Old 09-19-2018, 13:33   #1 (permalink)
Member: 1984599
Sonork: PM For Sonork Id ;P
Thanks Meter: 37
Pinouts are perfectly ok T211
It always show this SM-T211
ISP Pinout --tried on both 1bit adapter and 4bit adapter
pinouts are perfectly Ok..Checked under microscope
it always shows this error
CMD Pullup Level:505 mV
CMD Active Level:1839 mV
Box IO Level:2800 mV
CLK Rate:24000 kHz
Bus Width:1bit,SDR
HiPower mode is off!
Can't init device, Reason: CMD Timeout Error
Old 09-20-2018, 05:56   #2 (permalink)
Member: 1112585
Sonork: 100.1645028
Thanks Meter: 91
Connect data(cmd, clk, d0) first Or connect Power(vcc. vccq) first.
Try it.
Old 09-21-2018, 18:43   #3 (permalink)
NoName®'s Avatar
Member: 129885
Sonork: 100:1603514
Thanks Meter: 6,202
Hi CMD Pullup Level:505 mV its to low for success connect - try to connect USB power and use HiPower mode.
The Following 2 Users Say Thank You to NoName® For This Useful Post:
Old 09-24-2018, 10:28   #4 (permalink)
Member: 2127758
Thanks Meter: 26
I got the same ISP REV 2.1 adapter...
maybe we have to add the two resistor on R2 and R3? 100Ohm, right?
Old 09-24-2018, 22:44   #5 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
Yes, you can add 100-200 Ohm resistors for better CMD/Data_0 levels recognition
Page generated in 0.17713 seconds with 8 queries
