04-23-2021, 10:14 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Promise Land, Age: 34
Member: 575597 Status: Offline Sonork: 100.1590575 Thanks Meter: 559 | Mi 9T pro ufs 2.1 824a i try to chip off ufs 824a and put in adapter cant detect. this adapter work for ufs 2.1 chip or not..thanks. i plan to erase persist file and bypass via vpn.. but it cant connect to adapter. |
04-26-2021, 10:58 | #3 (permalink) |
Member: 575597 Status: Offline Sonork: 100.1590575 Thanks Meter: 559 | hi sir layder,, i found pinout of the chip but cannot connect,,. 178573449_369280864394871_4785819319778482198_n.jpg |
04-27-2021, 17:41 | #4 (permalink) |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | |
04-28-2021, 04:43 | #5 (permalink) | ||
Member: 575597 Status: Offline Sonork: 100.1590575 Thanks Meter: 559 | Quote:
what you mean all sir...ex: in socket 1 ground and in chip solder all ground | ||
04-28-2021, 04:46 | #6 (permalink) |
Member: 575597 Status: Offline Sonork: 100.1590575 Thanks Meter: 559 | i see this video that he solder only 8 connection in socket that connect to chip. https://www.youtube.com/watch?v=Rfob_fWH-hw |
04-29-2021, 12:41 | #8 (permalink) | |
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
z3x team is reccomended use only our adapters for correct work with UFS chips | |
05-02-2021, 16:57 | #12 (permalink) |
Member: 13148 Status: Offline Thanks Meter: 2,948 | You can solder to the UFS chip however you want. I explained above that only some of the chips will work with one pin of the ground or power of the chip. Our team is trying to convey this to the users of the form, because they will repeat and approve after you, as you are doing now, that it should work. |
