ravinad2010 | 10-14-2020 14:34 | Help Jio F120B Repartitioned and programmed still shows Qualcomm port no power on hi team,
Jio f120b after flash set goes to dead condition.
doing emmc repartition and flashing using easy jtag every thing ok but mobile not power on. it shows Qualcomm port only. please help. Code:
---------- eMMC Device Information ----------
eMMC CID : 90014A483447326111025988DAE194CB
eMMC CSD : D02701320F5903FFFFFFFFEF8A4040D3
eMMC Manufacturer ID: 0090 , OEM ID: 014A
eMMC Date: 09/2017 Rev.0x2
eMMC NAME: H4G2a , S/N: 1502141153
eMMC NAME (HEX): 483447326120
EMMC ROM1 (Main User Data) Capacity: 3728 MB , 0x748000 pages , 0xE9000000 bytes
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB
EMMC RPMB is programmed and written -329872481 times
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.6 (MMC 4.5)
Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area)
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x01
Backup saved: H4G2a_1502141153_20201014_1858.extcsd
Card Supported Command sets [S_CMD_SET: 0x01]
HPI Features [HPI_FEATURE: 0x03]:
implementation based on CMD12
Background operations support [BKOPS_SUPPORT: 0x01]
Max Packet Read Cmd [MAX_PACKED_READS: 0x08]
Max Packet Write Cmd [MAX_PACKED_WRITES: 0x08]
Data TAG support [DATA_TAG_SUPPORT: 0x01]
Data TAG Unit Size [TAG_UNIT_SIZE: 0x00]
Tag Resources Size [TAG_RES_SIZE: 0x06]
Context Management Capabilities [CONTEXT_CAPABILITIES: 0x78]
Large Unit Size [LARGE_UNIT_SIZE_M1: 0x01]
Extended partition attribute support [EXT_SUPPORT: 0x03]
Generic CMD6 Timer [GENERIC_CMD6_TIME: 0x64]
Power off notification [POWER_OFF_LONG_TIME: 0x64]
Cache Size [CACHE_SIZE] is 512 KiB
Background operations status [BKOPS_STATUS: 0x00]
1st Initialisation Time after programmed sector [INI_TIMEOUT_AP: 0x0a]
Power class for 52MHz, DDR at 3.6V [PWR_CL_DDR_52_360: 0x00]
Power class for 52MHz, DDR at 1.95V [PWR_CL_DDR_52_195: 0x00]
Power class for 200MHz at 3.6V [PWR_CL_200_360: 0x00]
Power class for 200MHz, at 1.95V [PWR_CL_200_195: 0x00]
Minimum Performance for 8bit at 52MHz in DDR mode:
[MIN_PERF_DDR_W_8_52: 0x00]
[MIN_PERF_DDR_R_8_52: 0x00]
TRIM Multiplier [TRIM_MULT: 0x02]
Secure Feature support [SEC_FEATURE_SUPPORT: 0x55]
Boot Information [BOOT_INFO: 0x07]
Device supports alternative boot method
Device supports dual data rate during boot
Device supports high speed timing during boot
Boot partition size [BOOT_SIZE_MULTI: 0x20]
Access size [ACC_SIZE: 0x06]
High-capacity erase unit size [HC_ERASE_GRP_SIZE: 0x01]
High-capacity erase timeout [ERASE_TIMEOUT_MULT: 0x02]
Reliable write sector count [REL_WR_SEC_C: 0x10]
High-capacity W protect group size [HC_WP_GRP_SIZE: 0x10]
Sleep current (VCC) [S_C_VCC: 0x07]
Sleep current (VCCQ) [S_C_VCCQ: 0x07]
Sleep/awake timeout [S_A_TIMEOUT: 0x13]
Sector Count [SEC_COUNT: 0x00748000]
Minimum Write Performance for 8bit:
[MIN_PERF_W_8_52: 0x08]
[MIN_PERF_R_8_52: 0x08]
[MIN_PERF_W_8_26_4_52: 0x08]
[MIN_PERF_R_8_26_4_52: 0x08]
Minimum Write Performance for 4bit:
[MIN_PERF_W_4_26: 0x08]
[MIN_PERF_R_4_26: 0x08]
Power classes registers:
[PWR_CL_26_360: 0x00]
[PWR_CL_52_360: 0x00]
[PWR_CL_26_195: 0x00]
[PWR_CL_52_195: 0x00]
Partition switching timing [PARTITION_SWITCH_TIME: 0x03]
Out-of-interrupt busy timing [OUT_OF_INTERRUPT_TIME: 0x05]
I/O Driver Strength [DRIVER_STRENGTH: 0x01]
Card Type [CARD_TYPE: 0x17]
CSD structure version [CSD_STRUCTURE: 0x02]
Command set [CMD_SET: 0x00]
Command set revision [CMD_SET_REV: 0x00]
Power class [POWER_CLASS: 0x00]
High-speed interface timing [HS_TIMING: 0x00]
Erased memory content [ERASED_MEM_CONT: 0x00]
Boot configuration bytes [PARTITION_CONFIG: 0x38]
No access to boot partition
Boot config protection [BOOT_CONFIG_PROT: 0x00]
Boot bus Conditions [BOOT_BUS_CONDITIONS: 0x00]
High-density erase group definition [ERASE_GROUP_DEF: 0x00]
Boot write protection status registers [BOOT_WP_STATUS]: 0x00
Boot Area Write protection [BOOT_WP]: 0x00
Power ReadOnly locking: possible
Permanent ReadOnly locking: possible
Read Only lock status: not locked
User area write protection register [USER_WP]: 0x10
FW configuration [FW_CONFIG]: 0x00
RPMB Size [RPMB_SIZE_MULT]: 0x20
Write reliability setting register [WR_REL_SET]: 0x1f
Write reliability parameter register [WR_REL_PARAM]: 0x05
Enable background operations handshake [BKOPS_EN]: 0x00
HPI management [HPI_MGMT]: 0x00
Max Enhanced Area Size [MAX_ENH_SIZE_MULT]: 0x0000e9
Partitions attribute [PARTITIONS_ATTRIBUTE]: 0x00
General Purpose Partition Size [GP_SIZE_MULT_4]: 0x000000
[GP_SIZE_MULT_3]: 0x000000
[GP_SIZE_MULT_2]: 0x000000
[GP_SIZE_MULT_1]: 0x000000
Enhanced User Data Area Size [ENH_SIZE_MULT]: 0x000000
Enhanced User Data Start Address [ENH_START_ADDR]: 0x000000
Bad Block Management mode [SEC_BAD_BLK_MGMNT]: 0x00
Periodic Wake-up [PERIODIC_WAKEUP]: 0x00
Program CID/CSD in DDR mode support [PROGRAM_CID_CSD_DDR_SUPPORT]: 0x00
Native sector size [NATIVE_SECTOR_SIZE]: 0x01
Sector size emulation [USE_NATIVE_SECTOR]: 0x00
Sector size [DATA_SECTOR_SIZE]: 0x00
1st initialization after disabling sector size emulation [INI_TIMEOUT_EMU]: 0x0a
Class 6 commands control [CLASS_6_CTRL]: 0x00
Number of addressed group to be released[DYNCAP_NEEDED]: 0x00
Exception events control [EXCEPTION_EVENTS_CTRL]: 0x0000
Exception events status [EXCEPTION_EVENTS_STATUS]: 0x0000
Extended Partitions Attribute [EXT_PARTITIONS_ATTRIBUTE]: 0x0000
Packed command status [PACKED_COMMAND_STATUS]: 0x00
Packed command failure index [PACKED_FAILURE_INDEX]: 0x00
Power Off Notification [POWER_OFF_NOTIFICATION]: 0x00
Control to turn the Cache ON/OFF [CACHE_CTRL]: 0x00
The protective MBR's 0xEE partition is oversized! Auto-repairing.
Found valid GPT with protective MBR; using GPT.
Real (Hardware) Disk/Image size: 748000 sectors 3.6 GiB
Soft (Partitioned) Disk/Image size: 747FBC sectors 3.6 GiB
Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20
Logical sector size: 0x200 bytes ,First/Last usable sector: 34,7634910
Partition info successfully found
------ Detected 30 partitions ------
P0 (MODEM) [0x4000000 0x4000000] Size: 64.0MB
P1 (SBL1) [0x8000000 0x80000] Size: 512.0KB
P2 (SBL1BAK) [0x8080000 0x80000] Size: 512.0KB
P3 (ABOOT) [0x8100000 0x100000] Size: 1.0MB
P4 (ABOOTBAK) [0x8200000 0x100000] Size: 1.0MB
P5 (RPM) [0x8300000 0x80000] Size: 512.0KB
P6 (RPMBAK) [0x8380000 0x80000] Size: 512.0KB
P7 (TZ) [0x8400000 0xc0000] Size: 768.0KB
P8 (TZBAK) [0x84c0000 0xc0000] Size: 768.0KB
P9 (PAD) [0x8580000 0x100000] Size: 1.0MB
P10 (MODEMST1) [0x8680000 0x180000] Size: 1.500MB
P11 (MODEMST2) [0x8800000 0x180000] Size: 1.500MB
P12 (MISC) [0x8980000 0x100000] Size: 1.0MB
P13 (FSC) [0x8a80000 0x400] Size: 1.0KB
P14 (SSD) [0x8a80400 0x2000] Size: 8.0KB
P15 (SPLASH) [0x8a82400 0xa00000] Size: 10.0MB
P16 (DDR) [0xc000000 0x8000] Size: 32.0KB
P17 (FSG) [0xc008000 0x180000] Size: 1.500MB
P18 (SEC) [0xc188000 0x4000] Size: 16.0KB
P19 (BOOT) [0xc18c000 0x2000000] Size: 32.0MB
P20 (SYSTEM) [0xe18c000 0x32000000] Size: 800.0MB
P21 (PERSIST) [0x4018c000 0x2000000] Size: 32.0MB
P22 (USBMSC) [0x44000000 0x3e800000] Size: 1000.0MB
P23 (CACHE) [0x84000000 0x10000000] Size: 256.0MB
P24 (RECOVERY) [0x94000000 0x2000000] Size: 32.0MB
P25 (DEVINFO) [0x96000000 0x100000] Size: 1.0MB
P26 (KEYSTORE) [0x98000000 0x80000] Size: 512.0KB
P27 (OEM) [0x98080000 0x4000000] Size: 64.0MB
P28 (CONFIG) [0x9c080000 0x80000] Size: 512.0KB
P29 (USERDATA) [0x9c100000 0x4cefbe00] Size: 1.201GB
------ Android information ------
Detected LINUX(Android) SYSTEM : 0x000E18C000 (800.0MB)
Short EXT fs info:
Block size: 4.0KB
Inode size: 256
Inodes: 50848
Short Android info:
Build ID: MMB29M
Display Build ID: LYF-F120B-001-02-16-080419
Release Incremental ID: LYF-F120B-001-02-16-080419
Release Base ID: 6.0.1
Security Path: xxxx-xx-xx
Device Model: F120B
Device Manufacturer: LYF
Device Name A: F120B
Device Name B: msm8909_512
Device Board Name: msm8909
Architecture ABI: armeabi-v7a
Device manufacturer: Jio
Device Platform: msm8909
Product ID: msm8909_512
Build Description: msm8909_512-user 6.0.1 MMB29M eng.mercury.20190408.123601 dev-keys
FRP Partition Path: /dev/block/bootdevice/by-name/config
Backup saved: BuildProp_20201014_1859.txt
Detected USERDATA USERDATA : 0x009C100000 (1.201GB)
Short EXT fs info:
Block size: 4.0KB
Inode size: 256
Inodes: 78880
Short userdata info:
Unable to read gesture.key , code 2
Done. |
