02-09-2014, 17:46 | #17 (permalink) | |
No Life Poster Join Date: Apr 2012 Location: bahrain.
Member: 1742913 Status: Offline Sonork: 100.1604070 Thanks Meter: 328 | Quote:
but i try to more than 20 phones(no product name) did not detected eazy jtag software, its getting error eMMC Card initialisation error but product name showing phones are connected, i can write rom1,rom2 file so hw u connect no product name phone? pinouts any change? did u have any special formate? can u explain,,, | |
02-09-2014, 20:21 | #18 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: Motalib Plaza,Dhaka,Bangladesh Age: 39
Member: 485407 Status: Offline Sonork: 100.1580486 Thanks Meter: 183 | Quote:
02-09-2014, 21:49 | #19 (permalink) | |
No Life Poster Join Date: Sep 2007 Location: PAKISTAN
Member: 585807 Status: Offline Thanks Meter: 781 | Quote:
bro. use latest exe 1.0.101 and same pinout must connect emmc if not connect than you must replaced emmc. thanksssssssssss z3x team | |
02-09-2014, 22:21 | #20 (permalink) | |
and u did 2 phones, how? i didnt see any post before any sucsess report with out change emmc.(i mean no product name). only u did amazing... im waiting z3x blank product name real solution. hope they will(blang) do for users | |
02-10-2014, 00:04 | #21 (permalink) |
Moderator Join Date: Jan 2008 Location: <jeddah al saudia> Age: 36
Member: 668050 Status: Offline Sonork: 100.1656307 Thanks Meter: 991 | i repair mor than 10 phone via dead boot they are all no have product name,,, butt every think is working fine and customers are using phones,,,,is there any problem |
02-10-2014, 11:14 | #22 (permalink) | |
there is not have product name, its right. but u can see in download mode- PRODUCT NAME: CUSTOM DOWNLAOD BINARY:2564566545. this type of phone we can alive back.no need eazy jtag,no need gpg emmc box... only needed 1mmc card, and 1usb jig, need pit file and offical firmware. but my qustion is we can repire, product name null and custom binnary downlod no phones?(with out change emmc) | |
The Following User Says Thank You to android unbrik For This Useful Post: |
02-10-2014, 14:07 | #23 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,557 | Quote:
if after rom2 writing no any changes, then problem with emmc. you can try Format emmc. after format emmc goto factory status and need repair exscd. after repair excsd need flash again rom1 and rom2. and then flash via odin. if something wrong while this steps - then unknown problem with emmc and cant be fixed. From my test and report of users: 70% of problems with DIRECT EMMC read/write - long wires, GND wire bad, voltage not stable or not right, bad soldering. Remember connect direct emmc is more complicated than JTAG connect. | |
The Following 6 Users Say Thank You to blang For This Useful Post: |
02-10-2014, 15:28 | #24 (permalink) |
Member: 585807 Status: Offline Thanks Meter: 781 | one more ok i9300 logs <br>Successfully connected to box on COM4<b> Box S/N: ***********, ,FW Ver.: 01.48 Loading eMMC Addon Firmware... CMD Pullup Level:1206 mV CMD Active Level:1629 mV EMMC CID 15010056545530304DFC202B111A5007 EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 05/1997 FW rev.0xfc EMMC NAME: <b>VTU00M</b> , S/N: 539693338 EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Backup saved: VTU00M_ 539693338_20140106_1006.extcsd Done. Running:SAMSUNG: Smart Factory Reset + Format... <br>Successfully connected to box on COM4<b> Box S/N: 1717160DCD0D8A9F, ,FW Ver.: 01.48 Loading eMMC Addon Firmware... CMD Pullup Level:1227 mV CMD Active Level:1629 mV EMMC CID 15010056545530304DFC202B111A5007 EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 05/1997 FW rev.0xfc EMMC NAME: <b>VTU00M</b> , S/N: 539693338 EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Backup saved: VTU00M_ 539693338_20140106_1006.extcsd Sending Smart Wipe Request... Wiping Card... Please do not touch it!!! Done. <font color="red">Please don't forget to repair extCSD from backup!!!</font> Running:Repair extCSD... <br>Successfully connected to box on COM4<b> Box S/N: 1717160DCD0D8A9F, ,FW Ver.: 01.48 Loading eMMC Addon Firmware... <font color="red">Warning: CMD Pullup Level (1185 mV) too low , check cables etc.!!!</font> CMD Active Level:1629 mV EMMC CID 15010056545530304DFC202B111A5007 EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 05/1997 FW rev.0xfc EMMC NAME: <b>VTU00M</b> , S/N: 539693338 EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Writing... eMMC ACK Error !!! eMMC ACK Error !!! eMMC ACK Error !!! Done! <br>Successfully connected to box on COM4<b> Box S/N: 1717160DCD0D8A9F, ,FW Ver.: 01.48 Loading eMMC Addon Firmware... CMD Pullup Level:1216 mV CMD Active Level:1619 mV EMMC CID 15010056545530304DFC202B111A5007 EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 05/1997 FW rev.0xfc EMMC NAME: <b>VTU00M</b> , S/N: 539693338 EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Writing 000000200000 bytes to 00000000 ...ROM2 Write Speed: 222 kB/s Done !!! <br>Successfully connected to box on COM4<b> Box S/N: 1717160DCD0D8A9F, ,FW Ver.: 01.48 Loading eMMC Addon Firmware... CMD Pullup Level:1216 mV CMD Active Level:1619 mV EMMC CID 15010056545530304DFC202B111A5007 EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 05/1997 FW rev.0xfc EMMC NAME: <b>VTU00M</b> , S/N: 539693338 EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Writing 000020000000 bytes to 00000000 ...ROM1 Retry writing adress 0x00009040 Done !!! |
02-10-2014, 16:48 | #25 (permalink) | |
ur previous log and this log and too difrent. this phone alive? | |
02-11-2014, 01:56 | #27 (permalink) |
Freak Poster Join Date: Feb 2013 Location: Rio de Janeiro/Brazil
Member: 1880722 Status: Offline Thanks Meter: 61 | I am interested in buying this box this week, for I am with a client without a i9300 product name. tried several rom via Odin and PIT files. not resolved still see many with repair log informing successful and others not is already possible to say that we have a viable solution for big chance repair successfully? |
02-11-2014, 07:59 | #28 (permalink) |
Freak Poster Join Date: Feb 2005 Location: muscat oman Age: 50
Member: 112404 Status: Offline Thanks Meter: 21 | EasyJtag Suite ver.: 1.0.101.0 started. Operating system ver.: Windows 7 (build 7601, Service Pack 1). Successefuly connected to box on COM12 Box S/N: 0F0F0E07FDCE3B1B, ,FW Ver.: 01.48 Box Working Mode: JTAG Box. Box Drivers version: 3.0.0.0, are OK Z3X Card Serial : AA00-5DBD , ver: 22 Successfully connected to box on COM12 Box S/N: 0F0F0E07FDCE3B1B, ,FW Ver.: 01.48 Loading eMMC Addon Firmware... CMD Pullup Level:1340 mV CMD Active Level:1907 mV EMMC CID 15010056545530304DF1A10056F2AF15 EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 10/2012 FW rev.0xf1 EMMC NAME: VTU00M , S/N: 2701154034 EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Backup saved: VTU00M_2701154034_20140102_1015.extcsd Done. Running:SAMSUNG: Smart Factory Reset + Format... Successfully connected to box on COM12 Box S/N: 0F0F0E07FDCE3B1B, ,FW Ver.: 01.48 Loading eMMC Addon Firmware... CMD Pullup Level:1330 mV CMD Active Level:1907 mV EMMC CID 15010056545530304DF1A10056F2AF15 EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 10/2012 FW rev.0xf1 EMMC NAME: VTU00M , S/N: 2701154034 EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Backup saved: VTU00M_2701154034_20140102_1015.extcsd Sending Smart Wipe Request... Wiping Card... Please do not touch it!!! Done. Please don't forget to repair extCSD from backup!!! Running:SAMSUNG: MoviNAND Format... Successfully connected to box on COM12 Box S/N: 0F0F0E07FDCE3B1B, ,FW Ver.: 01.48 Loading eMMC Addon Firmware... CMD Pullup Level:1330 mV CMD Active Level:1887 mV EMMC CID 15010056545530304DF1A10056F2AF15 EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 10/2012 FW rev.0xf1 EMMC NAME: VTU00M , S/N: 2701154034 EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Backup saved: VTU00M_2701154034_20140102_1015.extcsd Sending Internal Reconfiguration Request... Waiting configuration Apply!!! Restoring configuration... EMMC ROM2/3 (Boot Partitions) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Wiping Card... Please do not touch it!!! Done. Please don't forget to repair extCSD from backup!!! extCSD file...C:\Program Files\Z3X\EASYJTAG\Backups\VTU00M_ 752822457_20140101_1100.extcsd Running:Repair extCSD... Successfully connected to box on COM12 Box S/N: 0F0F0E07FDCE3B1B, ,FW Ver.: 01.48 Loading eMMC Addon Firmware... CMD Pullup Level:1330 mV CMD Active Level:1887 mV EMMC CID 15010056545530304DF1A10056F2AF15 EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 10/2012 FW rev.0xf1 EMMC NAME: VTU00M , S/N: 2701154034 EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Writing... eMMC ACK Error !!! eMMC ACK Error !!! eMMC ACK Error !!! Done! Writing file...D:\easy jtag\n7100\N7100_Rom2_Alive_Boot_BN.bin Successfully connected to box on COM12 Box S/N: 0F0F0E07FDCE3B1B, ,FW Ver.: 01.48 Loading eMMC Addon Firmware... CMD Pullup Level:1320 mV CMD Active Level:1907 mV EMMC CID 15010056545530304DF1A10056F2AF15 EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 10/2012 FW rev.0xf1 EMMC NAME: VTU00M , S/N: 2701154034 EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Writing 000000100000 bytes to 00000000 ...ROM2 Write Speed: 217 kB/s Done !!! Writing file...D:\easy jtag\n7100\N7100_Rom1_Alive_Dump_BN.bin Successfully connected to box on COM12 Box S/N: 0F0F0E07FDCE3B1B, ,FW Ver.: 01.48 Loading eMMC Addon Firmware... CMD Pullup Level:1320 mV CMD Active Level:1887 mV EMMC CID 15010056545530304DF1A10056F2AF15 EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 10/2012 FW rev.0xf1 EMMC NAME: VTU00M , S/N: 2701154034 EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Writing 000020000000 bytes to 00000000 ...ROM1 Write Speed: 301 kB/s Done !!! n7100 everything done but phone dead |
02-11-2014, 18:58 | #29 (permalink) |
No Life Poster Join Date: Mar 2007 Location: on moon right now !
Member: 469192 Status: Offline Thanks Meter: 48 | i think for i9300 no product name cant be solve until now bcz i have tried many many times and show like this with different phones i have 3 phones without product name Successfully connected to box on COM85 Box S/N: 0800300C6DB1E596, ,FW Ver.: 01.48 Loading eMMC Addon Firmware... CMD Pullup Level:1216 mV CMD Active Level:1660 mV Can't Init EMMC !!! ( Ready Condition TIMEOUT! ) Warning: Error purging CDC device: 0 but for dead phone and repair boot its check ok and i can repair phone ok also so why when phone without product name cant be detect and other (for dead boot ) its detected ok i m 100% sure about wires and connection to the pcb |
The Following User Says Thank You to alialjorany For This Useful Post: |
02-11-2014, 19:19 | #30 (permalink) |
Freak Poster Join Date: Apr 2004 Location: Mumbai, kuwait, UAE
Member: 63065 Status: Offline Sonork: 100.102547 Thanks Meter: 24 | Loading eMMC Addon Firmware... CMD Pullup Level:1443 mV CMD Active Level:1773 mV Can't Init EMMC !!! ( Ready Condition TIMEOUT! ) eMMC Card initialisation error! Same error on several phones. BR, |
