01-06-2018, 15:06 | #1 (permalink) |
Freak Poster Join Date: Apr 2010
Member: 1291708 Status: Offline Thanks Meter: 15 | g550fy dead HiPower mode is OFF Frequence: 14 Mhz CMD Pullup Level: 474 mV CMD Active Level: 2382 mV EMMC Device Information : EMMC CID: 150100514E31364D42000DCEAC8E1392 EMMC CSD: D02701320F5903FFF6DBFFEF8E406068 EMMC Manufacture Name: SAMSUNG EMMC Manufacture ID: 0x15 , OEM ID: 0100 EMMC Manufacture Date: 1/2016 , Rev: 00 EMMC NAME: QN16MB , S/N: 0DCEAC8E , rev. 00 EMMC NAME (HEX): 514E31364D42 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 512 KB (000000080000) EMMC Permanent Write Protection: Yes EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QN16MB_0DCEAC8E_20180106_191213.extcsd EMMC Init completed. remove write protection successful eMMC_tool Suite ver. 1.4.8.0 Microsoft Windows 7 (32 bit) build 7600 (6.1.7600.16385) Looking for EasyJTAG box... EasyJTAG API ver. 2008 Setting IO Levels to 3.3V Setting frequence to 14 Mhz HiPower mode is OFF EasyJTAG Box Serial = 1500000FEA48D3C4 Card Serial = AAEC-044C EasyJTAG Box Firmware = 01.62 Changelog: 08.08.2017 (ver 1.4.8.0) Fix: Bugs that have been found through your crash report Fix: Saving VCF for contacts Add: Multiple file selection for Samsung firmware Add: Write full Extcsd or write only the boot configuration ("Repair Extcsd" button) Add: Intel vendor (for easy read/write ROM2/ROM3/GP1) Add: "Pinouts" tab (taken from the catalog of classic software) Add: Checker for Sony TrimArea Add: Speed graph for "Random verify emmc" Add: Fat16/Fat32/exFat support (Explorer) HiPower mode is OFF Frequence: 14 Mhz CMD Pullup Level: 453 mV CMD Active Level: 1216 mV Can't init device. Reason: CMD Timeout Error HiPower mode is OFF Frequence: 14 Mhz CMD Pullup Level: 474 mV CMD Active Level: 2382 mV EMMC Device Information : EMMC CID: 150100514E31364D42000DCEAC8E1392 EMMC CSD: D02701320F5903FFF6DBFFEF8E406068 EMMC Manufacture Name: SAMSUNG EMMC Manufacture ID: 0x15 , OEM ID: 0100 EMMC Manufacture Date: 1/2016 , Rev: 00 EMMC NAME: QN16MB , S/N: 0DCEAC8E , rev. 00 EMMC NAME (HEX): 514E31364D42 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 512 KB (000000080000) EMMC Permanent Write Protection: Yes EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QN16MB_0DCEAC8E_20180106_191213.extcsd EMMC Init completed. Get firmware version Brand = samsung Model = SM-G550FY Phone platform = exynos3 CPU Abi = armeabi-v7a Android release = 6.0.1 Firmware version = MMB29K.G550FYDDU1BQK2 Firmware date = Thu Nov 9 14:23:03 KST 2017 HiPower mode is OFF Frequence: 14 Mhz CMD Pullup Level: 484 mV CMD Active Level: 2361 mV EMMC Device Information : EMMC CID: 150100514E31364D42000DCEAC8E1392 EMMC CSD: D02701320F5903FFF6DBFFEF8E406068 EMMC Manufacture Name: SAMSUNG EMMC Manufacture ID: 0x15 , OEM ID: 0100 EMMC Manufacture Date: 1/2016 , Rev: 00 EMMC NAME: QN16MB , S/N: 0DCEAC8E , rev. 00 EMMC NAME (HEX): 514E31364D42 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 512 KB (000000080000) EMMC Permanent Write Protection: Yes EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QN16MB_0DCEAC8E_20180106_191225.extcsd EMMC Init completed. Operation: Remove WriteProtection ... Successfully HiPower mode is OFF Frequence: 14 Mhz CMD Pullup Level: 505 mV CMD Active Level: 2371 mV EMMC Device Information : EMMC CID: 150100514E31364D42000DCEAC8E1392 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture Name: SAMSUNG EMMC Manufacture ID: 0x15 , OEM ID: 0100 EMMC Manufacture Date: 1/2016 , Rev: 00 EMMC NAME: QN16MB , S/N: 0DCEAC8E , rev. 00 EMMC NAME (HEX): 514E31364D42 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 512 KB (000000080000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QN16MB_0DCEAC8E_20180106_191236.extcsd EMMC Init completed. Get firmware version Brand = samsung Model = SM-G550FY Phone platform = exynos3 CPU Abi = armeabi-v7a Android release = 6.0.1 Firmware version = MMB29K.G550FYDDU1BQK2 Firmware date = Thu Nov 9 14:23:03 KST 2017 i think RPMB partition is too low here show 512 kb but it should be 4 mb what should i do |
