07-30-2020, 10:41 | #4 (permalink) |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | You can't post aya detail for you problem (info of you eMMC, connectin, etc) I do not have telepathic abilities to understand how to help you |
The Following User Says Thank You to layder For This Useful Post: |
07-30-2020, 14:16 | #5 (permalink) | |
No Life Poster Join Date: Apr 2016 Location: B A N G L A D E S H
Member: 2556542 Status: Offline Thanks Meter: 1,790 | Quote:
next time i will post all log but problem still some mmo.................emmc . | |
07-30-2020, 16:35 | #6 (permalink) |
Member: 2556542 Status: Offline Thanks Meter: 1,790 | Emmc are unusable final solution Fix it This emmc other device find partition but jtag+ not found partition Code: Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 36 MHz CMD Pullup Level: 1810 mV CMD Active Level: 1862 mV EMMC Device Information : EMMC CID: 65646F4D204D4F52128100000615444D EMMC CSD: D07FFF320F59007FF6DB80001E40001D EMMC Manufacture : , EMMC NAME: MMOR , HEX: 4D004D4F5200 , S/N: 00000615 , rev. 0x81 EMMC Manufacture ID: 0x65 , OEM ID: 0x6F , Device Type: Device (removable) , Date: 4/2017 EMMC ROM 1 (Main User Data) Capacity: 2095982 MB (01FFB6E00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 2048 KB (000000200000) EMMC RPMB (Replay Protected Memory Block) Capacity: 128 KB (000000020000) Counter: 0 , Response: Maybe not clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG]: 0x78 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x03 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: MMOR_00000615_20200730_075357.extcsd EMMC Init completed. Warning: Maybe your emmc damaged eMMC are unusable. Code: Checking security ... Selected pinout: GEN2 ISP Pinout Change EasyJTAG Pinout OK Z3X EasyJtag Software ver. 3.7.0.17 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: 4CC179F40BE74F5B, ,FW Ver.: 02.52 CMD Pullup Level:2281 mV CMD Active Level:2744 mV Box IO Level:2800 mV CLK Rate:24000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 65646F4D204D4F52128100000615444D eMMC CSD : D07FFF320F59007FF6DB80001E40001D eMMC Manufacturer ID: 0065 , OEM ID: 646F eMMC Date: 04/2017 Rev.0x81 eMMC NAME: M MOR , S/N: 1557 eMMC NAME (HEX): 4D204D4F5220 EMMC ROM1 (Main User Data) Capacity: 2095982 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC RPMB is not yet programmed (clear) or RPMB Counter failure EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x78] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x78. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00000400] Partitioning Support [PARTITIONING_SUPPORT]: 0x03 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: M_ 1557_20200730_0758.extcsd Blocks Reading Error (0x0 , 1 , Reason: CMD Timeout Error ) Blocks Reading Error (0x200 , 1 , Reason: CMD Timeout Error ) Warning! Read error 0 strange behavior now likely! Blocks Reading Error (0x1FFB6DFFE00 , 1 , Reason: CMD Timeout Error ) Warning! Read error 0 strange behavior now likely! Partition info not found Done. Code: Z3X EasyJtag Software ver. 3.7.0.17 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: 4CC179F40BE74F5B, ,FW Ver.: 02.52 CMD Pullup Level:2279 mV CMD Active Level:2741 mV Box IO Level:2800 mV CLK Rate:36000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 65646F4D204D4F52128100000615444D eMMC CSD : D07FFF320F59007FF6DB80001E40001D eMMC Manufacturer ID: 0065 , OEM ID: 646F eMMC Date: 04/2017 Rev.0x81 eMMC NAME: M MOR , S/N: 1557 eMMC NAME (HEX): 4D204D4F5220 EMMC ROM1 (Main User Data) Capacity: 2095982 MB , 0xFFDB7000 pages , 0x1FFB6E00000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC RPMB is not yet programmed (clear) or RPMB Counter failure EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x78] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x78. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00000400] Partitioning Support [PARTITIONING_SUPPORT]: 0x03 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: M_ 1557_20200730_0806.extcsd ============================================= Extended CSD rev 1.5 (MMC 4.41) ============================================= Card Supported Command sets [S_CMD_SET: 0x01] HPI Features [HPI_FEATURE: 0x01]: implementation based on CMD13 Background operations support [BKOPS_SUPPORT: 0x00] Background operations status [BKOPS_STATUS: 0x00] 1st Initialisation Time after programmed sector [INI_TIMEOUT_AP: 0x00] Power class for 52MHz, DDR at 3.6V [PWR_CL_DDR_52_360: 0x00] Power class for 52MHz, DDR at 1.95V [PWR_CL_DDR_52_195: 0x00] Minimum Performance for 8bit at 52MHz in DDR mode: [MIN_PERF_DDR_W_8_52: 0x00] [MIN_PERF_DDR_R_8_52: 0x00] TRIM Multiplier [TRIM_MULT: 0x00] Secure Feature support [SEC_FEATURE_SUPPORT: 0x15] Secure Erase Multiplier [SEC_ERASE_MULT: 0x00] Secure TRIM Multiplier [SEC_TRIM_MULT: 0x00] Boot Information [BOOT_INFO: 0x01] Device supports alternative boot method Boot partition size [BOOT_SIZE_MULTI: 0x10] Access size [ACC_SIZE: 0x06] High-capacity erase unit size [HC_ERASE_GRP_SIZE: 0x01] High-capacity erase timeout [ERASE_TIMEOUT_MULT: 0x00] Reliable write sector count [REL_WR_SEC_C: 0x08] High-capacity W protect group size [HC_WP_GRP_SIZE: 0x01] Sleep current (VCC) [S_C_VCC: 0x00] Sleep current (VCCQ) [S_C_VCCQ: 0x00] Sleep/awake timeout [S_A_TIMEOUT: 0x00] Sector Count [SEC_COUNT: 0x003ab800] Minimum Write Performance for 8bit: [MIN_PERF_W_8_52: 0x00] [MIN_PERF_R_8_52: 0x00] [MIN_PERF_W_8_26_4_52: 0x00] [MIN_PERF_R_8_26_4_52: 0x00] Minimum Write Performance for 4bit: [MIN_PERF_W_4_26: 0x00] [MIN_PERF_R_4_26: 0x00] Power classes registers: [PWR_CL_26_360: 0x00] [PWR_CL_52_360: 0x00] [PWR_CL_26_195: 0x00] [PWR_CL_52_195: 0x00] Partition switching timing [PARTITION_SWITCH_TIME: 0x00] Out-of-interrupt busy timing [OUT_OF_INTERRUPT_TIME: 0x00] Card Type [CARD_TYPE: 0x03] HS eMMC @52MHz - at rated device voltage(s) CSD structure version [CSD_STRUCTURE: 0x02] Command set [CMD_SET: 0x00] Command set revision [CMD_SET_REV: 0x00] Power class [POWER_CLASS: 0x00] High-speed interface timing [HS_TIMING: 0x00] Erased memory content [ERASED_MEM_CONT: 0x00] Boot configuration bytes [PARTITION_CONFIG: 0x78] No access to boot partition Boot config protection [BOOT_CONFIG_PROT: 0x00] Boot bus Conditions [BOOT_BUS_CONDITIONS: 0x00] High-density erase group definition [ERASE_GROUP_DEF: 0x00] Boot write protection status registers [BOOT_WP_STATUS]: 0x00 Boot Area Write protection [BOOT_WP]: 0x00 Power ReadOnly locking: possible Permanent ReadOnly locking: possible Read Only lock status: not locked User area write protection register [USER_WP]: 0x00 FW configuration [FW_CONFIG]: 0x00 RPMB Size [RPMB_SIZE_MULT]: 0x01 Write reliability setting register [WR_REL_SET]: 0x00 Write reliability parameter register [WR_REL_PARAM]: 0x00 Enable background operations handshake [BKOPS_EN]: 0x00 H/W reset function [RST_N_FUNCTION]: 0x00 HPI management [HPI_MGMT]: 0x00 Partitioning Support [PARTITIONING_SUPPORT]: 0x03 Device support partitioning feature Device can have enhanced tech. Max Enhanced Area Size [MAX_ENH_SIZE_MULT]: 0x000100 Partitions attribute [PARTITIONS_ATTRIBUTE]: 0x00 Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 General Purpose Partition Size [GP_SIZE_MULT_4]: 0x000000 [GP_SIZE_MULT_3]: 0x000000 [GP_SIZE_MULT_2]: 0x000000 [GP_SIZE_MULT_1]: 0x000000 Enhanced User Data Area Size [ENH_SIZE_MULT]: 0x000000 Enhanced User Data Start Address [ENH_START_ADDR]: 0x000000 Bad Block Management mode [SEC_BAD_BLK_MGMNT]: 0x00 Blocks Reading Error (0x0 , 1 , Reason: CMD Timeout Error ) Blocks Reading Error (0x200 , 1 , Reason: CMD Timeout Error ) Warning! Read error 0 strange behavior now likely! Blocks Reading Error (0x1FFB6DFFE00 , 1 , Reason: CMD Timeout Error ) Warning! Read error 0 strange behavior now likely! Partition info not found Done. Z3X EasyJtag Software ver. 3.7.0.17 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: 4CC179F40BE74F5B, ,FW Ver.: 02.52 CMD Pullup Level:2279 mV CMD Active Level:2741 mV Box IO Level:2800 mV CLK Rate:36000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 65646F4D204D4F52128100000615444D eMMC CSD : D07FFF320F59007FF6DB80001E40001D eMMC Manufacturer ID: 0065 , OEM ID: 646F eMMC Date: 04/2017 Rev.0x81 eMMC NAME: M MOR , S/N: 1557 eMMC NAME (HEX): 4D204D4F5220 EMMC ROM1 (Main User Data) Capacity: 2095982 MB , 0xFFDB7000 pages , 0x1FFB6E00000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC RPMB is not yet programmed (clear) or RPMB Counter failure EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x78] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x78. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00000400] Partitioning Support [PARTITIONING_SUPPORT]: 0x03 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: M_ 1557_20200730_0808.extcsd ============================================= Extended CSD rev 1.5 (MMC 4.41) ============================================= Card Supported Command sets [S_CMD_SET: 0x01] HPI Features [HPI_FEATURE: 0x01]: implementation based on CMD13 Background operations support [BKOPS_SUPPORT: 0x00] Background operations status [BKOPS_STATUS: 0x00] 1st Initialisation Time after programmed sector [INI_TIMEOUT_AP: 0x00] Power class for 52MHz, DDR at 3.6V [PWR_CL_DDR_52_360: 0x00] Power class for 52MHz, DDR at 1.95V [PWR_CL_DDR_52_195: 0x00] Minimum Performance for 8bit at 52MHz in DDR mode: [MIN_PERF_DDR_W_8_52: 0x00] [MIN_PERF_DDR_R_8_52: 0x00] TRIM Multiplier [TRIM_MULT: 0x00] Secure Feature support [SEC_FEATURE_SUPPORT: 0x15] Secure Erase Multiplier [SEC_ERASE_MULT: 0x00] Secure TRIM Multiplier [SEC_TRIM_MULT: 0x00] Boot Information [BOOT_INFO: 0x01] Device supports alternative boot method Boot partition size [BOOT_SIZE_MULTI: 0x10] Access size [ACC_SIZE: 0x06] High-capacity erase unit size [HC_ERASE_GRP_SIZE: 0x01] High-capacity erase timeout [ERASE_TIMEOUT_MULT: 0x00] Reliable write sector count [REL_WR_SEC_C: 0x08] High-capacity W protect group size [HC_WP_GRP_SIZE: 0x01] Sleep current (VCC) [S_C_VCC: 0x00] Sleep current (VCCQ) [S_C_VCCQ: 0x00] Sleep/awake timeout [S_A_TIMEOUT: 0x00] Sector Count [SEC_COUNT: 0x003ab800] Minimum Write Performance for 8bit: [MIN_PERF_W_8_52: 0x00] [MIN_PERF_R_8_52: 0x00] [MIN_PERF_W_8_26_4_52: 0x00] [MIN_PERF_R_8_26_4_52: 0x00] Minimum Write Performance for 4bit: [MIN_PERF_W_4_26: 0x00] [MIN_PERF_R_4_26: 0x00] Power classes registers: [PWR_CL_26_360: 0x00] [PWR_CL_52_360: 0x00] [PWR_CL_26_195: 0x00] [PWR_CL_52_195: 0x00] Partition switching timing [PARTITION_SWITCH_TIME: 0x00] Out-of-interrupt busy timing [OUT_OF_INTERRUPT_TIME: 0x00] Card Type [CARD_TYPE: 0x03] HS eMMC @52MHz - at rated device voltage(s) CSD structure version [CSD_STRUCTURE: 0x02] Command set [CMD_SET: 0x00] Command set revision [CMD_SET_REV: 0x00] Power class [POWER_CLASS: 0x00] High-speed interface timing [HS_TIMING: 0x00] Erased memory content [ERASED_MEM_CONT: 0x00] Boot configuration bytes [PARTITION_CONFIG: 0x78] No access to boot partition Boot config protection [BOOT_CONFIG_PROT: 0x00] Boot bus Conditions [BOOT_BUS_CONDITIONS: 0x00] High-density erase group definition [ERASE_GROUP_DEF: 0x00] Boot write protection status registers [BOOT_WP_STATUS]: 0x00 Boot Area Write protection [BOOT_WP]: 0x00 Power ReadOnly locking: possible Permanent ReadOnly locking: possible Read Only lock status: not locked User area write protection register [USER_WP]: 0x00 FW configuration [FW_CONFIG]: 0x00 RPMB Size [RPMB_SIZE_MULT]: 0x01 Write reliability setting register [WR_REL_SET]: 0x00 Write reliability parameter register [WR_REL_PARAM]: 0x00 Enable background operations handshake [BKOPS_EN]: 0x00 H/W reset function [RST_N_FUNCTION]: 0x00 HPI management [HPI_MGMT]: 0x00 Partitioning Support [PARTITIONING_SUPPORT]: 0x03 Device support partitioning feature Device can have enhanced tech. Max Enhanced Area Size [MAX_ENH_SIZE_MULT]: 0x000100 Partitions attribute [PARTITIONS_ATTRIBUTE]: 0x00 Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 General Purpose Partition Size [GP_SIZE_MULT_4]: 0x000000 [GP_SIZE_MULT_3]: 0x000000 [GP_SIZE_MULT_2]: 0x000000 [GP_SIZE_MULT_1]: 0x000000 Enhanced User Data Area Size [ENH_SIZE_MULT]: 0x000000 Enhanced User Data Start Address [ENH_START_ADDR]: 0x000000 Bad Block Management mode [SEC_BAD_BLK_MGMNT]: 0x00 Blocks Reading Error (0x0 , 1 , Reason: CMD Timeout Error ) Blocks Reading Error (0x200 , 1 , Reason: CMD Timeout Error ) Warning! Read error 0 strange behavior now likely! Blocks Reading Error (0x1FFB6DFFE00 , 1 , Reason: CMD Timeout Error ) Warning! Read error 0 strange behavior now likely! Partition info not found Done. Z3X EasyJtag Software ver. 3.7.0.17 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: 4CC179F40BE74F5B, ,FW Ver.: 02.52 CMD Pullup Level:2277 mV CMD Active Level:2741 mV Box IO Level:2800 mV CLK Rate:36000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 65646F4D204D4F52128100000615444D eMMC CSD : D07FFF320F59007FF6DB80001E40001D eMMC Manufacturer ID: 0065 , OEM ID: 646F eMMC Date: 04/2017 Rev.0x81 eMMC NAME: M MOR , S/N: 1557 eMMC NAME (HEX): 4D204D4F5220 EMMC ROM1 (Main User Data) Capacity: 2095982 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC RPMB is not yet programmed (clear) or RPMB Counter failure EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x78] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x78. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00000400] Partitioning Support [PARTITIONING_SUPPORT]: 0x03 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: M_ 1557_20200730_0811.extcsd Blocks Reading Error (0x0 , 1 , Reason: CMD Timeout Error ) Blocks Reading Error (0x200 , 1 , Reason: CMD Timeout Error ) Warning! Read error 0 strange behavior now likely! Blocks Reading Error (0x1FFB6DFFE00 , 1 , Reason: CMD Timeout Error ) Warning! Read error 0 strange behavior now likely! Partition info not found Done. |
07-31-2020, 04:18 | #9 (permalink) | |
spd cpu bga 153 and chinise phone most of cases these emmc when check emmc are unusable. | |
07-31-2020, 09:35 | #10 (permalink) | |
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
The phrase "something does not work for me, but it works there" does not allow developers and support to understand what exactly and in what situation does not work. The phrase "Fix it" does not explain exactly what to fix. If you want to receive high-quality answers from support and help develop the product, then instead of 10 photos of the made device, it is better to describe the entire problem in detail so that we can reproduce it | |
