02-14-2021, 14:44 | #1 (permalink) |
Freak Poster Join Date: Oct 2016 Location: india
Member: 2636476 Status: Offline Thanks Meter: 61 | honor 9n after emmc reapir imei 0000 and i have same phone back full dump when i write other phone full backup set on but imei show 0 then i write my phone security backup log is attach set show your device has failed verification Code: Setting interface to EasyJtag2/E-Socket Setting bus width to 8 Bit Setting frequence to 42 MHz EMMC Device Information : EMMC CID: 90014A484347386134A1C7400ECA7589 EMMC CSD: D02701328F5903FFFFFFFFEF8A400027 EMMC Manufacture : SKHYNIX , EMMC NAME: HCG8a4 , HEX: 484347386134 , S/N: C7400ECA , rev. 0xA1 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 7/2018 EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 119 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x02 , width 8bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: HCG8a4_C7400ECA_20210214_181919.extcsd EMMC Init completed. Operation: Write by vendor (Qualcomm/HiSilicon/Omap) Partition name: modemnvm_factory Filename: EMMC_HCG8a4_ROM1_000000000000_000040000000.bin , Offset: 000000600000 , filesize: 4194304 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 4664.65 KB/s Partition name: nvme Filename: EMMC_HCG8a4_ROM1_000000000000_000040000000.bin , Offset: 000000A00000 , filesize: 6291456 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 9765.24 KB/s Partition name: modemnvm_backup Filename: EMMC_HCG8a4_ROM1_000000000000_000040000000.bin , Offset: 000005400000 , filesize: 4194304 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 8897.99 KB/s Partition name: modemnvm_img Filename: EMMC_HCG8a4_ROM1_000000000000_000040000000.bin , Offset: 000005800000 , filesize: 8388608 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 9663.26 KB/s Partition name: modemnvm_system Filename: EMMC_HCG8a4_ROM1_000000000000_000040000000.bin , Offset: 000006000000 , filesize: 4194304 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 9060.57 KB/s Partition name: modem_secure Filename: EMMC_HCG8a4_ROM1_000000000000_000040000000.bin , Offset: 000008A00000 , filesize: 14680064 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 16442.84 KB/s Partition name: modem_om Filename: EMMC_HCG8a4_ROM1_000000000000_000040000000.bin , Offset: 000009800000 , filesize: 33554432 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 16776.27 KB/s Partition name: modemnvm_update Filename: EMMC_HCG8a4_ROM1_000000000000_000040000000.bin , Offset: 00000FA00000 , filesize: 25165824 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 16817.12 KB/s Partition name: modem_fw Filename: EMMC_HCG8a4_ROM1_000000000000_000040000000.bin , Offset: 000023000000 , filesize: 100663296 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 22963.32 KB/s |
