06-02-2018, 13:23 | #1 (permalink) |
No Life Poster Join Date: Mar 2013 Location: Nepal Age: 41
Member: 1906979 Status: Offline Sonork: 100.1681049 Thanks Meter: 162 | j727vpp dead with combination file (logs inside) Code: 6/2/2018 2:24:13 PM> 6/2/2018 2:24:14 PM> eMMC_tool Suite ver. 1.5.0.0 (release date: 16.04.2018) 6/2/2018 2:24:15 PM> Microsoft Windows 7 (32 bit) build 7601 (6.1.7601.18015) 6/2/2018 2:24:15 PM> 6/2/2018 2:24:15 PM> Looking for EasyJTAG box... 6/2/2018 2:24:15 PM> EasyJTAG API ver. 2100 6/2/2018 2:24:15 PM> OpenUSB returned = 0 6/2/2018 2:24:16 PM> EasyJTAG Box Serial = 6/2/2018 2:24:17 PM> Card Serial = 6/2/2018 2:24:17 PM> EasyJTAG Box Firmware = 2.22 6/2/2018 2:24:17 PM> 6/2/2018 2:24:24 PM> Looking for EasyJTAG box... 6/2/2018 2:24:24 PM> EasyJTAG API ver. 2100 6/2/2018 2:24:24 PM> Setting IO Levels to 1.8V 6/2/2018 2:24:24 PM> Setting frequence to 36 Mhz 6/2/2018 2:24:24 PM> EasyJTAG Box Serial = 6/2/2018 2:24:24 PM> EasyJTAG Box Firmware = 2.22 6/2/2018 2:24:25 PM> Setting interface to EasyJtag2/ISP_HiPower 6/2/2018 2:24:25 PM> Setting bus width to 1 Bit 6/2/2018 2:24:25 PM> HiPower mode is ON 6/2/2018 2:24:25 PM> Setting frequence to 36 Mhz 6/2/2018 2:24:25 PM> CMD Pullup Level: 1801 mV 6/2/2018 2:24:25 PM> CMD Active Level: 1860 mV 6/2/2018 2:24:25 PM> eMMC Init returned = 0 6/2/2018 2:24:25 PM> EMMC Device Information : 6/2/2018 2:24:25 PM> EMMC CID: 15010051333133424200B630D88BC4EB 6/2/2018 2:24:25 PM> EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D 6/2/2018 2:24:25 PM> EMMC Manufacture : SAMSUNG , EMMC NAME: Q313BB , HEX: 513331334242 , S/N: B630D88B , rev. 0x00 6/2/2018 2:24:25 PM> EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 12/2017 6/2/2018 2:24:25 PM> EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) 6/2/2018 2:24:25 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 6/2/2018 2:24:25 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) 6/2/2018 2:24:25 PM> EMMC Permanent Write Protection: No 6/2/2018 2:24:25 PM> EMMC Temporary Write Protection: No 6/2/2018 2:24:25 PM> Extended CSD Information : 6/2/2018 2:24:25 PM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) 6/2/2018 2:24:25 PM> Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot 6/2/2018 2:24:25 PM> Boot Bus Config: 0x00 , width 1bit 6/2/2018 2:24:25 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled 6/2/2018 2:24:25 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 6/2/2018 2:24:25 PM> Device supports partitioning features 6/2/2018 2:24:25 PM> Device can have enhanced technological features in partitions and user data area 6/2/2018 2:24:25 PM> Device can have extended partitions attribute 6/2/2018 2:24:25 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 6/2/2018 2:24:25 PM> Backup saved: Q313BB_B630D88B_20180602_142425.extcsd 6/2/2018 2:24:25 PM> EMMC Init completed. 6/2/2018 2:24:25 PM> 6/2/2018 2:24:25 PM> Operation: Find table from emmc 6/2/2018 2:24:25 PM> 6/2/2018 2:24:25 PM> Vendor: Samsung 6/2/2018 2:24:25 PM> Searching GPT ... 6/2/2018 2:24:25 PM> GPT header is found and is valid 6/2/2018 2:24:25 PM> Checking for ROM2 ... 6/2/2018 2:24:29 PM> Read error! address: 000000360000 size: 000000008000 (But the data was successfully read) 6/2/2018 2:24:29 PM> ROM2 is blank 6/2/2018 2:24:29 PM> GPT header successfully parsed 6/2/2018 2:24:29 PM> 6/2/2018 2:24:29 PM> EFS backup is performed. Please wait... 6/2/2018 2:24:30 PM> Setting IO Levels to 1.8V 6/2/2018 2:24:31 PM> 6/2/2018 2:24:31 PM> Too many errors. Enabling ResetBox mode 6/2/2018 2:24:31 PM> 6/2/2018 2:24:31 PM> Exception: read_dir/get_inode: [system/kern_sec_info2] 6/2/2018 2:24:31 PM> Exception: read_dir/get_inode: [system/kern_sec_info3] 6/2/2018 2:24:31 PM> Exception: read_dir/get_inode: [system/saiv] 6/2/2018 2:24:31 PM> Exception: read_dir/get_inode: [system/vendor] 6/2/2018 2:24:31 PM> Exception: read_dir/get_inode: [system/xbin] 6/2/2018 2:24:31 PM> Exception: read_dir/get_inode: [system/csc] 6/2/2018 2:24:32 PM> Exception: read_dir/get_inode: [efs/tima_key] 6/2/2018 2:24:32 PM> Exception: read_dir/get_inode: [efs/umc] 6/2/2018 2:24:38 PM> EFS saved to: 6/2/2018 2:24:38 PM> \Backups\EFS\efs_SM-J727VPP_,180305,_20180602_142432.bin 6/2/2018 2:24:38 PM> \Backups\EFS\efs_for_z3x_oldtype_SM-J727VPP_,180305,_20180602_142432.tar 6/2/2018 2:24:38 PM> \Backups\EFS\efs_for_z3x_newtype_SM-J727VPP_,180305,_20180602_142432.tar 6/2/2018 2:24:38 PM> 6/2/2018 2:24:38 PM> All Done 6/2/2018 2:24:38 PM> 6/2/2018 2:24:52 PM> Looking for EasyJTAG box... 6/2/2018 2:24:52 PM> EasyJTAG API ver. 2100 6/2/2018 2:24:52 PM> Setting IO Levels to 2.8V 6/2/2018 2:24:52 PM> Setting frequence to 36 Mhz 6/2/2018 2:24:52 PM> EasyJTAG Box Serial = 6/2/2018 2:24:52 PM> EasyJTAG Box Firmware = 2.22 6/2/2018 2:24:53 PM> Setting interface to EasyJtag2/ISP_HiPower 6/2/2018 2:24:53 PM> Setting bus width to 1 Bit 6/2/2018 2:24:53 PM> HiPower mode is ON 6/2/2018 2:24:53 PM> Setting frequence to 36 Mhz 6/2/2018 2:24:53 PM> CMD Pullup Level: 2110 mV 6/2/2018 2:24:53 PM> CMD Active Level: 2785 mV 6/2/2018 2:24:53 PM> eMMC Init returned = 0 6/2/2018 2:24:53 PM> EMMC Device Information : 6/2/2018 2:24:53 PM> EMMC CID: 15010051333133424200B630D88BC4EB 6/2/2018 2:24:53 PM> EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D 6/2/2018 2:24:53 PM> EMMC Manufacture : SAMSUNG , EMMC NAME: Q313BB , HEX: 513331334242 , S/N: B630D88B , rev. 0x00 6/2/2018 2:24:53 PM> EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 12/2017 6/2/2018 2:24:53 PM> EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) 6/2/2018 2:24:53 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 6/2/2018 2:24:53 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) 6/2/2018 2:24:53 PM> EMMC Permanent Write Protection: No 6/2/2018 2:24:53 PM> EMMC Temporary Write Protection: No 6/2/2018 2:24:53 PM> Extended CSD Information : 6/2/2018 2:24:53 PM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) 6/2/2018 2:24:53 PM> Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot 6/2/2018 2:24:53 PM> Boot Bus Config: 0x00 , width 1bit 6/2/2018 2:24:53 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled 6/2/2018 2:24:53 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 6/2/2018 2:24:53 PM> Device supports partitioning features 6/2/2018 2:24:53 PM> Device can have enhanced technological features in partitions and user data area 6/2/2018 2:24:53 PM> Device can have extended partitions attribute 6/2/2018 2:24:53 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 6/2/2018 2:24:53 PM> Backup saved: Q313BB_B630D88B_20180602_142453.extcsd 6/2/2018 2:24:53 PM> EMMC Init completed. 6/2/2018 2:24:53 PM> 6/2/2018 2:24:53 PM> Scanning soft partitions 6/2/2018 2:24:53 PM> GPT header is found and is valid 6/2/2018 2:24:53 PM> Partition: sbl1, [000000400000 - 000000480000], size: 000000080000 (512. KB) 6/2/2018 2:24:53 PM> Partition: sbl1bak, [000000480000 - 000000500000], size: 000000080000 (512. KB) 6/2/2018 2:24:53 PM> Partition: ddr, [000000500000 - 000000580000], size: 000000080000 (512. KB) 6/2/2018 2:24:53 PM> Partition: rpm, [000000580000 - 000000600000], size: 000000080000 (512. KB) 6/2/2018 2:24:53 PM> Partition: tz, [000000600000 - 000000800000], size: 000000200000 (2.00 MB) 6/2/2018 2:24:53 PM> Partition: aboot, [000000800000 - 000000A00000], size: 000000200000 (2.00 MB) 6/2/2018 2:24:53 PM> Partition: sec, [000000A00000 - 000000A40000], size: 000000040000 (256. KB) 6/2/2018 2:24:53 PM> Partition: lksecapp, [000000A40000 - 000000AC0000], size: 000000080000 (512. KB) 6/2/2018 2:24:53 PM> Partition: keymaster, [000000AC0000 - 000000B40000], size: 000000080000 (512. KB) 6/2/2018 2:24:53 PM> Partition: cmnlib, [000000B40000 - 000000B80000], size: 000000040000 (256. KB) 6/2/2018 2:24:53 PM> Partition: fsg, [000000B80000 - 000000F80000], size: 000000400000 (4.00 MB) 6/2/2018 2:24:53 PM> Partition: cmnlib64, [000000F80000 - 000000FC0000], size: 000000040000 (256. KB) 6/2/2018 2:24:53 PM> Partition: pad, [000000FC0000 - 000001000000], size: 000000040000 (256. KB) 6/2/2018 2:24:53 PM> Partition: modemst1, [000001000000 - 000001400000], size: 000000400000 (4.00 MB) 6/2/2018 2:24:53 PM> Partition: modemst2, [000001400000 - 000001800000], size: 000000400000 (4.00 MB) 6/2/2018 2:24:53 PM> Partition: efs, [000001C00000 - 000002C00000], size: 000001000000 (16.0 MB) 6/2/2018 2:24:53 PM> Partition: fsc, [000002C00000 - 000002F40000], size: 000000340000 (3.25 MB) 6/2/2018 2:24:53 PM> Partition: ssd, [000002F40000 - 000002F80000], size: 000000040000 (256. KB) 6/2/2018 2:24:53 PM> Partition: devcfg, [000002F80000 - 000002FC0000], size: 000000040000 (256. KB) 6/2/2018 2:24:53 PM> Partition: apdp, [000002FC0000 - 000002FE0000], size: 000000020000 (128. KB) 6/2/2018 2:24:53 PM> Partition: msadp, [000002FE0000 - 000003000000], size: 000000020000 (128. KB) 6/2/2018 2:24:53 PM> Partition: param, [000003000000 - 000003C00000], size: 000000C00000 (12.0 MB) 6/2/2018 2:24:53 PM> Partition: backup, [000003C00000 - 000004000000], size: 000000400000 (4.00 MB) 6/2/2018 2:24:53 PM> Partition: boot, [000004000000 - 000006000000], size: 000002000000 (32.0 MB) 6/2/2018 2:24:53 PM> Partition: recovery, [000006000000 - 000008000000], size: 000002000000 (32.0 MB) 6/2/2018 2:24:53 PM> Partition: bota, [000008000000 - 000008800000], size: 000000800000 (8.00 MB) 6/2/2018 2:24:53 PM> Partition: fota, [000008800000 - 000008C00000], size: 000000400000 (4.00 MB) 6/2/2018 2:24:53 PM> Partition: persist, [000008C00000 - 00000AC00000], size: 000002000000 (32.0 MB) 6/2/2018 2:24:53 PM> Partition: persistent, [00000AC00000 - 00000AD00000], size: 000000100000 (1.00 MB) 6/2/2018 2:24:53 PM> Partition: steady, [00000AD00000 - 00000B100000], size: 000000400000 (4.00 MB) 6/2/2018 2:24:53 PM> Partition: keystore, [00000B100000 - 00000B200000], size: 000000100000 (1.00 MB) 6/2/2018 2:24:53 PM> Partition: config, [00000B200000 - 00000B300000], size: 000000100000 (1.00 MB) 6/2/2018 2:24:53 PM> Partition: dsp, [00000B300000 - 00000C300000], size: 000001000000 (16.0 MB) 6/2/2018 2:24:53 PM> Partition: modem, [00000C300000 - 000012300000], size: 000006000000 (96.0 MB) 6/2/2018 2:24:53 PM> Partition: apnhlos, [000012300000 - 000014700000], size: 000002400000 (36.0 MB) 6/2/2018 2:24:53 PM> Partition: reserved2, [000014700000 - 000014800000], size: 000000100000 (1.00 MB) 6/2/2018 2:24:53 PM> Partition: system, [000014800000 - 0000E6000000], size: 0000D1800000 (3.27 GB) 6/2/2018 2:24:53 PM> Partition: cache, [0000E6000000 - 00010B800000], size: 000025800000 (600. MB) 6/2/2018 2:24:53 PM> Partition: carrier, [00010B800000 - 00010C800000], size: 000001000000 (16.0 MB) 6/2/2018 2:24:53 PM> Partition: userdata, [00010C800000 - 0003AB3FB000], size: 00029EBFB000 (10.4 GB) 6/2/2018 2:24:53 PM> GPT header successfully parsed 6/2/2018 2:24:53 PM> 6/2/2018 2:24:53 PM> Get firmware version 6/2/2018 2:24:53 PM> 6/2/2018 2:24:54 PM> Brand = Verizon 6/2/2018 2:24:54 PM> Manufacturer = samsung 6/2/2018 2:24:54 PM> Model = SM-J727VPP 6/2/2018 2:24:54 PM> Phone platform = msm8953 6/2/2018 2:24:54 PM> CPU Abi = arm64-v8a 6/2/2018 2:24:54 PM> Android release = 7.0 6/2/2018 2:24:54 PM> Firmware version = NRD90M.J727VPPVRU1AQK4 6/2/2018 2:24:54 PM> Firmware date = Tue Dec 5 14:45:26 KST 2017 Code: 6/2/2018 1:41:30 PM> EasyJTAG Box Firmware = 2.22 6/2/2018 1:41:31 PM> Setting interface to EasyJtag2/ISP_HiPower 6/2/2018 1:41:31 PM> Setting bus width to 1 Bit 6/2/2018 1:41:31 PM> HiPower mode is ON 6/2/2018 1:41:31 PM> Setting frequence to 36 Mhz 6/2/2018 1:41:31 PM> CMD Pullup Level: 2911 mV 6/2/2018 1:41:31 PM> CMD Active Level: 2801 mV 6/2/2018 1:41:31 PM> eMMC Init returned = 0 6/2/2018 1:41:31 PM> EMMC Device Information : 6/2/2018 1:41:31 PM> EMMC CID: 15010051333133424200B630D88BC4EB 6/2/2018 1:41:31 PM> EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D 6/2/2018 1:41:31 PM> EMMC Manufacture : SAMSUNG , EMMC NAME: Q313BB , HEX: 513331334242 , S/N: B630D88B , rev. 0x00 6/2/2018 1:41:31 PM> EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 12/2017 6/2/2018 1:41:31 PM> EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) 6/2/2018 1:41:31 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 6/2/2018 1:41:31 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) 6/2/2018 1:41:31 PM> EMMC Permanent Write Protection: No 6/2/2018 1:41:31 PM> EMMC Temporary Write Protection: No 6/2/2018 1:41:31 PM> Extended CSD Information : 6/2/2018 1:41:31 PM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) 6/2/2018 1:41:31 PM> Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot 6/2/2018 1:41:31 PM> Boot Bus Config: 0x00 , width 1bit 6/2/2018 1:41:31 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled 6/2/2018 1:41:31 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 6/2/2018 1:41:31 PM> Device supports partitioning features 6/2/2018 1:41:31 PM> Device can have enhanced technological features in partitions and user data area 6/2/2018 1:41:31 PM> Device can have extended partitions attribute 6/2/2018 1:41:31 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 6/2/2018 1:41:31 PM> Backup saved: Q313BB_B630D88B_20180602_134131.extcsd 6/2/2018 1:41:31 PM> EMMC Init completed. 6/2/2018 1:41:31 PM> 6/2/2018 1:41:31 PM> Scanning soft partitions 6/2/2018 1:41:31 PM> GPT header is found and is valid 6/2/2018 1:41:32 PM> Partition: sbl1, [000000400000 - 000000480000], size: 000000080000 (512. KB) 6/2/2018 1:41:32 PM> Partition: sbl1bak, [000000480000 - 000000500000], size: 000000080000 (512. KB) 6/2/2018 1:41:32 PM> Partition: ddr, [000000500000 - 000000580000], size: 000000080000 (512. KB) 6/2/2018 1:41:32 PM> Partition: rpm, [000000580000 - 000000600000], size: 000000080000 (512. KB) 6/2/2018 1:41:32 PM> Partition: tz, [000000600000 - 000000800000], size: 000000200000 (2.00 MB) 6/2/2018 1:41:32 PM> Partition: aboot, [000000800000 - 000000A00000], size: 000000200000 (2.00 MB) 6/2/2018 1:41:32 PM> Partition: sec, [000000A00000 - 000000A40000], size: 000000040000 (256. KB) 6/2/2018 1:41:32 PM> Partition: lksecapp, [000000A40000 - 000000AC0000], size: 000000080000 (512. KB) 6/2/2018 1:41:32 PM> Partition: keymaster, [000000AC0000 - 000000B40000], size: 000000080000 (512. KB) 6/2/2018 1:41:32 PM> Partition: cmnlib, [000000B40000 - 000000B80000], size: 000000040000 (256. KB) 6/2/2018 1:41:32 PM> Partition: fsg, [000000B80000 - 000000F80000], size: 000000400000 (4.00 MB) 6/2/2018 1:41:32 PM> Partition: cmnlib64, [000000F80000 - 000000FC0000], size: 000000040000 (256. KB) 6/2/2018 1:41:32 PM> Partition: pad, [000000FC0000 - 000001000000], size: 000000040000 (256. KB) 6/2/2018 1:41:32 PM> Partition: modemst1, [000001000000 - 000001400000], size: 000000400000 (4.00 MB) 6/2/2018 1:41:32 PM> Partition: modemst2, [000001400000 - 000001800000], size: 000000400000 (4.00 MB) 6/2/2018 1:41:32 PM> Partition: efs, [000001C00000 - 000002C00000], size: 000001000000 (16.0 MB) 6/2/2018 1:41:32 PM> Partition: fsc, [000002C00000 - 000002F40000], size: 000000340000 (3.25 MB) 6/2/2018 1:41:32 PM> Partition: ssd, [000002F40000 - 000002F80000], size: 000000040000 (256. KB) 6/2/2018 1:41:32 PM> Partition: devcfg, [000002F80000 - 000002FC0000], size: 000000040000 (256. KB) 6/2/2018 1:41:32 PM> Partition: apdp, [000002FC0000 - 000002FE0000], size: 000000020000 (128. KB) 6/2/2018 1:41:32 PM> Partition: msadp, [000002FE0000 - 000003000000], size: 000000020000 (128. KB) 6/2/2018 1:41:32 PM> Partition: param, [000003000000 - 000003C00000], size: 000000C00000 (12.0 MB) 6/2/2018 1:41:32 PM> Partition: backup, [000003C00000 - 000004000000], size: 000000400000 (4.00 MB) 6/2/2018 1:41:32 PM> Partition: boot, [000004000000 - 000006000000], size: 000002000000 (32.0 MB) 6/2/2018 1:41:32 PM> Partition: recovery, [000006000000 - 000008000000], size: 000002000000 (32.0 MB) 6/2/2018 1:41:32 PM> Partition: bota, [000008000000 - 000008800000], size: 000000800000 (8.00 MB) 6/2/2018 1:41:32 PM> Partition: fota, [000008800000 - 000008C00000], size: 000000400000 (4.00 MB) 6/2/2018 1:41:32 PM> Partition: persist, [000008C00000 - 00000AC00000], size: 000002000000 (32.0 MB) 6/2/2018 1:41:32 PM> Partition: persistent, [00000AC00000 - 00000AD00000], size: 000000100000 (1.00 MB) 6/2/2018 1:41:32 PM> Partition: steady, [00000AD00000 - 00000B100000], size: 000000400000 (4.00 MB) 6/2/2018 1:41:32 PM> Partition: keystore, [00000B100000 - 00000B200000], size: 000000100000 (1.00 MB) 6/2/2018 1:41:32 PM> Partition: config, [00000B200000 - 00000B300000], size: 000000100000 (1.00 MB) 6/2/2018 1:41:32 PM> Partition: dsp, [00000B300000 - 00000C300000], size: 000001000000 (16.0 MB) 6/2/2018 1:41:32 PM> Partition: modem, [00000C300000 - 000012300000], size: 000006000000 (96.0 MB) 6/2/2018 1:41:32 PM> Partition: apnhlos, [000012300000 - 000014700000], size: 000002400000 (36.0 MB) 6/2/2018 1:41:32 PM> Partition: reserved2, [000014700000 - 000014800000], size: 000000100000 (1.00 MB) 6/2/2018 1:41:32 PM> Partition: system, [000014800000 - 0000E6000000], size: 0000D1800000 (3.27 GB) 6/2/2018 1:41:32 PM> Partition: cache, [0000E6000000 - 00010B800000], size: 000025800000 (600. MB) 6/2/2018 1:41:32 PM> Partition: carrier, [00010B800000 - 00010C800000], size: 000001000000 (16.0 MB) 6/2/2018 1:41:32 PM> Partition: userdata, [00010C800000 - 0003AB3FBE00], size: 00029EBFBE00 (10.4 GB) 6/2/2018 1:41:32 PM> GPT header successfully parsed 6/2/2018 1:41:32 PM> 6/2/2018 1:41:32 PM> Get firmware version 6/2/2018 1:41:32 PM> 6/2/2018 1:41:33 PM> Brand = Verizon 6/2/2018 1:41:33 PM> Manufacturer = samsung 6/2/2018 1:41:33 PM> Model = SM-J727VPP 6/2/2018 1:41:33 PM> Phone platform = msm8953 6/2/2018 1:41:33 PM> CPU Abi = arm64-v8a 6/2/2018 1:41:33 PM> Android release = 7.0 6/2/2018 1:41:33 PM> Firmware version = NRD90M.J727VPPVRS2ARC1 6/2/2018 1:41:33 PM> Firmware date = Wed Mar 14 17:03:03 KST 2018 phone is still dead |
