Old 12-02-2019, 10:00   #1 (permalink)
Member: 1929052
Thanks Meter: 22
k53a48 only quallcom qloader can t flash
hi team i can t repair new emmc k6 note everything ok but only qloader port can t flash
this is first log old emmc always androis t stopped when factory reset phone stuck lenovo
ooking for EasyJTAG box...
20.11.2019 21:10:53> EasyJTAG API ver. 3307
20.11.2019 21:10:53> Setting IO Levels to 1.8V
20.11.2019 21:10:53> Setting frequence to 36 MHz
20.11.2019 21:10:53> EasyJTAG Box Serial = 1896675587FFB2D7
20.11.2019 21:10:53> EasyJTAG Box Firmware = 2.48
20.11.2019 21:10:53> Setting interface to EasyJtag2/ISP_HiPower
20.11.2019 21:10:54> Setting bus width to 1 Bit
20.11.2019 21:10:54> HiPower mode is ON
20.11.2019 21:10:54> Setting frequence to 36 MHz
20.11.2019 21:10:54> CMD Pullup Level: 1824 mV
20.11.2019 21:10:54> CMD Active Level: 1879 mV
20.11.2019 21:10:54> eMMC Init returned = 0
20.11.2019 21:10:54> EMMC Device Information :
20.11.2019 21:10:54> EMMC CID: 150100525831424D420767EAAAD1B34D
20.11.2019 21:10:54> EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D
20.11.2019 21:10:54> EMMC Manufacture : SAMSUNG , EMMC NAME: RX1BMB , HEX: 525831424D42 , S/N: 67EAAAD1 , rev. 0x07
20.11.2019 21:10:54> EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 11/2016
20.11.2019 21:10:54> EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000)
20.11.2019 21:10:54> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
20.11.2019 21:10:54> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 75360 , Response: Not Clean
20.11.2019 21:10:54> EMMC Permanent Write Protection: No
20.11.2019 21:10:54> EMMC Temporary Write Protection: No
20.11.2019 21:10:54> Extended CSD Information :
20.11.2019 21:10:54> Extended CSD rev: 1.8 (MMC 5.1)
20.11.2019 21:10:54> Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area)
20.11.2019 21:10:54> Boot Bus Config: 0x00 , width 1bit
20.11.2019 21:10:54> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
20.11.2019 21:10:54> Supported partition features [PARTITIONING_SUPPORT]: 0x07
20.11.2019 21:10:54> Device supports partitioning features
20.11.2019 21:10:54> Device can have enhanced technological features in partitions and user data area
20.11.2019 21:10:54> Device can have extended partitions attribute
20.11.2019 21:10:54> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
20.11.2019 21:10:54> Backup saved: RX1BMB_67EAAAD1_20191120_211054.extcsd
20.11.2019 21:10:54> EMMC Init completed.
20.11.2019 21:10:55> Scanning soft partitions
20.11.2019 21:10:55> GPT header is found and is valid
20.11.2019 21:10:55> Partition: modem, [000001000000 - 000006400000], size: 000005400000 (84,0 MB)
20.11.2019 21:10:55> Partition: sec, [000006400000 - 000006404000], size: 000000004000 (16,0 KB)
20.11.2019 21:10:55> Partition: lksecapp, [000006404000 - 000006424000], size: 000000020000 (128 KB)
20.11.2019 21:10:55> Partition: lksecappbak, [000006424000 - 000006444000], size: 000000020000 (128 KB)
20.11.2019 21:10:55> Partition: cmnlib, [000006444000 - 000006484000], size: 000000040000 (256 KB)
20.11.2019 21:10:55> Partition: cmnlibbak, [000006484000 - 0000064C4000], size: 000000040000 (256 KB)
20.11.2019 21:10:55> Partition: cmnlib64, [0000064C4000 - 000006504000], size: 000000040000 (256 KB)
20.11.2019 21:10:55> Partition: cmnlib64bak, [000006504000 - 000006544000], size: 000000040000 (256 KB)
20.11.2019 21:10:55> Partition: keymaster, [000006544000 - 000006584000], size: 000000040000 (256 KB)
20.11.2019 21:10:55> Partition: keymasterbak, [000006584000 - 0000065C4000], size: 000000040000 (256 KB)
20.11.2019 21:10:55> Partition: aboot, [0000065C4000 - 0000067C4000], size: 000000200000 (2,00 MB)
20.11.2019 21:10:55> Partition: abootbak, [0000067C4000 - 0000069C4000], size: 000000200000 (2,00 MB)
20.11.2019 21:10:55> Partition: devinfo, [0000069C4000 - 000006AC4000], size: 000000100000 (1,00 MB)
20.11.2019 21:10:55> Partition: limits, [000006AC4000 - 000006ACC000], size: 000000008000 (32,0 KB)
20.11.2019 21:10:55> Partition: prov32, [000006ACC000 - 000006B0C000], size: 000000040000 (256 KB)
20.11.2019 21:10:55> Partition: prov32bak, [000006B0C000 - 000006B4C000], size: 000000040000 (256 KB)
20.11.2019 21:10:55> Partition: kpadA, [000006B4C000 - 000007000000], size: 0000004B4000 (4,70 MB)
20.11.2019 21:10:55> Partition: fsc, [000007000000 - 000007000400], size: 000000000400 (1,00 KB)
20.11.2019 21:10:55> Partition: ssd, [000007000400 - 000007002400], size: 000000002000 (8,00 KB)
20.11.2019 21:10:55> Partition: sbl1, [000007002400 - 000007082400], size: 000000080000 (512 KB)
20.11.2019 21:10:55> Partition: sbl1bak, [000007082400 - 000007102400], size: 000000080000 (512 KB)
20.11.2019 21:10:55> Partition: rpm, [000007102400 - 000007182400], size: 000000080000 (512 KB)
20.11.2019 21:10:55> Partition: rpmbak, [000007182400 - 000007202400], size: 000000080000 (512 KB)
20.11.2019 21:10:55> Partition: tz, [000007202400 - 000007402400], size: 000000200000 (2,00 MB)
20.11.2019 21:10:55> Partition: tzbak, [000007402400 - 000007602400], size: 000000200000 (2,00 MB)
20.11.2019 21:10:55> Partition: devcfg, [000007602400 - 000007642400], size: 000000040000 (256 KB)
20.11.2019 21:10:55> Partition: devcfgbak, [000007642400 - 000007682400], size: 000000040000 (256 KB)
20.11.2019 21:10:55> Partition: dsp, [000007682400 - 000008682400], size: 000001000000 (16,0 MB)
20.11.2019 21:10:55> Partition: modemst1, [000008682400 - 000008802400], size: 000000180000 (1,50 MB)
20.11.2019 21:10:55> Partition: modemst2, [000008802400 - 000008982400], size: 000000180000 (1,50 MB)
20.11.2019 21:10:55> Partition: DDR, [000008982400 - 00000898A400], size: 000000008000 (32,0 KB)
20.11.2019 21:10:55> Partition: fsg, [00000898A400 - 000008B0A400], size: 000000180000 (1,50 MB)
20.11.2019 21:10:55> Partition: kpadB, [000008B0A400 - 000009000000], size: 0000004F5C00 (4,96 MB)
20.11.2019 21:10:55> Partition: boot, [000009000000 - 00000D000000], size: 000004000000 (64,0 MB)
20.11.2019 21:10:55> Partition: recovery, [00000D000000 - 000011000000], size: 000004000000 (64,0 MB)
20.11.2019 21:10:55> Partition: apdp, [000011000000 - 000011040000], size: 000000040000 (256 KB)
20.11.2019 21:10:55> Partition: msadp, [000011040000 - 000011080000], size: 000000040000 (256 KB)
20.11.2019 21:10:55> Partition: dpo, [000011080000 - 000011082000], size: 000000002000 (8,00 KB)
20.11.2019 21:10:55> Partition: splash, [000011082000 - 000011B82000], size: 000000B00000 (11,0 MB)
20.11.2019 21:10:55> Partition: misc, [000011B82000 - 000011C82000], size: 000000100000 (1,00 MB)
20.11.2019 21:10:55> Partition: keystore, [000011C82000 - 000011D02000], size: 000000080000 (512 KB)
20.11.2019 21:10:55> Partition: config, [000011D02000 - 000011D0A000], size: 000000008000 (32,0 KB)
20.11.2019 21:10:55> Partition: oem, [000011D0A000 - 000015D0A000], size: 000004000000 (64,0 MB)
20.11.2019 21:10:55> Partition: mota, [000015D0A000 - 000015D8A000], size: 000000080000 (512 KB)
20.11.2019 21:10:55> Partition: dip, [000015D8A000 - 000015E8A000], size: 000000100000 (1,00 MB)
20.11.2019 21:10:55> Partition: mdtp, [000015E8A000 - 000017E8A000], size: 000002000000 (32,0 MB)
20.11.2019 21:10:55> Partition: syscfg, [000017E8A000 - 000017F0A000], size: 000000080000 (512 KB)
20.11.2019 21:10:55> Partition: mcfg, [000017F0A000 - 00001830A000], size: 000000400000 (4,00 MB)
20.11.2019 21:10:55> Partition: persist, [00001830A000 - 00001A30A000], size: 000002000000 (32,0 MB)
20.11.2019 21:10:55> Partition: cache, [00001A30A000 - 00002A30A000], size: 000010000000 (256 MB)
20.11.2019 21:10:55> Partition: mrd, [00002B000000 - 00002F000000], size: 000004000000 (64,0 MB)
20.11.2019 21:10:55> Partition: system, [00002F000000 - 00010F000000], size: 0000E0000000 (3,50 GB)
20.11.2019 21:10:55> Partition: preload, [00010F000000 - 000128000000], size: 000019000000 (400 MB)
20.11.2019 21:10:55> Partition: userdata, [000128000000 - 000747BFBE00], size: 00061FBFBE00 (24,5 GB)
20.11.2019 21:10:55> GPT header successfully parsed
20.11.2019 21:10:55> Get firmware version
20.11.2019 21:10:58> Brand = Lenovo
20.11.2019 21:10:58> Manufacturer = LENOVO
20.11.2019 21:10:58> Device = K53
20.11.2019 21:10:58> Model = Lenovo K53
20.11.2019 21:10:58> Phone platform = msm8937
20.11.2019 21:10:58> CPU Abi = arm64-v8a
20.11.2019 21:10:58> Android release = 7.0
20.11.2019 21:10:58> Firmware version = K53_S228_171114_ROW
20.11.2019 21:10:58> Firmware date = 2017? 11? 14? ??? 14:31:34 CST
Old 12-02-2019, 10:04   #2 (permalink)
Member: 1929052
Thanks Meter: 22
here is new emmc log
01.12.2019 00:18:10> Looking for EasyJTAG box...
01.12.2019 00:18:10> EasyJTAG API ver. 3307
01.12.2019 00:18:10> Setting IO Levels to 2.8V
01.12.2019 00:18:10> Setting frequence to 14 MHz
01.12.2019 00:18:10> EasyJTAG Box Serial = 1896675587FFB2D7
01.12.2019 00:18:10> EasyJTAG Box Firmware = 2.48
01.12.2019 00:18:11> Setting interface to EasyJtag2/E-Socket
01.12.2019 00:18:11> Setting bus width to 8 Bit
01.12.2019 00:18:11> Setting frequence to 14 MHz
01.12.2019 00:18:11> eMMC Init returned = 0
01.12.2019 00:18:12> EMMC Device Information :
01.12.2019 00:18:12> EMMC CID: 150100525831424D4207F5BFCE9253E1
01.12.2019 00:18:12> EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D
01.12.2019 00:18:12> EMMC Manufacture : SAMSUNG , EMMC NAME: RX1BMB , HEX: 525831424D42 , S/N: F5BFCE92 , rev. 0x07
01.12.2019 00:18:12> EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 5/2016
01.12.2019 00:18:12> EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000)
01.12.2019 00:18:12> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
01.12.2019 00:18:12> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Clean
01.12.2019 00:18:12> EMMC Permanent Write Protection: No
01.12.2019 00:18:12> EMMC Temporary Write Protection: No
01.12.2019 00:18:12> Extended CSD Information :
01.12.2019 00:18:12> Extended CSD rev: 1.8 (MMC 5.1)
01.12.2019 00:18:12> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
01.12.2019 00:18:12> Boot Bus Config: 0x00 , width 1bit
01.12.2019 00:18:12> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
01.12.2019 00:18:12> Supported partition features [PARTITIONING_SUPPORT]: 0x07
01.12.2019 00:18:12> Device supports partitioning features
01.12.2019 00:18:12> Device can have enhanced technological features in partitions and user data area
01.12.2019 00:18:12> Device can have extended partitions attribute
01.12.2019 00:18:12> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
01.12.2019 00:18:12> Backup saved: RX1BMB_F5BFCE92_20191201_001812.extcsd
01.12.2019 00:18:12> EMMC Init completed.
01.12.2019 00:18:12> Operation: Write by vendor (Qualcomm/HiSilicon/Omap)
01.12.2019 00:18:12> Creating GPT-partitioninig
01.12.2019 00:18:12> Writing PrimaryGPT at address: 000000000000
01.12.2019 00:18:12> Writing BackupGPT at address: 000747BFBE00
01.12.2019 00:18:12> GPT-partitioning done
01.12.2019 00:18:12> Partition name: modem
01.12.2019 00:18:12> Filename: modem_0.img , Offset: 000001000000 , filesize: 39394133 bytes
01.12.2019 00:18:12> eMMC switching to ROM1
01.12.2019 00:18:12> Writing partition...
01.12.2019 00:18:16> Done writing partition. Write speed: 9928,46 KB/s
01.12.2019 00:18:16> Partition name: sec
01.12.2019 00:18:16> Filename: sec_0.img , Offset: 000006400000 , filesize: 376 bytes
01.12.2019 00:18:16> eMMC switching to ROM1
01.12.2019 00:18:16> Writing partition...
01.12.2019 00:18:16> Done writing partition. Write speed: 158,26 KB/s
01.12.2019 00:18:16> Partition name: lksecapp
01.12.2019 00:18:16> Filename: lksecapp_0.img , Offset: 000006404000 , filesize: 24028 bytes
01.12.2019 00:18:16> Done writing partition. Write speed: 2858,13 KB/s
01.12.2019 00:18:16> Partition name: lksecappbak
01.12.2019 00:18:16> Filename: lksecappbak_0.img , Offset: 000006424000 , filesize: 24028 bytes
01.12.2019 00:18:17> Writing partition...
01.12.2019 00:18:17> Done writing partition. Write speed: 1261,72 KB/s
01.12.2019 00:18:17> Partition name: cmnlib
01.12.2019 00:18:17> Filename: cmnlib_0.img , Offset: 000006444000 , filesize: 128150 bytes
01.12.2019 00:18:17> eMMC switching to ROM1
01.12.2019 00:18:17> Done writing partition. Write speed: 4897,88 KB/s
01.12.2019 00:18:17> Partition name: cmnlibbak
01.12.2019 00:18:17> Filename: cmnlibbak_0.img , Offset: 000006484000 , filesize: 128150 bytes
01.12.2019 00:18:17> Done writing partition. Write speed: 4392,72 KB/s
01.12.2019 00:18:17> Partition name: cmnlib64
01.12.2019 00:18:17> Filename: cmnlib64_0.img , Offset: 0000064C4000 , filesize: 146355 bytes
01.12.2019 00:18:17> Done writing partition. Write speed: 8144,65 KB/s
01.12.2019 00:18:17> Partition name: cmnlib64bak
01.12.2019 00:18:17> Filename: cmnlib64bak_0.img , Offset: 000006504000 , filesize: 146355 bytes
01.12.2019 00:18:18> Done writing partition. Write speed: 5415,31 KB/s
01.12.2019 00:18:18> Partition name: keymaster
01.12.2019 00:18:18> Filename: keymaster_0.img , Offset: 000006544000 , filesize: 119973 bytes
01.12.2019 00:18:18> eMMC switching to ROM1
01.12.2019 00:18:18> Writing partition...
01.12.2019 00:18:18> Done writing partition. Write speed: 4826,12 KB/s
01.12.2019 00:18:18> Partition name: keymasterbak
01.12.2019 00:18:18> Filename: keymasterbak_0.img , Offset: 000006584000 , filesize: 119973 bytes
01.12.2019 00:18:18> Done writing partition. Write speed: 4898,53 KB/s
01.12.2019 00:18:18> Partition name: aboot
01.12.2019 00:18:18> Filename: aboot_0.img , Offset: 0000065C4000 , filesize: 274742 bytes
01.12.2019 00:18:18> Done writing partition. Write speed: 7169,61 KB/s
01.12.2019 00:18:18> Partition name: abootbak
01.12.2019 00:18:18> Filename: abootbak_0.img , Offset: 0000067C4000 , filesize: 274742 bytes
01.12.2019 00:18:18> Done writing partition. Write speed: 6929,03 KB/s
01.12.2019 00:18:18> Partition name: devinfo
01.12.2019 00:18:18> Filename: devinfo_0.img , Offset: 0000069C4000 , filesize: 4596 bytes
01.12.2019 00:18:19> Writing partition...
01.12.2019 00:18:19> Done writing partition. Write speed: 691,89 KB/s
01.12.2019 00:18:19> Partition name: limits
01.12.2019 00:18:19> Filename: limits_0.img , Offset: 000006AC4000 , filesize: 163 bytes
01.12.2019 00:18:19> eMMC switching to ROM1
01.12.2019 00:18:19> Done writing partition. Write speed: 59,49 KB/s
01.12.2019 00:18:19> Partition name: prov32
01.12.2019 00:18:19> Filename: prov32_0.img , Offset: 000006ACC000 , filesize: 1167 bytes
01.12.2019 00:18:19> Done writing partition. Write speed: 76,40 KB/s
01.12.2019 00:18:19> Partition name: prov32bak
01.12.2019 00:18:19> Filename: prov32bak_0.img , Offset: 000006B0C000 , filesize: 1167 bytes
01.12.2019 00:18:19> Done writing partition. Write speed: 244,41 KB/s
01.12.2019 00:18:19> Partition name: kpadA
01.12.2019 00:18:19> Filename: kpadA_0.img , Offset: 000006B4C000 , filesize: 21470 bytes
01.12.2019 00:18:19> Done writing partition. Write speed: 1212,37 KB/s
01.12.2019 00:18:19> Partition name: fsc
01.12.2019 00:18:19> Filename: fsc_0.img , Offset: 000007000000 , filesize: 31 bytes
01.12.2019 00:18:20> Writing partition...
01.12.2019 00:18:20> Done writing partition. Write speed: 12,20 KB/s
01.12.2019 00:18:20> Partition name: ssd
01.12.2019 00:18:20> Filename: ssd_0.img , Offset: 000007000400 , filesize: 746 bytes
01.12.2019 00:18:20> eMMC switching to ROM1
01.12.2019 00:18:20> Done writing partition. Write speed: 150,72 KB/s
01.12.2019 00:18:20> Partition name: sbl1
01.12.2019 00:18:20> Filename: sbl1_0.img , Offset: 000007002400 , filesize: 219228 bytes
01.12.2019 00:18:20> Done writing partition. Write speed: 6472,84 KB/s
01.12.2019 00:18:20> Partition name: sbl1bak
01.12.2019 00:18:20> Filename: sbl1bak_0.img , Offset: 000007082400 , filesize: 219228 bytes
01.12.2019 00:18:20> Done writing partition. Write speed: 6292,49 KB/s
01.12.2019 00:18:20> Partition name: rpm
01.12.2019 00:18:20> Filename: rpm_0.img , Offset: 000007102400 , filesize: 99313 bytes
01.12.2019 00:18:20> Done writing partition. Write speed: 4123,87 KB/s
01.12.2019 00:18:20> Partition name: rpmbak
01.12.2019 00:18:20> Filename: rpmbak_0.img , Offset: 000007182400 , filesize: 99313 bytes
01.12.2019 00:18:21> Writing partition...
01.12.2019 00:18:21> Done writing partition. Write speed: 4134,40 KB/s
01.12.2019 00:18:21> Partition name: tz
01.12.2019 00:18:21> Filename: tz_0.img , Offset: 000007202400 , filesize: 455171 bytes
01.12.2019 00:18:21> eMMC switching to ROM1
01.12.2019 00:18:21> Done writing partition. Write speed: 8352,56 KB/s
01.12.2019 00:18:21> Partition name: tzbak
01.12.2019 00:18:21> Filename: tzbak_0.img , Offset: 000007402400 , filesize: 455171 bytes
01.12.2019 00:18:21> Done writing partition. Write speed: 8410,52 KB/s
01.12.2019 00:18:21> Partition name: devcfg
01.12.2019 00:18:21> Filename: devcfg_0.img , Offset: 000007602400 , filesize: 15407 bytes
01.12.2019 00:18:21> Done writing partition. Write speed: 877,85 KB/s
01.12.2019 00:18:21> Partition name: devcfgbak
01.12.2019 00:18:21> Filename: devcfgbak_0.img , Offset: 000007642400 , filesize: 15407 bytes
01.12.2019 00:18:21> Done writing partition. Write speed: 2220,78 KB/s
01.12.2019 00:18:21> Partition name: dsp
01.12.2019 00:18:22> Filename: dsp_0.img , Offset: 000007682400 , filesize: 2838009 bytes
01.12.2019 00:18:22> eMMC switching to ROM1
01.12.2019 00:18:22> Writing partition...
01.12.2019 00:18:22> Done writing partition. Write speed: 11207,03 KB/s
01.12.2019 00:18:22> Partition name: modemst1
01.12.2019 00:18:22> Filename: modemst1_0.img , Offset: 000008682400 , filesize: 921262 bytes
01.12.2019 00:18:22> Done writing partition. Write speed: 9723,77 KB/s
01.12.2019 00:18:22> Partition name: modemst2
01.12.2019 00:18:22> Filename: modemst2_0.img , Offset: 000008802400 , filesize: 921265 bytes
01.12.2019 00:18:23> Done writing partition. Write speed: 9823,62 KB/s
01.12.2019 00:18:23> Partition name: DDR
01.12.2019 00:18:23> Filename: DDR_0.img , Offset: 000008982400 , filesize: 379 bytes
01.12.2019 00:18:23> eMMC switching to ROM1
01.12.2019 00:18:23> Writing partition...
01.12.2019 00:18:23> Done writing partition. Write speed: 170,64 KB/s
01.12.2019 00:18:23> Partition name: fsg
01.12.2019 00:18:23> Filename: fsg_0.img , Offset: 00000898A400 , filesize: 921250 bytes
01.12.2019 00:18:23> Done writing partition. Write speed: 9936,89 KB/s
01.12.2019 00:18:23> Partition name: kpadB
01.12.2019 00:18:23> Filename: kpadB_0.img , Offset: 000008B0A400 , filesize: 22613 bytes
01.12.2019 00:18:23> Done writing partition. Write speed: 1205,31 KB/s
01.12.2019 00:18:23> Partition name: boot
01.12.2019 00:18:23> Filename: boot_0.img , Offset: 000009000000 , filesize: 16341622 bytes
01.12.2019 00:18:25> Done writing partition. Write speed: 11574,71 KB/s
01.12.2019 00:18:25> Partition name: recovery
01.12.2019 00:18:25> Filename: recovery_0.img , Offset: 00000D000000 , filesize: 19970184 bytes
01.12.2019 00:18:25> eMMC switching to ROM1
01.12.2019 00:18:25> Writing partition...
01.12.2019 00:18:27> Done writing partition. Write speed: 12104,07 KB/s
01.12.2019 00:18:27> Partition name: apdp
01.12.2019 00:18:27> Filename: apdp_0.img , Offset: 000011000000 , filesize: 4171 bytes
01.12.2019 00:18:27> eMMC switching to ROM1
01.12.2019 00:18:27> Writing partition...
01.12.2019 00:18:27> Done writing partition. Write speed: 757,40 KB/s
01.12.2019 00:18:27> Partition name: msadp
01.12.2019 00:18:27> Filename: msadp_0.img , Offset: 000011040000 , filesize: 4170 bytes
01.12.2019 00:18:27> Done writing partition. Write speed: 835,92 KB/s
01.12.2019 00:18:27> Partition name: dpo
01.12.2019 00:18:27> Filename: dpo_0.img , Offset: 000011080000 , filesize: 59 bytes
01.12.2019 00:18:27> Done writing partition. Write speed: 25,17 KB/s
01.12.2019 00:18:27> Partition name: splash
01.12.2019 00:18:27> Filename: splash_0.img , Offset: 000011082000 , filesize: 63729 bytes
01.12.2019 00:18:27> Done writing partition. Write speed: 3067,72 KB/s
01.12.2019 00:18:27> Partition name: misc
01.12.2019 00:18:27> Filename: misc_0.img , Offset: 000011B82000 , filesize: 4596 bytes
01.12.2019 00:18:28> Writing partition...
01.12.2019 00:18:28> Done writing partition. Write speed: 630,75 KB/s
01.12.2019 00:18:28> Partition name: keystore
01.12.2019 00:18:28> Filename: keystore_0.img , Offset: 000011C82000 , filesize: 2310 bytes
01.12.2019 00:18:28> eMMC switching to ROM1
01.12.2019 00:18:28> Done writing partition. Write speed: 392,67 KB/s
01.12.2019 00:18:28> Partition name: config
01.12.2019 00:18:28> Filename: config_0.img , Offset: 000011D02000 , filesize: 329 bytes
01.12.2019 00:18:28> Done writing partition. Write speed: 142,66 KB/s
01.12.2019 00:18:28> Partition name: oem
01.12.2019 00:18:28> Filename: oem_0.img , Offset: 000011D0A000 , filesize: 292851 bytes
01.12.2019 00:18:28> Done writing partition. Write speed: 7135,22 KB/s
01.12.2019 00:18:28> Partition name: mota
01.12.2019 00:18:28> Filename: mota_0.img , Offset: 000015D0A000 , filesize: 2310 bytes
01.12.2019 00:18:28> Done writing partition. Write speed: 153,46 KB/s
01.12.2019 00:18:28> Partition name: dip
01.12.2019 00:18:28> Filename: dip_0.img , Offset: 000015D8A000 , filesize: 4596 bytes
01.12.2019 00:18:29> Done writing partition. Write speed: 300,64 KB/s
01.12.2019 00:18:29> Partition name: mdtp
01.12.2019 00:18:29> Filename: mdtp_0.img , Offset: 000015E8A000 , filesize: 343159 bytes
01.12.2019 00:18:29> eMMC switching to ROM1
01.12.2019 00:18:29> Writing partition...
01.12.2019 00:18:29> Done writing partition. Write speed: 10078,50 KB/s
01.12.2019 00:18:29> Partition name: syscfg
01.12.2019 00:18:29> Filename: syscfg_0.img , Offset: 000017E8A000 , filesize: 2310 bytes
01.12.2019 00:18:29> Done writing partition. Write speed: 396,71 KB/s
01.12.2019 00:18:29> Partition name: mcfg
01.12.2019 00:18:29> Filename: mcfg_0.img , Offset: 000017F0A000 , filesize: 18311 bytes
01.12.2019 00:18:29> Done writing partition. Write speed: 1052,51 KB/s
01.12.2019 00:18:29> Partition name: persist
01.12.2019 00:18:29> Filename: persist_0.img , Offset: 00001830A000 , filesize: 450267 bytes
01.12.2019 00:18:29> Done writing partition. Write speed: 8304,96 KB/s
01.12.2019 00:18:29> Partition name: cache
01.12.2019 00:18:29> Filename: cache_0.img , Offset: 00001A30A000 , filesize: 30653949 bytes
01.12.2019 00:18:30> Writing partition...
01.12.2019 00:18:32> Done writing partition. Write speed: 11965,71 KB/s
01.12.2019 00:18:32> Partition name: mrd
01.12.2019 00:18:32> Filename: mrd_0.img , Offset: 00002B000000 , filesize: 292851 bytes
01.12.2019 00:18:32> eMMC switching to ROM1
01.12.2019 00:18:32> Writing partition...
01.12.2019 00:18:32> Done writing partition. Write speed: 7040,28 KB/s
01.12.2019 00:18:32> Partition name: system
01.12.2019 00:18:32> Filename: system_0.img , Offset: 00002F000000 , filesize: 1610484543 bytes
01.12.2019 00:20:44> Done writing partition. Write speed: 11992,05 KB/s
01.12.2019 00:20:44> Partition name: preload
01.12.2019 00:20:44> Filename: preload_0.img , Offset: 00010F000000 , filesize: 40840260 bytes
01.12.2019 00:20:44> eMMC switching to ROM1
01.12.2019 00:20:44> Writing partition...
01.12.2019 00:20:47> Done writing partition. Write speed: 12193,95 KB
Old 12-02-2019, 10:05   #3 (permalink)
Member: 1929052
Thanks Meter: 22
i can t flash any tool
umt says
: Qualcomm HS-USB QDLoader 9008 (COM250)
Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2
Opening Port...OK
Invalid response from device!
Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable.
Some phones may need Special Boot Cable or TestPoint for EDL mode.
Found Port : Qualcomm HS-USB QDLoader 9008 (COM250)
Connecting to phone...OK
Waiting for response...Ignored
Init Handshake Sequence...OK
Hardware ID : E1F00400 [8937] 2A7A0000
OPK_DATA : C94306FF09FC94E60BC36DBEFB7F88648D7764E5313003FECA 69404ACB06A874
Initializing Protocol...OK
Using Auto Loader Selection [1]
Preparing Loader...Done
Sending Loader [8937_008]...Done
Executing Loader...OK
Using User Defined Storage Type : eMMC
DebugData : UXVhbGNvbW0gSFMtVVNCIFFETG9hZGVyIDkwMDggKENPTTI1MC k=
Using Alternate Method...
Error getting Payload Information!
Error Log : UXVhbGNvbW0gSFMtVVNCIFFETG9hZGVyIDkwMDggKENPTTI1MC k=
Please use correct loader and check USB port / cable.
Operation Finished.
Old 12-02-2019, 10:06   #4 (permalink)
Member: 1929052
Thanks Meter: 22
umt says
Opening Port...OK
Operation Finished.
Old 12-04-2019, 19:43   #5 (permalink)
Member: 1929052
Thanks Meter: 22
no one help ?????????????
Page generated in 0.23482 seconds with 8 queries
