06-03-2022, 08:37 | #1 (permalink) |
No Life Poster Join Date: Aug 2012 Location: Bali-Indonesia
Member: 1800628 Status: Offline Thanks Meter: 941 | oppo a3s cph1803 stuck on search emmc chip Build: 1.22.0.1187 Build Date/Time: May 25 2022 11:46:56 Box API Version: 3505 FS Driver Version: 04012021 SQLite Version: 3.37.1 FSCK Engine Version: 04012021 ESE DB Version: 04012021 System Util Version: 04012021 System: Windows NT 6.2 (Build 9200) / 64 BIT CPU: AMD Athlon 3000G with Radeon Vega Graphics Total RAM: 5.94 GB System Date: 6/3/2022 3:34:06 PM Official Site: https://efm.easy-jtag.com/ Site: https://emmc-fm.com/ Telegram Russian Support: https://t.me/z3xefm FRP Apps: https://efm.easy-jtag.com/frp/ Z3X Card Serial: AA2317A6 EasyJtag Box v1 Found at: COM26 EasyJtag Box Firmware: 1.63.0 Whats News 25/05/2022 New Quick Buttons (Open Dev Manager/Task Manager) Qualcomm Fixes Scanner Fixes New Loaders New Api 3505 New Emmc Vendors Calc OnePlus Ufs Size Qlm Mi Account Unlock 09/01/2022 !FINAL VERSION! Qualcomm Fixes Scanner Fixes Repartition Fixes Other Small Fixes 05/11/2021 Fix Hex Viewer Errors 13/10/2021 Support SUPER.img Dump New Qlm CPU ID 06/10/2021 New Hex Viewer 09/09/2021 Add Restart App Button Source: EasyJtag Port [EMMC/SD/MMC] Generation: GPT [QC/SAMS/BCM/INTEL/MTK] Box Voltage set to: 1800 mV Scanner Thread Created.. Config: 1011111111101111 Setup HiPower CLK: OFF Connecting To EasyJtag Box: 1800mV/14MHz/1BIT EasyJtag Box Found! Result: 0/OK CMD Pullup Level: 1660 mV CMD Active Level: 1742 mV EasyJtag S/N: 0F01300C22E581EB EasyJtag Box FirmWare: 1.63.0 Box Bus Width = 1 BIT Box Hardware = EasyJtag 1st Generation Search Emmc Chip... EMMC NOT Found! Error: -1/CMD_TOUT_ERR Scanner Thread Terminated Elapsed: 00:00:01:425 Found 0 Partition(s).. Search Partitions Fail.. Check EMMC or Soldering Wires.. Source: EasyJtag Port [EMMC/SD/MMC] Generation: GPT [QC/SAMS/BCM/INTEL/MTK] Box Voltage set to: 3300 mV Scanner Thread Created.. Config: 1011111111101111 Setup HiPower CLK: OFF Connecting To EasyJtag Box: 3300mV/21MHz/1BIT EasyJtag Box Found! Result: 0/OK CMD Pullup Level: 2010 mV CMD Active Level: 2980 mV EasyJtag S/N: 0F01300C22E581EB EasyJtag Box FirmWare: 1.63.0 Box Bus Width = 1 BIT Box Hardware = EasyJtag 1st Generation Search Emmc Chip... NT,i want reset pin code |
