05-22-2018, 12:28 | #1 (permalink) |
Freak Poster Join Date: Jul 2008 Location: meerut
Member: 804463 Status: Offline Thanks Meter: 77 | Htc t327w Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 1700B0072508DD51, ,FW Ver.: 01.62 CMD Pullup Level:2145 mV CMD Active Level:2485 mV Box IO Level:3300 mV CLK Rate:14000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 90014A2058494E5948140409B78ECF86 EMMC CSD : D02701320F5903FFFFFFFFE78A4040E2 EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 12/2012 Rev.0x14 EMMC NAME: XINYH , S/N: 67745678 EMMC NAME (HEX): 2058494E594800 EMMC ROM1 (Main User Data) Capacity: 2296 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 2048 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: Yes Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00002000] Partitioning Support [PARTITIONING_SUPPORT]: 0x03 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x01 --------------------------------------------- Backup saved: XINYH_ 67745678_20180522_1643.extcsd Blocks Reading Error (0x0 , 1 , Reason: CMD Timeout Error ) Blocks Reading Error (0x1 , 1 , Reason: CMD Timeout Error ) Blocks Reading Error (0x47BFFF , 1 , Reason: CMD Timeout Error ) Done. Running:SAMSUNG: Remove Write Protection... Z3X EasyJtag Software ver. 2.9.0.3 Skip loading eMMC Addon Firmware CMD Pullup Level:2145 mV CMD Active Level:2485 mV Box IO Level:3300 mV CLK Rate:14000 kHz This eMMC is not Write Protected! Done. Running:MMC: Password force remove... Z3X EasyJtag Software ver. 2.9.0.3 Skip loading eMMC Addon Firmware CMD Pullup Level:2145 mV CMD Active Level:2485 mV Box IO Level:3300 mV CLK Rate:14000 kHz Force erase SD/MMC password, wait up to 3 min... DATA Ready Timeout Error Force erase SD/MMC password Failed. HOW TO REMOVE MMC password |
