06-25-2020, 08:27 | #1 (permalink) |
No Life Poster Join Date: Mar 2018 Location: Future.... ✌️
Member: 2825953 Status: Offline Thanks Meter: 246 | Oppo A5 PBAM00 Screen Lock & FRP Lock Has been Removed by Easy Jtag OS ver.: Windows 7 (build 7601, Service Pack 1). Admin rights OK Autorun Agent ver:1.0.0.0 Crash Reporting ver:1.4.0.3 EasyJTAG SPI Plugin ver:1.1.1.11 Android ADB API ver:2.0.0.0 FTDI API ver:3.2.4.0 LibUSB API ver:1.2.6.0 Visual C++ Runtime ver:10.0.30319.1 Setting box Pinout ... Box Drivers version: 3.0.0.0 Z3X Card Serial : AA27-78BA , ver: 22 Z3X Card Activation [JTAGPLUS] : ACTIVATED Z3X Card Activation [LG] : NOT ACTIVATED Z3X Card Activation [SAMS] : NOT ACTIVATED Z3X Card Activation [JTAG] : ACTIVATED Found 2 serial devices COM7 USB\VID_05C6&PID_9008&REV_0000 Qualcomm HS-USB QDLoader 9008 (COM7) COM32 USB\VID_1781&PID_AAAC&REV_0100&MI_00 Easy Jtag Plus Control Port (COM32) Selected pinout: GEN2 ISP Pinout Change EasyJTAG Pinout OK Z3X EasyJtag Software ver. 3.6.2.3 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: F6F272D292237F2E, ,FW Ver.: 02.50 CMD Pullup Level:2100 mV CMD Active Level:2736 mV Box IO Level:2800 mV CLK Rate:1000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100475036424D420196E49BE416CF eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 01/2019 Rev.0x1 eMMC NAME: GP6BMB , S/N: 2531564516 eMMC NAME (HEX): 475036424D42 EMMC ROM1 (Main User Data) Capacity: 59640 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is programmed and written 182521 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: GP6BMB_2531564516_20200622_2246.extcsd Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 747C000 sectors 58.2 GiB Soft (Partitioned) Disk/Image size: 747BFBC sectors 58.2 GiB Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,122142686 Partition info successfully found ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x003E800000 (3.750GB) Short EXT fs info: Size: 3.750GB Block size: 4.0KB Inode size: 256 Inodes: 245760 Short Android info: Build ID: OPM1.171019.026 Release Base ID: 8.1.0 Security Path: 2020-04-05 Architecture ABI: arm64-v8a Device manufacturer: OPPO Build Description: msm8953_64-user 8.1.0 OPM1.171019.026 eng.root.20200407.230017 release-keys Backup saved: BuildProp_20200622_2246.txt --------------------------------------------- Detected USERDATA USERDATA : 0x0186800000 (52.139GB) Unable to mount USERDATA , code : 95 Userdata Superblock contents:: A7B6B88D 0826CFC4 AD915A06 909821B0 E19A4AE6 15F21D2B AA3782F7 68B81DEC §¶¸..&ÏÄ*‘Z...!°ášJæ.ò.+ª7‚÷h¸.ì; BE2A6467 D3DF8BD0 B3FB2F65 088F2C5F 50AEBDB0 BFC1CEDA A2764B75 BC75F44E ¾*dgÓߋгû/e..,_P®½°¿ÁÎÚ¢vKu¼uôN; EC970958 0390D9DA 8F2FBB71 AD7A7319 767DB379 C8BA16A8 E6C9A00B 294947C3 ì— X..ÙÚ./»q*zs.v}³yȺ.¨æÉ*.)IGÃ; 9D330392 0C5881BD 23760D10 C3CA45FD F33EC1B0 D392A1F7 3289A638 9CC01430 .3.’.X.½#v..ÃÊEýó>Á°Ó’¡÷2‰¦8œÀ.0; BACF8BA0 DD8F5DA2 252A307E A2190CAB 4A1981FE 72A7053E C9D18462 30C9047E ºÏ‹*Ý.]¢%*0~¢..«J..þr§.>ÉÑ„b0É.~; A5172F6D 58489A1F 6678788A 55D83A2C B5281DB0 1B308AE6 CA29CC01 56E1B2EE ¥./mXHš.fxxŠUØ:,µ(.°.0ŠæÊ)Ì.Vá²î; 14FBD0A1 E6E2FF04 CAD25D60 6482BE33 46EEE415 96688B11 1C1F6C45 867F4847 .ûСæâÿ.ÊÒ]`d‚¾3Fîä.–h‹...lE†.HG; E09386CB F0E35F70 958F79C8 3532B4ED B7747926 06541587 443450C6 8A0137A1 à“†Ëðã_p•.yÈ52´í·ty&.T.‡D4PÆŠ.7¡; Done. Checking security ... Z3X EasyJtag Software ver. 3.6.2.3 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: F6F272D292237F2E, ,FW Ver.: 02.50 CMD Pullup Level:2102 mV CMD Active Level:2738 mV Box IO Level:2800 mV CLK Rate:1000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100475036424D420196E49BE416CF eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 01/2019 Rev.0x1 eMMC NAME: GP6BMB , S/N: 2531564516 eMMC NAME (HEX): 475036424D42 EMMC ROM1 (Main User Data) Capacity: 59640 MB , 0x747C000 pages , 0xE8F800000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is programmed and written 182521 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Writing Recovery Command to MISC (33) Done. Checking security ... Running:Format FRP Partition... Z3X EasyJtag Software ver. 3.6.2.3 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: F6F272D292237F2E, ,FW Ver.: 02.50 CMD Pullup Level:2099 mV CMD Active Level:2738 mV Box IO Level:2800 mV CLK Rate:1000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100475036424D420196E49BE416CF eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 01/2019 Rev.0x1 eMMC NAME: GP6BMB , S/N: 2531564516 eMMC NAME (HEX): 475036424D42 EMMC ROM1 (Main User Data) Capacity: 59640 MB , 0x747C000 pages , 0xE8F800000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is programmed and written 182521 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 747C000 sectors 58.2 GiB Soft (Partitioned) Disk/Image size: 747BFBC sectors 58.2 GiB Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,122142686 Partition info successfully found Formatting FRP... Detected LINUX(Android) CACHE : 0x001F300000 (256.0MB) , formatting... Done. Detected LINUX(Android) CONFIG : 0x002F480000 (32.0KB) formatting... Done. Detected LINUX(Android) USERDATA : 0x0186800000 (52.139GB) , formatting... Done. Done. Done. |
