[GUIDE] How to find DIRECT EMMC PINOUT. Step by step with pictures. How to find DIRECT EMMC PINOUT. Attention! This way is not safe for working pcb. For pinout find need: Quote:
Now steps.: 1. Here pcb. for example we take GT-I9500 board. http://imageshack.us/a/img199/1019/s76.JPG 2. Multimeter. [IMG]http://4.bp.********.com/-GbDO8OqTJ8Y/UEyboG-xbUI/AAAAAAAAChY/HmedxGWOWbo/s1600/Multimeter.jpg[/IMG] 3. Here pcb with removed EMMC. http://imageshack.com/a/img20/1432/ms6j.jpg 4. Here pcb with market pins. Check position point before start job. http://imageshack.us/a/img29/705/0vll.jpg 5. Here default pinout of BGA169 emmc with position point and pinout. http://imageshack.com/a/img818/9664/57fj.jpg 6. Now using tester need test where go pins. http://imageshack.us/a/img59/5724/7v19.jpg LETS GO. Now you can connect to emmc. Check this FAQ - How connect EMMC DIRECT!!!! Lets collect in this thread tested emmc pinouts. Other type of EMMC: http://imageshack.com/a/img842/8197/0iad.jpg |
Please pinout JTAG Z3X gentlemen, you would be so kind to add pinotu of each of the models performed this fantastic box repair EMMC please thanks |
P1000 1 Attachment(s) |
give us the pin out diagrams with latest update thanks,,,.....d master,great team Z3X |
can u share i 9300 s3 and n7100 not2 pls |
1 Attachment(s) i9100 emmc pinout not tested yet. |
Mr. Blang from where can I got the files Main and boot for repair emmc? I need for S2 i9100, i8190, N7000, thx |
Samsung Note 2 N7100 EMMC Pinouts |
Lg ms770 1 Attachment(s) I am trying to read the eMMC chip on a LG MS770 phone that is in working order. The eMMC chip is a Toshiba THGBM4GGD2HBAIC 4GB chip. I traced back Vcc, Clk, Cmd, VccQ, and D0. However when I attempt to read the eMMC chip I get the following error: EasyJtag Suite ver.: 1.0.88.0 started. Operating system ver.: Windows 7 (build 7601, Service Pack 1), 64-bit edition. Successefuly connected to box on COM39 Box S/N: 16XXXX, ,FW Ver.: 01.47 Box Working Mode: JTAG Box. Box Drivers version: 3.0.0.0, are OK Z3X Card Serial : AA81-7A1C , ver: 22 Successefuly connected to box on COM39 Box S/N: 16XXXX, ,FW Ver.: 01.47 Loading eMMC Addon Firmware... CMD Pullup Level:1660 mV CMD Active Level:2155 mV eMMC ACK Error ( Check Connection ) eMMC Card initialisation error! I have rechecked my connections and reconfirmed my connection points on my test phone. See attached image for solder connections. Any suggestions? J2 |
how to fing pinouts in this pcb |
MS770 eMMC Pinout 1 Attachment(s) Mr. Blang, Feel free to add this pinout image to the Easy-JTAG LG MS-770 support files. Using the attached eMMC pinout, I was able to dump the Toshiba memory chip. I have included the log from Easy-JTAG to confirm the connection: Successefuly connected to box on COM39 Box S/N: 16XXX, ,FW Ver.: 01.47 Loading eMMC Addon Firmware... CMD Pullup Level:1949 mV CMD Active Level:2320 mV EMMC CID 11010030303847344200C794CBC68F6D EMMC CSD D00E00320F5903FFFFFFFFE79640001F EMMC Manufactorer ID: 11 EMMC OEM ID: 0100 EMMC Date: 08/2012 FW rev.0x0 HW rev.0x0 EMMC Serial #: 3348417478 EMMC NAME: 008G4B EMMC Capacity: 7456 MB (High Density Card) ============================================= Extended CSD rev 1.5 (MMC 4.41) ============================================= Card Supported Command sets [S_CMD_SET: 0x00] - Standard MMC command sets HPI Features [HPI_FEATURE: 0x01]: implementation based on CMD13 Background operations support [BKOPS_SUPPORT: 0x01] Background operations status [BKOPS_STATUS: 0x00] TRIM Multiplier [TRIM_MULT: 0x04] Secure Feature support [SEC_FEATURE_SUPPORT: 0x15] Secure Erase Multiplier [SEC_ERASE_MULT: 0x10] Secure TRIM Multiplier [SEC_TRIM_MULT: 0x42] Boot Information [BOOT_INFO: 0x07] Device supports alternative boot method Device supports dual data rate during boot Device supports high speed timing during boot Boot partition size [BOOT_SIZE_MULTI: 0x10] Access size [ACC_SIZE: 0x07] High-capacity erase unit size [HC_ERASE_GRP_SIZE: 0x08] High-capacity erase timeout [ERASE_TIMEOUT_MULT: 0x02] Reliable write sector count [REL_WR_SEC_C: 0x10] High-capacity W protect group size [HC_WP_GRP_SIZE: 0x01] Sleep current (VCC) [S_C_VCC: 0x07] Sleep current (VCCQ) [S_C_VCCQ: 0x09] Sleep/awake timeout [S_A_TIMEOUT: 0x11] Sector Count [SEC_COUNT: 0x00e90000] Partition switching timing [PARTITION_SWITCH_TIME: 0x01] Out-of-interrupt busy timing [OUT_OF_INTERRUPT_TIME: 0x05] Card Type [CARD_TYPE: 0x07] CSD structure version [CSD_STRUCTURE: 0x02] Command set [CMD_SET: 0x00] Command set revision [CMD_SET_REV: 0x00] Power class [POWER_CLASS: 0x00] High-speed interface timing [HS_TIMING: 0x00] Erased memory content [ERASED_MEM_CONT: 0x01] Boot configuration bytes [PARTITION_CONFIG: 0x00] Not boot enable No access to boot partition Boot config protection [BOOT_CONFIG_PROT: 0x00] Boot bus Conditions [BOOT_BUS_CONDITIONS: 0x00] High-density erase group definition [ERASE_GROUP_DEF: 0x00] ============================================= Boot write protection status registers [BOOT_WP_STATUS]: 0x00 Boot Area Write protection [BOOT_WP]: 0x00 Power ReadOnly locking: possible Permanent ReadOnly locking: possible Read Only lock status: not locked ============================================= User area write protection register [USER_WP]: 0x00 FW configuration [FW_CONFIG]: 0x00 RPMB Size [RPMB_SIZE_MULT]: 0x02 Write reliability setting register [WR_REL_SET]: 0x00 Write reliability parameter register [WR_REL_PARAM]: 0x05 Enable background operations handshake [BKOPS_EN]: 0x00 H/W reset function [RST_N_FUNCTION]: 0x00 HPI management [HPI_MGMT]: 0x00 Partitioning Support [PARTITIONING_SUPPORT]: 0x03 Device support partitioning feature Device can have enhanced tech. Max Enhanced Area Size [MAX_ENH_SIZE_MULT]: 0x0003b4 Partitions attribute [PARTITIONS_ATTRIBUTE]: 0x00 Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 General Purpose Partition Size [GP_SIZE_MULT_4]: 0x000000 [GP_SIZE_MULT_3]: 0x000000 [GP_SIZE_MULT_2]: 0x000000 [GP_SIZE_MULT_1]: 0x000000 Enhanced User Data Area Size [ENH_SIZE_MULT]: 0x000000 Enhanced User Data Start Address [ENH_START_ADDR]: 0x000000 Bad Block Management mode [SEC_BAD_BLK_MGMNT]: 0x00 |
I think the main problem is to find out the datasheet of the used eMMC in a particular mobile. Is there anywhere an eMMC datasheet of eMMC chips where i can see which eMMC pin is VCC,VCCQ,D0,CLK ... .? |
I Need Pinout Emmc S2 HD SHV-E120L Plz Help Me , Thanks Mr Blang !!! |
Mr blang. I am representing for all of us in the USA. please give more support for English in the United States and more pictures of pin outs. I need the pin out for the direct eMMC connection for a GS III L710 |
