.:B-A-G:. | 05-14-2022 09:32 | help in redmi 7 dead after write persist !! hi
i try to remove mi account in redmi7 with file Redmi_7_Mi _Account+Frp in this post https://forum.gsmhosting.com/vbb/f67.../#post14270041
erase is ok but in write i have many error and cant power on phone
info phone: Code:
13.05.2022 17:00:16> Android Info:
13.05.2022 17:00:16> Vendor = Xiaomi
13.05.2022 17:00:16> CPU ABI = arm64-v8a
13.05.2022 17:00:16> Android Version = 10
13.05.2022 17:00:16> Inc. Version = V11.0.2.0.QFLEUXM
13.05.2022 17:00:16> Firm Date = Sat Mar 13 02:44:08 WIB 2021
13.05.2022 17:00:16> Security Patch = 2021-03-01
13.05.2022 17:00:16> MIUI Version = V11
13.05.2022 17:00:17>
13.05.2022 17:00:17> Scanner Thread Terminated
13.05.2022 17:00:17> Elapsed: 00:00:10:476
13.05.2022 17:00:17> Found 64 Partition(s)..
13.05.2022 17:00:17> Scan Done. Init Main Engine...13.05.2022 17:00:16> Android Info:
13.05.2022 17:00:17> Scan Done. Init Main Engine... Code:
13.05.2022 18:43:39> Vendor = Xiaomi
13.05.2022 18:43:39> Android version = 10
13.05.2022 18:43:39> Firm date = Sat Mar 13 02:44:08 WIB 2021
13.05.2022 18:43:39> SDK version = 29
13.05.2022 18:43:39> Locale = en-GB
13.05.2022 18:43:39> Time Zone = Asia/Shanghai
13.05.2022 18:43:39> ID = QKQ1.191008.001
13.05.2022 18:43:39> CPU ABI = arm64-v8a
13.05.2022 18:43:39> CPU ABI LIST = arm64-v8a,armeabi-v7a,armeabi
13.05.2022 18:43:39> CPU ABI LIST32 = armeabi-v7a,armeabi
13.05.2022 18:43:39> CPU ABI LIST64 = arm64-v8a
13.05.2022 18:43:39> FOTA OEM = Xiaomi
13.05.2022 18:43:39> Inc. Version = V11.0.2.0.QFLEUXM
13.05.2022 18:43:39> Security Patch = 2021-03-01
13.05.2022 18:43:39> Mod. Device = onclite_eea_global
13.05.2022 18:43:39> MIUI Version = V11
13.05.2022 18:43:39> Flavor = onc-user
13.05.2022 18:43:39> logs: Code:
13.05.2022 16:59:27> Z3X EasyJtag EMMC File Manager v 1.18 at 29/06/2020 Started..
13.05.2022 16:59:33> Box API Version: 3401
13.05.2022 16:59:33> FS Driver Version: 29062020
13.05.2022 16:59:33> SQLite Version: 3.32.0
13.05.2022 16:59:33> FSCK Engine Version: 29062020
13.05.2022 16:59:33> ESE DB Version: 29062020
13.05.2022 16:59:33> System Util Version: 29062020
13.05.2022 16:59:33> System: Windows NT 6.2 (Build 9200) / 64 BIT
13.05.2022 16:59:33> CPU: Intel(R) Core(TM) i5-4570 CPU @ 3.20GHz
13.05.2022 16:59:33> Total RAM: 7,89 GB
13.05.2022 16:59:33> Telegram Support: https://t.me/z3xefm
13.05.2022 16:59:33> FRP Apps: http://efm.easy-jtag.com/frp/
13.05.2022 16:59:37> Z3X Card Serial: AAB8CFBD
13.05.2022 16:59:37> EasyJtag Box v1 Found at: COM17
13.05.2022 16:59:37> EasyJtag Box Firmware: 1.63.0
13.05.2022 17:00:06> Source: EasyJtag Port [EMMC/SD/MMC]
13.05.2022 17:00:06> Generation: GPT [QC/SAMS/BCM/INTEL/MTK]
13.05.2022 17:00:06> Box Voltage set to: 2800 mV
13.05.2022 17:00:06> Scanner Thread Created..
13.05.2022 17:00:06> Config: 1011111111101111
13.05.2022 17:00:06> Setup HiPower CLK: OFF
13.05.2022 17:00:06> Connecting To EasyJtag Box: 2800mV/21MHz/1BIT
13.05.2022 17:00:08> EasyJtag Box Found! Result: 0/OK
13.05.2022 17:00:08> CMD Pullup Level: 2000 mV
13.05.2022 17:00:08> CMD Active Level: 2340 mV
13.05.2022 17:00:08> EasyJtag S/N: 04040B05853D1B89
13.05.2022 17:00:08> EasyJtag Box FirmWare: 1.63
13.05.2022 17:00:08> Box Bus Width = 1 BIT
13.05.2022 17:00:08> Box Hardware = EasyJtag 1st Generation
13.05.2022 17:00:08> Search EMMC Chip...
13.05.2022 17:00:08> EMMC Chip Found! 0/OK
13.05.2022 17:00:08> EMMC CID: 13014E53304A394E38100F88B1905662
13.05.2022 17:00:08> EMMC CSD: D05F01328F5913FFFFFFFFEF964000A8
13.05.2022 17:00:08> EMMC VENDOR: MICRON
13.05.2022 17:00:08> EMMC NAME: S0J9N8
13.05.2022 17:00:08> EMMC SERIAL: 0F88B190
13.05.2022 17:00:08> EMMC REVISION: 10
13.05.2022 17:00:08> EMMC ROM1 Size: 122142720 Block(s)/59640 MB
13.05.2022 17:00:08> EMMC ROM2/3 Size: 8192 Block(s)/4096 KB
13.05.2022 17:00:08> EMMC RPMB Size: 32768 Block(s)/16384 KB
13.05.2022 17:00:08> EMMC RPMB Counter: 6811
13.05.2022 17:00:08> EMMC RPMB Answer: 0/OK
13.05.2022 17:00:08> Switch To ROM1 Part: 0/OK
13.05.2022 17:00:08> EMMC REV: 1.8 (for MMC v5.1)
13.05.2022 17:00:08> EMMC VER: MMC 5.1
13.05.2022 17:00:08> EMMC DEV Life Time: 0x01 - Normal
13.05.2022 17:00:08> EMMC MLC Life Time: 0x01 - 0% - 10% Life Time Used
13.05.2022 17:00:08> EMMC SLC Life Time: 0x02 - 10% - 20% Life Time Used
13.05.2022 17:00:08> EMMC Boot Config: 0x38/0x00/0x01
13.05.2022 17:00:08> ExtCSD Automatically Saved..
13.05.2022 17:00:08> Scanning Data From EMMC. Please wait..
13.05.2022 17:00:08> Scanning GUID Partition Table from ROM1
13.05.2022 17:00:08> GUID Partition Table is Found. Max Parts: 60
13.05.2022 17:00:08> GPT: GPT [000000000000 - 000000004400] Size: 17,00 KB
13.05.2022 17:00:08> GPT: FSC [000000005000 - 000000002000] Size: 8,00 KB
13.05.2022 17:00:08> GPT: SSD [000000007000 - 000000002000] Size: 8,00 KB
13.05.2022 17:00:08> GPT: DPO [000000009000 - 000000002000] Size: 8,00 KB
13.05.2022 17:00:08> GPT: SWITCH [00000000B000 - 000000004000] Size: 16,00 KB
13.05.2022 17:00:08> GPT: SEC [00000000F000 - 000000009000] Size: 36,00 KB
13.05.2022 17:00:09> GPT: DDR [000000018000 - 000000010000] Size: 64,00 KB
13.05.2022 17:00:09> GPT: CONFIG [000000028000 - 000000010000] Size: 64,00 KB
13.05.2022 17:00:09> GPT: LIMITS [000000038000 - 000000008000] Size: 32,00 KB
13.05.2022 17:00:09> GPT: LKSECAPP [000000040000 - 000000020000] Size: 128,00 KB
13.05.2022 17:00:09> GPT: LKSECAPPBAK [000000060000 - 000000020000] Size: 128,00 KB
13.05.2022 17:00:09> GPT: DEVCFG [000000080000 - 000000040000] Size: 256,00 KB
13.05.2022 17:00:09> GPT: DEVCFGBAK [0000000C0000 - 000000040000] Size: 256,00 KB
13.05.2022 17:00:09> GPT: APDP [000000100000 - 000000040000] Size: 256,00 KB
13.05.2022 17:00:09> GPT: MSADP [000000140000 - 000000040000] Size: 256,00 KB
13.05.2022 17:00:09> GPT: RPM [000000180000 - 000000080000] Size: 512,00 KB
13.05.2022 17:00:09> GPT: RPMBAK [000000200000 - 000000080000] Size: 512,00 KB
13.05.2022 17:00:09> GPT: MOTA [000000280000 - 000000080000] Size: 512,00 KB
13.05.2022 17:00:09> GPT: KEYSTORE [000000300000 - 000000080000] Size: 512,00 KB
13.05.2022 17:00:09> GPT: SYSCFG [000000380000 - 000000080000] Size: 512,00 KB
13.05.2022 17:00:09> GPT: MISC [000000400000 - 000000100000] Size: 1,00 MB
13.05.2022 17:00:09> GPT: DIP [000000500000 - 000000100000] Size: 1,00 MB
13.05.2022 17:00:09> GPT: SBL1 [000000600000 - 000000100000] Size: 1,00 MB
13.05.2022 17:00:09> GPT: SBL1BAK [000000700000 - 000000100000] Size: 1,00 MB
13.05.2022 17:00:09> GPT: CMNLIB [000000800000 - 000000100000] Size: 1,00 MB
13.05.2022 17:00:09> GPT: CMNLIBBAK [000000900000 - 000000100000] Size: 1,00 MB
13.05.2022 17:00:09> GPT: CMNLIB64 [000000A00000 - 000000100000] Size: 1,00 MB
13.05.2022 17:00:09> GPT: CMNLIB64BAK [000000B00000 - 000000100000] Size: 1,00 MB
13.05.2022 17:00:09> GPT: KEYMASTER [000000C00000 - 000000100000] Size: 1,00 MB
13.05.2022 17:00:09> GPT: KEYMASTERBAK [000000D00000 - 000000100000] Size: 1,00 MB
13.05.2022 17:00:09> GPT: ABOOT [000000E00000 - 000000200000] Size: 2,00 MB
13.05.2022 17:00:09> GPT: ABOOTBAK [000001000000 - 000000200000] Size: 2,00 MB
13.05.2022 17:00:09> GPT: FSG [000001200000 - 000000200000] Size: 2,00 MB
13.05.2022 17:00:09> GPT: TZ [000001400000 - 000000400000] Size: 4,00 MB
13.05.2022 17:00:09> GPT: TZBAK [000001800000 - 000000400000] Size: 4,00 MB
13.05.2022 17:00:09> GPT: MCFG [000001C00000 - 000000400000] Size: 4,00 MB
13.05.2022 17:00:09> GPT: MODEMST1 [000002000000 - 000000800000] Size: 8,00 MB
13.05.2022 17:00:09> GPT: MODEMST2 [000002800000 - 000000800000] Size: 8,00 MB
13.05.2022 17:00:09> GPT: DEVINFO [000003000000 - 000000800000] Size: 8,00 MB
13.05.2022 17:00:09> GPT: DEVBK1 [000003800000 - 000000800000] Size: 8,00 MB
13.05.2022 17:00:09> GPT: DSP [000004000000 - 000001000000] Size: 16,00 MB
13.05.2022 17:00:09> GPT: OOPS [000005000000 - 000001000000] Size: 16,00 MB
13.05.2022 17:00:09> GPT: SPLASH [000006000000 - 000002000000] Size: 32,00 MB
13.05.2022 17:00:09> GPT: PERSIST [000008000000 - 000004000000] Size: 64,00 MB
13.05.2022 17:00:09> GPT: PERSISTBAK [00000C000000 - 000004000000] Size: 64,00 MB
13.05.2022 17:00:09> GPT: MDTP [000010000000 - 000002000000] Size: 32,00 MB
13.05.2022 17:00:09> GPT: LOGDUMP [000012000000 - 000006000000] Size: 96,00 MB
13.05.2022 17:00:09> GPT: BOOT [000018000000 - 000004000000] Size: 64,00 MB
13.05.2022 17:00:09> GPT: RECOVERY [00001C000000 - 000004000000] Size: 64,00 MB
13.05.2022 17:00:09> GPT: MODEM [000020000000 - 000005800000] Size: 88,00 MB
13.05.2022 17:00:09> GPT: LOGO [000025800000 - 000001F00000] Size: 31,00 MB
13.05.2022 17:00:09> GPT: DTBO [000027700000 - 000000800000] Size: 8,00 MB
13.05.2022 17:00:09> GPT: VBMETA [000027F00000 - 000000100000] Size: 1,00 MB
13.05.2022 17:00:09> GPT: MIUIDUMP [000028000000 - 000008000000] Size: 128,00 MB
13.05.2022 17:00:09> GPT: CACHE [000030000000 - 000010000000] Size: 256,00 MB
13.05.2022 17:00:09> GPT: OEM [000040000000 - 000010000000] Size: 256,00 MB
13.05.2022 17:00:09> GPT: CUST [000050000000 - 000034000000] Size: 832,00 MB
13.05.2022 17:00:09> GPT: VENDOR [000084000000 - 000040000000] Size: 1,00 GB
13.05.2022 17:00:09> GPT: SYSTEM [0000C4000000 - 0000E0000000] Size: 3,50 GB
13.05.2022 17:00:09> GPT: USERDATA [0001A4000000 - 000CEB7FBE00] Size: 51,68 GB
13.05.2022 17:00:09> GPT: BACKUP_GPT [000E8F7FBE00 - 000000004200] Size: 16,50 KB
13.05.2022 17:00:09> Reading Table Completed
13.05.2022 17:00:09> Scanning GUID Partition Table from ROM2
13.05.2022 17:00:09> GPT Signature Not Found. Break..
13.05.2022 17:00:09> Scanning GUID Partition Table from ROM3
13.05.2022 17:00:10> Partition #44 mount as [/dev_44] - 16,00 MB
13.05.2022 17:00:10> Partition #47 mount as [/dev_47] - 64,00 MB
13.05.2022 17:00:10> Partition #48 mount as [/dev_48] - 64,00 MB
13.05.2022 17:00:10> Partition #53 mount as [/MODEM] - 88,00 MB
13.05.2022 17:00:10> Partition #58 mount as [/cache] - 256,00 MB
13.05.2022 17:00:10> Partition #60 mount as [/dev_60] - 832,00 MB
13.05.2022 17:00:10> Partition #61 mount as [/vendor] - 1,00 GB
13.05.2022 17:00:10> Partition #62 mount as [/dev_62] - 3,50 GB
13.05.2022 17:00:10> =================================
13.05.2022 17:00:10> Warning! Partition #63 - 'USERDATA' is ENCRYPTED!
13.05.2022 17:00:10> EmptyCheck:
13.05.2022 17:00:10> EMPTY - #4 - [FSC]
13.05.2022 17:00:10> EMPTY - #6 - [DPO]
13.05.2022 17:00:10> EMPTY - #7 - [SWITCH]
13.05.2022 17:00:10> EMPTY - #11 - [LIMITS]
13.05.2022 17:00:11> EMPTY - #16 - [APDP]
13.05.2022 17:00:11> EMPTY - #17 - [MSADP]
13.05.2022 17:00:11> EMPTY - #20 - [MOTA]
13.05.2022 17:00:11> EMPTY - #21 - [KEYSTORE]
13.05.2022 17:00:12> EMPTY - #22 - [SYSCFG]
13.05.2022 17:00:12> EMPTY - #24 - [DIP]
13.05.2022 17:00:13> EMPTY - #38 - [MCFG]
13.05.2022 17:00:13> EMPTY - #44 - [OOPS]
13.05.2022 17:00:13> EMPTY - #48 - [MDTP]
13.05.2022 17:00:13> EMPTY - #49 - [LOGDUMP]
13.05.2022 17:00:14> EMPTY - #53 - [LOGO]
13.05.2022 17:00:14> EMPTY - #56 - [MIUIDUMP]
13.05.2022 17:00:14> EMPTY - #58 - [OEM]
13.05.2022 17:00:14> EmptyCheck: Done
13.05.2022 17:00:16> Platform = msm8953
13.05.2022 17:00:17> Resetting EasyJtag Box. Wait..
13.05.2022 17:00:18> CMD Pullup Level: 2010 mV
13.05.2022 17:00:18> CMD Active Level: 2557 mV
13.05.2022 17:00:19> Reader Engine Initialized.. 0/OK
13.05.2022 17:00:19> Source: EasyJtag Port [EMMC/SD/MMC]
13.05.2022 17:00:19> Generation: GPT [QC/SAMS/BCM/INTEL/MTK]
13.05.2022 17:00:19> Operation Done: [Init Engine], Elapsed: 00:00:01:845
13.05.2022 17:00:42> Qualcomm Flash:
13.05.2022 17:00:43> Path: C:\flash\unlock\Redmi_7_Mi _Account+Frp\
13.05.2022 17:00:43> Initializing Flash Engine..
13.05.2022 17:00:43> Loading Firmwares:
13.05.2022 17:00:43> rawprogram0.xml
13.05.2022 17:00:43> Updating Size of Part 'userdata' to Actual..
13.05.2022 17:00:43> Loading Patches:
13.05.2022 17:00:43> patch0.xml
13.05.2022 17:01:15> Start Flashing..
13.05.2022 17:01:15> Checking Files..
13.05.2022 17:01:15> Partitions for Write: 3
13.05.2022 17:01:15> Total Files Size: 0x000004008000/64,03 MB
13.05.2022 17:01:15> Erase Before Writing: TRUE
13.05.2022 17:01:15> Full Erase Partitions: FALSE
13.05.2022 17:01:15> Erase Google FRP: TRUE
13.05.2022 17:01:15> Force Repartition: FALSE
13.05.2022 17:01:15> Verify Write Data: TRUE
13.05.2022 17:01:15> Part Name: 'config'
13.05.2022 17:01:15> File: Abdul.bin, Addr: 0x000000028000, FileSize: 32,00 KB
13.05.2022 17:01:15> Erasing Partition..
13.05.2022 17:01:15> Erase Done. Count: 128
13.05.2022 17:01:15> Writing to Partition - ROM1
13.05.2022 17:01:15> Error Writing Sector: 320, Count: 64, Err: -8/W_DATA_CRC_ERR
13.05.2022 17:01:15> Try Again #1
13.05.2022 17:01:16> Try Again #2
13.05.2022 17:01:16> Error Writing Sector: 320, Count: 64, Err: -8/W_DATA_CRC_ERR
13.05.2022 17:01:16> Try Again #3
13.05.2022 17:01:16> Write Done. Count: 64
13.05.2022 17:01:16> Part Name: 'persist'
13.05.2022 17:01:16> File: persist.img, Addr: 0x000008000000, FileSize: 32,00 MB
13.05.2022 17:01:16> Erasing Partition..
13.05.2022 17:02:29> Erase Done. Count: 131072
13.05.2022 17:02:29> Writing to Partition - ROM1
13.05.2022 17:02:29> Error Writing Sector: 262144, Count: 512, Err: -8/W_DATA_CRC_ERR
13.05.2022 17:02:29> Try Again #1
13.05.2022 17:02:30> Try Again #2
13.05.2022 17:02:30> Error Writing Sector: 262144, Count: 512, Err: -8/W_DATA_CRC_ERR
13.05.2022 17:02:30> Try Again #3
13.05.2022 17:02:30> Resetting EasyJtag Box...
13.05.2022 17:02:32> CMD Pullup Level: 2010 mV
13.05.2022 17:02:32> CMD Active Level: 2340 mV
13.05.2022 17:02:32> Try Again #1
13.05.2022 17:02:32> Error Writing Sector: 262144, Count: 512, Err: -8/W_DATA_CRC_ERR
13.05.2022 17:02:32> Resetting EasyJtag Box...
13.05.2022 17:02:33> CMD Pullup Level: 2000 mV
13.05.2022 17:02:33> CMD Active Level: 2340 mV
13.05.2022 17:02:34> Try Again #2
13.05.2022 17:02:34> Error Writing Sector: 262144, Count: 512, Err: -8/W_DATA_CRC_ERR
13.05.2022 17:02:34> Resetting EasyJtag Box...
13.05.2022 17:02:35> CMD Pullup Level: 1990 mV
13.05.2022 17:02:35> CMD Active Level: 2340 mV
13.05.2022 17:02:35> Try Again #3
13.05.2022 17:02:35> Too Many Errors. Stopped. Err: -8/W_DATA_CRC_ERR
13.05.2022 17:02:36>
13.05.2022 17:02:36> Error Writing Sector: 262656, Count: 512, Err: -8/W_DATA_CRC_ERR
13.05.2022 17:02:36> Try Again #1
13.05.2022 17:02:36> Try Again #2
13.05.2022 17:02:37>
13.05.2022 17:02:37> Error Writing Sector: 262656, Count: 512, Err: -8/W_DATA_CRC_ERR
13.05.2022 17:02:37> Try Again #3 any help thx |
