[QUOTE=layder;13985301] Quote:
Thank you!!!!!!!! |
@layder All are asking temperory Mi account remove solution not parmenant please tell steps. |
[QUOTE=lihua;14054021] Quote:
good idea , team reply? |
i guess its possible to disable mi account if easy team add one option tab: add system img file to modify with easy jtag for remove or patch finddevice apk and modify and add mi addresses to host file for block connections from mi services.of course after disable mi account. |
how i can remove mi accaunt rdmi 7a |
#Do ISP Or Chip OFF #Open Easy Plus Module #Open Write By Vendor Option N DO Detect #Erase Persist N Write Persist From Factory Firmware Note:-Make Sure U Untick Erase N Reparation Option... Now Disconnect N Reinstall Chip Or Remove ISP Jumpers N Check If Account Byass Then Ok If Not Do Reset Via Recovery Using Any Box Which Support Recovery Reset... After Power On Phone Now Enable ADB N Disable MI Cloud Apps To Avoid Relock... |
Actually, you can block hosts that are being used by findmyphone app. This way you'll get working device without apps crashing but mi sevices won't work as well. The problem is that you need to have unlocked bootloader to do that. |
Redmi note8 pro can remove mi account just by erasing persist partition You may test on other UFS base devices |
One of solution to use device with locks on server - install firewall software at device and block conection mi services to internet to remove lock file from device - simply flash "persist" partition from original firmware |
Need persist file for redmi 8a cant unpack the frimware ???? how can we get the persist file? the phone stuck on logo after erease persit partition !!! |
Persist file can be extract from a firmware file. Make sure you download the one described as "fastboot" rom. |
Can some provide us with the simple tutorial how we can go into internet and remove redmi devices from the saver |
