Old 03-10-2014, 01:12   #31 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
Thanks Meter: 4,475
Originally Posted by Reza Gsm1 View Post
hi mr nuri
not needed to write extcsd form backup ?
Originally Posted by mike_shinoda View Post
yes bro no need write.
Hi
For Reset Warranty BIT to 0 for i9500,Only Need Write Rom2 From First Post
For Reset Warrant BIT to 0 for SM-N900,Need Format+Factory reset and Write extcsd+Rom2
But,Please Note,,,i did test in one phone,,,,(phone have a problem with reset on logo) but Warrant Bit still remain on 1 and didn't reset to 0
So,if any one want test ,Make sure you have own risk for damage SM-N900
I think Smasung changed plan for new exynos,it's not same as I9500
Old 03-10-2014, 02:33   #32 (permalink)
Member: 1886939
Sonork: 100.1650305
Thanks Meter: 78
I think the easiest way is root n install triangle away n just click in reset count flasher
Old 03-10-2014, 08:15   #33 (permalink)
Diamond Gsm's Avatar
Member: 2064519
Thanks Meter: 83
Originally Posted by BABAK NURI View Post
Hi
hi.
i do what you said and waranty bit 0 and i flash with any rom (1file & 4file) but phone was hang on logo. i reset and write EFS but not solved. i do again write I9500_Alive_Rom1_Main_BN but continue problem and phone jast hang on logo
this picture after write I9500_Alive_Rom1_Main_BN
befor write in recovery mode show efs, system.... with red description
can u help me sir ?
Old 03-10-2014, 13:08   #34 (permalink)
Member: 2064519
Thanks Meter: 83
solved ...................
The Following User Says Thank You to Diamond Gsm For This Useful Post:
Old 03-11-2014, 02:35   #35 (permalink)
jmr
Member: 614683
Sonork: 100.1605379
Thanks Meter: 370
can post how solved your problem
Old 03-11-2014, 14:51   #36 (permalink)
Member: 2064519
Thanks Meter: 83
what's your problem bro ???????
Old 03-15-2014, 23:59   #37 (permalink)
Member: 2148709
Can you explain how to do? Gt i 9500, rom 2, where i flash? i need to open the device?
I have warranty bit 1, i only need the confirmation or instruction to do.
thanks
Old 03-16-2014, 13:46   #38 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
Thanks Meter: 4,475
Braulio00
Yes,You Need Easy_JTAG Box,,,Need Open Phone,,,,Need Solder few Wires...Then You Can Reset Your WARRANTY BIT
The Following User Says Thank You to BABAK NURI For This Useful Post:
Old 03-17-2014, 13:06   #39 (permalink)
Member: 243979
hello sir, where can i get the solution for note 2, as i need to reset knox counter and give it to service center for some issue. please help me out as i was unable to find the thread for note to N7100
Old 04-09-2014, 02:01   #40 (permalink)
Member: 2149341
Thanks Meter: 31
I doo all this now my phone keep restarting at the first screen when i enter on download mode i see this RMPB :invalid rmpb data is there is any solution for this and thanks
Old 04-09-2014, 12:50   #41 (permalink)
Member: 1677480
hi.
i do all what u said mr nuri but my phone now is dead
i do write rom2, 3 and 1 again but not solved
if i format emmc then can i repair again and alive phone ?
pls help me
Old 04-09-2014, 13:05   #42 (permalink)
Member: 1677480
do agian to resize boot partition and RMPB
Old 04-22-2014, 09:14   #43 (permalink)
ozeracar's Avatar
Member: 32738
Thanks Meter: 32
Hi
I have phone with 4.2.2,,but need read dump
but ,what's a point for downgrade?
hi sir
i am from turkey
my country not accept super imei because check imei for all phones
if have same imei to 2 phones , network blocks for that phones.
so:
we have many i9500 efs corrupt.
i ask ? :
if i downgrade boot to 4.2.2 CAN I WRITE CUSTOM IMEI and repair network
Old 04-23-2014, 20:34   #44 (permalink)
Member: 2149341
Thanks Meter: 31
i resize the RBPM partition but the phone wont boot or enter into download mode i try the jig but still no download mode plz i need your help here
Old 04-25-2014, 01:47   #45 (permalink)
Member: 2149341
Thanks Meter: 31
I managed to enter into the download mode the warranty is set to 0 but the phone wont boot up and it wont to flash with odin always error pit i check and i found the resistor dat0 is brocken i wonder if is it the probleme or not please i need your help here its urgent
Page generated in 0.23622 seconds with 9 queries
