05-02-2023, 17:34 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Pakistan Age: 45
Member: 383211 Status: Offline Thanks Meter: 131 | f11 auto mtk port.any solution Microsoft Windows 10 (64 bit) build 19042 (10.0.19041.329) Looking for EasyJTAG box... EasyJTAG API ver. 3403 EasyJTAG Box Serial = 2B82710456C6FC4A Card Serial = AA9FD6F4 EasyJTAG Box Firmware = 2.5302 Changelog: 05/05/2021 (ver 1.6.6.0) Add: New keys for Oppo unpack Fix: Bugs that have been found through your crash report 05.05.2021 (ver 2.0.1.0) Add: Vendor LG Add: Mediatek Preloader Parser Add: OnePlus Unpacker Add: Xiaomi Custom EDL Authorization Add: Xiaomi Remove Mi Account (only Qualcomm) Operation: Connect to Z3X EasyJtagPlus Setting Interface to EasyJtag2/ISP Setting IO Levels to 1.8V Setting Frequence to 9 Mhz Setting BusWidth to 1 Bit CMD Pullup Level: 1832 mV CMD Active Level: 1883 mV Setting HS Timing to Enabled Can't init device. Error: -1. Reason: CMD Timeout Error Operation: Connect to Z3X EasyJtagPlus Setting Interface to EasyJtag2/ISP Setting Frequence to 9 Mhz Setting BusWidth to 1 Bit CMD Pullup Level: 2127 mV CMD Active Level: 2285 mV Setting HS Timing to Enabled Can't init device. Error: -1. Reason: CMD Timeout Error Operation: Connect to Z3X EasyJtagPlus Setting Interface to EasyJtag2/ISP Setting Frequence to 12 Mhz Setting BusWidth to 1 Bit CMD Pullup Level: 2128 mV CMD Active Level: 2286 mV Setting HS Timing to Enabled Can't init device. Error: -1. Reason: CMD Timeout Error Operation: Connect to Z3X EasyJtagPlus Setting Interface to EasyJtag2/ISP Setting Frequence to 12 Mhz Setting BusWidth to 1 Bit CMD Pullup Level: 2128 mV CMD Active Level: 2286 mV Setting HS Timing to Enabled Can't init device. Error: -1. Reason: CMD Timeout Error Operation: Connect to Z3X EasyJtagPlus Setting Interface to EasyJtag2/ISP Setting Frequence to 9 Mhz Setting BusWidth to 1 Bit CMD Pullup Level: 2130 mV CMD Active Level: 2285 mV Setting HS Timing to Enabled Can't init device. Error: -1. Reason: CMD Timeout Error Operation: Connect to Z3X EasyJtagPlus Setting Interface to EasyJtag2/ISP Setting Frequence to 9 Mhz Setting BusWidth to 1 Bit CMD Pullup Level: 2130 mV CMD Active Level: 2290 mV Setting HS Timing to Enabled EMMC Device Information : EMMC CID: 90014A68433861503E034833A2C81605 EMMC CSD: D02700328F5903FFFFFFFFEF8E400043 Manufacturer: SKHYNIX , NAME: hC8aP> , HEX: 68433861503E , S/N: 4833A2C8 , Rev: 03 Manufacturer ID: 90 , OEM ID: 4A , Device Type: BGA (Discrete embedded) , Date: 1/2019 EMMC ROM 1 (Main User Data) Capacity: 59640 MB (0x000E8F800000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (0x000000400000) EMMC RPMB Capacity: 16384 KB (0x000001000000) , Counter: 10460 , Response: Not Clean Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot partition 1 enabled for boot , Boot ACK Boot Bus Config: 0x02 , x8 (sdr/ddr) bus width in boot operation mode H/W Reset Function [RST_N_FUNCTION]: 0x01 , RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition settings [PARTITION_SETTING_COMPLETED]: 0x00 EMMC Init completed Extcsd backup saved: hC8aP__4833A2C8_20230502_085136.extcsd (old backup) Connected successfully Operation: Smart Report ... Device Life Time Estimation (MLC) [269]: 0x02 10% - 20% device life time used Device Life Time Estimation (SLC) [268]: 0x00 Not defined Pre EOL information [267]: 0x01 Normal Done Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 9 MHz CMD Pullup Level: 1833 mV CMD Active Level: 1882 mV EMMC Device Information : EMMC CID: 90014A68433861503E034833A2C81605 EMMC CSD: D02700328F5903FFFFFFFFEF8E400043 EMMC Manufacture : SKHYNIX , EMMC NAME: hC8aP> , HEX: 68433861503E , S/N: 4833A2C8 , rev. 0x03 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 1/2019 EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 10460 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x02 , width 8bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: hC8aP__4833A2C8_20230502_212459.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: boot_para, [000000008000 - 000000108000], size: 000000100000 (1.00 MB) Partition: recovery, [000000108000 - 000004108000], size: 000004000000 (64.0 MB) Partition: para, [000004108000 - 000004188000], size: 000000080000 (512. KB) Partition: opporeserve1, [000004188000 - 000004988000], size: 000000800000 (8.00 MB) Partition: opporeserve2, [000004988000 - 000008988000], size: 000004000000 (64.0 MB) Partition: opporeserve3, [000008988000 - 00000C988000], size: 000004000000 (64.0 MB) Partition: oppo_custom, [00000C988000 - 00000CA88000], size: 000000100000 (1.00 MB) Partition: expdb, [00000CA88000 - 00000DE88000], size: 000001400000 (20.0 MB) Partition: frp, [00000DE88000 - 00000DF88000], size: 000000100000 (1.00 MB) Partition: nvcfg, [00000DF88000 - 00000FF88000], size: 000002000000 (32.0 MB) Partition: nvdata, [00000FF88000 - 000013F88000], size: 000004000000 (64.0 MB) Partition: metadata, [000013F88000 - 000015F88000], size: 000002000000 (32.0 MB) Partition: protect1, [000015F88000 - 000016788000], size: 000000800000 (8.00 MB) Partition: protect2, [000016788000 - 000017000000], size: 000000878000 (8.47 MB) Partition: seccfg, [000017000000 - 000017800000], size: 000000800000 (8.00 MB) Partition: persist, [000017800000 - 00001A800000], size: 000003000000 (48.0 MB) Partition: sec1, [00001A800000 - 00001AA00000], size: 000000200000 (2.00 MB) Partition: proinfo, [00001AA00000 - 00001AD00000], size: 000000300000 (3.00 MB) Partition: md1img, [00001AD00000 - 000021100000], size: 000006400000 (100. MB) Partition: spmfw, [000021100000 - 000021200000], size: 000000100000 (1.00 MB) Partition: scp1, [000021200000 - 000021800000], size: 000000600000 (6.00 MB) Partition: scp2, [000021800000 - 000021E00000], size: 000000600000 (6.00 MB) Partition: sspm_1, [000021E00000 - 000021F00000], size: 000000100000 (1.00 MB) Partition: sspm_2, [000021F00000 - 000022000000], size: 000000100000 (1.00 MB) Partition: cam_vpu1, [000022000000 - 000022F00000], size: 000000F00000 (15.0 MB) Partition: cam_vpu2, [000022F00000 - 000023E00000], size: 000000F00000 (15.0 MB) Partition: cam_vpu3, [000023E00000 - 000024D00000], size: 000000F00000 (15.0 MB) Partition: gz1, [000024D00000 - 000025D00000], size: 000001000000 (16.0 MB) Partition: gz2, [000025D00000 - 000026D00000], size: 000001000000 (16.0 MB) Partition: nvram, [000026D00000 - 00002AD00000], size: 000004000000 (64.0 MB) Partition: lk, [00002AD00000 - 00002B200000], size: 000000500000 (5.00 MB) Partition: lk2, [00002B200000 - 00002B700000], size: 000000500000 (5.00 MB) Partition: boot, [00002B700000 - 00002D700000], size: 000002000000 (32.0 MB) Partition: logo, [00002D700000 - 00002E700000], size: 000001000000 (16.0 MB) Partition: dtbo, [00002E700000 - 00002F700000], size: 000001000000 (16.0 MB) Partition: tee1, [00002F700000 - 00002FC00000], size: 000000500000 (5.00 MB) Partition: tee2, [00002FC00000 - 000030800000], size: 000000C00000 (12.0 MB) Partition: odm, [000030800000 - 000040800000], size: 000010000000 (256. MB) Partition: vendor, [000040800000 - 000083800000], size: 000043000000 (1.05 GB) Partition: system, [000083800000 - 0001D0800000], size: 00014D000000 (5.20 GB) Partition: cache, [0001D0800000 - 0001EB800000], size: 00001B000000 (432. MB) Partition: userdata, [0001EB800000 - 000E8BCFBE00], size: 000CA04FBE00 (50.5 GB) Partition: otp, [000E8BCFBE00 - 000E8E7FBE00], size: 000002B00000 (43.0 MB) Partition: flashinfo, [000E8E7FBE00 - 000E8F7FBE00], size: 000001000000 (16.0 MB) GPT header successfully parsed Get firmware version Error: Mount [data] failed PartType: LINUX Error: Except: Unmount [data/] failed Firmware info not found |
