Old 02-05-2014, 19:17   #1 (permalink)
Cheater -Don't Deal with him-
Member: 686535
Sonork: 1592667
Thanks Meter: 108
HTC One X (endeavoru) TEGRA repair done but jammed in HBOOT
hi to all
repair log:
Loading eMMC Addon Firmware...
CMD Pullup Level:3176 mV
CMD Active Level:2846 mV
EMMC CID 1501004B325530304D00F9D476E53F25
EMMC CSD D02701320F5903FFF6DBFFFF8A404007
EMMC Manufacturer ID: 15
EMMC OEM ID: 0100
EMMC Date: 03/2012 FW rev.0x0 HW rev.0x0
EMMC Serial #: 4191450853
EMMC NAME: K2U00M
EMMC Capacity: 29820 MB (High Density Card)
Writing 000000200000 bytes to 00000000 ...ROM2
Write Speed: 132 kB/s
Done !!!
Writing file...C:\Documents and Settings\choklat\Mes documents\one x\Nouveau dossier\512MB_HTC_ONE_X_ROM1\512MB_HTC_ONE_X_ROM1. bin
Successefuly connected to box on COM27
Box S/N: 04040919xxxxxxxxx, ,FW Ver.: 01.48
CMD Pullup Level:3145 mV
CMD Active Level:2825 mV
EMMC OEM ID: 0100
EMMC NAME: K2U00M
Writing 000020000000 bytes to 00000000 ...ROM1
Write Speed: 163 kB/s
Done !!!
after repair my phone now in fastboot ...hboot but i cant unlock boot loader via dev my phone accept unlock code.bin but after restart always locked and s-on
hboot 1.39.0000
s-on .
lockedcid
HTC__Y13
version-main: 3.20.401.1
plz help me
and sorry for my bad eng
Old 02-05-2014, 19:34   #2 (permalink)
unlock.mk's Avatar
Member: 1671934
Thanks Meter: 247
After repair , phone now works normal?
Baseband , imei, sn are ok ?
The Following 2 Users Say Thank You to unlock.mk For This Useful Post:
Old 02-05-2014, 19:41   #3 (permalink)
Member: 686535
Sonork: 1592667
Thanks Meter: 108
D:\h\fastboot>fastboot getvar all
< waiting for device >
(bootloader) version: 0.5a
(bootloader) version-bootloader: 1.39.0
(bootloader) version-baseband: 5.1204.1
(bootloader) version-cpld: None
(bootloader) version-microp: None
(bootloader) version-main: 3.20.401.1
(bootloader) serialno: SH26CW105349
(bootloader) imei: 353426056880966
(bootloader) product: endeavoru
(bootloader) platform: HBOOT-T30S
(bootloader) modelid: PJ4610000
(bootloader) cidnum: HTC__Y13
(bootloader) battery-status: good
(bootloader) battery-voltage: 3609mV
(bootloader) devpower: 22
(bootloader) partition-layout: None
(bootloader) security: on
(bootloader) build-mode: SHIP
(bootloader) boot-mode: FASTBOOT
(bootloader) commitno-bootloader: None
(bootloader) hbootpreupdate: 2
(bootloader) gencheckpt: 0
all: Done!
finished. total time: 0.906s
Old 02-05-2014, 19:41   #4 (permalink)
Member: 686535
Sonork: 1592667
Thanks Meter: 108
plz help me for flash my phone
Old 02-05-2014, 20:27   #5 (permalink)
NoName®'s Avatar
Member: 129885
Sonork: 100:1603514
Thanks Meter: 6,202
For making flasheable your HTC one X you need to do following procedure:
1. Connect pinout as described on support
2. Make moviNAND format operation , restore extSCD backup. ( Now device are emptyboard and all data erased from flash tnx sikander3786 for trick )
3. Write corresponding dump into the ROM1 - 512MB_HTC_ONE_X_ROM1
4. Write HTC_ONE_X_ROM2.rar to ROM2 and ROM3
5. Download from here HTC_ONE_X_SOLUTION_TEST.rar Pass: "GPGEMMC ARE ****ED COPYPASTERS"
6. Write rawpt_16g.BIN or rawpt_32g.BIN at USER ROM1 area depeding of your eMMC size ( see in connection log )
7. Check SHOW SOFTWARE PARTITIONS INFO checkbox and detect eMMC - you will see partition list if all OK and presets list will be updated
8. Write EMMC_00200000_BIF_HTC__Y13_353999999999999.BIN in BIF partition ( select partition in presets list , you may fix IMEI in any hex editor )
9. Write EMMC_00400000_SIF_1.00.000.0_1.0000.0000.00.bin in SIF partition ( select partition in presets list , phone will be 1.00.000.000 )
10. Download RUU_ENDEAVOR_U_JB_45_S_HTC_Europe_3.14.401.31_R_Ra dio_5.1204.162.29_release_302015_signed.exe
11. If you want another region you can edit CID in EMMC_00200000_BIF_HTC__Y13_353999999999999.BIN current HTC__Y13
12. Desolder wires and flash phone. Do not forget remove JUMPER from eMMC reset pin.
If you need to upgdate boot - try this solution
P.S. If this will not work we need another rooted device with lower HBOOT version to get correct downgrade data.
P.P.S. GPGEMMC focusers , you may do all this things in sw or even put in ONE SUPER REPAIR button and call this world first but do not forget write credits from where you have copied data.
Link: HTC_ONE_X_SOLUTION_TEST
The Following 4 Users Say Thank You to NoName® For This Useful Post:
Old 02-10-2014, 15:23   #6 (permalink)
Member: 686535
Sonork: 1592667
Thanks Meter: 108
for NoName®
plz file password
thx
Old 02-10-2014, 18:10   #7 (permalink)
NoName®'s Avatar
Member: 129885
Sonork: 100:1603514
Thanks Meter: 6,202
Originally Posted by roklat View Post
for NoName®
plz file password
thx
Lock at step 5. Word begins from FUC letters ;-)
The Following User Says Thank You to NoName® For This Useful Post:
Old 02-22-2014, 10:26   #8 (permalink)
tito™'s Avatar
Member: 709437
Sonork: 100.1611201
Thanks Meter: 25
2. Write corresponding dump into the ROM1 - 512MB_HTC_ONE_X_ROM1
3. Write HTC_ONE_X_ROM2.rar to ROM2 and ROM3
4. Download from here HTC_ONE_X_SOLUTION_TEST.rar Pass: "GPGEMMC ARE ****ED COPYPASTERS"
5. Write rawpt_16g.BIN or rawpt_32g.BIN at USER ROM1 area depeding of your eMMC size ( see in connection log )
6. Write EMMC_00200000_BIF_HTC__Y13_353999999999999.BIN in BIF partition ( you may fix IMEI in any hex editor )
7. Write EMMC_00400000_SIF_1.00.000.0_1.0000.0000.00.bin in SIF partition ( phone will be 1.00.000.000 )
8. Download RUU_ENDEAVOR_U_JB_45_S_HTC_Europe_3.14.401.31_R_Ra dio_5.1204.162.29_release_302015_signed.exe
9. If you want another region you can edit CID in EMMC_00200000_BIF_HTC__Y13_353999999999999.BIN current HTC__Y13
10. Desolder wires and flash phone. Do not forget remove JUMPER from eMMC reset pin.
I tried This Solution But Still In APX MODE
Is There Any Solutions
Old 02-24-2014, 01:10   #9 (permalink)
NoName®'s Avatar
Member: 129885
Sonork: 100:1603514
Thanks Meter: 6,202
Maybe any logs etc ??? I am dont know anything about your device...
Old 03-05-2014, 12:21   #10 (permalink)
Member: 686535
Sonork: 1592667
Thanks Meter: 108
hi admin
plz i need more info about solution htc one tegra not flashing from this poste:
how to write bif and sif partition
plz step step
thx advenced
Old 03-05-2014, 13:01   #11 (permalink)
Member: 686535
Sonork: 1592667
Thanks Meter: 108
NVIDIA TABLE detected...
Boot RVA Correction : 400000
Header ID: A6C42320021249BE2BB05DE0C7A6D912
Warning: Header Size = 2240
Warning: Entries Count = 27
MMCBLK0P0 (BCT) Adress in BOOT1+BOOT2 0x0, Length: 0x400000
MMCBLK0P1 (PT) Adress in USER: 0x0, Length: 0x200000
MMCBLK0P2 (EBT) Adress in USER: 0x200000, Length: 0x400000
MMCBLK0P3 (DIA) Adress in USER: 0x600000, Length: 0x400000
MMCBLK0P4 (BIF) Adress in USER: 0xA00000, Length: 0x200000
MMCBLK0P5 (GP1) Adress in USER: 0xC00000, Length: 0x200000
MMCBLK0P6 (WLN) Adress in USER: 0xE00000, Length: 0x600000
MMCBLK0P7 (WDM) Adress in USER: 0x1400000, Length: 0x200000
MMCBLK0P8 (RCA) Adress in USER: 0x1600000, Length: 0x600000
MMCBLK0P9 (LNX) Adress in USER: 0x1C00000, Length: 0x800000
MMCBLK0P10 (SOS) Adress in USER: 0x2400000, Length: 0x800000
MMCBLK0P11 (PG1) Adress in USER: 0x2C00000, Length: 0x1000000
MMCBLK0P12 (PG2) Adress in USER: 0x3C00000, Length: 0x1000000
MMCBLK0P13 (PG3) Adress in USER: 0x4C00000, Length: 0x1000000
MMCBLK0P14 (SIF) Adress in USER: 0x5C00000, Length: 0x400000
MMCBLK0P15 (SP1) Adress in USER: 0x6000000, Length: 0x400000
MMCBLK0P16 (RV1) Adress in USER: 0x6400000, Length: 0x1C00000
MMCBLK0P17 (APP) Adress in USER: 0x8000000, Length: 0x50000000
MMCBLK0P18 (CAC) Adress in USER: 0x58000000, Length: 0x14000000
MMCBLK0P19 (ISD) Adress in USER: 0x6C000000, Length: 0x650000000
MMCBLK0P20 (UDA) Adress in USER: 0x6BC000000, Length: 0x89400000
MMCBLK0P21 (DUM) Adress in USER: 0x745400000, Length: 0x200000
MMCBLK0P22 (MSC) Adress in USER: 0x745600000, Length: 0x200000
MMCBLK0P23 (RFS) Adress in USER: 0x745800000, Length: 0x600000
MMCBLK0P24 (DLG) Adress in USER: 0x745E00000, Length: 0x1600000
MMCBLK0P25 (PDT) Adress in USER: 0x747400000, Length: 0x200000
MMCBLK0P26 (GPT) Adress in USER: 0x747600000, Length: 0x200000
Done...Presets has been updated...
Done.
Old 03-06-2014, 09:36   #12 (permalink)
Registered User
Member: 1809208
Thanks Meter: 28
Why everyone just missed the factory format and movinand erase functions? Did you erase the chip and write extCSD before writing dumps?
In a similar case, I was able to unlock the bootloader after I erased the chip and re-writed it.
The Following User Says Thank You to sikander3786 For This Useful Post:
Old 03-06-2014, 22:41   #13 (permalink)
NoName®'s Avatar
Member: 129885
Sonork: 100:1603514
Thanks Meter: 6,202
Thank for testing , and conforming that format work ok. I am have no any test PCB in hands...
I am updated GUIDE with format step.
Old 04-29-2014, 10:44   #14 (permalink)
Member: 2175330
Unhappy No password
Password pliz .................................................. ..
Old 05-03-2014, 11:59   #15 (permalink)
Member: 1012390
Thanks Meter: 95
plz help !
after finished 6. Write rawpt_16g.BIN or rawpt_32g.BIN at USER ROM1 area depeding of your eMMC size ( see in connection log )
i can't load partition list
Z3X EasyJtag Software ver. 1.3.2.0
Loading eMMC Addon Firmware... IO: 1850 mV
Box S/N: 0D00600xxxxxxxxx, ,FW Ver.: 01.50
CMD Pullup Level:1763 mV
CMD Active Level:1815 mV
eMMC Device Information
EMMC CID : 1501004B325530304D0553F255803FFA
EMMC CSD : D02701320F5903FFF6DBFFFF8A404006
EMMC Manufacturer ID: 0015 , OEM ID: 0100
EMMC Date: 03/2012 Rev.0x5
EMMC NAME: K2U00M , S/N: 1408390528
EMMC ROM1 (Main User Data) Capacity: 29820 MB
EMMC ROM2 (Boot Partition 1) Capacity: 512 kB
EMMC ROM3 (Boot Partition 2) Capacity: 512 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB
Extended CSD rev 1.5 (MMC 4.41)
Boot configuration [PARTITION_CONFIG: 0x50] Boot from:ROM3 (Boot Partition 2)
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x50.
Backup saved: K2U00M_1408390528_20140406_1732.extcsd
Searching for partition tables...
Done.
Page generated in 0.24197 seconds with 8 queries
