02-03-2021, 10:30 | #1 (permalink) |
Freak Poster Join Date: Jan 2007 Location: karor lal-esan pakistan
Member: 427028 Status: Offline Sonork: 100.1639042 Thanks Meter: 63 | how to dead boot repair oppo a1k Setting frequence to 21 MHz CMD Pullup Level: 1815 mV CMD Active Level: 1938 mV EMMC Device Information : EMMC CID: 150100514436334D4203A949D24D7652 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: QD63MB , HEX: 514436334D42 , S/N: A949D24D , rev. 0x03 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 7/2019 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 1069 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x02 , width 8bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QD63MB_A949D24D_20210203_142701.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: boot_para, [000000008000 - 000000108000], size: 000000100000 (1.00 MB) Partition: recovery, [000000108000 - 000002108000], size: 000002000000 (32.0 MB) Partition: para, [000002108000 - 000002188000], size: 000000080000 (512. KB) Partition: opporeserve1, [000002188000 - 000002988000], size: 000000800000 (8.00 MB) Partition: opporeserve2, [000002988000 - 000006988000], size: 000004000000 (64.0 MB) Partition: opporeserve3, [000006988000 - 00000A988000], size: 000004000000 (64.0 MB) Partition: oppo_custom, [00000A988000 - 00000AA88000], size: 000000100000 (1.00 MB) Partition: expdb, [00000AA88000 - 00000BE88000], size: 000001400000 (20.0 MB) Partition: frp, [00000BE88000 - 00000BF88000], size: 000000100000 (1.00 MB) Partition: vbmeta, [00000BF88000 - 00000C788000], size: 000000800000 (8.00 MB) Partition: nvcfg, [00000C788000 - 00000E788000], size: 000002000000 (32.0 MB) Partition: nvdata, [00000E788000 - 000012788000], size: 000004000000 (64.0 MB) Partition: metadata, [000012788000 - 000014788000], size: 000002000000 (32.0 MB) Partition: protect1, [000014788000 - 000014F88000], size: 000000800000 (8.00 MB) Partition: protect2, [000014F88000 - 000015800000], size: 000000878000 (8.47 MB) Partition: seccfg, [000015800000 - 000016000000], size: 000000800000 (8.00 MB) Partition: persist, [000016000000 - 000019000000], size: 000003000000 (48.0 MB) Partition: sec1, [000019000000 - 000019200000], size: 000000200000 (2.00 MB) Partition: proinfo, [000019200000 - 000019500000], size: 000000300000 (3.00 MB) Partition: md1img, [000019500000 - 00001F900000], size: 000006400000 (100. MB) Partition: spmfw, [00001F900000 - 00001FA00000], size: 000000100000 (1.00 MB) Partition: scp1, [00001FA00000 - 00001FB00000], size: 000000100000 (1.00 MB) Partition: scp2, [00001FB00000 - 00001FC00000], size: 000000100000 (1.00 MB) Partition: sspm_1, [00001FC00000 - 00001FD00000], size: 000000100000 (1.00 MB) Partition: sspm_2, [00001FD00000 - 00001FE00000], size: 000000100000 (1.00 MB) Partition: gz1, [00001FE00000 - 000020E00000], size: 000001000000 (16.0 MB) Partition: gz2, [000020E00000 - 000021E00000], size: 000001000000 (16.0 MB) Partition: nvram, [000021E00000 - 000025E00000], size: 000004000000 (64.0 MB) Partition: lk, [000025E00000 - 000025F00000], size: 000000100000 (1.00 MB) Partition: lk2, [000025F00000 - 000026000000], size: 000000100000 (1.00 MB) Partition: boot, [000026000000 - 000028000000], size: 000002000000 (32.0 MB) Partition: logo, [000028000000 - 000029000000], size: 000001000000 (16.0 MB) Partition: dtbo, [000029000000 - 00002A000000], size: 000001000000 (16.0 MB) Partition: tee1, [00002A000000 - 00002A500000], size: 000000500000 (5.00 MB) Partition: tee2, [00002A500000 - 00002B000000], size: 000000B00000 (11.0 MB) Partition: odm, [00002B000000 - 00003B000000], size: 000010000000 (256. MB) Partition: vendor, [00003B000000 - 000074800000], size: 000039800000 (920. MB) Partition: system, [000074800000 - 0001A0800000], size: 00012C000000 (4.69 GB) Partition: cache, [0001A0800000 - 0001BB800000], size: 00001B000000 (432. MB) Partition: userdata, [0001BB800000 - 0007440FBE00], size: 0005888FBE00 (22.1 GB) Partition: otp, [0007440FBE00 - 000746BFBE00], size: 000002B00000 (43.0 MB) Partition: flashinfo, [000746BFBE00 - 000747BFBE00], size: 000001000000 (16.0 MB) GPT header successfully parsed Get firmware version Firmware info not found any bro in pakistan ho can online solved my problem i am new in easy jtag |
02-03-2021, 10:47 | #2 (permalink) |
Insane Poster Join Date: Sep 2018 Location: India
Member: 2868909 Status: Offline Thanks Meter: 36 | Hello there, You need to backup your security partitions first and then perform a factory reset / erase all roms and install a fresh new dump . Restore your security partition which u backed up and then flash it via oppo flash tool or with any professional tool (many dongles now support this chipset for flashing ) but if you want to flash it via jtag plus then you need to take the chip out , flashing via isp obtains error most of the time. Br. |
The Following User Says Thank You to johnnybravo9889 For This Useful Post: |
