01-14-2019, 18:09 | #1 (permalink) |
Insane Poster Join Date: Oct 2017
Member: 2772222 Status: Offline Thanks Meter: 9 | LG K430TV write ROM2 (Boot) from Firmware I did the Pinout an tried Connect with Easy JTag, buts says tha eMMc is DEAD. I dont know whats happened to eMMC die during flash. I think de firmware of eMMC was dameged . What coud have been? So I removed eMMC chip. I am using another eMMC, KMQE10013M. Original was KMF310012M. I will try repair using ROM from K430TV. My friend give me EXTCSD for this device. Log: eMMC CID : 150100514531334D4207A04FE0BD433F eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 04/2016 Rev.0x7 eMMC NAME: QE13MB , S/N: 2689589437 eMMC NAME (HEX): 514531334D42 EMMC ROM1 (Main User Data) Capacity: 14910 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 Boot from:ROM2 (Boot Partition 1): How can I write ROM2 (Boot partiton) from Firmware? |
01-14-2019, 18:51 | #2 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
MTK CPU based phones have bootconfig depended where is preloader placed: if preloader write to ROM2 boot config is: Boot configuration [179] / Boot Bus Config [177] / H/W Reset Function [162]: 0x48 / 0x00 / 0x01 if preloader write to ROM3 boot config is: Boot configuration [179] / Boot Bus Config [177] / H/W Reset Function [162]: 0x50 / 0x00 / 0x01 there is no difference where the preloader is. it is important that the bootconfig points to it you can write ROM2 as backup of ROM2 at first page (eMMC general) - Select ROM to access, select file, write binary file you can write preloader file to ROM from FlashTool firmware - you need open firmware at "Write by vendor" tab, select Mediatek, choose scatter file, select partititon to write, write it Last edited by layder; 01-14-2019 at 18:57. | |
The Following User Says Thank You to layder For This Useful Post: |
01-14-2019, 19:24 | #3 (permalink) |
Member: 2772222 Status: Offline Thanks Meter: 9 | How to interpret it: preloader_0_1.bin Found 10 supported eMMC CID: name = 'HAG2e' hex = 0x484147326505 [SKHYNIX] eNAND_H26M52103FMR/16GB @FBGA169 eNAND_H9TQ17A8GTMCUR-KTM/16GB @BGA221 eNAND_H9TQ17A8GTMCUR-KUM/16GB @BGA221 eNAND_H9TQ17ABJTMCUR-KTM/16GB @BGA221 eNAND_H9TQ17ABJTMCUR-KUM/16GB @BGA221 name = 'QN16MB' hex = 0x514E31364D42 [SAMSUNG] name = 'Q316AB' hex = 0x513331364142 [SAMSUNG] name = 'Q313MB' hex = 0x513331334D42 [SAMSUNG] moviNAND_KMQ310013M-B419/16GB @BGA221 name = 'F312MB' hex = 0x463331324D42 [SAMSUNG] name = 'F722MB' hex = 0x463732324D42 [SAMSUNG] moviNAND_KMF720012M-B214/8GB @BGA221 name = 'Q31SMB' hex = 0x513331534D42 [SAMSUNG] name = 'QE13MB' hex = 0x514531334D42 [SAMSUNG] name = 'Q316BB' hex = 0x513331364242 [SAMSUNG] name = 'FE12MB' hex = 0x464531324D42 [SAMSUNG] "you can write ROM2 as backup of ROM2 at first page (eMMC general) - Select ROM to access, select file, write binary file" But I dont have DUMP. I will read about the function of preloader to understand the process. |
01-14-2019, 23:06 | #4 (permalink) | |
If you phone not connect as "MTK VCOM port", you need to desolder eMMC and check it, and write correct preloader from firmware using "Write by vendor" Tab at EasyJTAG plus software, also know as "eMMC Tool Shuite" | |
