02-17-2020, 20:12 | #1 (permalink) |
Freak Poster Join Date: Jul 2012 Location: brazil
Member: 1789551 Status: Offline Thanks Meter: 90 | BGA221 eMMC NAME: S0J9N8 - Easy jtag plus not connect i need write mtk scatter file. Code: EasyJtag Suite Classic ver.: 3.6.2.3 / wxWidgets 3.1.3-W-U started. OS ver.: Windows 10 (build 18362), 64-bit edition. Admin rights FAIL Android Explorer ver:1.0.0.13 Autorun Agent ver:1.0.0.0 Crash Reporting ver:1.4.0.3 eMMC Odin ver:1.0.0.6 QUALCOMM Direct ver:1.0.6936.8894 EasyJTAG SPI Plugin ver:1.1.1.11 Android ADB API ver:2.0.0.0 FTDI API ver:3.2.4.0 LibUSB API ver:1.2.6.0 Visual C++ Runtime ver:10.0.30319.1 Setting box Pinout ... Box Drivers version: 10.0.18362.1 Z3X Card Serial : AAB7-9EC2 , ver: 22 Z3X Card Activation [JTAGPLUS] : ACTIVATED Z3X Card Activation [LG] : NOT ACTIVATED Z3X Card Activation [SAMS] : NOT ACTIVATED Z3X Card Activation [JTAG] : ACTIVATED Found 1 serial devices COM20 USB\VID_1781&PID_AAAC&REV_0100&MI_00 Dispositivo Serial USB (COM20) Selected pinout: GEN2 High Speed Pinout Change EasyJTAG Pinout OK Z3X EasyJtag Software ver. 3.6.2.3 Loading eMMC GEN2 Firmware... IO: 1800 mV Initial pull results: clock: 887mV pin connected ok command: 109mV pin unconnected data0: 108mV pin unconnected data1: 107mV pin unconnected data2: 109mV pin unconnected data3: 109mV pin unconnected data4: 107mV pin unconnected data5: 106mV pin unconnected data6: 109mV pin unconnected data7: 108mV pin unconnected Box S/N: 15AEEBC0126DD0AB, ,FW Ver.: 02.50 Box IO Level:1800 mV CLK Rate:14000 kHz Bus Width:8bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 13014E53304A394E3810126C3B2F8653 eMMC CSD : D05F01328F5913FFFFFFFFEF964000A9 eMMC Manufacturer ID: 0013 , OEM ID: 014E eMMC Date: 08/2019 Rev.0x10 eMMC NAME: S0J9N8 , S/N: 309082927 eMMC NAME (HEX): 53304A394E38 EMMC ROM1 (Main User Data) Capacity: 59640 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is not yet programmed (clear) or RPMB General failure EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x02 , width 8bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: S0J9N8_ 309082927_20200217_1607.extcsd Partition info not found Done. Selected eMMC Interface Failed to load partition Code: eMMC_tool Suite ver. 1.6.2.0 (release date: 30.06.2019) Microsoft Windows 10 (64 bit) build 18362 (10.0.18362.653) Looking for EasyJTAG box... EasyJTAG API ver. 3307 EasyJTAG Box Serial = 15AEEBC0126DD0AB Card Serial = AAB79EC2 EasyJTAG Box Firmware = 2.50 Changelog: 30.06.2019 (ver 1.6.1.0) Fix: Bugs that have been found through your crash report Setting interface to EasyJtag2/E-Socket Setting bus width to 8 Bit Setting frequence to 14 MHz Can't init device. Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] Can't init device. Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] Canceled |
02-18-2020, 06:57 | #2 (permalink) | |
No Life Poster Join Date: Aug 2017 Location: India
Member: 2746336 Status: Offline Sonork: NULL Thanks Meter: 47 | Quote:
02-18-2020, 11:58 | #4 (permalink) | |
Member: 1789551 Status: Offline Thanks Meter: 90 | Quote:
Same problem yet. How I set 1.8V ? this option is disable for choose. Because if i set 2.8V Easy jtag Tool 3.6.2 no working too Code: eMMC_tool Suite ver. 1.6.2.0 (release date: 30.06.2019) Microsoft Windows 10 (64 bit) build 18362 (10.0.18362.653) Looking for EasyJTAG box... EasyJTAG API ver. 3307 EasyJTAG Box Serial = 15AEEBC0126DD0AB Card Serial = AAB79EC2 EasyJTAG Box Firmware = 2.50 Changelog: 30.06.2019 (ver 1.6.1.0) Fix: Bugs that have been found through your crash report Setting interface to EasyJtag2/E-Socket Setting bus width to 4 Bit Setting frequence to 14 MHz Can't init device. Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] Can't init device. Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] Can't init device. Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] Setting interface to EasyJtag2/E-Socket Setting bus width to 4 Bit Setting frequence to 14 MHz Can't init device. Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] Can't init device. Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] Canceled Setting interface to EasyJtag2/E-Socket Setting bus width to 8 Bit Setting frequence to 14 MHz Can't init device. Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] Can't init device. Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] Can't init device. Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] | |
03-07-2020, 05:33 | #6 (permalink) |
No Life Poster Join Date: Apr 2012
Member: 1743727 Status: Offline Thanks Meter: 76 | facing same problem with bga 254 with moorc adopter classic suite detect emmc on i.8 io but we easy jteg pulse suit fails to detect and there is no opction to reduce io volateg please enable that option for e socket so that we can drop io voltage when we need Last edited by kumarrocky; 03-07-2020 at 05:38. |
