01-16-2019, 15:15 | #1 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Shiraz Iran Age: 37
Member: 1171122 Status: Offline Sonork: 100.1623220 Thanks Meter: 151 | J500H not connect with ISP to easy Jtag... Try to connect it to easy by direct emmc but box not detected my phone!!! I pull 100 ohm resistor between CMD-vccq and Data-vccq but not change any things. can some one help me? thanks |
01-16-2019, 23:10 | #2 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
If you have no connection - you can use HiPower CLK mode and power from USB, also you can try to reduce Frequence | |
01-17-2019, 06:15 | #3 (permalink) | |
Member: 1171122 Status: Offline Sonork: 100.1623220 Thanks Meter: 151 | Quote:
I have not plus! Also I try HiPower CLK and USB cable and reduce Frequence, but not changed any thing! Is it possible this J500H has to emmc pinout? Last edited by layder; 01-17-2019 at 13:06. Reason: merge posts | |
01-17-2019, 12:30 | #4 (permalink) |
Member: 13148 Status: Offline Thanks Meter: 2,948 | ISP connection does not guarantee you 100% success for the following reasons: when supplying power to the board (1,8v and 2.8v), some chips and a processor can be put into operation and interfere with working with the eMMC chip. Therefore, the only way out is to make the ISP connection to supply power to the board through usb, and use the "HiPower CLK" mode you need to make special adapter with connected together 4 CLK pins on on the adapter and use this adapter only with "HiPower" mode at this mode from box use only GND, CMD, CLK, Dat0 wires, and use USB cable and power board through USB connector Last edited by layder; 01-17-2019 at 13:07. |
The Following 3 Users Say Thank You to layder For This Useful Post: |
