01-11-2021, 12:37 | #1 (permalink) |
No Life Poster Join Date: Jan 2010
Member: 1212133 Status: Offline Thanks Meter: 58 | Lenovo RPMB - must be clean EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 6 , Response: Not Clean Should it work with Lenovo Yoga 850m - ( Qualcom CPU)? Who knows? Thank you |
01-12-2021, 23:39 | #6 (permalink) | |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Quote:
Can You Post Full Log of eMMC? Then I Tell You Also Write CPU like MSMxxxx - xxx | |
01-13-2021, 09:34 | #7 (permalink) |
Member: 1212133 Status: Offline Thanks Meter: 58 | Here it is the log HiPower mode is ON Setting frequence to 21 MHz CMD Pullup Level: 3248 mV CMD Active Level: 3310 mV EMMC Device Information : EMMC CID: 90014A484247346132A546A1D99F5486 EMMC CSD: D02701328F5903FFFFFFFFE78A400016 EMMC Manufacture : SKHYNIX , EMMC NAME: HBG4a2 , HEX: 484247346132 , S/N: 46A1D99F , rev. 0xA5 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 5/2017 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 16405 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: HBG4a2_46A1D99F_20210113_092620.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: modem, [000004000000 - 000009400000], size: 000005400000 (84.0 MB) Partition: fsc, [00000C000000 - 00000C000400], size: 000000000400 (1.00 KB) Partition: ssd, [00000C000400 - 00000C002400], size: 000000002000 (8.00 KB) Partition: sbl1, [00000C002400 - 00000C082400], size: 000000080000 (512. KB) Partition: sbl1bak, [00000C082400 - 00000C102400], size: 000000080000 (512. KB) Partition: rpm, [00000C102400 - 00000C182400], size: 000000080000 (512. KB) Partition: rpmbak, [00000C182400 - 00000C202400], size: 000000080000 (512. KB) Partition: tz, [00000C202400 - 00000C402400], size: 000000200000 (2.00 MB) Partition: tzbak, [00000C402400 - 00000C602400], size: 000000200000 (2.00 MB) Partition: devcfg, [00000C602400 - 00000C642400], size: 000000040000 (256. KB) Partition: devcfgbak, [00000C642400 - 00000C682400], size: 000000040000 (256. KB) Partition: dsp, [00000C682400 - 00000D682400], size: 000001000000 (16.0 MB) Partition: modemst1, [00000D682400 - 00000D802400], size: 000000180000 (1.50 MB) Partition: modemst2, [00000D802400 - 00000D982400], size: 000000180000 (1.50 MB) Partition: DDR, [000010000000 - 000010008000], size: 000000008000 (32.0 KB) Partition: fsg, [000010008000 - 000010188000], size: 000000180000 (1.50 MB) Partition: sec, [000010188000 - 00001018C000], size: 000000004000 (16.0 KB) Partition: splash, [000014000000 - 000014B00000], size: 000000B00000 (11.0 MB) Partition: aboot, [000018000000 - 000018100000], size: 000000100000 (1.00 MB) Partition: abootbak, [000018100000 - 000018200000], size: 000000100000 (1.00 MB) Partition: boot, [000018200000 - 00001C200000], size: 000004000000 (64.0 MB) Partition: recovery, [00001C200000 - 000020200000], size: 000004000000 (64.0 MB) Partition: devinfo, [000020200000 - 000020300000], size: 000000100000 (1.00 MB) Partition: system, [000020300000 - 0000E0300000], size: 0000C0000000 (3.00 GB) Partition: cache, [0000E4000000 - 0000F4000000], size: 000010000000 (256. MB) Partition: persist, [0000F4000000 - 0000F6000000], size: 000002000000 (32.0 MB) Partition: misc, [0000F6000000 - 0000F6100000], size: 000000100000 (1.00 MB) Partition: keystore, [0000F6100000 - 0000F6180000], size: 000000080000 (512. KB) Partition: config, [0000F6180000 - 0000F6188000], size: 000000008000 (32.0 KB) Partition: oem, [0000F6188000 - 000106188000], size: 000010000000 (256. MB) Partition: limits, [000108000000 - 000108008000], size: 000000008000 (32.0 KB) Partition: mota, [00010C000000 - 00010C080000], size: 000000080000 (512. KB) Partition: dip, [00010C080000 - 00010C180000], size: 000000100000 (1.00 MB) Partition: mdtp, [00010C180000 - 00010E180000], size: 000002000000 (32.0 MB) Partition: syscfg, [00010E180000 - 00010E200000], size: 000000080000 (512. KB) Partition: mcfg, [00010E200000 - 00010E600000], size: 000000400000 (4.00 MB) Partition: lksecapp, [000110000000 - 000110020000], size: 000000020000 (128. KB) Partition: lksecappbak, [000110020000 - 000110040000], size: 000000020000 (128. KB) Partition: cmnlib, [000110040000 - 000110080000], size: 000000040000 (256. KB) Partition: cmnlibbak, [000110080000 - 0001100C0000], size: 000000040000 (256. KB) Partition: cmnlib64, [0001100C0000 - 000110100000], size: 000000040000 (256. KB) Partition: cmnlib64bak, [000110100000 - 000110140000], size: 000000040000 (256. KB) Partition: keymaster, [000110140000 - 000110180000], size: 000000040000 (256. KB) Partition: keymasterbak, [000110180000 - 0001101C0000], size: 000000040000 (256. KB) Partition: apdp, [000114000000 - 000114040000], size: 000000040000 (256. KB) Partition: msadp, [000114040000 - 000114080000], size: 000000040000 (256. KB) Partition: dpo, [000114080000 - 000114082000], size: 000000002000 (8.00 KB) Partition: cust, [000114082000 - 000148082000], size: 000034000000 (832. MB) Partition: userdata, [000148082000 - 000747BFBE00], size: 0005FFB79E00 (24.0 GB) GPT header successfully parsed so, do you think it can work with RPMB not being clean? Thanks |
