02-07-2021, 14:12 | #1 (permalink) |
Insane Poster Join Date: Apr 2014
Member: 2175541 Status: Offline Thanks Meter: 24 | HTC ONE M9 DEAD emmc file manager PLEASE HELP Box API Version: 3401 FS Driver Version: 29062020 SQLite Version: 3.32.0 FSCK Engine Version: 29062020 ESE DB Version: 29062020 System Util Version: 29062020 System: Windows NT 6.2 (Build 9200) / 64 BIT CPU: Intel(R) Core(TM) i5-6600K CPU @ 3.50GHz Total RAM: 15.96 GB Telegram Support: https://t.me/z3xefm FRP Apps: Z3X FRP Files Z3X Card Serial: AA2DABF1 EasyJtag Box v1 Found at: COM17 EasyJtag Box Firmware: 1.63.0 Source: EasyJtag Port [EMMC/SD/MMC] Generation: GPT [QC/SAMS/BCM/INTEL/MTK] Box Voltage set to: 3300 mV Scanner Thread Created.. Config: 1011111111101111 Setup HiPower CLK: OFF Connecting To EasyJtag Box: 3300mV/21MHz/1BIT EasyJtag Box Found! Result: 0/OK CMD Pullup Level: 2010 mV CMD Active Level: 2495 mV EasyJtag S/N: 0100700BCA3427B0 EasyJtag Box FirmWare: 1.63 Box Bus Width = 1 BIT Box Hardware = EasyJtag 1st Generation Search EMMC Chip... EMMC Chip Found! 0/OK EMMC CID: 90014A48424734650507A5A13DAB226C EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D2 EMMC VENDOR: SKHYNIX EMMC NAME: HBG4e EMMC SERIAL: A5A13DAB EMMC REVISION: 07 EMMC ROM1 Size: 61079552 Block(s)/29824 MB EMMC ROM2/3 Size: 8192 Block(s)/4096 KB EMMC RPMB Size: 8192 Block(s)/4096 KB EMMC RPMB Counter: 1620 EMMC RPMB Answer: 0/OK Switch To ROM1 Part: 0/OK EMMC REV: 1.7 (for MMC v5.0, v5.01) EMMC VER: MMC 5.0 EMMC DEV Life Time: 0x01 -> Normal EMMC MLC Life Time: 0x0B -> Exceeded its Maximum Estimated Device Life Time EMMC SLC Life Time: 0x01 -> 0% - 10% Life Time Used Warning! EMMC Health Report is Very BAD! EMMC Boot Config: 0x00/0x00/0x01 ExtCSD Automatically Saved.. Scanning Data From EMMC. Please wait.. Scanning GUID Partition Table from ROM1 GUID Partition Table is Found. Max Parts: 72 GPT: GPT [000000000000 - 000000004400] Size: 17.00 KB GPT: BOARD_INFO [000000004400 - 000000004000] Size: 16.00 KB GPT: PG1FS [000000008400 - 000000400000] Size: 4.00 MB GPT: SBL1 [000000408400 - 000000100000] Size: 1.00 MB GPT: PMIC [000000508400 - 000000100000] Size: 1.00 MB GPT: DUMMY [000000608400 - 000002800000] Size: 40.00 MB GPT: RESERVE_1 [000002E08400 - 0000001F7C00] Size: 1.97 MB GPT: MFG [000003000000 - 000000040000] Size: 256.00 KB GPT: PG2FS [000003040000 - 0000017AFC00] Size: 23.69 MB GPT: RPM [0000047EFC00 - 000000080000] Size: 512.00 KB GPT: TZ [00000486FC00 - 000000200000] Size: 2.00 MB GPT: SDI [000004A6FC00 - 000000018000] Size: 96.00 KB GPT: HYP [000004A87C00 - 000000200000] Size: 2.00 MB GPT: ABOOT [000004C87C00 - 000000100000] Size: 1.00 MB GPT: TOOL_DIAG [000004D87C00 - 000000A00000] Size: 10.00 MB GPT: SP1 [000005787C00 - 000000A00000] Size: 10.00 MB GPT: DDR [000006187C00 - 000000100000] Size: 1.00 MB GPT: RFG_0 [000006287C00 - 000000100000] Size: 1.00 MB GPT: RFG_1 [000006387C00 - 000000100000] Size: 1.00 MB GPT: RFG_2 [000006487C00 - 000000100000] Size: 1.00 MB GPT: RFG_3 [000006587C00 - 000000100000] Size: 1.00 MB GPT: RFG_4 [000006687C00 - 000000100000] Size: 1.00 MB GPT: RFG_5 [000006787C00 - 000000100000] Size: 1.00 MB GPT: RFG_6 [000006887C00 - 000000100000] Size: 1.00 MB GPT: RFG_7 [000006987C00 - 000000100000] Size: 1.00 MB GPT: FSG [000006A87C00 - 000000180000] Size: 1.50 MB GPT: RADIO [000006C07C00 - 000003B00400] Size: 59.00 MB GPT: ADSP [00000A708000 - 000001400000] Size: 20.00 MB GPT: LIMITS [00000BB08000 - 000000000400] Size: 1.00 KB GPT: RESERVE_2 [00000BB08400 - 0000004F7C00] Size: 4.97 MB GPT: PERSIST [00000C000000 - 000001600000] Size: 22.00 MB GPT: RAMDUMP [00000D600000 - 000000A00000] Size: 10.00 MB GPT: MISC [00000E000000 - 000000100000] Size: 1.00 MB GPT: MODEM_ST1 [00000E100000 - 000000180000] Size: 1.50 MB GPT: MODEM_ST2 [00000E280000 - 000000180000] Size: 1.50 MB GPT: FATALDEVLOG [00000E400000 - 000001400000] Size: 20.00 MB GPT: DEVLOG [00000F800000 - 000001E00000] Size: 30.00 MB GPT: PDATA [000011600000 - 000000040000] Size: 256.00 KB GPT: CONTROL [000011640000 - 000000004000] Size: 16.00 KB GPT: EXTRA [000011644000 - 000000010000] Size: 64.00 KB GPT: CDMA_RECORD [000011654000 - 000000100000] Size: 1.00 MB GPT: FSC [000011754000 - 000000000400] Size: 1.00 KB GPT: SSD [000011754400 - 000000002000] Size: 8.00 KB GPT: SENSOR_HUB [000011756400 - 000000080000] Size: 512.00 KB GPT: SEC [0000117D6400 - 000000020000] Size: 128.00 KB GPT: ABOOTBAK [0000117F6400 - 000000100000] Size: 1.00 MB GPT: CIR_IMG [0000118F6400 - 000000002800] Size: 10.00 KB GPT: LOCAL [0000118F8C00 - 000000140400] Size: 1.25 MB GPT: FRP [000011A39000 - 000000080000] Size: 512.00 KB GPT: CPE [000011AB9000 - 000000200000] Size: 2.00 MB GPT: CARRIER [000011CB9000 - 000001400000] Size: 20.00 MB GPT: SKYLINK [0000130B9000 - 000000040000] Size: 256.00 KB GPT: RFG_8 [0000130F9000 - 000000020000] Size: 128.00 KB GPT: RFG_9 [000013119000 - 000000020000] Size: 128.00 KB GPT: RFG_10 [000013139000 - 000000020000] Size: 128.00 KB GPT: RFG_11 [000013159000 - 000000020000] Size: 128.00 KB GPT: RFG_12 [000013179000 - 000000020000] Size: 128.00 KB GPT: RFG_13 [000013199000 - 000000020000] Size: 128.00 KB GPT: RFG_14 [0000131B9000 - 000000020000] Size: 128.00 KB GPT: RFG_15 [0000131D9000 - 000000020000] Size: 128.00 KB GPT: ABSOLUTE [0000131F9000 - 000001000000] Size: 16.00 MB GPT: RESERVE [0000141F9000 - 000000E07000] Size: 14.03 MB GPT: HOSD [000015000000 - 000004000000] Size: 64.00 MB GPT: BOOT [000019000000 - 000004000000] Size: 64.00 MB GPT: RECOVERY [00001D000000 - 000004000000] Size: 64.00 MB GPT: CACHE [000021000000 - 000014000000] Size: 320.00 MB GPT: SYSTEM [000035000000 - 000118000000] Size: 4.38 GB GPT: USERDATA [00014D000000 - 0005E0000000] Size: 23.50 GB GPT: APPPRELOAD [00072D000000 - 000012200000] Size: 290.00 MB GPT: COTA [00073F200000 - 000003C00000] Size: 60.00 MB GPT: BATTERY [000742E00000 - 000000A00000] Size: 10.00 MB GPT Backup Header Not Found Reading Table Completed Scanning GUID Partition Table from ROM2 GPT Signature Not Found. Break.. Scanning GUID Partition Table from ROM3 GPT Signature Not Found. Break.. Partition #30 mount as [/RADIO] -> 59.00 MB Partition #31 mount as [/ADSP] -> 20.00 MB Partition #34 mount as [/persist] -> 22.00 MB Partition #39 mount as [/fataldevlog] -> 20.00 MB Partition #40 mount as [/devlog] -> 30.00 MB Partition #53 mount as [/CPE] -> 2.00 MB Partition #54 mount as [/dev_54] -> 20.00 MB Partition #69 mount as [/dev_69] -> 320.00 MB Partition #70 mount as [/dev_70] -> 4.38 GB Partition #71 mount as [/data] -> 23.50 GB Partition #72 mount as [/preload] -> 290.00 MB Partition #73 mount as [/dev_73] -> 60.00 MB EmptyCheck: EMPTY -> #8 - [DUMMY] EMPTY -> #9 - [RESERVE_1] EMPTY -> #17 - [TOOL_DIAG] EMPTY -> #22 - [RFG_2] EMPTY -> #23 - [RFG_3] EMPTY -> #24 - [RFG_4] EMPTY -> #25 - [RFG_5] EMPTY -> #26 - [RFG_6] EMPTY -> #27 - [RFG_7] EMPTY -> #28 - [FSG] EMPTY -> #32 - [RESERVE_2] EMPTY -> #40 - [PDATA] EMPTY -> #41 - [CONTROL] EMPTY -> #42 - [EXTRA] EMPTY -> #44 - [FSC] EMPTY -> #45 - [SSD] EMPTY -> #46 - [SENSOR_HUB] EMPTY -> #48 - [ABOOTBAK] EMPTY -> #50 - [LOCAL] EMPTY -> #51 - [FRP] EMPTY -> #55 - [RFG_8] EMPTY -> #56 - [RFG_9] EMPTY -> #57 - [RFG_10] EMPTY -> #58 - [RFG_11] EMPTY -> #59 - [RFG_12] EMPTY -> #60 - [RFG_13] EMPTY -> #61 - [RFG_14] EMPTY -> #62 - [RFG_15] EMPTY -> #63 - [ABSOLUTE] EMPTY -> #64 - [RESERVE] EMPTY -> #73 - [BATTERY] EmptyCheck: Done Android Info: Brand = htc Vendor = HTC Device = htc_himauhl Model = HTC One M9 Product = htc_himauhl Platform = msm8994 CPU ABI = arm64-v8a Android Version = 6.0 Firm Version = MRA58K release-keys Inc. Version = 670679.12 Firm Date = 四 12月 17 00:16:43 CST 2015 Security Patch = 2015-12-01 Scanner Thread Terminated Elapsed: 00:00:25:956 Found 74 Partition(s).. Scan Done. Init Main Engine... Resetting EasyJtag Box. Wait.. CMD Pullup Level: 2021 mV CMD Active Level: 2485 mV Reader Engine Initialized.. 0/OK Source: EasyJtag Port [EMMC/SD/MMC] Generation: GPT [QC/SAMS/BCM/INTEL/MTK] Operation Done: [Init Engine], Elapsed: 00:00:02:285 DO I HAVE TO REPLACE NAND? |
02-07-2021, 14:47 | #2 (permalink) |
Insane Poster Join Date: Sep 2018 Location: India
Member: 2868909 Status: Offline Thanks Meter: 36 | Hello mate , yes you emmc has lived its days ;-P but my friend you can give it a try by creating zero partition and see if it kicks back to life else you have to replace it. First of All back up your security partitions (read everything except the big parts like system user data and vendor etc. Also create 512 mb dump of rom 1 along with rom 2&3 of your emmc . 2- Factory reset your emmc / erase all roms 3- Create zero gp partitions in emmc tools section under tool tabs 4- Check if Bad health is gone , if it’s still there then you need to replace else you can write fresh new dump (if it’s available else you can also use the dump which you took) 5- Restore your security files which you backed up. 6- Flash stock rom and your device shall come to life again. (But for a short period of time only , it’s long life cannot be guaranteed) Good Luck. |
The Following User Says Thank You to johnnybravo9889 For This Useful Post: |
02-07-2021, 18:02 | #4 (permalink) | |
Member: 2868909 Status: Offline Thanks Meter: 36 | Quote:
What does that mean friend ? you can create zero gp partition in z3x emmc manager by clicking on create zero gp partition which can be under emmc tools tab in Tools tab. If want to use jtag emmc plus software you can do it under HW partition tab and create all gp partition make sure you don’t change values and leave it 0mb or disabled check all gp 1,2,3&4 and final write , you will not face bad health error issue after this and if it still shows then you need to change the emmc. | |
02-07-2021, 19:16 | #5 (permalink) |
Member: 2175541 Status: Offline Thanks Meter: 24 | Setting frequence to 21 MHz CMD Pullup Level: 2021 mV CMD Active Level: 2505 mV EMMC Device Information : EMMC CID: 90014A48424734650507A5A13DAB226C EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D2 EMMC Manufacture : SKHYNIX , EMMC NAME: HBG4e , HEX: 484247346500 , S/N: A5A13DAB , rev. 0x07 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 2/2015 EMMC ROM 1 (Main User Data) Capacity: 29824 MB (000748000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 1620 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: HBG4e_A5A13DAB_20210207_191130.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: board_info, [000000004400 - 000000008400], size: 000000004000 (16.0 KB) Partition: pg1fs, [000000008400 - 000000408400], size: 000000400000 (4.00 MB) Partition: sbl1, [000000408400 - 000000508400], size: 000000100000 (1.00 MB) Partition: pmic, [000000508400 - 000000608400], size: 000000100000 (1.00 MB) Partition: dummy, [000000608400 - 000002E08400], size: 000002800000 (40.0 MB) Partition: reserve_1, [000002E08400 - 000003000000], size: 0000001F7C00 (1.97 MB) Partition: mfg, [000003000000 - 000003040000], size: 000000040000 (256. KB) Partition: pg2fs, [000003040000 - 0000047EFC00], size: 0000017AFC00 (23.6 MB) Partition: rpm, [0000047EFC00 - 00000486FC00], size: 000000080000 (512. KB) Partition: tz, [00000486FC00 - 000004A6FC00], size: 000000200000 (2.00 MB) Partition: sdi, [000004A6FC00 - 000004A87C00], size: 000000018000 (96.0 KB) Partition: hyp, [000004A87C00 - 000004C87C00], size: 000000200000 (2.00 MB) Partition: aboot, [000004C87C00 - 000004D87C00], size: 000000100000 (1.00 MB) Partition: tool_diag, [000004D87C00 - 000005787C00], size: 000000A00000 (10.0 MB) Partition: sp1, [000005787C00 - 000006187C00], size: 000000A00000 (10.0 MB) Partition: ddr, [000006187C00 - 000006287C00], size: 000000100000 (1.00 MB) Partition: rfg_0, [000006287C00 - 000006387C00], size: 000000100000 (1.00 MB) Partition: rfg_1, [000006387C00 - 000006487C00], size: 000000100000 (1.00 MB) Partition: rfg_2, [000006487C00 - 000006587C00], size: 000000100000 (1.00 MB) Partition: rfg_3, [000006587C00 - 000006687C00], size: 000000100000 (1.00 MB) Partition: rfg_4, [000006687C00 - 000006787C00], size: 000000100000 (1.00 MB) Partition: rfg_5, [000006787C00 - 000006887C00], size: 000000100000 (1.00 MB) Partition: rfg_6, [000006887C00 - 000006987C00], size: 000000100000 (1.00 MB) Partition: rfg_7, [000006987C00 - 000006A87C00], size: 000000100000 (1.00 MB) Partition: fsg, [000006A87C00 - 000006C07C00], size: 000000180000 (1.50 MB) Partition: radio, [000006C07C00 - 00000A708000], size: 000003B00400 (59.0 MB) Partition: adsp, [00000A708000 - 00000BB08000], size: 000001400000 (20.0 MB) Partition: limits, [00000BB08000 - 00000BB08400], size: 000000000400 (1.00 KB) Partition: reserve_2, [00000BB08400 - 00000C000000], size: 0000004F7C00 (4.97 MB) Partition: persist, [00000C000000 - 00000D600000], size: 000001600000 (22.0 MB) Partition: ramdump, [00000D600000 - 00000E000000], size: 000000A00000 (10.0 MB) Partition: misc, [00000E000000 - 00000E100000], size: 000000100000 (1.00 MB) Partition: modem_st1, [00000E100000 - 00000E280000], size: 000000180000 (1.50 MB) Partition: modem_st2, [00000E280000 - 00000E400000], size: 000000180000 (1.50 MB) Partition: fataldevlog, [00000E400000 - 00000F800000], size: 000001400000 (20.0 MB) Partition: devlog, [00000F800000 - 000011600000], size: 000001E00000 (30.0 MB) Partition: pdata, [000011600000 - 000011640000], size: 000000040000 (256. KB) Partition: control, [000011640000 - 000011644000], size: 000000004000 (16.0 KB) Partition: extra, [000011644000 - 000011654000], size: 000000010000 (64.0 KB) Partition: cdma_record, [000011654000 - 000011754000], size: 000000100000 (1.00 MB) Partition: fsc, [000011754000 - 000011754400], size: 000000000400 (1.00 KB) Partition: ssd, [000011754400 - 000011756400], size: 000000002000 (8.00 KB) Partition: sensor_hub, [000011756400 - 0000117D6400], size: 000000080000 (512. KB) Partition: sec, [0000117D6400 - 0000117F6400], size: 000000020000 (128. KB) Partition: abootbak, [0000117F6400 - 0000118F6400], size: 000000100000 (1.00 MB) Partition: cir_img, [0000118F6400 - 0000118F8C00], size: 000000002800 (10.0 KB) Partition: local, [0000118F8C00 - 000011A39000], size: 000000140400 (1.25 MB) Partition: frp, [000011A39000 - 000011AB9000], size: 000000080000 (512. KB) Partition: cpe, [000011AB9000 - 000011CB9000], size: 000000200000 (2.00 MB) Partition: carrier, [000011CB9000 - 0000130B9000], size: 000001400000 (20.0 MB) Partition: skylink, [0000130B9000 - 0000130F9000], size: 000000040000 (256. KB) Partition: rfg_8, [0000130F9000 - 000013119000], size: 000000020000 (128. KB) Partition: rfg_9, [000013119000 - 000013139000], size: 000000020000 (128. KB) Partition: rfg_10, [000013139000 - 000013159000], size: 000000020000 (128. KB) Partition: rfg_11, [000013159000 - 000013179000], size: 000000020000 (128. KB) Partition: rfg_12, [000013179000 - 000013199000], size: 000000020000 (128. KB) Partition: rfg_13, [000013199000 - 0000131B9000], size: 000000020000 (128. KB) Partition: rfg_14, [0000131B9000 - 0000131D9000], size: 000000020000 (128. KB) Partition: rfg_15, [0000131D9000 - 0000131F9000], size: 000000020000 (128. KB) Partition: absolute, [0000131F9000 - 0000141F9000], size: 000001000000 (16.0 MB) Partition: reserve, [0000141F9000 - 000015000000], size: 000000E07000 (14.0 MB) Partition: hosd, [000015000000 - 000019000000], size: 000004000000 (64.0 MB) Partition: boot, [000019000000 - 00001D000000], size: 000004000000 (64.0 MB) Partition: recovery, [00001D000000 - 000021000000], size: 000004000000 (64.0 MB) Partition: cache, [000021000000 - 000035000000], size: 000014000000 (320. MB) Partition: system, [000035000000 - 00014D000000], size: 000118000000 (4.38 GB) Partition: userdata, [00014D000000 - 00072D000000], size: 0005E0000000 (23.5 GB) Partition: apppreload, [00072D000000 - 00073F200000], size: 000012200000 (290. MB) Partition: cota, [00073F200000 - 000742E00000], size: 000003C00000 (60.0 MB) Partition: battery, [000742E00000 - 000743800000], size: 000000A00000 (10.0 MB) GPT header successfully parsed Get firmware version Brand = htc Manufacturer = HTC Device = htc_himauhl Model = HTC One M9 Phone platform = msm8994 CPU Abi = arm64-v8a Android release = 5.1 Firmware version = LMY47O release-keys Firmware date = 四 7月 9 20:12:05 CST 2015 |
02-08-2021, 05:25 | #7 (permalink) |
Member: 2868909 Status: Offline Thanks Meter: 36 | Have you flashed stock firmware after writing the dump file bro ? Reboot into bootloader and check your device cid , build etc and flash with correct firmware the phone should boot normally . |
