help with n7100 dead help with n7100 dead i repaier boot but when i write dump file iget this erorr Z3X EasyJtag Software ver. 1.6.1.1 Loading eMMC Addon Firmware... IO: 2850 mV Box S/N: ,FW Ver.: 01.50 Warning: CMD Pullup Level (825 mV) too low , check cables etc.!!! CMD Active Level:2248 mV eMMC Device Information EMMC CID : 15010056545530304DF1C01A144B7F64 EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 07/2012 Rev.0xf1 EMMC NAME: VTU00M , S/N: 3222934603 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Backup saved: VTU00M_3222934603_20140705_0921.extcsd Done. Running:Change BOOT CONFIG... Z3X EasyJtag Software ver. 1.6.1.1 Skip loading eMMC Addon Firmware CMD Pullup Level:825 mV CMD Active Level:2248 mV Writing eMMC Register... Written: REG : 179 VAL :48 Done. Running:Change BOOT WIDTH... Z3X EasyJtag Software ver. 1.6.1.1 Skip loading eMMC Addon Firmware CMD Pullup Level:825 mV CMD Active Level:2248 mV Writing eMMC Register... Written: REG : 177 VAL :1 Done. log write dump Z3X EasyJtag Software ver. 1.6.1.1 Skip loading eMMC Addon Firmware CMD Pullup Level:825 mV CMD Active Level:2248 mV Writing eMMC Register... Written: REG : 179 VAL :48 Done. Running:Change BOOT WIDTH... Z3X EasyJtag Software ver. 1.6.1.1 Skip loading eMMC Addon Firmware CMD Pullup Level:825 mV CMD Active Level:2248 mV Writing eMMC Register... Written: REG : 177 VAL :1 Done. Z3X EasyJtag Software ver. 1.6.1.1 Skip loading eMMC Addon Firmware CMD Pullup Level:825 mV CMD Active Level:2248 mV Input file : D:\s6312\n7100\N7100_Rom1_Alive_Dump_BN.bin Writing 000020000000 bytes to 00000000 ...ROM2 (BOOT1 ROM) Write Length has been corrected to 0x000000200000 bytes... Retry writing adress 0x00000000 (Attempt #1)... Retry Fail !!! Retry writing adress 0x00000000 (Attempt #2)... Retry Fail !!! Retry writing adress 0x00000000 (Attempt #3)... Retry Fail !!! Write Block Failed, Reason: DATA SND CRC Error |
steel no answer from team |
and boot config than write rom 1 512 mb and rom2 2mb your phone alive how to repaire oooo search button use |
EMMC NAME: VTU00M , S/N: 3222934603 not000000 |
from log I can see you changed boot config attach new log to see your boot partition |
looks like EMMC bad. change EMMC and see result. |
try to find this emmc on markit try to find this emmc . i uplod emmc picture on this link https://mega.co.nz/#!Fsk0WBhA!kzCdi2...yilseuGT-ocXPU. |
