GSMSERVER GSM Shop
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 07-01-2020, 13:21   #1 (permalink)
jamohaki's Avatar
Member: 83397
Thanks Meter: 140
Help s6570m how to repair boot?
SOMEONE TRIED TO UPDATE SOFTWARE AND PHONE END UP WITH DEAD BOOT.HOW TO REPAIR BOOT VIA EMMC?
Z3X EasyJtag Software ver. 3.7.0.11
Loading eMMC GEN1 Firmware... IO: 1850 mV
Box S/N: 1616120653F9FBE6, ,FW Ver.: 01.63
CMD Pullup Level:1928 mV
CMD Active Level:2052 mV
Box IO Level:1850 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is off!
---------- eMMC Device Information ----------
eMMC CID : 1501004A4A533030410386B1493F80D0
eMMC CSD : D02701320F5903FFF6DBFFE78A404056
eMMC Manufacturer ID: 0015 , OEM ID: 0100
eMMC Date: 08/2013 Rev.0x3
eMMC NAME: JJS00A , S/N: 2259765567
eMMC NAME (HEX): 4A4A53303041
IC Name: Samsung , KMJJS000WA-B409/4GB @FBGA153
EMMC ROM1 (Main User Data) Capacity: 3728 MB
EMMC ROM2 (Boot Partition 1) Capacity: 0 kB
EMMC ROM3 (Boot Partition 2) Capacity: 0 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 0 kB
EMMC RPMB is not yet programmed (clear) or RPMB General failure
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.5 (MMC 4.41)
Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured.
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00.
H/W reset function [RST_N_FUNCTION]: 0x00
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00002000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x03
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: JJS00A_2259765567_20200701_1514.extcsd
Found invalid GPT and valid MBR; converting MBR to GPT format
Detected 23 meta partitions :
Meta partition 0
Meta partition A155
Meta partition A156
Meta partition A157
Meta partition A158
Meta partition A159
Meta partition A15A
Meta partition A15B
Meta partition A15C
Meta partition A15D
Meta partition A15E
Meta partition A15F
Meta partition A160
Meta partition A161
Meta partition A162
Meta partition A163
Meta partition A164
Meta partition A165
Meta partition A166
Meta partition A167
Meta partition A168
Meta partition A169
Meta partition A16A
You will need to delete this partition or resize it in another utility.
Real (Hardware) Disk/Image size: 748000 sectors 3.6 GiB
Soft (Partitioned) Disk/Image size: 747FBC sectors 3.6 GiB
Disk identifier (GUID): 8E424302-D59A-2A0B-9927-ADCB24387D0E
Logical sector size: 0x200 bytes ,First/Last usable sector: 34,7634910
Partition info successfully found
Done.
Page generated in 0.14425 seconds with 7 queries
