07-18-2018, 19:01 | #376 (permalink) |
No Life Poster Join Date: Apr 2013 Location: morocco Age: 36
Member: 1917054 Status: Offline Thanks Meter: 268 | PLZ urgent j2 prime g532g Setting frequence to 21 Mhz CMD Pullup Level: 2866 mV CMD Active Level: 3217 mV EMMC Device Information : EMMC CID: 90014A4838473475920109D9A53F74C6 EMMC CSD: D02701320F5903FFFFFFFFE78A40002A EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4u , HEX: 483847347500 , S/N: 09D9A53F , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 7/2017 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: H8G4u_09D9A53F_20180718_175811.extcsd EMMC Init completed. |
07-18-2018, 19:06 | #377 (permalink) |
Member: 1917054 Status: Offline Thanks Meter: 268 | Operation: Write by vendor (MediaTek) Partition name: PRELOADER Filename: preloader.bin , Offset: 000000000000 , filesize: 4194304 bytes eMMC switching to ROM2 Erasing partition... Writing partition... Done writing partition. Write speed: 322.76 KB/s Partition name: lk Filename: lk.bin , Offset: 000001000000 , filesize: 2097152 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 333.88 KB/s Partition name: efuse Filename: efuse.bin , Offset: 000001B80000 , filesize: 524288 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 333.20 KB/s Partition name: tee1 Filename: tee1.bin , Offset: 000001C00000 , filesize: 6291456 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Error writing at address: 000001C00000 , error: -8, DATA SND CRC Error ... Retry #1 Error writing at address: 000001C00000 , error: -1, CMD Timeout Error ... Retry #2 Error writing at address: 000001C00000 , error: -1, CMD Timeout Error ... Retry #3 Done writing partition. Write speed: 315.96 KB/s Partition name: param Filename: param.bin , Offset: 000005000000 , filesize: 8388608 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 252.12 KB/s Writing DL_Info... Writing DL_Info done Writing BootConfig ... Reg: 179 Value: 0x48 Reg: 177 Value: 0x00 Reg: 162 Value: 0x01 Done All done time: [00:01:48:629] |
07-19-2018, 08:33 | #379 (permalink) |
Freak Poster Join Date: Mar 2011 Location: India
Member: 1536185 Status: Offline Sonork: 100.167.1876 Thanks Meter: 64 | g532f dead boot repair error i need to repair g532f dead boot but this error comes im new to easy jtag what is the problem please help me |
07-31-2018, 06:05 | #383 (permalink) |
Freak Poster Join Date: May 2008
Member: 775567 Status: Offline Sonork: tybsky Thanks Meter: 59 | g532f bl file wire successfully set not on help Operation: Write by vendor (Samsung) Creating GPT-partitioninig Writing PrimaryGPT at address: 000000000000 Writing BackupGPT at address: 0001D1FFBE00 Writing PIT at address: 000000004400 GPT-partitioning done Unpacking file: lk.bin Unpacking file: efuse.img Unpacking file: trustzone.bin Unpacking file: param.bin Partition name: LK Filename: lk.bin , Offset: 000001000000 , filesize: 590336 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 429.79 KB/s Partition name: EFUSE Filename: efuse.img , Offset: 000001B80000 , filesize: 768 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 90.26 KB/s Partition name: TEE1 Filename: trustzone.bin , Offset: 000001C00000 , filesize: 324352 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 639.62 KB/s Partition name: PARAM Filename: param.bin , Offset: 000005000000 , filesize: 747520 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 658.59 KB/s Check BOOT_PARTITION_EN for the selected vendor All done time: [00:00:09:614] |
07-31-2018, 13:38 | #384 (permalink) |
No Life Poster Join Date: Oct 2009 Location: Rajasthan INDIA
Member: 1147254 Status: Offline Sonork: 100.1620677 Thanks Meter: 639 | Try This: http://forum.gsmhosting.com/vbb/12976607-post16.html After Write Please Give Report Here ( With LOG & Screen Shot ) If Problem Not Solve I Will Give Other Solution Thanks & Regards By: All TECH 4 You |
The Following User Says Thank You to Yashbanswara For This Useful Post: |
08-01-2018, 19:12 | #385 (permalink) | |
Product Supporter Join Date: Oct 2010 Location: DHAKA Mobile
Member: 1417131 Status: Offline Sonork: Uninstalled Thanks Meter: 1,090 | Where preloder on this bl Need preloder because its mtk bass Phone Or one more thing, Flash all time without preloder on this model Will not dead Quote:
The Following User Says Thank You to farukpdm For This Useful Post: |
08-02-2018, 10:06 | #387 (permalink) |
Member: 775567 Status: Offline Sonork: tybsky Thanks Meter: 59 | Setting frequence to 14 Mhz CMD Pullup Level: 2217 mV CMD Active Level: 2444 mV EMMC Device Information : EMMC CID: 90014A483847347592011196604DA4E6 EMMC CSD: D02701320F5903FFFFFFFFE78A40002A EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4u , HEX: 483847347500 , S/N: 1196604D , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 10/2017 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: H8G4u_1196604D_20180802_015905.extcsd EMMC Init completed. Setting frequence to 14 Mhz CMD Pullup Level: 2423 mV CMD Active Level: 2598 mV EMMC Device Information : EMMC CID: 90014A483847347592011196604DA4E6 EMMC CSD: D02701320F5903FFFFFFFFE78A40002A EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4u , HEX: 483847347500 , S/N: 1196604D , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 10/2017 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: H8G4u_1196604D_20180802_015911.extcsd EMMC Init completed. Opening file: H8G4u_samsung.pit Pit: H8G4u_samsung.pit Entry count: 31 The size of the last section has been updated Setting frequence to 14 Mhz CMD Pullup Level: 2423 mV CMD Active Level: 2588 mV EMMC Device Information : EMMC CID: 90014A483847347592011196604DA4E6 EMMC CSD: D02701320F5903FFFFFFFFE78A40002A EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4u , HEX: 483847347500 , S/N: 1196604D , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 10/2017 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: H8G4u_1196604D_20180802_015917.extcsd EMMC Init completed. Operation: Write by vendor (Samsung) Creating GPT-partitioninig Writing PrimaryGPT at address: 000000000000 Writing BackupGPT at address: 0001D1FFBE00 Writing PIT at address: 000000004400 GPT-partitioning done Partition name: LK Filename: lk.bin , Offset: 000001000000 , filesize: 2097152 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 598.84 KB/s Partition name: EFUSE Filename: efuse.bin , Offset: 000001B80000 , filesize: 524288 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 683.98 KB/s Partition name: TEE1 Filename: tee1.bin , Offset: 000001C00000 , filesize: 6291456 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 752.23 KB/s Partition name: PARAM Filename: PARAM.bin , Offset: 000005000000 , filesize: 8388608 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 738.05 KB/s Writing BootConfig ... Reg: 179 Value: 0x48 Reg: 177 Value: 0x00 Reg: 162 Value: 0x01 Done All done time: [00:00:30:916] Setting frequence to 14 Mhz CMD Pullup Level: 2402 mV CMD Active Level: 2578 mV EMMC Device Information : EMMC CID: 90014A483847347592011196604DA4E6 EMMC CSD: D02701320F5903FFFFFFFFE78A40002A EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4u , HEX: 483847347500 , S/N: 1196604D , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 10/2017 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: H8G4u_1196604D_20180802_020422.extcsd EMMC Init completed. but still dead |
08-02-2018, 10:17 | #388 (permalink) |
No Life Poster Join Date: Jan 2015 Location: Narsingdi, Dhaka, Bangladesh Age: 28
Member: 2325851 Status: Offline Sonork: 100.1680491 Thanks Meter: 2,363 | Last edited by pintu_das; 08-02-2018 at 10:26. |
The Following 2 Users Say Thank You to pintu_das For This Useful Post: |
08-02-2018, 16:36 | #390 (permalink) |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | http://forum.gsmhosting.com/vbb/f672...ixing-2444381/ use 1.5.0 to write BL, or use bin files from support (z3x shell) |
The Following User Says Thank You to layder For This Useful Post: |
