Old 08-11-2014, 12:19   #1 (permalink)
gsmkiller173's Avatar
Member: 209582
Sonork: 100.1607015
Thanks Meter: 149
I9100p unknown baseband
EasyJtag Suite ver.: 1.6.0.0 / wxWidgets 3.1.0-W-U started.
Operating system ver.: Windows 7 (build 7601, Service Pack 1).
Successefuly connected to box on COM41
Box S/N: 0808FD02>>>>>>>>, ,FW Ver.: 01.50
Box Working Mode: JTAG Box.
Box Drivers version: 3.0.0.0, are OK
Z3X Card Serial : AA48-17F4 , ver: 22
Z3X Card Activation [LG] : NOT ACTIVATED , ACTIVATE NOW
Z3X Card Activation [SAMS] : ACTIVATED
Z3X Card Activation [JTAG] : ACTIVATED
Loading D:\Z3X\Jtag File\I9100\Samsung_GT-I9100_16gb_model_efs_v1_01.rcp
Loading repair file: 'D:\Z3X\Jtag File\I9100\Samsung_GT-I9100_16gb_model_efs_v1_01.rcp'
Repair File ver. : Easy Repair for Mfg: SAMSUNG Model: GT-I9100, Ver.: 1.00
Repair file options. : NONE
Easy-Repair file load OK!
Using EasyRepair Mode...
Checking repair data...
For support and updates visit http://easy-jtag.com
Check security...OK
Initialising: SAMSUNG GT-I9100 Config ver.:1.00
I/O Level set to : 2800 mV
Box S/N: 0808FD02B5471585 ,FW Ver.: 01.50
Connecting to Target...
JTAG device: S5PC210
CPU IDCODE : 0x4BA00477 Mfg.: 0x23b, Part: 0xba00, Ver.: 0x4
CPU Manufacturer: QUALCOMM , CPU Name: CORTEX A9
Halting CPU...
Init target ...
Starting target communication...
Detecting emmc memory parameters of bank (0) ...
EMMC #0 : ID : 0x00010015 Name : VYL00M Size : 14.7 G , (30777344) Blocks
EMMC #1 : ID : 0x00010000 Name : VYL00M Size : 512.0 K , (1024) Blocks
eMMC flash device(s) found, Device ID : 0x00150001
NAND Writing EFS...
Timeout Error while reading approx : 0x00000100 bytes over DCC
Unknown DCC answer /PROTOCOL/
Failed writing file EFS.BIN to eMMC flash 0 at offset 0x00400000
The Following User Says Thank You to gsmkiller173 For This Useful Post:
Old 08-12-2014, 10:03   #2 (permalink)
Member: 209582
Sonork: 100.1607015
Thanks Meter: 149
For support and updates visit EasyJtag ? most powerfull eMMC and JTAG tool on market. - EMMC BOX, JTAG BOX ,Z3X , BOOT REPAIR , FORENSICS TOOL
Check security...OK
Box S/N: 0808FD02\........ ,FW Ver.: 01.50
Halting CPU...
Init target ...
Executing: C:\Program Files\Z3X\EASYJTAG\Scripts\Show_Partitions_EMMC_GP T.txt
Searching for partition tables...
Warning: Header Size = 512 (expected 92)
Medium UUID: 52444E41-494F-2044-4D4D-43204449534B
MMCBLK0P0 (EFS) Range: [0X400000,0X17FFE00] ,Len: 1400000
MMCBLK0P1 (SBL1) Range: [0X1800000,0X193FE00] ,Len: 140000
MMCBLK0P2 (SBL2) Range: [0X1A00000,0X1B3FE00] ,Len: 140000
MMCBLK0P3 (PARAM) Range: [0X1C00000,0X23FFE00] ,Len: 800000
MMCBLK0P4 (KERNEL) Range: [0X2400000,0X2BFFE00] ,Len: 800000
MMCBLK0P5 (RECOVERY) Range: [0X2C00000,0X33FFE00] ,Len: 800000
MMCBLK0P6 (CACHE) Range: [0X3400000,0X97FFE00] ,Len: 6400000
MMCBLK0P7 (MODEM) Range: [0X9800000,0XA7FFE00] ,Len: 1000000
MMCBLK0P8 (FACTORYFS) Range: [0XA800000,0X2A7FFE00] ,Len: 20000000
MMCBLK0P9 (DATAFS) Range: [0X2A800000,0XAA7FFE00] ,Len: 80000000
MMCBLK0P10 (UMS) Range: [0XAA800000,0X38AFFFE00] ,Len: 2E0800000
MMCBLK0P11 (HIDDEN) Range: [0X38B000000,0X3AAFFFE00] ,Len: 20000000
Created helper script 'dump_gpt_partitions.txt' for dumping all regions in device
Created helper script 'write_gpt_partitions.txt' for writing all regions in device
Presets list on main window has been updated!
OK
Reading dump to file...C:\Users\imran\Desktop\SAMSUNG_GT-I9100_0x00400000_0x01400000.bin
Reading 0x000001400000 bytes from emmc adress 0x000000400000
Dumped 20971520 bytes in 31.370279s (652.847 KiB/s) OK.
Checking NAND Image : C:\Users\imran\Desktop\I9100 Good EFS\efs.bin
File successefuly loaded!
Writing memory from file...C:\Users\imran\Desktop\I9100 Good EFS\efs.bin
eMMC Write OK! Elapsed time: 183.299408s (111.730 KiB/s)
Old 08-12-2014, 13:13   #3 (permalink)
fahad ali khan's Avatar
Member: 1771086
Thanks Meter: 2,410
try full flashing 100% ok your problem .................... if problem same then try flashing downgrade v
The Following 2 Users Say Thank You to fahad ali khan For This Useful Post:
Old 08-12-2014, 13:34   #4 (permalink)
Member: 1771086
Thanks Meter: 2,410
How Repair "EFS" "Null Imei" "Unknown BaseBand" "Low Signal" And All Related To EFS
Guide:
1-Select "Speed"
2-Select "I9100" Model
3-Set "Start Address" "Data Length"
Start Address : "0x0000 0040 0000"
Lentgh : "0X0000 0140 0000"
4-Uncheck 3 option...Select "Rom1"
5-Open "I9100_EFS.bin" in "Main" Window
6-Select "Use Adress as Offset xxxxxx"
7-Press "write"
The Following 3 Users Say Thank You to fahad ali khan For This Useful Post:
Old 08-13-2014, 06:50   #5 (permalink)
Member: 209582
Sonork: 100.1607015
Thanks Meter: 149
Guide:
1-Select "Speed"
Lentgh : "0X0000 0140 0000[IMG]resource://skype_ff_extension-at-jetpack/skype_ff_extension/data/call_skype_logo.png[/IMG]0140 0000"
7-Press "write"
Old 08-13-2014, 10:01   #6 (permalink)
Member: 1771086
Thanks Meter: 2,410
Guide:
1-Select "Speed"
7-Press "write"
if this parass complete
after write Dump file ok
then this problem hardwaer
The Following User Says Thank You to fahad ali khan For This Useful Post:
Page generated in 0.18012 seconds with 8 queries
