02-01-2019, 18:29 | #31 (permalink) | |
Junior Member Join Date: Jan 2012
Member: 1713721 Status: Offline Thanks Meter: 8 | Quote:
Astro 320 Hwid:1339 Regions Found: 10 Region Offset Size ------ ------ ---- (0x2b) 43, 0x00000000, 0x00010000 X-Loader (0x05) 5, 0x00010000, 0x00040000 U-Boot (0x10) 16, 0x00050000, 0x00100000 Logo (0x22) 34, 0x00150000, 0x00020000 (0x29) 41, 0x00170000, 0x00440000 NV (non-vol memory region) (0x5b) 91, 0x005b0000, 0x000c0000 (0x2d) 45, 0x00670000, 0x00020000 (0x0e) 14, 0x00690000, 0x00900000 Firmware (0x53) 83, 0x02300000, 0x00000000 Filesystem (Fat32) (0x30) 48, 0x02300000, 0x00000000 Filesystem (Fat32) Virtual? The most important regions are the first two and the NV. If these regions are corrupt you can not turn on the GPS, nor update it. Make a backup of the emmc memory and maybe I can confirm this. Some gps models have the important regions in a Nand memory and the filesystem in the emmc, but they are few cases, such as the Etrex20 / 30. You can also post a photo of the pcb board and so we can see if there is any memory nand or just emmc. If it is the case that only one emmc takes, the problem could be that emmc is damaged, but you could replace it with another equal or larger, with a backup of another that works (same gps model). Unfortunately the creators of easyjtag do not give much support to Garmin GPS, it's a shame, because there is a lot of information to do it. A greeting. Last edited by haute; 02-01-2019 at 18:37. | |
02-03-2019, 11:58 | #32 (permalink) |
Member: 1713721 Status: Offline Thanks Meter: 8 | These are the emmc regions of the Garmin Nuvi 2x5W, it is the model known emmc pins, in the easy-jtag database. Nuvi2x5W Hwid:827/851/932 Regions Found: 11 Region Offset Size ------ ------ ---- (0x2b) 43, 0x00000000, 0x00020000 X-Loader (0x05) 5, 0x00020000, 0x00040000 U-Boot (0x10) 16, 0x00060000, 0x00080000 Logo (0x22) 34, 0x000e0000, 0x00020000 (0x29) 41, 0x00100000, 0x00400000 NV (non-vol memory region) (0x2d) 45, 0x00500000, 0x00020000 (0x0e) 14, 0x00520000, 0x00880000 Firmware (0x56) 86, 0x00da0000, 0x00080000 (0x5b) 91, 0x00e20000, 0x00080000 (0x0f) 15, 0x00ea0000, 0x00560000 (0x30) 48, 0x01400000, 0x00000000 Filesystem (Fat32) |
02-24-2019, 11:31 | #33 (permalink) |
Freak Poster Join Date: Jan 2004 Location: Romania Age: 55
Member: 50585 Status: Offline Thanks Meter: 63 | TomTom VIA Pinout ISP Setting interface to EasyJtag2/ISP Setting bus width to 4 Bit Setting frequence to 24 Mhz CMD Pullup Level: 2808 mV CMD Active Level: 2795 mV EMMC Device Information : EMMC CID: 1501004D344731454D109103989F6E6D EMMC CSD: 902601320F5903FFFFFF9FFF964040D1 EMMC Manufacture : SAMSUNG , EMMC NAME: M4G1EM , HEX: 4D344731454D , S/N: 9103989F , rev. 0x10 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 6/2011 EMMC ROM 1 (Main User Data) Capacity: 3816 MB (0000EE800000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 0 KB (000000000000) EMMC RPMB (Replay Protected Memory Block) Capacity: 0 KB (000000000000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.3 (MMC 4.3) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x00 Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: M4G1EM_9103989F_20190224_093906.extcsd EMMC Init completed. Warning: BusWidth is automatically set to 1 Bit Get firmware version GPT header is not found |
02-24-2019, 14:53 | #35 (permalink) |
No Life Poster Join Date: Oct 2002 Location: tunisia
Member: 16625 Status: Offline Sonork: 1578753 Thanks Meter: 161 | Hi all, i am interested in gps. i have a garmin GPS 72 which is dead. is there any dump for it? how can i read its dump using jtag? this is its board : Nouveau document 2019-02-24 14.39.39_2.jpg Nouveau document 2019-02-24 14.39.39_1.jpg |
02-24-2019, 17:22 | #36 (permalink) | |
Member: 50585 Status: Offline Thanks Meter: 63 | Quote:
https://mega.nz/fm/BPpAGSzJ | |
