Old 01-01-2021, 18:47   #1 (permalink)
Member: 61595
Sonork: 100.1610188
Thanks Meter: 97
after reset phone dead
phone now dead status log here
if any software damage in this logs please guide me how to solve
Found 3 serial devices
COM45 USB\VID_1781&PID_AAAC&REV_0100&MI_00 Easy Jtag Plus Control Port (COM45)
COM73 root\rimports RIM Virtual Serial Port v2 (COM73)
COM361 USB\VID_0E8D&PID_0003&REV_0100 MediaTek USB Port (COM361)
Selected pinout: GEN2 ISP Pinout
Change EasyJTAG Pinout OK
Z3X EasyJtag Software ver. 3.7.0.20
Loading eMMC GEN2 Firmware... IO: 2600 mV
Box S/N: 65F175B271A79A6C, ,FW Ver.: 02.53
CMD Pullup Level:2141 mV
CMD Active Level:2296 mV
Box IO Level:2600 mV
CLK Rate:18000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
---------- eMMC Device Information ----------
eMMC CID : 150100514436334D420325629BB957E5
eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D
eMMC Manufacturer ID: 0015 , OEM ID: 0100
eMMC Date: 05/2020 Rev.0x3
eMMC NAME: QD63MB , S/N: 627219385
eMMC NAME (HEX): 514436334D42
EMMC ROM1 (Main User Data) Capacity: 29820 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB
EMMC RPMB is programmed and written 643 times
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1)
Boot bus config [177]: 0x02 , width 8bits , Partition config [179]: 0x48.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: QD63MB_ 627219385_20210101_2306.extcsd
Found valid GPT with protective MBR; using GPT.
Real (Hardware) Disk/Image size: 3A3E000 sectors 29.1 GiB
Soft (Partitioned) Disk/Image size: 3A3DFBC sectors 29.1 GiB
Disk identifier (GUID): 00000000-0000-0000-0000-000000000000
Logical sector size: 0x200 bytes ,First/Last usable sector: 34,61071326
Partition info successfully found
------ Detected 42 partitions ------
P0 (BOOT_PARA) [0x8000 0x100000] Size: 1.0MB
P1 (RECOVERY) [0x108000 0x2000000] Size: 32.0MB
P2 (PARA) [0x2108000 0x80000] Size: 512.0KB
P3 (OPPORESERVE1) [0x2188000 0x800000] Size: 8.0MB
P4 (OPPORESERVE2) [0x2988000 0x4000000] Size: 64.0MB
P5 (OPPORESERVE3) [0x6988000 0x4000000] Size: 64.0MB
P6 (OPPO_CUSTOM) [0xa988000 0x100000] Size: 1.0MB
P7 (EXPDB) [0xaa88000 0x1400000] Size: 20.0MB
P8 (FRP) [0xbe88000 0x100000] Size: 1.0MB
P9 (VBMETA) [0xbf88000 0x800000] Size: 8.0MB
P10 (NVCFG) [0xc788000 0x2000000] Size: 32.0MB
P11 (NVDATA) [0xe788000 0x4000000] Size: 64.0MB
P12 (METADATA) [0x12788000 0x2000000] Size: 32.0MB
P13 (PROTECT1) [0x14788000 0x800000] Size: 8.0MB
P14 (PROTECT2) [0x14f88000 0x878000] Size: 8.468MB
P15 (SECCFG) [0x15800000 0x800000] Size: 8.0MB
P16 (PERSIST) [0x16000000 0x3000000] Size: 48.0MB
P17 (SEC1) [0x19000000 0x200000] Size: 2.0MB
P18 (PROINFO) [0x19200000 0x300000] Size: 3.0MB
P19 (MD1IMG) [0x19500000 0x6400000] Size: 100.0MB
P20 (SPMFW) [0x1f900000 0x100000] Size: 1.0MB
P21 (SCP1) [0x1fa00000 0x100000] Size: 1.0MB
P22 (SCP2) [0x1fb00000 0x100000] Size: 1.0MB
P23 (SSPM_1) [0x1fc00000 0x100000] Size: 1.0MB
P24 (SSPM_2) [0x1fd00000 0x100000] Size: 1.0MB
P25 (GZ1) [0x1fe00000 0x1000000] Size: 16.0MB
P26 (GZ2) [0x20e00000 0x1000000] Size: 16.0MB
P27 (NVRAM) [0x21e00000 0x4000000] Size: 64.0MB
P28 (LK) [0x25e00000 0x100000] Size: 1.0MB
P29 (LK2) [0x25f00000 0x100000] Size: 1.0MB
P30 (BOOT) [0x26000000 0x2000000] Size: 32.0MB
P31 (LOGO) [0x28000000 0x1000000] Size: 16.0MB
P32 (DTBO) [0x29000000 0x1000000] Size: 16.0MB
P33 (TEE1) [0x2a000000 0x500000] Size: 5.0MB
P34 (TEE2) [0x2a500000 0xb00000] Size: 11.0MB
P35 (ODM) [0x2b000000 0x10000000] Size: 256.0MB
P36 (VENDOR) [0x3b000000 0x39800000] Size: 920.0MB
P37 (SYSTEM) [0x74800000 0x12c000000] Size: 4.687GB
P38 (CACHE) [0x1a0800000 0x1b000000] Size: 432.0MB
P39 (USERDATA) [0x1bb800000 0x5888fbe00] Size: 22.132GB
P40 (OTP) [0x7440fbe00 0x2b00000] Size: 43.0MB
P41 (FLASHINFO) [0x746bfbe00 0x1000000] Size: 16.0MB
------ Android information ------
Detected LINUX(Android) SYSTEM : 0x0074800000 (4.687GB)
Short EXT fs info:
Block size: 4.0KB
Inode size: 256
Inodes: 302512
Short Android info:
Unable to read prop.plist , code : 2
Detected USERDATA USERDATA : 0x01BB800000 (22.132GB)
Unable to mount USERDATA , code : 95
Userdata Superblock contents::
00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................;
Done.
Old 01-01-2021, 20:37   #2 (permalink)
Member: 2185549
Thanks Meter: 535
Common causes broken hardware broken lines brn cpu and emmc make sure hardware wise its ohkay u cud use a microscope for a better view
If hardware is ohkay write extcsd from backup made by jtag
If it ddint work
Set boot config
Please follow order
Page generated in 0.11384 seconds with 8 queries
