Old 02-09-2014, 14:39   #16 (permalink)
drjaved_akhter's Avatar
Member: 585807
Thanks Meter: 781
Originally Posted by moh_boulk17 View Post
this problem slove 100%?? Be i think this problem HW
no product not hardware .it is software problem .Emmc corrupt and now we format emmc with great software easy jtag emmc direct .
The Following 4 Users Say Thank You to drjaved_akhter For This Useful Post:
Old 02-09-2014, 17:46   #17 (permalink)
Member: 1742913
Sonork: 100.1604070
Thanks Meter: 328
br,
but i try to more than 20 phones(no product name) did not detected eazy jtag software, its getting error eMMC Card initialisation error
but product name showing phones are connected, i can write rom1,rom2 file
so hw u connect no product name phone? pinouts any change? did u have any special formate? can u explain,,,
Old 02-09-2014, 20:21   #18 (permalink)
raselopu's Avatar
Member: 485407
Sonork: 100.1580486
Thanks Meter: 183
Originally Posted by android unbrik View Post
br,
Yes. Same question here to drjaved akhter & one more thing that these solved phones have original emmc or replaced?
Old 02-09-2014, 21:49   #19 (permalink)
Member: 585807
Thanks Meter: 781
br,
bro.
use latest exe 1.0.101 and same pinout must connect emmc if not connect than you must replaced emmc.
thanksssssssssss z3x team
Old 02-09-2014, 22:21   #20 (permalink)
Member: 1742913
Sonork: 100.1604070
Thanks Meter: 328
bro.
br, al ready im using, latest software. i try 2day also 3phones(no product name) did not connect. alwayes gettin eMMC Card initialisation error!
and u did 2 phones, how? i didnt see any post before any sucsess report with out change emmc.(i mean no product name). only u did amazing...
im waiting z3x blank product name real solution. hope they will(blang) do for users
Old 02-10-2014, 00:04   #21 (permalink)
Moderator
chand_gee's Avatar
Member: 668050
Sonork: 100.1656307
Thanks Meter: 991
i repair mor than 10 phone via dead boot they are all no have product name,,,
butt every think is working fine and customers are using phones,,,,is there any problem
Old 02-10-2014, 11:14   #22 (permalink)
Member: 1742913
Sonork: 100.1604070
Thanks Meter: 328
br, i think u did only deadboot repire,
there is not have product name, its right. but u can see in download mode-
PRODUCT NAME:
CUSTOM DOWNLAOD BINARY:2564566545.
this type of phone we can alive back.no need eazy jtag,no need gpg emmc box... only needed 1mmc card, and 1usb jig, need pit file and offical firmware.
but my qustion is we can repire, product name null and custom binnary downlod no phones?(with out change emmc)
The Following User Says Thank You to android unbrik For This Useful Post:
Old 02-10-2014, 14:07   #23 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Thanks Meter: 186,557
PRODUCT NAME:
for repair empty product code 1st. need try write rom2. product code there.
if after rom2 writing no any changes, then problem with emmc.
you can try Format emmc.
after format emmc goto factory status and need repair exscd.
after repair excsd need flash again rom1 and rom2.
and then flash via odin.
if something wrong while this steps - then unknown problem with emmc and cant be fixed.
From my test and report of users: 70% of problems with DIRECT EMMC read/write - long wires, GND wire bad, voltage not stable or not right, bad soldering. Remember connect direct emmc is more complicated than JTAG connect.
The Following 6 Users Say Thank You to blang For This Useful Post:
Old 02-10-2014, 15:28   #24 (permalink)
Member: 585807
Thanks Meter: 781
one more ok i9300
logs
<br>Successfully connected to box on COM4<b>
Box S/N: ***********, ,FW Ver.: 01.48
Loading eMMC Addon Firmware...
CMD Pullup Level:1206 mV
CMD Active Level:1629 mV
EMMC CID 15010056545530304DFC202B111A5007
EMMC CSD D02701320F5903FFF6DBFFFF8E40406D
EMMC Manufacturer ID: 0015 , OEM ID: 0100
EMMC Date: 05/1997 FW rev.0xfc
EMMC NAME: <b>VTU00M</b> , S/N: 539693338
EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card)
EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB
EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB
Extended CSD rev 1.6 (MMC 4.5)
Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1)
Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48.
Backup saved: VTU00M_ 539693338_20140106_1006.extcsd
Done.
Running:SAMSUNG: Smart Factory Reset + Format...
Box S/N: 1717160DCD0D8A9F, ,FW Ver.: 01.48
CMD Pullup Level:1227 mV
Sending Smart Wipe Request...
Wiping Card... Please do not touch it!!!
Done.
<font color="red">Please don't forget to repair extCSD from backup!!!</font>
Running:Repair extCSD...
<font color="red">Warning: CMD Pullup Level (1185 mV) too low , check cables etc.!!!</font>
Writing...
eMMC ACK Error !!!
eMMC ACK Error !!!
eMMC ACK Error !!!
Done!
CMD Pullup Level:1216 mV
CMD Active Level:1619 mV
Writing 000000200000 bytes to 00000000 ...ROM2
Write Speed: 222 kB/s
Done !!!
Writing 000020000000 bytes to 00000000 ...ROM1
Retry writing adress 0x00009040
Done !!!
Old 02-10-2014, 16:48   #25 (permalink)
Member: 1742913
Sonork: 100.1604070
Thanks Meter: 328
one more ok i9300
logs
Done.
Done.
Writing...
eMMC ACK Error !!!
eMMC ACK Error !!!
eMMC ACK Error !!!
Done!
Done !!!
Done !!!
ur previous log and this log and too difrent. this phone alive?
Old 02-10-2014, 20:19   #26 (permalink)
Member: 585807
Thanks Meter: 781
yes and take customer brother
The Following User Says Thank You to drjaved_akhter For This Useful Post:
Old 02-11-2014, 01:56   #27 (permalink)
SR°LORŪ's Avatar
Member: 1880722
Thanks Meter: 61
I am interested in buying this box this week, for I am with a client without a i9300 product name.
tried several rom via Odin and PIT files. not resolved still see many with repair log informing successful and others not is already possible to say that we have a viable solution for big chance
repair successfully?
Old 02-11-2014, 07:59   #28 (permalink)
qpraba's Avatar
Member: 112404
Thanks Meter: 21
EasyJtag Suite ver.: 1.0.101.0 started.
Operating system ver.: Windows 7 (build 7601, Service Pack 1).
Successefuly connected to box on COM12
Box S/N: 0F0F0E07FDCE3B1B, ,FW Ver.: 01.48
Box Working Mode: JTAG Box.
Box Drivers version: 3.0.0.0, are OK
Z3X Card Serial : AA00-5DBD , ver: 22
Successfully connected to box on COM12
CMD Pullup Level:1340 mV
CMD Active Level:1907 mV
EMMC CID 15010056545530304DF1A10056F2AF15
EMMC Date: 10/2012 FW rev.0xf1
EMMC NAME: VTU00M , S/N: 2701154034
Backup saved: VTU00M_2701154034_20140102_1015.extcsd
Done.
CMD Pullup Level:1330 mV
Done.
Running:SAMSUNG: MoviNAND Format...
CMD Active Level:1887 mV
Sending Internal Reconfiguration Request...
Waiting configuration Apply!!!
Restoring configuration...
EMMC ROM2/3 (Boot Partitions) Capacity: 2048 kB
Done.
extCSD file...C:\Program Files\Z3X\EASYJTAG\Backups\VTU00M_ 752822457_20140101_1100.extcsd
Writing...
eMMC ACK Error !!!
eMMC ACK Error !!!
eMMC ACK Error !!!
Done!
Writing file...D:\easy jtag\n7100\N7100_Rom2_Alive_Boot_BN.bin
CMD Pullup Level:1320 mV
Writing 000000100000 bytes to 00000000 ...ROM2
Write Speed: 217 kB/s
Done !!!
Writing file...D:\easy jtag\n7100\N7100_Rom1_Alive_Dump_BN.bin
Write Speed: 301 kB/s
Done !!!
n7100 everything done but phone dead
Old 02-11-2014, 18:58   #29 (permalink)
alialjorany's Avatar
Member: 469192
Thanks Meter: 48
i think for i9300 no product name cant be solve until now
bcz
i have tried many many times and show like this with different phones i have 3 phones without product name
Successfully connected to box on COM85
Box S/N: 0800300C6DB1E596, ,FW Ver.: 01.48
CMD Active Level:1660 mV
Can't Init EMMC !!! ( Ready Condition TIMEOUT! )
Warning: Error purging CDC device: 0
but for dead phone and repair boot its check ok and i can repair phone ok also
so why when phone without product name cant be detect and other (for dead boot ) its detected ok
i m 100% sure about wires and connection to the pcb
The Following User Says Thank You to alialjorany For This Useful Post:
Old 02-11-2014, 19:19   #30 (permalink)
titanic's Avatar
Member: 63065
Sonork: 100.102547
Thanks Meter: 24
CMD Pullup Level:1443 mV
CMD Active Level:1773 mV
Same error on several phones.
BR,
Page generated in 0.33574 seconds with 10 queries
