 PM> Device can have enhanced technological features in partitions and user data area 12/2/2019 8:06:28 PM> Device can have extended partitions attribute 12/2/2019 8:06:28 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 12/2/2019 8:06:28 PM> Backup saved: H8G4u_19572856_20191202_200628.extcsd 12/2/2019 8:06:28 PM> EMMC Init completed. 12/2/2019 8:06:28 PM> 12/2/2019 8:06:28 PM> Operation: Write by vendor (Samsung) 12/2/2019 8:06:28 PM> 12/2/2019 8:06:28 PM> Creating GPT-partitioninig 12/2/2019 8:06:28 PM> Writing PrimaryGPT at address: 000000000000 12/2/2019 8:06:28 PM> Writing BackupGPT at address: 0001D1FFBE00 12/2/2019 8:06:29 PM> Writing PIT at address: 000000004400 12/2/2019 8:06:29 PM> GPT-partitioning done 12/2/2019 8:06:29 PM> 12/2/2019 8:06:29 PM> Unpacking file: preloader.img 12/2/2019 8:06:29 PM> Unpacking file: lk.bin 12/2/2019 8:06:29 PM> Unpacking file: efuse.img 12/2/2019 8:06:29 PM> Unpacking file: trustzone.bin 12/2/2019 8:06:29 PM> Unpacking file: param.bin 12/2/2019 8:06:29 PM> 12/2/2019 8:06:29 PM> Partition name: BOOTLOADER 12/2/2019 8:06:29 PM> Filename: preloader.img , Offset: 000000000000 , filesize: 170240 bytes 12/2/2019 8:06:29 PM> eMMC switching to ROM2 12/2/2019 8:06:29 PM> Erasing partition... 12/2/2019 8:06:50 PM> Writing partition... 12/2/2019 8:06:51 PM> Done writing partition. Write speed: 159.44 KB/s 12/2/2019 8:06:51 PM> Partition name: LK 12/2/2019 8:06:51 PM> Filename: lk.bin , Offset: 000001000000 , filesize: 614912 bytes 12/2/2019 8:06:51 PM> eMMC switching to ROM1 12/2/2019 8:06:52 PM> Erasing partition... 12/2/2019 8:06:54 PM> Writing partition... 12/2/2019 8:06:56 PM> Done writing partition. Write speed: 288.42 KB/s 12/2/2019 8:06:56 PM> Partition name: EFUSE 12/2/2019 8:06:56 PM> Filename: efuse.img , Offset: 000001B80000 , filesize: 768 bytes 12/2/2019 8:06:56 PM> eMMC switching to ROM1 12/2/2019 8:06:57 PM> Erasing partition... 12/2/2019 8:06:57 PM> Writing partition... 12/2/2019 8:06:57 PM> Done writing partition. Write speed: 14.68 KB/s 12/2/2019 8:06:57 PM> Partition name: TEE1 12/2/2019 8:06:57 PM> Filename: trustzone.bin , Offset: 000001C00000 , filesize: 324352 bytes 12/2/2019 8:06:57 PM> eMMC switching to ROM1 12/2/2019 8:06:58 PM> Erasing partition... 12/2/2019 8:06:59 PM> Writing partition... 12/2/2019 8:07:00 PM> Done writing partition. Write speed: 445.95 KB/s 12/2/2019 8:07:00 PM> Partition name: PARAM 12/2/2019 8:07:00 PM> Filename: param.bin , Offset: 000005000000 , filesize: 747520 bytes 12/2/2019 8:07:00 PM> eMMC switching to ROM1 12/2/2019 8:07:00 PM> Erasing partition... 12/2/2019 8:07:02 PM> Writing partition... 12/2/2019 8:07:03 PM> Done writing partition. Write speed: 560.99 KB/s 12/2/2019 8:07:06 PM> 12/2/2019 8:07:07 PM> Operation: Writing BootConfig ... 12/2/2019 8:07:07 PM> Reg: 179 Value: 0x48 12/2/2019 8:07:07 PM> Reg: 177 Value: 0x00 12/2/2019 8:07:08 PM> Reg: 162 Value: 0x01 12/2/2019 8:07:09 PM> Done 12/2/2019 8:07:09 PM> 12/2/2019 8:07:09 PM> All done time: [00:00:39:994] 12/2/2019 8:07:09 PM> 12/2/2019 8:07:13 PM> Looking for EasyJTAG box... 12/2/2019 8:07:13 PM> EasyJTAG API ver. 3307 12/2/2019 8:07:13 PM> Setting IO Levels to 3.3V 12/2/2019 8:07:13 PM> Setting frequence to 21 MHz 12/2/2019 8:07:15 PM> EasyJTAG Box Serial = 0B011006F8DECFFA 12/2/2019 8:07:15 PM> EasyJTAG Box Firmware = 1.63 12/2/2019 8:07:18 PM> HiPower mode is ON 12/2/2019 8:07:18 PM> Setting frequence to 21 MHz 12/2/2019 8:07:18 PM> CMD Pullup Level: 2052 mV 12/2/2019 8:07:18 PM> CMD Active Level: 2918 mV 12/2/2019 8:07:19 PM> eMMC Init returned = 0 12/2/2019 8:07:19 PM> EMMC Device Information : 12/2/2019 8:07:19 PM> EMMC CID: 90014A48384734759201195728561534 12/2/2019 8:07:19 PM> EMMC CSD: D02701320F5903FFFFFFFFE78A40002A 12/2/2019 8:07:19 PM> EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4u , HEX: 483847347500 , S/N: 19572856 , rev. 0x01 12/2/2019 8:07:19 PM> EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 1/2018 12/2/2019 8:07:19 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) 12/2/2019 8:07:19 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 12/2/2019 8:07:19 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Maybe not clean 12/2/2019 8:07:19 PM> EMMC Permanent Write Protection: No 12/2/2019 8:07:19 PM> EMMC Temporary Write Protection: No 12/2/2019 8:07:19 PM> Extended CSD Information : 12/2/2019 8:07:19 PM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) 12/2/2019 8:07:19 PM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) 12/2/2019 8:07:19 PM> Boot Bus Config: 0x00 , width 1bit 12/2/2019 8:07:19 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled 12/2/2019 8:07:19 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 12/2/2019 8:07:19 PM> Device supports partitioning features 12/2/2019 8:07:19 PM> Device can have enhanced technological features in partitions and user data area 12/2/2019 8:07:19 PM> Device can have extended partitions attribute 12/2/2019 8:07:19 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 12/2/2019 8:07:19 PM> Backup saved: H8G4u_19572856_20191202_200719.extcsd 12/2/2019 8:07:19 PM> EMMC Init completed. 12/2/2019 8:07:19 PM> 12/2/2019 8:07:19 PM> Get firmware version 12/2/2019 8:07:19 PM> 12/2/2019 8:07:27 PM> Brand = samsung 12/2/2019 8:07:27 PM> Manufacturer = samsung 12/2/2019 8:07:27 PM> Device = grandpplte 12/2/2019 8:07:27 PM> Model = SM-G532G 12/2/2019 8:07:27 PM> Phone platform = mt6737t 12/2/2019 8:07:27 PM> CPU Abi = armeabi-v7a 12/2/2019 8:07:27 PM> Mediatek platform = MT6737T 12/2/2019 8:07:27 PM> Android release = 6.0.1 12/2/2019 8:07:27 PM> Firmware version = MMB29T.G532GDXU1APJ7 12/2/2019 8:07:27 PM> Firmware date = Wed Oct 26 23:36:39 KST 2016 |
12-02-2019, 19:39 | #495 (permalink) |
Member: 13148 Status: Offline Thanks Meter: 2,948 | You need read forum sometime to know how to work with the program http://forum.gsmhosting.com/vbb/f672.../#post13889604 |
