10-27-2019, 04:13 | #1 (permalink) |
Insane Poster Join Date: Apr 2014
Member: 2170126 Status: Offline Sonork: Whtas & Fb Thanks Meter: 53 | Redmi 6 Pro mi Account Frp remove done by Easyjtag Box 10/26/2019 2:01:36 PM> EasyJTAG Box Firmware = 1.63 10/26/2019 2:01:39 PM> Setting frequence to 21 MHz 10/26/2019 2:01:39 PM> CMD Pullup Level: 2072 mV 10/26/2019 2:01:39 PM> CMD Active Level: 2145 mV 10/26/2019 2:01:39 PM> eMMC Init returned = 0 10/26/2019 2:01:39 PM> EMMC Device Information : 10/26/2019 2:01:39 PM> EMMC CID: 90014A68423861503E01C6BB201F1676 10/26/2019 2:01:39 PM> EMMC CSD: D02700328F5903FFFFFFFFEF8E400042 10/26/2019 2:01:39 PM> EMMC Manufacture : SKHYNIX , EMMC NAME: hB8aP> , HEX: 68423861503E , S/N: C6BB201F , rev. 0x01 10/26/2019 2:01:39 PM> EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 1/2019 10/26/2019 2:01:39 PM> EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) 10/26/2019 2:01:39 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 10/26/2019 2:01:39 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 18491 , Response: Not Clean 10/26/2019 2:01:39 PM> EMMC Permanent Write Protection: No 10/26/2019 2:01:39 PM> EMMC Temporary Write Protection: No 10/26/2019 2:01:39 PM> Extended CSD Information : 10/26/2019 2:01:39 PM> Extended CSD rev: 1.8 (MMC 5.1) 10/26/2019 2:01:39 PM> Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) 10/26/2019 2:01:39 PM> Boot Bus Config: 0x00 , width 1bit 10/26/2019 2:01:39 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled 10/26/2019 2:01:39 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 10/26/2019 2:01:39 PM> Device supports partitioning features 10/26/2019 2:01:39 PM> Device can have enhanced technological features in partitions and user data area 10/26/2019 2:01:39 PM> Device can have extended partitions attribute 10/26/2019 2:01:39 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 10/26/2019 2:01:39 PM> Backup saved: hB8aP__C6BB201F_20191026_140139.extcsd 10/26/2019 2:01:39 PM> EMMC Init completed. 10/26/2019 2:01:39 PM> 10/26/2019 2:01:39 PM> Operation: File Explorer... 10/26/2019 2:01:39 PM> 10/26/2019 2:01:39 PM> Scan from: hB8aP> 10/26/2019 2:01:39 PM> 10/26/2019 2:01:39 PM> Vendor: Qualcomm 10/26/2019 2:01:39 PM> Searching GPT ... 10/26/2019 2:01:39 PM> GPT header is found and is valid 10/26/2019 2:01:39 PM> 10/26/2019 2:01:41 PM> GPT header successfully parsed 10/26/2019 2:01:50 PM> 10/26/2019 2:01:50 PM> Scan done 10/26/2019 2:01:50 PM> 10/26/2019 2:01:50 PM> Mount [config] SKIPPED PartType: FRP <<< FRP !!! 10/26/2019 2:01:50 PM> Mount [dsp] successfully PartType: LINUX 10/26/2019 2:01:50 PM> Mount [persist] successfully PartType: LINUX 10/26/2019 2:01:50 PM> Mount [persistbak] successfully PartType: LINUX 10/26/2019 2:01:50 PM> Mount [modem] successfully PartType: FAT16 10/26/2019 2:01:50 PM> Mount [cache] successfully PartType: LINUX 10/26/2019 2:01:50 PM> Mount [system] successfully PartType: LINUX 10/26/2019 2:01:50 PM> Mount [vendor] successfully PartType: LINUX 10/26/2019 2:01:50 PM> Mount [cust] successfully PartType: LINUX 10/26/2019 2:01:50 PM> Mount [userdata] SKIPPED PartType: Full Disk Encryption 10/26/2019 2:01:50 PM> 10/26/2019 2:01:50 PM> Get firmware version 10/26/2019 2:01:51 PM> Brand = xiaomi 10/26/2019 2:01:51 PM> Manufacturer = Xiaomi 10/26/2019 2:01:51 PM> Device = ******_india 10/26/2019 2:01:51 PM> Model = Redmi 6 Pro 10/26/2019 2:01:51 PM> CPU Abi = arm64-v8a 10/26/2019 2:01:51 PM> Android release = 9 10/26/2019 2:01:51 PM> Firmware version = ZQL1715-******_india-build-20190711190436 10/26/2019 2:01:51 PM> Miui Version = V10.3.3.0.PDMMIXM 10/26/2019 2:01:51 PM> Firmware date = Thu Jul 11 19:07:05 CST 2019 10/26/2019 2:01:51 PM> 10/26/2019 2:01:51 PM> About MiCloud: 10/26/2019 2:01:51 PM> MiCloud Find Device: locked 10/26/2019 2:01:51 PM> MiCloud Lost Mode: On 10/26/2019 2:01:51 PM> MiCloud User ID: 5213816795 10/26/2019 2:01:54 PM> MiCloud User Phone: Unknown 10/26/2019 2:01:54 PM> MiCloud User Mail: che******[email protected] 10/26/2019 2:01:54 PM> 10/26/2019 2:03:33 PM> Saving object: [XiaomiAccount.odex] 10/26/2019 2:03:33 PM> Completed: [00:00:00:078] 10/26/2019 2:03:33 PM> 10/26/2019 2:03:33 PM> All done https://postimg.cc/fSbd8XCR https://postimg.cc/7G971XgR https://postimg.cc/LqdzmJ9x https://postimg.cc/v1W5TGDb https://postimg.cc/5YbLFDFv |
The Following 5 Users Say Thank You to rajeshda69 For This Useful Post: |
10-27-2019, 10:02 | #2 (permalink) | |
No Life Poster Join Date: Sep 2012 Location: Mahoba
Member: 1810159 Status: Offline Thanks Meter: 256 | Quote:
Thnx | |
The Following User Says Thank You to sktamrkar For This Useful Post: |
11-22-2019, 03:37 | #7 (permalink) |
Member: 2170126 Status: Offline Sonork: Whtas & Fb Thanks Meter: 53 | https://i.postimg.cc/XJRhFRbg/redmi-6-pro-isp.jpg https://i.postimg.cc/MZBgxp73/redmi-6-pro-isp2.jpg use this bro press thanks buttun |
The Following 6 Users Say Thank You to rajeshda69 For This Useful Post: |
11-22-2019, 05:22 | #9 (permalink) | |
Freak Poster Join Date: Jan 2008 Location: phone care
Member: 667941 Status: Offline Sonork: 100.1611812 Thanks Meter: 61 | Quote:
first you read by vender then write it back with persist..or persist.bak. or you wrote flash only tick with this two file.. | |
11-24-2019, 03:22 | #10 (permalink) | |
Member: 2170126 Status: Offline Sonork: Whtas & Fb Thanks Meter: 53 | Quote:
same version ur phone miui 9 or miui 10 check first after write persist file if u downgrade ur phone bircked on fastboot | |
04-26-2020, 18:03 | #11 (permalink) |
Insane Poster Join Date: Mar 2008 Location: DERA BABA NANAK
Member: 723248 Status: Offline Thanks Meter: 7 | redmi 6 pro offline flash with easyjtag enjoy offline flash no need to pay check below pic for video link Last edited by manpreetsingh; 04-26-2020 at 18:10. |
