03-02-2021, 18:53 | #1 (permalink) |
Junior Member Join Date: Dec 2007 Location: algeria
Member: 645204 Status: Offline Thanks Meter: 1 | How to fix ext_csd with easy jtag? I try many times to fix ext_csd fir example change value in file;: 179 to 00 167 to 0a The emmc programming 100/100 with my ext_csd modify by me, or by repair ext csd. I connect to the emmc to check if is the ext csd is ok, i see it is ok. But if i start the product after disconnect the easy jtag plus, this product he can't work good and stop in logo. I try to check the emmc by the easy jtag plus tool, but i see the ext_csd back to the old value before changing. I try to programming the emmc with boot and rom1 and the ext csd all is ok, after disconnect the easy and check if the product work, this product can't work, use jtag plus secabd time to check, the value back to the old value (not changed after programing)??? Any one have a idea? |
03-17-2021, 13:19 | #2 (permalink) |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | You can't need to manually edit this file For change boot config you need use EasyJTAG software menu |
The Following User Says Thank You to layder For This Useful Post: |
